[Mapbender-commits] r9817 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Thu Nov 16 08:26:38 PST 2017
Author: armin11
Date: 2017-11-16 08:26:38 -0800 (Thu, 16 Nov 2017)
New Revision: 9817
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/php/wms.php
Fix for INSPIRE unique resource identifier handling
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2017-11-14 16:33:02 UTC (rev 9816)
+++ trunk/mapbender/http/classes/class_iso19139.php 2017-11-16 16:26:38 UTC (rev 9817)
@@ -312,8 +312,15 @@
$this->datasetId = $explodedUrl[count($explodedUrl) - 1];
$this->datasetIdCodeSpace = rtrim($code[0], $this->datasetId);
} else {
- $this->datasetId = $code[0];
- $this->datasetIdCodeSpace = "";
+ if (($parsedUrl['scheme'] == 'http' || $parsedUrl['scheme'] == 'https') && strpos($code[0],'#') !== false) {
+ $e = new mb_exception($code[0]);
+ $explodedUrl = explode('#', $code[0]);
+ $this->datasetId = $explodedUrl[1];
+ $this->datasetIdCodeSpace = $explodedUrl[0];
+ } else {
+ $this->datasetId = $code[0];
+ $this->datasetIdCodeSpace = "";
} else { //try to read code from RS_Identifier
$code = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2017-11-14 16:33:02 UTC (rev 9816)
+++ trunk/mapbender/http/php/wms.php 2017-11-16 16:26:38 UTC (rev 9817)
@@ -165,24 +165,12 @@
$AuthorityName = $metadataContactGroup["mb_group_name"];
//TODO: Problem - there is no single codespace if datasets have different ones !!!! - Find a generic solution
//$uniqueResourceIdentifierCodespace = $admin->getIdentifierCodespaceFromRegistry($departmentMetadata, $row_metadata);
+$metadataArray['datasetid_codespace'] = "";
+$AuthorityUrl = $admin->getIdentifierCodespaceFromRegistry($metadataContactGroup, $metadataArray);
-//check for given urls
-if (isset($metadataContactGroup["mb_group_registry_url"]) && $metadataContactGroup["mb_group_registry_url"] !== "") {
- $AuthorityUrl = $metadataContactGroup["mb_group_registry_url"];
-} else {
- $AuthorityUrl = $metadataContactGroup["mb_group_homepage"];
if ($AuthorityName == '') {
$AuthorityName = "defaultauthority";
-if ($AuthorityUrl == '') {
- if (defined("METADATA_DEFAULT_CODESPACE") && METADATA_DEFAULT_CODESPACE != '') {
- $AuthorityUrl = METADATA_DEFAULT_CODESPACE."/registry/spatial/dataset/";
- } else {
- $AuthorityUrl = "http://www.mapbender.org"."/registry/spatial/dataset/";
//Get Geometry Type if featuretype info was requested
if ($resource == 'featuretype') {
More information about the Mapbender_commits
