[Mapbender-commits] r9806 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Fri Oct 20 04:04:45 PDT 2017
Author: armin11
Date: 2017-10-20 04:04:45 -0700 (Fri, 20 Oct 2017)
New Revision: 9806
trunk/mapbender/http/classes/class_syncCkan.php
trunk/mapbender/http/php/mod_syncCkan_server.php
New option to sync to different ckan instances via ckan api
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php 2017-10-19 12:26:18 UTC (rev 9805)
+++ trunk/mapbender/http/classes/class_syncCkan.php 2017-10-20 11:04:45 UTC (rev 9806)
@@ -111,6 +111,89 @@
return $array;
+ public function getRemoteCkanRecordList($orga_filter,$central_filter,$filter,$ckan_api_url,$ckan_api_version) {
+ $ckanConnector = new connector($ckan_api_url.$ckan_api_version."/"."action/package_search?q=".$filter."&rows=1000"."&facet=true");
+ $ckanConnector->set("timeOut", "3");
+ if ($ckanConnector->timedOut == true) {
+ return false;
+ $listOfFilteredData = json_decode($ckanConnector->file);
+ $externalCkanMetadataArray = array();
+ $countExternalCkanMetadataArray = 0;
+ if ($listOfFilteredData->success == true) {
+ foreach($listOfFilteredData->result->results as $dataset) {
+ $externalCkanMetadataArray[$countExternalCkanMetadataArray]['uuid'] = $dataset->id;
+ //$externalCkanMetadataArray[$countExternalCkanMetadataArray]['name'] = $dataset->name;
+ $externalCkanMetadataArray[$countExternalCkanMetadataArray]['changedate'] = $dataset->metadata_modified;
+ $countExternalCkanMetadataArray++;
+ //echo $dataset->id." - ".$dataset->metadata_modified."<br>";
+ //$e = new mb_exception("Number of results: ".$countExternalCkanMetadataArray);
+ return $externalCkanMetadataArray;
+ public function getCkanRepresentationFromCkan($ckan_api_url, $ckan_api_version, $ckan_package_id, $central_filter, $orga_ident) {
+ $ckanConnector = new connector($ckan_api_url.$ckan_api_version."/"."action/package_show?id=".$ckan_package_id);
+ return false;
+ $ckanPackageJson = $ckanConnector->file;
+//$e = new mb_exception("remote ckan package: ".$ckanPackageJson);
+ $ckanPackageRemote = json_decode($ckanPackageJson);
+ $ckanPackage->title = "Demo: ".$ckanPackageRemote->result->title;
+//use identical name and value!
+ $ckanPackage->id = $ckanPackageRemote->result->id;
+$ckanPackage->name = $ckanPackageRemote->result->id;
+//."_external_id";
+$ckanPackage->owner_org = $orga_ident;
+$ckanPackage->notes = "notes...";
+$ckanPackage->groups[0]->name = "transparenzgesetz";
+$ckanPackage->state = "active";
+$ckanPackage->type = "decision-rp-1";
+$ckanPackage->license_id = "odc-odbl";
+ //pull filter
+ if (isset($central_filter) && $central_filter !== "") {
+ $central_filterArray = explode(":",$central_filter);
+ $ckanPackage->{$central_filterArray[0]} = $central_filterArray[1];
+ //$ckanPackage->transparency_category_de_rp = "spatial_data";
+ $resourcesArray = array();
+ foreach($ckanPackageRemote->result->resources as $resource) {
+ $newResource = new stdClass();
+ if (isset($resource->name) && $resource->name !=='') {
+ $newResource->name = $resource->name;
+ } else {
+ $newResource->name = "Testtitel (name) für resource";
+ if (isset($resource->url) && $resource->url !=='') {
+ $newResource->url = $resource->url;
+ } else {
+ $newResource->url = "http://www.geoportal.rlp.de";
+ if (isset($resource->format) && $resource->format !=='') {
+ $newResource->format = $resource->format;
+ } else {
+ $newResource->format = "PDF";
+ $resourcesArray[] = $newResource;
+ /*$resourcesArray[0]->url = "http://www.geoportal.rlp.de";
+ $resourcesArray[0]->format = "PDF";*/
+ $ckanPackage->resources = $resourcesArray;
+ //$e = new mb_exception("ckan json object test: ".json_encode($ckanPackage));
+ $returnArray = array();
+ $returnArray['json'] = json_encode($ckanPackage);
+ return $returnArray;
public function getCswRecordList($cswId, $orgaName, $recordType) {
//function to call external csw with orga filter (filter orga which is responsible for publication!)
$recordsPerPage = 20;
@@ -164,11 +247,11 @@
if (isset($this->mapbenderUserId) && (integer)$this->mapbenderUserId > 0) {
if (isset($this->syncOrgaId) && (integer)$this->syncOrgaId > 0) {
- $sql = "SELECT DISTINCT mb_group_id, mb_group_title, mb_group_name, mb_group_title, mb_group_email, mb_group_ckan_uuid, mb_group_ckan_api_key, mb_group_csw_catalogues, mb_user_mb_group.mb_user_mb_group_type FROM mb_group JOIN mb_user_mb_group ON mb_group_id = fkey_mb_group_id AND fkey_mb_user_id = $1 AND mb_group_id = $2 AND mb_user_mb_group_type IN (2,3)";
+ $sql = "SELECT DISTINCT mb_group_id, mb_group_title, mb_group_name, mb_group_title, mb_group_email, mb_group_ckan_uuid, mb_group_ckan_api_key, mb_group_csw_catalogues, mb_group_ckan_catalogues, mb_user_mb_group.mb_user_mb_group_type FROM mb_group JOIN mb_user_mb_group ON mb_group_id = fkey_mb_group_id AND fkey_mb_user_id = $1 AND mb_group_id = $2 AND mb_user_mb_group_type IN (2,3)";
$v = array($this->mapbenderUserId, $this->syncOrgaId);
$t = array('i','i');
} else {
- $sql = "SELECT DISTINCT mb_group_id, mb_group_title, mb_group_name, mb_group_title, mb_group_email, mb_group_ckan_uuid, mb_group_ckan_api_key, mb_group_csw_catalogues, mb_user_mb_group.mb_user_mb_group_type FROM mb_group JOIN mb_user_mb_group ON mb_group_id = fkey_mb_group_id AND fkey_mb_user_id = $1 AND mb_user_mb_group_type IN (2,3)";
+ $sql = "SELECT DISTINCT mb_group_id, mb_group_title, mb_group_name, mb_group_title, mb_group_email, mb_group_ckan_uuid, mb_group_ckan_api_key, mb_group_csw_catalogues, mb_group_ckan_catalogues, mb_user_mb_group.mb_user_mb_group_type FROM mb_group JOIN mb_user_mb_group ON mb_group_id = fkey_mb_group_id AND fkey_mb_user_id = $1 AND mb_user_mb_group_type IN (2,3)";
$v = array($this->mapbenderUserId);
$t = array('i');
@@ -189,6 +272,7 @@
$departmentsArray[$countDepArray]["ckan_api_key"] = $row["mb_group_ckan_api_key"];
//if ($row["mb_group_csw_catalogues"] !== null && $row["mb_group_csw_catalogues"] !== '') {
$departmentsArray[$countDepArray]["csw_catalogues"] = $row["mb_group_csw_catalogues"];
+ $departmentsArray[$countDepArray]["ckan_catalogues"] = $row["mb_group_ckan_catalogues"];
if ($row["mb_user_mb_group_type"] == 2) {
$departmentsArray[$countDepArray]["is_primary_group"] = true;
@@ -224,7 +308,201 @@
return $result;
- public function getSyncListCswJson($departmentsArray, $listAllMetadataInJson = false) {
+ public function getExternalSource() {
+ public function syncExternalSource() {
+ public function getSyncListRemoteCkanJson($departmentsArray, $departmentId, $listAllMetadataInJson = false) {
+ $syncListRemoteCkan = new stdClass(); //should handle the returned json object
+ $syncListResultRemoteCkan = new stdClass();
+ $syncListRemoteCkan->help = "helptext";
+ $syncListRemoteCkan->success = false;
+ $syncListRemoteCkan->function = "getSyncListRemoteCkanJson";
+ $numberOfCatalogue = 0;
+ //TODO - choose right department!!!!
+ //get array index
+ $index = 0;
+ $idFound == false;
+$e = new mb_exception("classes/class_syncCkan.php: parameter departmentId: ".$departmentId);
+ foreach ($departmentsArray as $department) {
+ $dId = (integer)$department['id'];
+ if ($dId == $departmentId) {
+ $idFound = true;
+ break;
+ $index++;
+ if ($idFound == false) {
+ $e = new mb_exception("classes/class_syncCkan.php: Requested department not found in departmentArray!");
+ return false;
+ $organization = $departmentsArray[$index];
+ $catalogues = json_decode($departmentsArray[$index]["ckan_catalogues"])->ckan_catalogues;
+ foreach ($catalogues as $catalogue) { //only one in this case
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->name = $catalogue->ckan_name;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->orga_filter = $catalogue->ckan_organisation_filter;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_server_ip = $catalogue->ckan_server_ip;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->filter = $catalogue->ckan_filter;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->central_filter = $catalogue->central_ckan_filter;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_api_url = $catalogue->ckan_api_url;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_api_version = $catalogue->ckan_api_version;
+ //things from mapbender database
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->name = $organization["name"];
+$syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->id = $organization["id"];
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->title = $organization["title"];
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->email = $organization["email"];
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_orga_ident = $organization["ckan_uuid"];
+$e = new mb_exception("classes/class_syncCkan.php: uuid from departmentArray: ".$organization["ckan_uuid"]);
+ if (isset($organization["ckan_uuid"]) && isset($organization["ckan_api_key"])) {
+ //Test if organization with the given external uuid exists in the coupled ckan
+ //show organizations of the authorized user (from geoportal group table) via action api
+ $ckan = new ckanApi($organization["ckan_api_key"], CKAN_SERVER_IP);
+ $ckan->base_url = $this->ckanApiProtocol.'://'.$this->ckanApiUrl.'/api/3/';
+ $ckan->api_version = $this->ckanApiVersion;
+ $result = $ckan->action_organization_list_for_user();
+ foreach($result->result as $orga) {
+ if ($orga->id == $organization["ckan_uuid"]) {
+ //foreach catalogue entry to sync
+ //echo "Corresponding ckan organization ".$orga->display_name." found for geoportal group ".$organization["name"]." with id ".$organization["id"]."!<br>";
+ //get list of ids for existing spatial datasets - category spatial should be defined!!!!!!
+ //http://localhost:5000/api/3/action/package_search?fq=transparency_category_de_rp:spatial_data
+ //with org: http://localhost:5000/api/3/action/package_search?fq=transparency_category_de_rp:spatial_data%20AND%20owner_org:81476cf5-6c52-4e99-8b9f-6150d63fcb32
+ //TODO: define standard category filter in ckan.conf!
+ //$queryObject->fq = STANDARD_CKAN_FILTER." AND owner_org:".$organization["ckan_uuid"];
+ $queryObject->fq = $catalogue->central_ckan_filter." AND owner_org:".$organization["ckan_uuid"];
+ //$queryObject->fq = "transparency_category_de_rp:spatial_data AND owner_org:".$organization["ckan_uuid"];
+ $queryObject->facet = "true";
+ $queryObject->rows = "1000"; //TODO: maybe an problem somewhen
+ $listOfFilteredData = $ckan->action_package_search(json_encode($queryObject));
+ $countCkanMetadataArray = 0;
+ $ckanMetadataArray = array();
+ //echo "List of datasets in ckan instance:"."<br>";
+ $ckanPackageNames = array();
+ //TODO - why only 10 records are given back when search?
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->count_ckan_packages = $listOfFilteredData->result->count;
+ //echo json_encode($listOfFilteredData)."<br>";
+ //$e = new mb_exception("Number of results: ".$listOfFilteredData->result->count);
+ foreach ($listOfFilteredData->result->results as $dataset) {
+ $ckanMetadataArray[$countCkanMetadataArray]['id'] = $dataset->id;
+ $ckanMetadataArray[$countCkanMetadataArray]['name'] = $dataset->name;
+ $ckanMetadataArray[$countCkanMetadataArray]['changedate'] = $dataset->metadata_modified;
+ if ($listAllMetadataInJson == true) {
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_packages[$countCkanMetadataArray]->id = $dataset->name;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_packages[$countCkanMetadataArray]->date_time = $dataset->metadata_modified;
+ //echo $dataset->title." - ".$dataset->name." - ".$dataset->metadata_modified."<br>";
+ $ckanPackageNames[] = $dataset->name;
+ $countCkanMetadataArray++;
+ //$e = new mb_exception("ckan dataset number: ".$countCkanMetadataArray);
+ } else {
+ $e = new mb_exception("classes/class_syncCkan.php: A problem while searching for datasets in ckan occured!");
+ // only list http://localhost:5000/api/3/action/package_list?q=owner_org:81476cf5-6c52-4e99-8b9f-6150d63fcb32
+ //pull all relevant information from mapbender database - first pull the resources which are owned by the corresponding group!
+ //only use metadata for which real licenses are defined !!!!!! - what should be done with the other metadata?- DO a left join!!!
+ //get list of distributed metadata sets with their relevant arributes from csw search!!!!!
+ //TODO: - exchange with ckan reader!!!!!
+ //$externalCkanMetadataArray = $this->getCswRecordList((integer)$catalogue->catalogue_id, $catalogue->organisation_filter, 'nonGeographicDataset');
+ $externalCkanMetadataArray = $this->getRemoteCkanRecordList($syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->orga_filter,$syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->central_filter,$syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->filter,$syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_api_url,$syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->ckan_api_version);
+ $countMetadataArray = count($externalCkanMetadataArray);
+ if ($countMetadataArray == 0) {
+ } else {
+ $numberRemoteCkanMetadata = 0;
+ $cswUuids = array();
+ foreach($externalCkanMetadataArray as $externalCkanMetadata) {
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->datasource_metadata[$numberRemoteCkanMetadata]->id = $externalCkanMetadata['uuid'];
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->datasource_metadata[$numberRemoteCkanMetadata]->date_time = $externalCkanMetadata['changedate'];
+ $cswUuids[] = $externalCkanMetadata['uuid'];
+ $numberRemoteCkanMetadata++;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->count_external_ckan_packages = $numberRemoteCkanMetadata;
+ //build diffs for ckan and geoportal
+ //Arrays: ckanPackageNames / cswUuids
+ //Those which are only in ckan: delete them
+ //TODO: Problem is that portalu/ingrid mix lowercase and uppercase uuids - to compare them always use lowercase
+ $cswUuidsLower = array_map('strtolower', $cswUuids);
+//$e = new mb_exception(json_encode($cswUuidsLower));
+//$e = new mb_exception(json_encode($ckanPackageNames));
+ $onlyInCkan = array_values(array_diff($ckanPackageNames, $cswUuidsLower)); //every time lowercase names!
+//$e = new mb_exception(json_encode($onlyInCkan));
+ //Those which are only in csw: create them
+ $onlyInRemoteCkan = array_values(array_diff($cswUuidsLower, $ckanPackageNames));
+//$e = new mb_exception(json_encode($onlyInRemoteCkan));
+ //Those which are in both - update them if geoportal metadata is newer than the package in ckan
+ $inBoth = array_values(array_intersect($ckanPackageNames, $cswUuidsLower));
+//$e = new mb_exception(json_encode($inBoth));
+ //rebuild key arrays to mixed case
+ $onlyInRemoteCkan = $this->searchUpperLowerCase($onlyInRemoteCkan, $cswUuids);
+ $inBoth = $this->searchUpperLowerCase($inBoth, $cswUuids);
+ //if the timestamps should be compared before
+ if ($this->compareTimestamps == true) {
+ foreach ($inBoth as $uuid) {
+ $e = new mb_notice("classes/class_syncCkan.php: search for uuid: ".$uuid."ckan time : ".$ckanMetadataArray[array_search($uuid, $this->array_column($ckanMetadataArray,'name'))]['changedate']. " - csw time: ".$externalCkanMetadataArray[array_search($uuid, $this->array_column($externalCkanMetadataArray,'uuid'))]['changedate']);
+ $dateTimeCkan = new DateTime($ckanMetadataArray[array_search($uuid, $this->array_column($ckanMetadataArray,'name'))]['changedate']);
+ $dateTimeRemoteCkan = new DateTime($externalCkanMetadataArray[array_search($uuid, $this->array_column($externalCkanMetadataArray,'uuid'))]['changedate']);
+ if ($dateTimeCkan > $dateTimeRemoteCkan) {
+ //delete from $inBoth!
+ $e = new mb_notice("classes/class_syncCkan.php: Ckans package newer than csw metadata!");
+ $inBoth = array_values(array_diff($inBoth, [$uuid]));
+ } else {
+ $e = new mb_notice("classes/class_syncCkan.php: Ckans package older than csw metadata!");
+ //$e = new mb_exception("Number of packages which are only in ckan: ".count($onlyInCkan)." - number of packages which are only in geoportal: ".count($onlyInGeoportal)." - number of packages which are in both catalogues: ".count($inBoth));
+ //$e = new mb_exception("both: ".gettype($inBoth)." number: ".count($inBoth)." json: ".json_encode($inBoth));
+ //$e = new mb_exception("only ckan: ".gettype($onlyInCkan)." number: ".count($onlyInCkan)." json: ".json_encode($onlyInCkan));
+ //$e = new mb_exception("only geoportal: ".gettype($onlyInGeoportal)." number: ".count($onlyInGeoportal)." json: ".json_encode($onlyInGeoportal));
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->update = $inBoth;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->delete = $onlyInCkan;
+ $syncListResultRemoteCkan->external_ckan[$numberOfCatalogue]->create = $onlyInRemoteCkan;
+ //then pull the ressources which are owned by the user but have no group defined - only if the primary group of the user is the corresponding group!
+ //maybe the catalogue itself is the best way to pull all relevant data, cause the coupling is resolved already!
+ //filter for datasets:
+ //open data - defined by the licenses
+ //transparency - no filter at all - licenses only of some exists - otherwise none or freetext
+ } else {
+ $e = new mb_exception("classes/class_syncCkan.php: Coupled ckan cannot be synchronized, cause the required organization-id and/or API-Key is was not found for ".$organization["name"]);
+ $numberOfCatalogue++;
+ //TODO DEBUG
+ /* foreach($syncListResultRemoteCkan->datasource_metadata[0]->create as $cswFileIdentifier) {
+ $e = new mb_exception($cswFileIdentifier);
+ $resultCkanRepresentation = $this->getCkanRepresentationFromRemoteCkan($syncListResultRemoteCkan->datasource_metadata[0]->id, $cswFileIdentifier, "orga_name", "orga_title", "orga_email", $this->topicDataThemeCategoryMap, "transparency_category_de_rp:environmental_information");
+ if (count($syncListResultRemoteCkan->external_ckan) >= 1) {
+ $syncList->result = $syncListResultRemoteCkan;
+ $syncList->success = true;
+ return json_encode($syncList);
+ public function getSyncListCswJson($departmentsArray, $orgaId, $listAllMetadataInJson = false) {
$syncListCsw = new stdClass(); //should handle the returned json object
$syncListResultCsw = new stdClass();
$syncListCsw->help = "helptext";
@@ -234,9 +512,7 @@
$organization = $departmentsArray[0];
$catalogues = json_decode($departmentsArray[0]["csw_catalogues"])->csw_catalogues;
$syncListResultCsw->external_csw[$numberOfCatalogue]->id = $catalogue->catalogue_id;
$syncListResultCsw->external_csw[$numberOfCatalogue]->orga_filter = $catalogue->organisation_filter;
$syncListResultCsw->external_csw[$numberOfCatalogue]->ckan_filter = $catalogue->ckan_filter;
@@ -250,6 +526,7 @@
@@ -260,6 +537,7 @@
$queryObject->fq = $catalogue->ckan_filter." AND owner_org:".$organization["ckan_uuid"];
@@ -295,45 +573,25 @@
- /*if ($organization['is_primary_group']) {
- $sql = "SELECT *, f_get_coupled_resources(metadata_id) from mb_metadata JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_user_id = $1 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0) AND export2csw IS true";
- $v = array($this->mapbenderUserId);
- $t = array('i');
- } else {
- $sql = "SELECT *, f_get_coupled_resources(metadata_id) from mb_metadata JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_group_id = $1 AND export2csw IS true";
- $v = array($organization['id']);
- $t = array('i');
$cswMetadataArray = $this->getCswRecordList((integer)$catalogue->catalogue_id, $catalogue->organisation_filter, 'nonGeographicDataset');
$countMetadataArray = count($cswMetadataArray);
- //echo "No published metadata found for user with id ".$userId." <br>";
- //delete all records from external ckan instance
- /*foreach ($ckanMetadataArray as $ckanPackage) {
- //echo "Ckan package ".$ckanPackage['name']." should be deleted"."<br>";
} else {
$numberCswMetadata = 0;
foreach($cswMetadataArray as $cswMetadata) {
- //if (count($layerArray) > 0 || count($featuretypeArray) > 0) {
- //use only those that have resources!
- //if ($geoportalMetadata['hasResource']) {
- if ($listAllMetadataInJson == true) {
- $syncListResultCsw->external_csw[$numberOfCatalogue]->csw_metadata[$numberCswMetadata]->id = $cswMetadata['uuid'];
- $syncListResultCsw->external_csw[$numberOfCatalogue]->csw_metadata[$numberCswMetadata]->date_time = $cswMetadata['changedate'];
- $cswUuids[] = $cswMetadata['uuid'];
- $numberCswMetadata++;
+ $syncListResultCsw->external_csw[$numberOfCatalogue]->datasource_metadata[$numberCswMetadata]->id = $cswMetadata['uuid'];
+ $syncListResultCsw->external_csw[$numberOfCatalogue]->datasource_metadata[$numberCswMetadata]->date_time = $cswMetadata['changedate'];
+ $cswUuids[] = $cswMetadata['uuid'];
+ $numberCswMetadata++;
$syncListResultCsw->external_csw[$numberOfCatalogue]->count_csw_packages = $numberCswMetadata;
@@ -349,7 +607,6 @@
$onlyInCsw = $this->searchUpperLowerCase($onlyInCsw, $cswUuids);
@@ -382,14 +639,13 @@
} else {
- //echo "<br> - ".$numberOfCatalogue."<br>";
//TODO DEBUG
- /* foreach($syncListResultCsw->external_csw[0]->create as $cswFileIdentifier) {
+ /* foreach($syncListResultCsw->datasource_metadata[0]->create as $cswFileIdentifier) {
- $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncListResultCsw->external_csw[0]->id, $cswFileIdentifier, "orga_name", "orga_title", "orga_email", $this->topicDataThemeCategoryMap, "transparency_category_de_rp:environmental_information");
+ $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncListResultCsw->datasource_metadata[0]->id, $cswFileIdentifier, "orga_name", "orga_title", "orga_email", $this->topicDataThemeCategoryMap, "transparency_category_de_rp:environmental_information");
@@ -428,7 +684,7 @@
- //TODO: define standard category filter in ckan.conf!
+ //TODO: define standard category filter in ckan.conf for spatial data!
$queryObject->rows = 1000;
@@ -458,7 +714,7 @@
} else {
- // only list http://localhost:5000/api/3/action/package_list?q=owner_org:81476cf5-6c52-4e99-8b9f-6150d63fcb32
+ //only list http://localhost:5000/api/3/action/package_list?q=owner_org:81476cf5-6c52-4e99-8b9f-6150d63fcb32
//TODO: test what wents wrong, if fkey_mb_group_id is set in mapbender
@@ -509,9 +765,9 @@
- $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->id = $geoportalMetadata['uuid'];
- $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->date_time = $geoportalMetadata['changedate'];
- $syncListResult->geoportal_organization[$numberGeoportalOrga]->geoportal_metadata[$numberGeoportalMetadata]->resources = json_decode($geoportalMetadata['resources']);
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->id = $geoportalMetadata['uuid'];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->date_time = $geoportalMetadata['changedate'];
+ $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->resources = json_decode($geoportalMetadata['resources']);
$geoportalUuids[] = $geoportalMetadata['uuid'];
$numberGeoportalMetadata++;
@@ -571,143 +827,53 @@
- public function syncSingleCsw($syncListJson) {
+ syncListJson - Format:
+ public function syncSingleDataSource($syncListJson, $dataSourceType, $checkOrgaIdentity = false) {
+ $dataSourceTypeArrayWithViews = array("portalucsw","mapbender");
$resultObject = new stdClass();
- $resultObject->help = "Syncing external csw with ckan for organization with id: ".$this->syncOrgaId;
+ $resultObject->help = "Syncing datasource of type ".$dataSourceType." for organization with id: ".$this->syncOrgaId;
$syncList = json_decode($syncListJson);
- //if ($syncList->id == $this->syncOrgaId) { - not relevant for csw sync, cause multiple csw may be synced for one ckan orga
- $numberOfDeletedPackages = 0;
- $numberOfCreatedPackages = 0;
- $numberOfUpdatedPackages = 0;
- //read ckan api-key from database again, because we wont transfer it via json thru the web ;-)
- $sql = "SELECT mb_group_ckan_api_key FROM mb_group WHERE mb_group_id = $1";
- $v = array($this->syncOrgaId);
- $t = array('s');
- $res = db_prep_query($sql, $v, $t);
- if ($res) {
- $row = db_fetch_assoc($res);
- $ckanApiKey = $row['mb_group_ckan_api_key'];
- $ckan = new ckanApi($ckanApiKey, CKAN_SERVER_IP);
- $ckan->base_url = $this->ckanApiProtocol.'://'.$this->ckanApiUrl.'/api/3/';
- $ckan->api_version = $this->ckanApiVersion;
- } else {
- $e = new mb_exception("classes/class_syncCkan.php: No api-key found for mapbender group: ".$this->syncOrgaId);
- return false;
- foreach($syncList->delete as $ckanNameToDelete) {
- //TODO - PortalU Problem lowercase/uppercase
- $ckanNameToDelete = strtolower($ckanNameToDelete);
- $result = $ckan->action_package_delete("{\"id\":\"".$ckanNameToDelete."\"}");
- if ($result->success == true) {
- $e = new mb_notice("classes/class_syncCkan.php: Ckan package with name ".$ckanNameToDelete." successfully deleted!");
- $numberOfDeletedPackages++;
- } else {
- $e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to delete ckan package with name ".$ckanNameToDelete);
- foreach ($syncList->csw_metadata as $datasetMetadata) {
- if (in_array($datasetMetadata->id, $syncList->update) || in_array($datasetMetadata->id, $syncList->create)) {
- //build resources array for each metadata
- /*$layerArrayMetadata = array();
- $featuretypeArrayMetadata = array();
- foreach ($datasetMetadata->resources->coupledResources->layerIds as $layerId) {
- $layerArrayMetadata[] = $layerId;
- foreach ($datasetMetadata->resources->coupledResources->featuretypeIds as $featuretypeId) {
- $featuretypeArrayMetadata[] = $featuretypeId;
- //check if dataset already exists in ckan - we know this, cause we want to update those
- //if (in_array($datasetMetadata['uuid'], $ckanMetadataArray['name'])) {
- //echo $datasetMetadata['uuid']." has to be updated!"."<br>";
- //} else {
- //echo $datasetMetadata['uuid']." has to be initial created!"."<br>";
- //check if deleted package with same uuid already exists, because the deleted packages only have the state deleted!
- //TODO fix upper/lowercase problem
- $resourceJson->id = strtolower($datasetMetadata->id); //find by id and name name:http://docs.ckan.org/en/latest/api/
- $result = $ckan->action_package_show(json_encode($resourceJson));
- //update existing package
- //$resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicCkanCategoryMap);
- //TODO - define parameter
- $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->name, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
- if ($resultCkanRepresentation != false) {
- $result = $ckan->action_package_update($resultCkanRepresentation['json']);
- //echo "Creation of package successful!"."<br>";
- //recreate views
- $viewsUpdateProtocol = $this->recreateResourceViews($ckan, $result, $resultCkanRepresentation);
- $numberOfUpdatedPackages++;
- //$e = new mb_exception($viewsUpdateProtocol);
- } else {
- //echo "A problem occured while trying to create the ckan package"."<br>";
- } else {
- //echo "A problem occured while trying to create the json object from geoportal metadata!"."<br>";
- } else {
- //create new package
- //echo "Package ".$datasetMetadata['uuid']." does not exist and has to be created!"."<br>";
- //TODO
- $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
- $result = $ckan->action_package_create($resultCkanRepresentation['json']);
- //recreate views
- $numberOfCreatedPackages++;
- } else {
- $e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to create the ckan package");
- } else {
- $e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to create the json object from csw metadata!");
- /*} else {
- $e = new mb_exception("classes/class_syncCkan.php (syncSingleCsw): Id from json is not identical to id from class! Sync will not be started!");
+ $numberOfDeletedPackages = 0;
+ $numberOfCreatedPackages = 0;
+ $numberOfUpdatedPackages = 0;
+ if ($checkOrgaIdentity == true && (integer)$syncList->id !== $this->syncOrgaId) {
+ $e = new mb_exception("classes/class_syncCkan.php (syncSingleDataSource): Id from json is not identical to id from class! Sync will not be started!");
$resultObject->success = false;
$resultObject->error->message = "Organization id for the invoked sync process could not be obtained - please check the id!";
- //$resultObject->help = "Sync of metadata for orga ";
return json_encode($resultObject);
- $resultObject->success = true;
- $resultObject->result->orga_id = $this->syncOrgaId;
- $resultObject->result->numberOfDeletedPackages = $numberOfDeletedPackages;
- $resultObject->result->numberOfUpdatedPackages = $numberOfUpdatedPackages;
- $resultObject->result->numberOfCreatedPackages = $numberOfCreatedPackages;
- return json_encode($resultObject);
- public function syncSingleOrga($syncListJson) {
- $resultObject = new stdClass();
- $resultObject->help = "Syncing mapbender with ckan for organization with id: ".$this->syncOrgaId;
- $syncList = json_decode($syncListJson);
- if ($syncList->id == $this->syncOrgaId) {
+ } else {
$t = array('s');
+ //$e = new mb_exception("classes/class_syncCkan.php (syncSingleDataSource): syncList->update: ".json_encode($syncList->update));
+ //$e = new mb_exception("classes/class_syncCkan.php (syncSingleDataSource): syncList->delete: ".json_encode($syncList->delete));
+ //$e = new mb_exception("classes/class_syncCkan.php (syncSingleDataSource): syncList->create: ".json_encode($syncList->create));
if ($res) {
+ $ckanApiKey = $row['mb_group_ckan_api_key'];
+ $ckan = new ckanApi($ckanApiKey, CKAN_SERVER_IP);
} else {
return false;
+ //delete orphaned datasets
+ switch ($dataSourceType) {
+ case "portalucsw":
+ //TODO - PortalU Problem lowercase/uppercase
+ $ckanNameToDelete = strtolower($ckanNameToDelete);
+ break;
+ case "ckan":
+ break;
@@ -716,81 +882,112 @@
- foreach ($syncList->geoportal_metadata as $datasetMetadata) {
+ //$e = new mb_exception("classes/class_syncCkan.php: complete syncList as json: ".$syncListJson);
+ foreach ($syncList->datasource_metadata as $datasetMetadata) {
+ //$e = new mb_exception("classes/class_syncCkan.php: try to sync dataset with id: ".$datasetMetadata->id);
- $layerArrayMetadata = array();
- //} else {
+ //do some special preproccessing
+ case "mapbender":
+ $layerArrayMetadata = array();
+ $featuretypeArrayMetadata = array();
+ foreach ($datasetMetadata->resources->coupledResources->layerIds as $layerId) {
+ $layerArrayMetadata[] = $layerId;
+ foreach ($datasetMetadata->resources->coupledResources->featuretypeIds as $featuretypeId) {
+ $featuretypeArrayMetadata[] = $featuretypeId;
+ $resourceJson->id = $datasetMetadata->id; //find by id and name name:http://docs.ckan.org/en/latest/api/
+ break;
+ //override uuid with lowercase representation of uuid - problem of portalu implementation
+ $resourceJson->id = strtolower($datasetMetadata->id);
+ break;
+ default:
+ break;
+ $result = $ckan->action_package_show(json_encode($resourceJson));
+ if ($result->success == true) {
+ //try to do an update
+ //first try to read from datasource
+ case "mapbender":
+ $resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap);
+ break;
+ $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->name, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
+ break;
+ default:
+ //TODO: pull ckan json object from remote ckan source and transform it into central object - map attributes!!!!
+ //$e = new mb_exception("classes/class_syncCkan.php: try to pull json object from remote ckan - id: ".$datasetMetadata->id);
+ $resultCkanRepresentation = $this->getCkanRepresentationFromCkan($syncList->ckan_api_url, $syncList->ckan_api_version, $datasetMetadata->id, $syncList->central_filter, $syncList->ckan_orga_ident);
- $resourceJson->id = $datasetMetadata->id; //find by id and name name:http://docs.ckan.org/en/latest/api/
- $resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap);
- //recreate views
+ //$resultCkanRepresentation = false;
+ //$resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap);
+ break;
+ //if reading was successful
+ if ($resultCkanRepresentation != false) {
+ //try to do an update via api
+ $result = $ckan->action_package_update($resultCkanRepresentation['json']);
+ //try to update views if they exists in this dataSourceType
+ if (in_array($dataSourceType, $dataSourceTypeArrayWithViews)) {
- } else {
+ $numberOfUpdatedPackages++;
} else {
+ $e = new mb_exception("classes/class_syncCkan.php: An error occured while trying to update ".$resultCkanRepresentation['json']);
} else {
- //recreate views
- } else {
+ $e = new mb_exception("classes/class_syncCkan.php: An error occured while generate json from external source");
+ } else {
+ //create new package
+ //first read from external source
+ case "mapbender":
+ break;
+ $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
+ break;
+ default:
+ break;
+ //if read from source was successful
+ $result = $ckan->action_package_create($resultCkanRepresentation['json']);
+ //if creation from external source was successful - try to create
+ $numberOfCreatedPackages++;
+ $viewsUpdateProtocol = $this->recreateResourceViews($ckan, $result, $resultCkanRepresentation);
} else {
- $e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to create the json object from geoportal metadata!");
+ $e = new mb_exception("classes/class_syncCkan.php: An error occured while trying to create ".$resultCkanRepresentation['json']);
+ } else {
+ $e = new mb_exception("classes/class_syncCkan.php: A problem occured while trying to create the json object from ".$dataSourceType." metadata!");
- } else {
- $e = new mb_exception("classes/class_syncCkan.php (syncSingleOrga): Id from json is not identical to id from class! Sync will not be started!");
- $resultObject->success = false;
- $resultObject->error->message = "Organization id for the invoked sync process could not be obtained - please check the id!";
+ $resultObject->success = true;
+ $resultObject->result->orga_id = $this->syncOrgaId;
+ $resultObject->result->numberOfDeletedPackages = $numberOfDeletedPackages;
+ $resultObject->result->numberOfUpdatedPackages = $numberOfUpdatedPackages;
+ $resultObject->result->numberOfCreatedPackages = $numberOfCreatedPackages;
- //private function getCkanRepresentationFromCsw($syncList->external_csw[0]->id, uuid) {
private function getCkanRepresentationFromCsw($cswId, $fileIdentifier, $ckan_orga_ident, $orgaTitle, $orgaEmail, $topicDataThemeCategoryMap, $ckanCategoryFilter) {
if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
$mapbenderUrl = MAPBENDER_PATH;
Modified: trunk/mapbender/http/php/mod_syncCkan_server.php
--- trunk/mapbender/http/php/mod_syncCkan_server.php 2017-10-19 12:26:18 UTC (rev 9805)
+++ trunk/mapbender/http/php/mod_syncCkan_server.php 2017-10-20 11:04:45 UTC (rev 9806)
@@ -11,8 +11,9 @@
require_once(dirname(__FILE__) . '/../php/mod_getDownloadOptions.php');
require_once(dirname(__FILE__).'/../../conf/ckan.conf');
-//http://localhost/mb_trunk/php/mod_syncCkan_new.php?userId=1&compareTimestamps=true&syncDepartment=24
-//http://localhost/mb_trunk/php/mod_syncCkan_new.php?userId=1&compareTimestamps=false
+//http://localhost/mb_trunk/php/mod_syncCkan_server.php?userId=1&compareTimestamps=true&syncDepartment=25&operation=syncCkan
//TODO: Problem - datestamp for ckan_package - wrong????? Bug in 2.5.3??? Will the index not be updated???
$registratingDepartments = false;
$userId = false;
@@ -63,8 +64,8 @@
if (isset($_REQUEST["operation"]) && $_REQUEST["operation"] !== "" && $_REQUEST["operation"] !== null) {
$testMatch = $_REQUEST["operation"];
- if (!($testMatch == 'listCatalogues' or $testMatch == 'syncCatalogue' or $testMatch == 'syncCsw')){
- $resultObject->error->message = 'Parameter operation is not valid (listCatalogues, syncCatalogue, syncCsw).';
+ if (!($testMatch == 'listCatalogues' or $testMatch == 'syncCatalogue' or $testMatch == 'syncCsw' or $testMatch == 'syncCkan')){
+ $resultObject->error->message = 'Parameter operation is not valid (listCatalogues, syncCatalogue, syncCsw, syncCkan).';
echo json_encode($resultObject);
die();
@@ -166,6 +167,43 @@
die();
+if ($operation == 'syncCkan') {
+ //check if user is allowed to sync for requested organisation
+ //TODO - make code better
+ //overwrite organization from cswId with right orgaId
+ $test = $syncCkanClass->syncOrgaId;
+ $syncCkanClass->syncOrgaId = $orgaId;
+ //$e = new mb_exception($syncCkanClass->syncOrgaId);
+ $departmentsArray = $syncCkanClass->getMapbenderOrganizations();
+ //rewind orgaid to cswid to get right synclist
+ $syncCkanClass->syncOrgaId = $test;
+ //TODO: alter csw based sync to give orgaId as parameter as this is done here
+ $syncListJsonCkan = $syncCkanClass->getSyncListRemoteCkanJson($departmentsArray, $syncCkanClass->syncOrgaId, true);
+ //for synching use right orga id for getting apikey for invoking $syncCkanClass->syncSingleCsw
+ if (isset($orgaId) && $orgaId !== null) {
+ $syncList = json_decode($syncListJsonCkan);
+ if ($syncList->success = true) {
+ foreach ($syncList->result->external_ckan as $orga) {
+ //TODO try to sync single orga - the class has already set the syncOrgaId if wished!
+ //if ($syncDepartment == $orga->id) {
+ //overwrite result with result from sync process
+ //$syncList = json_decode($syncCkanClass->syncSingleCsw(json_encode($orga)));
+ //new function
+//$e = new mb_exception($syncListJsonCkan);
+ $syncList = json_decode($syncCkanClass->syncSingleDataSource(json_encode($orga), "ckan"));
+ //create new syncListJson
+ $syncListJson = json_encode($syncList);
+ header('Content-type:application/json;charset=utf-8');
+ echo $syncListJson;
+ die();
if ($operation == 'syncCsw') {
@@ -176,7 +214,7 @@
- $syncListJsonCsw = $syncCkanClass->getSyncListCswJson($departmentsArray, true);
+ $syncListJsonCsw = $syncCkanClass->getSyncListCswJson($departmentsArray, $syncCkanClass->syncOrgaId, true);
$syncList = json_decode($syncListJsonCsw);
@@ -185,7 +223,10 @@
- $syncList = json_decode($syncCkanClass->syncSingleCsw(json_encode($orga)));
+ //new function
+ $syncList = json_decode($syncCkanClass->syncSingleDataSource(json_encode($orga), "portalucsw"));
@@ -208,7 +249,8 @@
//try to sync single orga - the class has already set the syncOrgaId if wished!
- $syncList = json_decode($syncCkanClass->syncSingleOrga(json_encode($orga)));
+ //$syncList = json_decode($syncCkanClass->syncSingleOrga(json_encode($orga)));
+ $syncList = json_decode($syncCkanClass->syncSingleDataSource(json_encode($orga), "mapbender", true));
More information about the Mapbender_commits
