[Mapbender-commits] r9807 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Wed Oct 25 07:03:50 PDT 2017
Author: armin11
Date: 2017-10-25 07:03:50 -0700 (Wed, 25 Oct 2017)
New Revision: 9807
trunk/mapbender/http/classes/class_crs.php
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Fix for resolve axis order for crs and INSPIRE ATOM feed generator
Modified: trunk/mapbender/http/classes/class_crs.php
--- trunk/mapbender/http/classes/class_crs.php 2017-10-20 11:04:45 UTC (rev 9806)
+++ trunk/mapbender/http/classes/class_crs.php 2017-10-25 14:03:50 UTC (rev 9807)
@@ -29,6 +29,7 @@
* https://github.com/deegree/deegree3/wiki/Axis-order-handling
* http://docs.geotools.org/latest/userguide/library/referencing/order.html
* http://mapserver.org/ogc/wms_server.html
+ * http://www.ogcnetwork.net/axisorder
class Crs {
@@ -58,16 +59,19 @@
//handles ows identifier: wms_1.0.0, wms_1.1.1, wms_1.3.0, wfs_1.0.0, wfs_1.1.0, wfs_2.0.0, wfs_2.0.2
public function alterAxisOrder ($targetOws) {
- $owsWithSpecialOrder = array("wms_1.0.0","wms_1.1.1","wfs_1.0.0");//lon/lat,east/north
- $owsWithOrderAsDefined = array("wms_1.3.0","wfs_1.1.0","wfs_2.0.0","wfs_2.0.2");
+ $owsWithSpecialOrder = array("wms_1.0.0","wms_1.1.1","wfs_1.0.0","gml_2.0.0","gml_2.1.0","gml_3.1.1","geojson");//lon/lat,east/north
+ $owsWithOrderAsDefined = array("wms_1.3.0","wfs_1.1.0","wfs_2.0.0","wfs_2.0.2","gml_3.2.0");
+ //$owsWithOrderAsDefined = array("wms_1.3.0","wfs_2.0.0","wfs_2.0.2");
$order = "east,north"; //dummy postgis/oracle spatial order
- if (in_array($targetOws, $owsWithSpecialOrder) && $this->identifierType == 'epsg' && $this->axisOrder !== $order) {
+ if (in_array($targetOws, $owsWithSpecialOrder) && $this->axisOrder !== $order) {
+ //if (in_array($targetOws, $owsWithSpecialOrder) && $this->identifierType == 'epsg' && $this->axisOrder !== $order) {
//return false; //cause it is hardcoded in the specs to user lon/lat as this is so in postgis
- return true;
+ return false;
} else {
- /*if (in_array($targetOws, $owsWithOrderAsDefined) && $this->axisOrder !== $order) {
+ if (in_array($targetOws, $owsWithOrderAsDefined) && $this->axisOrder !== $order) {
return true;
return false;
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2017-10-20 11:04:45 UTC (rev 9806)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2017-10-25 14:03:50 UTC (rev 9807)
@@ -1012,11 +1012,12 @@
/*<link rel="related" href="http://xyz.org/wfs?request=GetCapabilities&service=WFS&version=2.0.0" type="application/xml" title="Service implementing Direct Access operations"/>*/
$feedLink = $feedDoc->createElement("link");
if ($admin->getWFSOWSstring($mapbenderMetadata[$m]->wfs_id) == false) {
- $wfsGetCapabilitiesUrl = $mapbenderMetadata[$m]->wfs_getcapabilities;
+ //$wfsGetCapabilitiesUrl = $mapbenderMetadata[$m]->wfs_getcapabilities;
+ $wfsGetCapabilitiesUrl = $mapbenderPath."php/wfs.php?INSPIRE=1&FEATURETYPE_ID=".$mapbenderMetadata[$m]->featuretype_id;
} else {
- $wfsGetCapabilitiesUrl = $mapbenderServerUrl."/registry/wfs/".$mapbenderMetadata[$m]->wfs_id."?";
+ $wfsGetCapabilitiesUrl = $mapbenderServerUrl."/registry/wfs/".$mapbenderMetadata[$m]->wfs_id."?INSPIRE=1";
- $feedLink->setAttribute("href", $wfsGetCapabilitiesUrl."&request=GetCapabilities&VERSION=1.1.0&SERVICE=WFS");
+ $feedLink->setAttribute("href", $wfsGetCapabilitiesUrl."&request=GetCapabilities&VERSION=".$mapbenderMetadata[$m]->wfs_version."&SERVICE=WFS");
$feedLink->setAttribute("rel", "related");
$feedLink->setAttribute("type", "application/xml");
//$feedLink->setAttribute("hreflang", "en");
@@ -1197,7 +1198,7 @@
//use featuretype ref system - to build the bbox filters!!!
$crs = $mapbenderMetadata[$i]->featuretype_srs;
//log ref system of metadata - is this a good idea?
- $e = new mb_notice("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
+ //$e = new mb_exception("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
//*********************** New use crs class for checking if the order has to be changed in the filter!!!
$crsObject = new Crs($crs);
if ($crsObject->alterAxisOrder("wfs"."_".$mapbenderMetadata[$i]->wfs_version) == true) {
@@ -1206,31 +1207,6 @@
$alterAxisOrder = false;
- //handle other definitions of epsg ids
- //urn:ogc:def:crs:EPSG::31467
- //Handle CRS
- //alter all to uppercase
- $crsUpper = str_replace("epsg","EPSG",$crs);
- //Exchange :: with :
- $crsUpper = str_replace("::",":",$crsUpper);
- $crsUpper = str_replace(":6.9:",":",$crsUpper);
- $epsgId = explode('EPSG:',$crsUpper);
- $epsgId = end($epsgId);
- //check if order have to be altered
- if (strpos($crsUpper,'urn') !== false) {
- $e = new mb_notice("urn - found");
- //check if axis order should be changed
- if (check_epsg_wms_13($epsgId)) {
- //alter order of axis for 4326
- $alterAxisOrder = true;
- } else {
- $alterAxisOrder = false;
$e = new mb_notice("Epsg id of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$epsgId);
if (!($mapbenderMetadata[$i]->wfs_version) || $mapbenderMetadata[$i]->wfs_version == '') {
return "<error>Version of WFS : ".$mapbenderMetadata[$i]->wfs_version." is not supported to generate inspire download services for predefined datasets!</error>";
@@ -1283,7 +1259,7 @@
break;
$featureHits[$i] = (integer)$hits[0];
- $e = new mb_exception($featureHits[$i]." hits for featuretype ".$mapbenderMetadata[$i]->featuretype_name);
+ //$e = new mb_exception($featureHits[$i]." hits for featuretype ".$mapbenderMetadata[$i]->featuretype_name);
//calculate further bboxes if the # of hits extents some value
//minimum number of single tiles:
$countTiles = ceil($featureHits[$i]/$maxFeatureCount);
@@ -1301,7 +1277,7 @@
$miny = floatval(db_result($resExtent,0,"miny"));
$maxx = floatval(db_result($resExtent,0,"maxx"));
$maxy = floatval(db_result($resExtent,0,"maxy"));
- $e = new mb_exception("http/php/mod_inspireDownloadFeed.php: - minx: ".$minx. " - maxx: ".$maxx);
+ //$e = new mb_exception("http/php/mod_inspireDownloadFeed.php: - minx: ".$minx. " - maxx: ".$maxx);
//only calculate new boxes if countTiles > 1
if ($countTiles > 1) {
$diffX = $maxx - $minx; //in m - depends on given epsg code
@@ -1382,11 +1358,15 @@
if (!isset($mapbenderMetadata[$i]->geometry_field_name[0]) || $mapbenderMetadata[$i]->geometry_field_name[0] == '') {
$geometryFieldName = 'geometry';
+ } else {
+ $geometryFieldName = $mapbenderMetadata[$i]->geometry_field_name[0];
+ //$e = new mb_exception("mod_inspireDownloadFeed.php: geometryFieldName: ".$geometryFieldName);
+ //get bbox from wfs metadata
$currentBbox = explode(',',$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
//change axis order if crs definition and service needs it
if ($alterAxisOrder == true) {
- $e = new mb_exception("mod_inspireDownloadFeed.php: axis order should be altered!");
+ //$e = new mb_exception("mod_inspireDownloadFeed.php: axis order should be altered!");
$currentBboxNew = $currentBbox;
$currentBboxGetFeature[0] = $currentBboxNew[1];
$currentBboxGetFeature[1] = $currentBboxNew[0];
@@ -1395,6 +1375,8 @@
} else {
$currentBboxGetFeature = $currentBbox;
+ /*$e = new mb_exception("ftname: ".$mapbenderMetadata[$i]->featuretype_name);
+ $e = new mb_exception("gfname: ".$geometryFieldName);*/
if (strpos($mapbenderMetadata[$i]->featuretype_name, ':') !== false) {
$ftNamespace = explode(':', $mapbenderMetadata[$i]->featuretype_name);
$ftNamespace = $ftNamespace[0];
@@ -1459,6 +1441,8 @@
$gFLink = $wfsGetFeatureUrl."SERVICE=WFS&REQUEST=GetFeature&VERSION=";
$gFLink .= $mapbenderMetadata[$i]->wfs_version."&typeName=".$mapbenderMetadata[$i]->featuretype_name;
$gFLink .= "&srsName=".$mapbenderMetadata[$i]->featuretype_srs;
+ //TODO check if other epsg string should be used!
+ //$crsObject->identifier;
if (count($mapbenderMetadata[$i]->output_formats) >= 1 && strtoupper($mapbenderMetadata[$i]->geometry_field_name[0] !== "SHAPE")) {
//use first output format which have been found - TODO - check if it should be pulled from featuretype instead from wfs
$gFLink .= "&outputFormat=".rawurlencode($mapbenderMetadata[$i]->output_formats[0]);
@@ -1703,11 +1687,12 @@
$furtherLinkBbox[$m] = $featureTypeBboxWGS84[$m];
$newBox = explode(',',$furtherLinkBbox[$m]);
- if ($alterAxisOrder == true) {
+ /*if ($alterAxisOrder == true) {
$newBox = $newBox[1].",".$newBox[0].",".$newBox[3].",".$newBox[2];
- } else {
+ } else {*/
$newBox = $newBox[0].",".$newBox[1].",".$newBox[2].",".$newBox[3];
//generate content links
$feedEntryLink = $feedDoc->createElement("link");
if (count($getFeatureLink) > 1) {
@@ -2067,11 +2052,12 @@
$t = array('i');
$res = db_prep_query($sql,$v,$t);
//pull first element with type is string like "PropertyType"
+ $geometryElements = array("GeometryPropertyType","MultiSurfacePropertyType","GeometryPropertyType","CurvePropertyType","PolygonPropertyType","LineStringPropertyType","PointPropertyType","MultiPolygonPropertyType","MultiLineStringPropertyType","MultiPointPropertyType","SurfacePropertyType");
while ($row = db_fetch_array($res)) {
- //$e = new mb_notice("php/mod_inspireDownloadFeed.php: test element_type: ".$row['element_type']);
- if (strpos($row['element_type'], "PropertyType") !== false) {
+ //$e = new mb_exception("php/mod_inspireDownloadFeed.php: test element_type: ".$row['element_type']);
+ if (in_array($row['element_type'], $geometryElements)) {
$mapbenderMetadata[$indexMapbenderMetadata]->geometry_field_name[] = $row['element_name'];
- $e = new mb_notice("php/mod_inspireDownloadFeed.php: element_name of geometry field (type name like PropertyName) found: ".$row['element_name']);
+ //$e = new mb_exception("php/mod_inspireDownloadFeed.php: element_name of geometry field (type name like PropertyName) found: ".$row['element_name']);
break;
More information about the Mapbender_commits
