[Mapbender-commits] r9941 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 06:13:14 PDT 2018
Author: armin11
Date: 2018-08-09 06:13:14 -0700 (Thu, 09 Aug 2018)
New Revision: 9941
Removed:
   trunk/mapbender/http/classes/class_metadata_new.php
Rename search class to class_metadata.php
Deleted: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2018-08-09 13:10:58 UTC (rev 9940)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2018-08-09 13:13:14 UTC (rev 9941)
@@ -1,2274 +0,0 @@
-<?php
-#Script to call this class: http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php
-#Class for getting results out of the mapbender service registry
-#Resulttypes: WMS, WMS-Layer, (WFS), WFS-Featurtyps, WFS-Conf, WMC, Datasets, ...
-#Possible filters: registrating organizations, time, bbox (fully inside, intersects, fully outside), ISO Topic Categories, INSPIRE themes, INSPIRE: keywords, classification of data/service ... - maybe relevant for the german broker not for one instance, quality and actuality (maybe spatial and temporal), bbox, deegree of conformity with ir, access and use constraints, responsible parties - maybe one is enough? We must have a look at the INSPIRE Metadata IR
-#Metadata we need to fullfil the demands of INSPIRE:
-#1. INSPIRE conformity classification for WMS/WFS/WCS
-#2. Temporal Extents at WMS/WMS-Layer/WFS/WFS-Featuretype levels - for datasets if demanded - til now there is no demand defined in the guidance-paper for metadata ir
-#3. Classified access and use contraints - which classes? - Check IR Data Sharing and IR Metadata
-#4.
-#Every resource which should be send to INSPIRE can be filtered - but is not neccessary for a standardized approach
-#Another problem is the ranking of the different ressources. The ranking should be homogeneus.
-#Till now we rank the using of WMS Layers when Caps are requested and when s.o. load one layer into the geoportal.
-#TODO: The same things have to be done for the wfs-conf (Modules). Actually the invocation of inspire atom feeds are counted. Also the invocation of WMC documents are monitored.
-#Classes for filtering after the results have been send to the portal:
-#1. ISO Topic Categories
-#2. INSPIRE Themes
-#3. Access and use classification
-#4. departments which provides the ressources - we need the new concept for the administration of this departments - store the addresses in the group table and give the relation - originating group in table mb_user_mb_group
-#Cause we have a authorization layer, we need the id of the requesting user which is defined in the session. If no session is set, it should be the anonymous user of the portal.
-#We need a parameter for internationalization - it should be send with the search request! Some of the Classes can be provided with different languages.
-#WMC and GeoRSS-Feeds have no or a to complex authorization info - maybe we need to test if wmc consists of info which is fully or only partually available to the anonymous user.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/class_administration.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_json.php");
-require_once(dirname(__FILE__) . "/../php/mod_getDownloadOptions.php");
-//definition for the things which are common to all kind of metadata ressources
-class searchMetadata {
-	var $userId;
-	var $searchId;
-	var $searchText;
-	var $registratingDepartments;
-	var $isoCategories;
-	var $inspireThemes;
-	var $customCategories;
-	var $timeBegin;
-	var $timeEnd;
-	var $regTimeBegin;
-	var $regTimeEnd;
-	var $maxResults;
-	var $searchBbox;
-	var $searchTypeBbox;
-	var $accessRestrictions;
-	var $languageCode;
-	var $searchStartTime;
-	var $searchView;
-	var $searchURL;
-	var $searchEPSG;
-	var $searchResources;
-	var $searchPages;
-	var $outputFormat;
-	var $resultTarget; //web,webclient,file,internal
-	var $tempFolder;
-	var $orderBy;
-	var $hostName;
-	var $resourceIds;
-	var $restrictToOpenData;
-	var $originFromHeader;
-	var $resolveCoupledResources; //only for class of dataset metadata - it pulls the coupled ressources (ogc-services : wms-layer/wfs-featuretypes)
-	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader, $resolveCoupledResources = false){
-		$this->userId = (integer)$userId;
-		$this->searchId = $searchId;
-		$this->searchText = $searchText;
-		$this->registratingDepartments = $registratingDepartments; //array with ids of the registrating groups in the mb database
-		$this->registratingDepartmentsArray = explode(",",$this->registratingDepartments);
-		$this->isoCategories = $isoCategories;
-		$this->inspireThemes = $inspireThemes;
-		$this->customCategories = $customCategories;
-		$this->timeBegin = $timeBegin;
-		$this->timeEnd = $timeEnd;
-		$this->regTimeBegin = $regTimeBegin;
-		$this->regTimeEnd = $regTimeEnd;
-		$this->maxResults = (integer)$maxResults;
-		$this->searchBbox = $searchBbox;
-		$this->searchTypeBbox = $searchTypeBbox;
-		$this->accessRestrictions = $accessRestrictions;
-		$this->languageCode = $languageCode;
-		$this->searchEPSG = $searchEPSG;
-		$this->searchResources = $searchResources;
-		$this->searchPages = $searchPages;
-		$this->outputFormat = $outputFormat;
-		$this->resultTarget = $resultTarget;
-		$this->searchURL = $searchURL;
-		$this->hostName = $hostName;
-		$this->orderBy = $orderBy;
-		$this->resourceIds = $resourceIds;
-		if ($restrictToOpenData === "true") {
-			$this->restrictToOpenData = true;
-		} else {
-			$this->restrictToOpenData = false;
-		$this->originFromHeader = $originFromHeader;
-		$this->internalResult = null; //will only be filled, if resultTarget = 'internal', includes json for wms or wfs
-		$this->resolveCoupledResources = $resolveCoupledResources;
-		//definitions for generating tagClouds
-		$this->maxObjects = 15;
-		$this->maxFontSize = 30;
-		$this->maxWeight = 0;
-		$this->scale = 'linear';
-		$this->minFontSize = 10;
-		if (defined("ABSOLUTE_TMPDIR")){
-			$this->tempFolder = ABSOLUTE_TMPDIR;
-		} else {
-			$this->tempFolder = TMPDIR;
-		if ($this->outputFormat == 'json'){
-			$this->json = new Mapbender_JSON;
-		$this->accessableLayers = NULL;
-		//set a time to find time consumers
-		$this->searchStartTime = $this->microtime_float();
-		//Defining of the different database categories
-		$this->resourceClassifications = array();
-		$this->resourceClassifications[0]['title'] = "ISO 19115"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[0]['tablename'] = 'md_topic_category';
-		$this->resourceClassifications[0]['requestName'] = 'isoCategories';
-		$this->resourceClassifications[0]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[0]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[0]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[0]['id_dataset'] = 'metadata_id';
-		$this->resourceClassifications[0]['relation_wms'] = 'layer_md_topic_category';
-		$this->resourceClassifications[0]['relation_wfs'] = 'wfs_featuretype_md_topic_category';
-		$this->resourceClassifications[0]['relation_wmc'] = 'wmc_md_topic_category';
-		$this->resourceClassifications[0]['relation_dataset'] = 'mb_metadata_md_topic_category';
-//TODO: define this in mapbender
-		$this->resourceClassifications[1]['title'] = "INSPIRE"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[1]['tablename'] = 'inspire_category';
-		$this->resourceClassifications[1]['requestName'] = 'inspireThemes';
-		$this->resourceClassifications[1]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[1]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[1]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[1]['id_dataset'] = 'metadata_id';
-		$this->resourceClassifications[1]['relation_wms'] = 'layer_inspire_category';
-		$this->resourceClassifications[1]['relation_wfs'] = 'wfs_featuretype_inspire_category';
-		$this->resourceClassifications[1]['relation_wmc'] = 'wmc_inspire_category';
-		$this->resourceClassifications[1]['relation_dataset'] = 'mb_metadata_inspire_category';
-		switch($this->languageCode){
-			case "de":
-				$this->resourceClassifications[2]['title'] = "Sonstige"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-			break;
-			case "en":
-				$this->resourceClassifications[2]['title'] = "Custom";
-			break;
-			case "fr":
-				$this->resourceClassifications[2]['title'] = "Personnaliser";
-			break;
-			default:
-			break;
-		$this->resourceClassifications[2]['tablename'] = 'custom_category';
-		$this->resourceClassifications[2]['requestName'] = 'customCategories';
-		$this->resourceClassifications[2]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[2]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[2]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[2]['id_dataset'] = 'metadata_id';
-		$this->resourceClassifications[2]['relation_wms'] = 'layer_custom_category';
-		$this->resourceClassifications[2]['relation_wfs'] = 'wfs_featuretype_custom_category';
-		$this->resourceClassifications[2]['relation_wmc'] = 'wmc_custom_category';
-		$this->resourceClassifications[2]['relation_dataset'] = 'mb_metadata_custom_category';
-		//TODO: define this in mapbender
-		switch ($this->languageCode) {
-			case "de":
-				$this->resourceClassifications[3]['title'] = "Organisationen";
-				break;
-			case "en":
-				$this->resourceClassifications[3]['title'] = "Organizations";
-				break;
-			default:
-				break;
-		$this->resourceClassifications[3]['requestName'] = "registratingDepartments";
-		//Defining of the different result categories
-		$this->resourceCategories = array();
-		$this->resourceCategories[0]['name'] = 'WMS';
-		$this->resourceCategories[1]['name'] = 'WFS';
-		$this->resourceCategories[2]['name'] = 'WMC';
-		$this->resourceCategories[3]['name'] = 'DAD';
-		$this->resourceCategories[4]['name'] = 'DATASET';
-        		case 'de':
-                	$this->resourceCategories[0]['name2show'] = 'Darstellungsdienste';
-			$this->resourceCategories[1]['name2show'] = 'Such- und Download- und Erfassungsmodule';
-			$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
-			$this->resourceCategories[3]['name2show'] = 'KML/Newsfeeds';
-			$this->resourceCategories[4]['name2show'] = 'Datensätze';
-			$this->keywordTitle = 'Schlagwortliste';
-       			break;
-        		case 'en':
-               		$this->resourceCategories[0]['name2show'] = 'Viewingservices';
-			$this->resourceCategories[1]['name2show'] = 'Search- and Downloadservices';
-			$this->resourceCategories[2]['name2show'] = 'Combined Maps';
-			$this->resourceCategories[4]['name2show'] = 'Datasets';
-			$this->keywordTitle = 'Keywordlist';
-        		break;
-        		case 'fr':
-          	     	$this->resourceCategories[0]['name2show'] = 'Services de visualisation';
-			$this->resourceCategories[1]['name2show'] = 'Services de recherche et de téléchargement';
-			$this->resourceCategories[2]['name2show'] = 'Cartes composées';
-       			break;
-     			default:
-		//not needed til now - maybe usefull for georss output
-		if ($this->outputFormat == "xml") {
-			//Initialize XML documents
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wms") {
-				$this->wmsDoc = new DOMDocument('1.0');
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wfs") {
-				$this->wfsDoc = new DOMDocument('1.0');
-				$this->generateWFSMetadata($this->wfsDoc);
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wmc") {
-				$this->wmcDoc = new DOMDocument('1.0');
-				$this->generateWMCMetadata($this->wmcDoc);
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "georss") {
-				$this->georssDoc = new DOMDocument('1.0');
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "dataset") {
-				$this->datasetDoc = new DOMDocument('1.0');
-				$this->generateDatasetMetadata($this->datasetDoc);
-		if ($this->outputFormat === "json") {
-			$this->e = new mb_notice("orderBy old: ".$this->orderBy);
-				$this->databaseIdColumnName = 'featuretype_id';
-				$this->databaseTableName = 'wfs_featuretype';
-				//$this->keywordRelation = 'wfs_featuretype_keyword';
-				$this->searchView = 'wfs_search_table';
-				$this->whereStrCatExtension = " AND custom_category.custom_category_hidden = 0";
-				switch ($this->orderBy) {
-					case "rank":
-						$this->orderBy = " ORDER BY wfs_id,featuretype_id,wfs_conf_id ";
-						break;
-					case "id":
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY featuretype_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wfs_timestamp DESC ";
-						break;
-					default:
-				$this->resourceClasses = array(0,1,2);
-				$this->databaseIdColumnName = 'layer_id';
-				$this->databaseTableName = 'layer';
-				//$this->keywordRelation = 'layer_keyword';
-				$this->searchView = 'wms_search_table';
-				//$this->searchView = 'search_wms_view';
-					case "rank":
-						$this->orderBy = " ORDER BY load_count DESC";
-						break;
-					case "id":
-						$this->orderBy = " ORDER BY wms_id,layer_pos ASC";
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY layer_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wms_timestamp DESC ";
-						break;
-					default:
-				$this->generateWMSMetadata($this->wmsDoc);
-				$this->searchView = 'search_wmc_view';
-				$this->databaseIdColumnName = 'wmc_serial_id';
-				$this->databaseTableName = 'wmc';
-				//the following is needed to give a special filter to the custom cat table!
-					case "rank":
-						$this->orderBy = " ORDER BY load_count DESC ";
-						break;
-					case "id":
-						$this->orderBy = " ORDER BY wmc_id";
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY wmc_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wmc_timestamp DESC ";
-						break;
-					default:
-				$this->resourceClasses = array(0,1,2); #TODO adopt to count classifications
-				#$this->resourceClasses = array();
-				$this->databaseIdColumnName = 'metadata_id'; //not metadata_id as in original table!
-				$this->databaseTableName = 'mb_metadata';
-				//$this->searchView = 'wms_search_table';
-				//$this->searchView = 'search_dataset_view';
-				$this->searchView = 'dataset_search_table';
-					case "rank":
-						break;
-					case "id":
-						$this->orderBy = " ORDER BY metadata_id ASC";
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY title DESC";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY dataset_timestamp DESC ";
-						break;
-					default:
-						//$this->orderBy = " ORDER BY load_count DESC";
-	$this->e = new mb_notice("orderBy new: ".$this->orderBy);
-	private function microtime_float() {
-    		list($usec, $sec) = explode(" ", microtime());
-    		return ((float)$usec + (float)$sec);
-	private function generateXMLHead($xmlDoc) {
-		$xmlDoc->encoding = CHARSET;
-		$result = $xmlDoc->createElement("result");
-		$xmlDoc->appendChild($result);
-		//Result Count
-		$overLimit = $xmlDoc->createElement("overLimit");
-		$result->appendChild($overLimit);
-		//$tr_text = $xmlDoc->createTextNode($this->isOverLimit);
-		$tr_text = $xmlDoc->createTextNode("really?");
-		$overLimit->appendChild($tr_text);
-		$rd = $xmlDoc->createElement("redirect");
-		$result->appendChild($rd);
-		$trd = $xmlDoc->createTextNode("not yet ready...");
-		$rd->appendChild($trd);
-	private function generateXMLFoot($xmlDoc){
-		$results = $xmlDoc->getElementsByTagName("result");
-		foreach ($results as $result) {
-			$result->appendChild($ready);
-	private function flipDiagonally($arr) {
-    		$out = array();
-    		foreach ($arr as $key => $subarr) {
-      			foreach ($subarr as $subkey => $subvalue) {
-        			$out[$subkey][$key] = $subvalue;
-   		return $out;
-	private function generateWFSMetadataJSON($res, $n) {
-		//initialize object
-		$this->wfsJSON = new stdClass;
-		$this->wfsJSON->wfs = (object) array(
-				'md' => (object) array(
-					'nresults' => $n,
-					'p' => $this->searchPages,
-					'rpp' => $this->maxResults
-				'srv' => array()
-		//read out records
-		$serverCount = 0;
-		$wfsMatrix = db_fetch_all($res);
-		//sort result for accessing the right services
-		$wfsMatrix = $this->flipDiagonally($wfsMatrix);
-		//TODO check if order by db or order by php is faster!
-		#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
-		#print_r($wfsMatrix);
-		//read out first server entry - maybe this a little bit timeconsuming TODO
-		$j = 0; //count identical wfs_id => double featuretype
-		$l = 0; //index featuretype and or modul per wfs
-		$m = 0; //index modul per featuretype
-		for($i=0; $i<count($wfsMatrix);$i++){
-				$this->wfsJSON->wfs->srv[$i-$j]->id = $wfsMatrix[$i]['wfs_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->title = $wfsMatrix[$i]['wfs_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->abstract = $wfsMatrix[$i]['wfs_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->date = date("d.m.Y",$wfsMatrix[$i]['wfs_timestamp']);
-				$this->wfsJSON->wfs->srv[$i-$j]->respOrg = $wfsMatrix[$i]['mb_group_name'];
-				$this->wfsJSON->wfs->srv[$i-$j]->logoUrl = $wfsMatrix[$i]['mb_group_logo_path'];
-				$this->wfsJSON->wfs->srv[$i-$j]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?resource=wfs&id=".$wfsMatrix[$i]['wfs_id'];
-				//TODO: Capabilities link
-				$spatialSource = "";
-				$stateOrProvince = $wfsMatrix[$i]['administrativearea'];
-				if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
-					$spatialSource = $wfsMatrix[$i]['country'];
-				} else {
-					$spatialSource = $wfsMatrix[$i]['administrativearea'];
-				$this->wfsJSON->wfs->srv[$i-$j]->iso3166 = $spatialSource;
-				//check if a disclaimer has to be shown and give the relevant symbol
-				//$this->wfsJSON->wfs->srv[$i-$j]->tou = $wfsMatrix[$i]['termsofuse'];
-				list($hasConstraints, $symbolLink) = $this->hasConstraints("wfs", $wfsMatrix[$i]['wfs_id']);
-				$this->wfsJSON->wfs->srv[$i-$j]->hasConstraints = $hasConstraints;
-				$this->wfsJSON->wfs->srv[$i-$j]->symbolLink = $symbolLink;
-				//TODO check the field accessconstraints - which should be presented?
-				$this->wfsJSON->wfs->srv[$i-$j]->status = $wfsMatrix[$i]['status'];
-				$this->wfsJSON->wfs->srv[$i-$j]->avail = $wfsMatrix[$i]['availability'];
-				$this->wfsJSON->wfs->srv[$i-$j]->logged = $wfsMatrix[$i]['wfs_proxylog']; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->price = $wfsMatrix[$i]['wfs_pricevolume']; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->nwaccess = $wfsMatrix[$i]['wfs_network_access']; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->bbox = "-180.0,-90.0,180.0,90.0"; //$wfsMatrix[$i][''];
-				//if featuretype hasn't been created - do it
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype = array();
-				//fill in featuretype infos
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->id = (integer)$wfsMatrix[$i]['featuretype_id'];
-				//get other infos directly from database
-				$otherInformation = $this->getInfofromFeaturetypeId($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->id);
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->title = $wfsMatrix[$i]['featuretype_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->abstract = $wfsMatrix[$i]['featuretype_abstract'];
-				//TODO featuretype name
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->name = $otherInformation['featuretypeName'];
-				//TODO featuretype schema
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->schema = $otherInformation['describeFeaturetypeUrl'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?resource=featuretype&id=".$wfsMatrix[$i]['featuretype_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->bbox = $wfsMatrix[$i]['bbox'];//TODO: $wfsMatrix[$i]['bbox'];
-				//wfs capabilities url:
-				$this->wfsJSON->wfs->srv[$i-$j]->getCapabilitiesUrl = $otherInformation['getCapabilitiesUrl'];
-				//give info for inspire categories - not relevant for other services or instances of mapbender TODO: comment it if the mapbender installation is not used to generate inspire output
-				if (isset($wfsMatrix[$i]['md_inspire_cats']) & ($wfsMatrix[$i]['md_inspire_cats'] != '')){
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->inspire = 1;
-				else {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->inspire = 0;
-				//fill in categories
-				#if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat)) {
-				#	$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat = array();
-				#if (isset($wfsMatrix[$i]['iso_categories'])) {
-				//if (isset($wfsMatrix[$i]['inspire_category'])) {
-					//TODO write the categories as JSON into Database!
-					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->type = 'INSPIRE Kategorie';
- 					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->value = 'Umwelt';
-					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->symbol = 'umwelt.png';
-				#if (isset($wfsMatrix[$i]['custom_categories'])) {
-				//check if module is given
-				if (isset($wfsMatrix[$i]['wfs_conf_id']) && $wfsMatrix[$i]['wfs_conf_id'] != "") {
-					//if modul hasn't been created - do it
-					if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul)) {
-						$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul = array();
-					//fill in modul infos
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->id = $wfsMatrix[$i]['wfs_conf_id'];
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->title = $wfsMatrix[$i]['wfs_conf_description'];
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->abstract = $wfsMatrix[$i]['wfs_conf_abstract'];
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->type = $wfsMatrix[$i]['modultype'];
-					$equalEPSG = $wfsMatrix[$i]['featuretype_srs'];
-                       			$isEqual = true;
-					//control if EPSG is supported by Client
-		        		if ($equalEPSG == $this->searchEPSG){
-						$isEqual = false;
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->srsProblem = $isEqual;
-					//generate Link to show metadata
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?resource=featuretype&id=".$wfsMatrix[$i]['featuretype_id'];
-					$perText = $this->getPermissionValueForWFS($wfsMatrix[$i]['wfs_id'], $wfsMatrix[$i]['wfs_conf_id']);
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->permission = $perText;
-				if ($wfsMatrix[$i]['wfs_id'] == $wfsMatrix[$i+1]['wfs_id']){
-					$j++; //next record is the same service
-					$l++;
-				else
-					$l = 0;
-				if ($wfsMatrix[$i]['featuretype_id'] == $wfsMatrix[$i+1]['featuretype_id']){
-					$m++;
-				else
-					$m = 0;
-	private function generateWMCMetadataJSON($res, $n) {
-		$this->wmcJSON = new stdClass;
-		$this->wmcJSON->wmc = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$wmcMatrix = db_fetch_all($res);
-		$wmcMatrix = $this->flipDiagonally($wmcMatrix);
-		for($i=0; $i<count($wmcMatrix);$i++){
-			$this->wmcJSON->wmc->srv[$i]->id = $wmcMatrix[$i]['wmc_id'];
-			$this->wmcJSON->wmc->srv[$i]->title = $wmcMatrix[$i]['wmc_title'];
-			$this->wmcJSON->wmc->srv[$i]->abstract = $wmcMatrix[$i]['wmc_abstract'];
-			$this->wmcJSON->wmc->srv[$i]->date = date("d.m.Y",$wmcMatrix[$i]['wmc_timestamp']);
-			$this->wmcJSON->wmc->srv[$i]->respOrg = $wmcMatrix[$i]['mb_group_name'];
-			$this->wmcJSON->wmc->srv[$i]->logoUrl = $wmcMatrix[$i]['mb_group_logo_path'];
-			$this->wmcJSON->wmc->srv[$i]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=wmc&layout=tabs&id=".$wmcMatrix[$i]['wmc_id'];
-			$this->wmcJSON->wmc->srv[$i]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=".$wmcMatrix[$i]['wmc_id'];
-			$stateOrProvince = $wmcMatrix[$i]['mb_group_stateorprovince'];
-				$spatialSource = $wmcMatrix[$i]['mb_group_country'];
-			} else {
-				$spatialSource = $wmcMatrix[$i]['mb_group_stateorprovince'];
-			$this->wmcJSON->wmc->srv[$i-$j]->iso3166 = $spatialSource;
-			$this->wmcJSON->wmc->srv[$i-$j]->bbox = array($wmcMatrix[$i]['bbox']); //TODO: read out bbox from wmc $wmcMatrix[$i][''];
-			#$equalEPSG = $wmcMatrix[$i]['srs'];
-                       	#$isEqual = true;
-		        #if ($equalEPSG == $this->searchEPSG){
-			#	$isEqual = false;
-	private function generateDatasetMetadataJSON($res, $n) {
-		$this->datasetJSON = new stdClass;
-		$this->datasetJSON->dataset = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$datasetMatrix = db_fetch_all($res);
-		$datasetMatrix = $this->flipDiagonally($datasetMatrix);
-		$allCoupledLayers = array();
-		$allCoupledFeaturetypes = array();
-		for($i=0; $i<count($datasetMatrix);$i++){
-			$this->datasetJSON->dataset->srv[$i]->id = $datasetMatrix[$i]['dataset_id'];
-			$this->datasetJSON->dataset->srv[$i]->title = $datasetMatrix[$i]['title'];
-			$this->datasetJSON->dataset->srv[$i]->uuid = $datasetMatrix[$i]['fileidentifier'];
-			$this->datasetJSON->dataset->srv[$i]->abstract = $datasetMatrix[$i]['dataset_abstract'];
-			$this->datasetJSON->dataset->srv[$i]->date = date("Y-m-d",strtotime($datasetMatrix[$i]['dataset_timestamp']));
-			$this->datasetJSON->dataset->srv[$i]->respOrg = $datasetMatrix[$i]['mb_group_name'];
-			$this->datasetJSON->dataset->srv[$i]->logoUrl = $datasetMatrix[$i]['mb_group_logo_path'];
-			list($hasConstraints, $symbolLink) = $this->hasConstraints("dataset", $datasetMatrix[$i]['dataset_id']);
-			$this->datasetJSON->dataset->srv[$i]->hasConstraints = $hasConstraints;
-			$this->datasetJSON->dataset->srv[$i]->isopen = $datasetMatrix[$i]['isopen'];
-			$this->datasetJSON->dataset->srv[$i]->symbolLink = $symbolLink;
-			//TODO: other url - to metadata uuid!
-			$this->datasetJSON->dataset->srv[$i]->mdLink = "http://".$this->hostName."/mapbender/php/mod_iso19139ToHtml.php?url=".urlencode("http://".$this->hostName."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=").$datasetMatrix[$i]['fileidentifier'];
-			//TODO: preview?
-			$this->datasetJSON->dataset->srv[$i]->previewURL = $datasetMatrix[$i]['preview_url'];
-			$stateOrProvince = $datasetMatrix[$i]['mb_group_stateorprovince'];
-				$spatialSource = $datasetMatrix[$i]['mb_group_country'];
-			} else {
-				$spatialSource = $datasetMatrix[$i]['mb_group_stateorprovince'];
-			$this->datasetJSON->dataset->srv[$i]->iso3166 = $spatialSource;
-			$this->datasetJSON->dataset->srv[$i]->bbox = array($datasetMatrix[$i]['bbox']); //TODO: read out bbox from wmc $datasetMatrix[$i][''];
-			$this->datasetJSON->dataset->srv[$i]->timeBegin = date("Y-m-d",strtotime($datasetMatrix[$i]['timebegin']));
-			$this->datasetJSON->dataset->srv[$i]->timeEnd = date("Y-m-d",strtotime($datasetMatrix[$i]['timeend']));
-			//search for coupled resources!!!!
-			if ($this->resolveCoupledResources == true) {
-			//maybe generate uuid first to find search!!
-			//http://localhost/mb_trunk/php/mod_callMetadata.php?searchId=test2&searchText=wald&outputFormat=json&resultTarget=web&searchResources=dataset&resolveCoupledResources=true
-				$coupledResources = json_decode($datasetMatrix[$i]['coupled_resources']);
-				$layerCount = 0;
-				$featuretypeCount = 0;
-				foreach ($coupledResources->coupledResources->layerIds as $layer_id) {
-					$this->datasetJSON->dataset->srv[$i]->coupledResources->layer[$layerCount]->id = $layer_id;
-					$allCoupledLayers[] = $layer_id;
-					$layerCount++;
-				foreach ($coupledResources->coupledResources->featuretypeIds as $featuretype_id) {
-					//$e = new mb_exception("ft found: ".$featuretype_id);
-					$this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[$featuretypeCount]->id = $featuretype_id;
-					$allCoupledFeaturetypes[] = $featuretype_id;
-					$featuretypeCount++;
-		//search for coupled resources and push them into dataset json !
-			$layerSearchArray = array();
-			$featuretypeSearchArray = array();
-			$downloadOptionsArray = array();
-			$uniqueAllCoupledLayers = array_unique($allCoupledLayers);
-			$uniqueAllCoupledFeaturetypes = array_unique($allCoupledFeaturetypes);
-			$countUniqueLayers = count($uniqueAllCoupledLayers);
-			$countUniqueFeaturetypes = count($uniqueAllCoupledFeaturetypes);
-			if ($countUniqueLayers >= 1) {
-				//$e = new mb_exception("invoke search");
-				$coupledLayers = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, $countUniqueLayers, null, null, null, $this->languageCode, null, 'wms', 1, 'json', 'internal', null, null, $this->hostName, 'rank',implode(',',$uniqueAllCoupledLayers) ,false , null);
-				$srvCount = 0;
-				foreach (json_decode($coupledLayers->internalResult)->wms->srv as $server) {
-					//$e = new mb_exception("server id ->". $server->id);
-					foreach($server->layer as $layer) {
-						//$layerSearchArray[$layer->id] = $server->id;
-						$layerSearchArray[$layer->id] = $srvCount;
-						//pull inspire downloadoptions from layer information
-						foreach ($layer->downloadOptions as $downloadOption) {
-								if ($downloadOption->uuid != null) {
-									$downloadOptionsArray[$downloadOption->uuid] = json_encode($downloadOption->option);
-						//TODO!: do this also for the next hierachylevel - maybe invoke it recursive!!!
-						foreach($layer->layer as $sublayer) {
-							$layerSearchArray[$sublayer->id] = $srvCount;
-							foreach ($sublayer->downloadOptions as $downloadOption) {
-					$srvCount++;
-			//$e = new mb_exception("count featuretypes: ".time());
-			if ($countUniqueFeaturetypes >= 1) {
-				//$e = new mb_exception("some ft found");
-				$coupledFeaturetypes = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, $countUniqueFeaturetypes, null, null, null, $this->languageCode, null, 'wfs', 1, 'json', 'internal', null, null, $this->hostName, 'rank', implode(',',$uniqueAllCoupledFeaturetypes),false , null);
-				//$e = new mb_exception("featuretype: ".$coupledFeaturetypes->internalResult);
-				$srvCount = 0;
-				foreach (json_decode($coupledFeaturetypes->internalResult)->wfs->srv as $server) {
-					//$e = 	new mb_exception("wfs id: ".$server->id);
-					foreach($server->ftype as $featuretype) {
-						//$e = 	new mb_exception("wfs id: ".$server->id." ft id: ". $featuretype->id);
-						$featuretypeSearchArray[$featuretype->id] = $srvCount;
-					$srvCount++;
-			//insert objects into dataset result list
-				$layerCount = 0;
-				foreach ($this->datasetJSON->dataset->srv[$i]->coupledResources->layer as $layer) {
-					//$e = new mb_exception("layer: ".$layer->id);
-					//$e = new mb_exception("srvcount: ".$layerSearchArray[$layer->id]);
-					$this->datasetJSON->dataset->srv[$i]->coupledResources->layer[$layerCount]->srv = json_decode($coupledLayers->internalResult)->wms->srv[$layerSearchArray[$layer->id]];
-					$layerCount++;
-				foreach ($this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype as $ft) {
-					//$e = new mb_exception($ft->id ." in service:  ". $featuretypeSearchArray[$ft->id]);
-					$this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[$featuretypeCount]->srv = json_decode($coupledFeaturetypes->internalResult, true)->wfs->srv[$featuretypeSearchArray[$ft->id]];
-					//TODO check why featuretypes are not shown in the resultset - $this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[$featuretypeCount]->srv = json_decode($coupledFeaturetypes->internalResult)->wfs->srv[$featuretypeSearchArray[$ft->id]];
-					//delete all featuretypes that have not same id as ft->id
-					$cntFtype = 0;
-					foreach($this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[$featuretypeCount]->srv->ftype as $ftype) {
-						//$e = new mb_exception("classes/class_metadata_new.php: compare featuretype ids: ".$ftype->id." - ".$ft->id);
-						if ($ftype->id !== $ft->id) {
-							unset($this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[$featuretypeCount]->srv->ftype[$cntFtype]);
-						$cntFtype++;
-				//check for atom feed entry
-				//$e = new mb_exception("uuid: ".$datasetMatrix[$i]['fileidentifier']);
-				if ($downloadOptionsArray[$datasetMatrix[$i]['fileidentifier']] != null) {
-					//$e = new mb_exception("element found for uuid: ".$datasetMatrix[$i]['fileidentifier']);
-					$this->datasetJSON->dataset->srv[$i]->coupledResources->inspireAtomFeeds = json_decode($downloadOptionsArray[$datasetMatrix[$i]['fileidentifier']]);
-	private function generateWMSMetadataJSON($res, $n) {
-		$this->wmsJSON = new stdClass;
-		$this->wmsJSON->wms = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$wmsMatrix = db_fetch_all($res);
-		$layerIdArray = array();
-		//read out array with unique wms_ids in wmsMatrix
-		$wmsIdArray = array();
-		//initialize root layer id;
-		$rootLayerId = -1;
-		$j = 0;
-		//get array with all available layer_id for this user:
- 		$admin = new administration();
-		$this->accessableLayers = $admin->getLayersByPermission($this->userId);
-		#echo "<br>user_id: ".$this->userId."<br><br>";
-		#var_dump($this->accessableLayers);
-		#echo "<br>";
-		#$countWmsMatrix = count($wmsMatrix);
-		#echo $countWmsMatrix;
-		if ($n != 0) {
-		for($i=0; $i<count($wmsMatrix);$i++){
-			$layerID = $wmsMatrix[$i]['layer_id'];
-			#echo "<br>LayerID: ".$layerID."<br>";
-			#$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-			if (!in_array($layerID, $layerIdArray) or !in_array($rootLayerId, $layerIdArray)) {
-				$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-				//Select all layers of with this wms_id into new array per WMS - the grouping should be done by wms!
-				$subLayers = $this->filter_by_value($wmsMatrix, 'wms_id', $wmsID);
-				#echo "<br>wms_id: ".$wmsID."<br>";
-				#echo "<br>Number of sublayers: <br>";
-				#print(count($subLayers));
-				//Sort array by load_count - problem: maybe there are some groups between where count is to low (they have no load count because you cannot load them by name)? - Therefor we need some ideas - or pull them out of the database and show them greyed out. Another way will be to define a new group (or wms with the same id) for those layers which are more than one integer away from their parents
-				$subLayersFlip = $this->flipDiagonally($subLayers);
-				#var_dump($subLayers['layer_pos']);
-				#$subLayers = $this->flipDiagonally($subLayers);
-				//go backwards through the layerTree to get the layer with the highest position without gaps in between
-				#var_dump($subLayers['layer_id']);
-				#echo "<br>";
-				$index = array_search($layerID, $subLayersFlip['layer_id']);
-				#echo "<br>found layer_id= ".$layerID." at index: ".$index." in sublayerstable layer_pos=".$subLayers[$index]['layer_pos']." <br>";
-				#echo "<br>sublayers: ";
-				#var_dump($subLayersFlip);
-				#echo "<br>";
-				$rootIndex = $this->getLayerParent($subLayersFlip, $index);
-				$rootLayerPos = $subLayers[$rootIndex]['layer_pos'];
-				$rootLayerId = $subLayers[$rootIndex]['layer_id'];
-				#echo "<br>root layer for this layer: <br>";
-				#echo "<br>id= "..""
-				#echo "<br>";
-				#echo "<br>LayerId:<br>";
-				#echo "<br>".$layerID."<br>";
-				#echo "<br>rootLayerPos:<br>";
-				#echo "<br>".$rootLayerPos."<br>";
-				#echo "<br>rootLayerId:<br>";
-				#echo "<br>".$rootLayerId."<br>";
-				//push root layer id in array
-				array_push($layerIdArray, $rootLayerId);
-				#echo "<br>root Layer ID: ".$rootLayerId."<br>";
-				#array_multisort($subLayers['layer_pos'], SORT_ASC);
-				#print_r($subLayers);
-				#print_r("<br>rootIndex: ".$rootIndex."<br>");
-				//Create object for wms service level
-				$this->wmsJSON->wms->srv[$j]->id = (integer)$subLayers[$rootIndex]['wms_id'];
-				$this->wmsJSON->wms->srv[$j]->title = $subLayers[$rootIndex]['wms_title'];
-				$this->wmsJSON->wms->srv[$j]->abstract = $subLayers[$rootIndex]['wms_abstract'];
-				$this->wmsJSON->wms->srv[$j]->date = date("d.m.Y",$subLayers[$rootIndex]['wms_timestamp']);
-				#$this->wmsJSON->wms->srv[$j]->respOrg = "test";
-				$this->wmsJSON->wms->srv[$j]->loadCount = (integer)$subLayers[$rootIndex]['load_count'];
-				#$this->wmsJSON->wms->srv[$j]->mdLink = "http://".$_SERVER['HTTP_HOST']."/mapbender/geoportal/mod_layerMetadata.php?id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->getMapUrl = $this->getMapUrlfromWMSId((integer)$subLayers[$rootIndex]['wms_id']);
-				$stateOrProvince = $subLayers[$rootIndex]['stateorprovince'];
-				#echo $stateOrProvince."<br>";
-					$spatialSource = $subLayers[$rootIndex]['country'];
-				} else {
-					$spatialSource = $subLayers[$rootIndex]['stateorprovince'];
-				$this->wmsJSON->wms->srv[$j]->iso3166 = $spatialSource;
-				$this->wmsJSON->wms->srv[$j]->respOrg = $subLayers[$rootIndex]['mb_group_name'];
-				$this->wmsJSON->wms->srv[$j]->logoUrl = $subLayers[$rootIndex]['mb_group_logo_path'];
-				#$this->wmsJSON->wms->srv[$j]->tou = $subLayers[$rootIndex]['termsofuse'];
-				list($hasConstraints, $symbolLink) = $this->hasConstraints("wms", $subLayers[$rootIndex]['wms_id']);
-				$this->wmsJSON->wms->srv[$j]->hasConstraints = $hasConstraints;
-				$this->wmsJSON->wms->srv[$j]->isopen = $subLayers[$rootIndex]['isopen'];
-				$this->wmsJSON->wms->srv[$j]->symbolLink = $symbolLink;
-				$this->wmsJSON->wms->srv[$j]->status = $subLayers[$rootIndex]['status']; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->avail = $subLayers[$rootIndex]['availability']; //$wmsMatrix[$i][''];
-				//get info about defined price
-				if ($subLayers[$rootIndex]['wms_pricevolume'] == '' OR $subLayers[$rootIndex]['wms_pricevolume'] == 0){
-					$this->wmsJSON->wms->srv[$j]->price = NULL;
-				else {
-					$this->wmsJSON->wms->srv[$j]->price = $subLayers[$rootIndex]['wms_pricevolume'];
-				//get info about logging of resource
-				if ($subLayers[$rootIndex]['wms_proxylog'] == NULL OR $subLayers[$rootIndex]['wms_proxylog'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->logged = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->logged = true;
-				//get info about network_accessability
-				if ($subLayers[$rootIndex]['wms_network_access'] == NULL OR $subLayers[$rootIndex]['wms_network_access'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = true;
-				#$this->wmsJSON->wms->srv[$j]->logged = NULL; //$wmsMatrix[$i][''];
-				#$this->wmsJSON->wms->srv[$j]->price = NULL; //$wmsMatrix[$i][''];
-				#$this->wmsJSON->wms->srv[$j]->nwaccess = NULL; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->bbox = $subLayers[$rootIndex]['bbox']; //$wmsMatrix[$i][''];
-				//Call recursively the child elements, give and pull $layerIdArray to push the done elements in the array to avoid double results
-				//generate the layer-entry for the so called root layer - maybe this is only a group layer if there is a gap in the layer hierachy
-				$this->wmsJSON->wms->srv[$j]->layer = array();
-				$this->wmsJSON->wms->srv[$j]->layer[0]->id = (integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->title = $subLayers[$rootIndex]['layer_title'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->name = $subLayers[$rootIndex]['layer_name'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->abstract = $subLayers[$rootIndex]['layer_abstract'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=layer&layout=tabs&id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=layer&id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				$legendInfo = $this->getInfofromLayerId($this->wmsJSON->wms->srv[$j]->layer[0]->id);
-				$this->wmsJSON->wms->srv[$j]->layer[0]->getLegendGraphicUrl = $legendInfo['getLegendGraphicUrl'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->getLegendGraphicUrlFormat = $legendInfo['getLegendGraphicUrlFormat'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->legendUrl = $legendInfo['legendUrl'];
-				//get capabilities
-				$this->wmsJSON->wms->srv[$j]->layer[0]->getCapabilitiesUrl =  "http://".$this->hostName."/mapbender/php/wms.php?layer_id=".(integer)$subLayers[$rootIndex]['layer_id']."&INSPIRE=1&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
-				$this->wmsJSON->wms->srv[$j]->layer[0]->minScale = $legendInfo['minScale'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->maxScale = $legendInfo['maxScale'];
-				//pull downloadOptions as json with function from other script: php/mod_getDownloadOptions.php
-				$downloadOptionsCs = str_replace("{","",str_replace("}","",str_replace("}{",",",$legendInfo['downloadOptions'])));
-				$downloadOptions = json_decode(getDownloadOptions(explode(',',$downloadOptionsCs)));
-				$this->wmsJSON->wms->srv[$j]->layer[0]->downloadOptions = $downloadOptions;
-				if ($subLayers[$rootIndex]['layer_name'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 1;
-				if ($subLayers[$rootIndex]['layer_pos'] == '0'){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = true;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = false;
-				if ($subLayers[$rootIndex]['md_inspire_cats'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 1;
-				//get info about queryable or not
-				if ($subLayers[$rootIndex]['layer_queryable'] == 1){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 1;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 0;
-				#if ($subLayers[$rootIndex]['layer_name'] == ''){
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 0;
-				#else {
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 1;
-				$this->wmsJSON->wms->srv[$j]->layer[0]->loadCount = $subLayers[$rootIndex]['load_count'];
-				#$servObject->layer[$countsublayer]->mdLink = $_SERVER['HOST']."/mapbender/geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
-				#$servObject->layer[$countsublayer]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->bbox = $subLayers[$rootIndex]['bbox'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->permission = $this->getPermissionValueForLayer($subLayers[$rootIndex]['layer_id'], $subLayers[$rootIndex]['wms_id']); //TODO: Make this much more faster
-				//when the entry for the first server has been written, the server entry is fixed and the next one will be a new server or a part of the old one.
-				 //increment server (highest object id)
-				$layerIdArray = $this->writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, $this->wmsJSON->wms->srv[$j]->layer[0]);
-				$j++;
-				//generate php object - if root layer was found - > layer_parent='' give hint to visualize folder symbol.
-	private function generateWMSMetadata($xmlDoc) {
-		global $admin;
-		$starttime = $this->microtime_float();
-		list($sql, $v, $t, $n) = $this->generateSearchSQL();
-		//call database search in limits
-		$res = db_prep_query($sql, $v, $t);
-			//generate json
-			$this->generateWMSMetadataJSON($res,$n);
-			$usedTime = $this->microtime_float() - $starttime;
-			//put in the time to generate the data
-			$this->wmsJSON->wms->md->genTime = $usedTime;
-			$this->wmsJSON = $this->json->encode($this->wmsJSON);
-			if ($this->resultTarget == 'file') {
-				//$e = new mb_exception("write wms to file: ".$wmsJSONString);
-				$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json";
-				$admin->putToStorage($filename, $this->wmsJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
-				/*if($wmsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wmsFileHandle,$this->wmsJSON);
-					fclose($wmsFileHandle);
-			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
-				echo $this->wmsJSON;
-			if ($this->resultTarget == 'internal') {
-				$this->internalResult = $this->wmsJSON;
-			if ($this->resultTarget == 'categories') {
-				echo $this->catJSON;
-			if ($this->resultTarget == 'webclient') {
-				$this->allJSON = new stdClass;
-				$this->allJSON->categories = $this->json->decode($this->catJSON);
-				$this->allJSON->keywords =  $this->json->decode($this->keyJSON);
-				//load filter from file getFromStorage
-				$filename = $this->tempFolder."/".$this->searchId."_filter.json";
-				$fileExists = $admin->getFromStorage($filename,TMP_SEARCH_RESULT_STORAGE);
-				if ($fileExists == false) {
-					$e = new mb_exception("class_metadata_new.php: No filter json exists!");
-				} else {
-					$filterJSON = $fileExists;
-					$filterJSON = $this->json->decode($filterJSON);
-					$this->allJSON->filter = $filterJSON;
-				$this->allJSON->wms = $this->json->decode($this->wmsJSON);
-				//$e = new mb_exception("originFromHeader: ".$this->originFromHeader);
-				if ($this->originFromHeader != false) {
-					header('Access-Control-Allow-Origin: '.$this->originFromHeader);
-				//if (defined("CORS_WHITELIST") && CORS_WHITELIST != "") {
-				//	header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
-				echo  $this->json->encode($this->allJSON);
-				//echo "test";
-		$usedTime2 = $this->microtime_float() - $starttime;
-		//echo "<br>used time: ".$usedTime."<br>";
-		$e = new mb_notice("Time to generate WMS-Metadata: ".$usedTime2);
-		$e = new mb_notice("Wrote the MD_WMS-File");
-	private function generateWFSMetadata($xmlDoc) {
-			//generate json
-			$this->generateWFSMetadataJSON($res, $n);
-			$this->wfsJSON->wfs->md->genTime = $usedTime;
-			$this->wfsJSON = $this->json->encode($this->wfsJSON);
-				$admin->putToStorage($filename, $this->wfsJSON, TMP_SEARCH_RESULT_STORAGE, TMP_WMC_MAX_AGE);
-				/*if($wfsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wfsFileHandle,$this->wfsJSON);
-					fclose($wfsFileHandle);
-			if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
-				echo $this->wfsJSON;
-				$this->internalResult = $this->wfsJSON;
-					//$e = new mb_exception("class_metadata_new.php: No filter json exists!");
-				} else {
-				$this->allJSON->wfs = $this->json->decode($this->wfsJSON);
-				//echo "test";
-		$e = new mb_notice("Time to generate WFS-Metadata: ".$usedTime);
-		$e = new mb_notice("Wrote the MD_WFS-File");
-	private function generateWMCMetadata($xmlDoc) {
-			//generate json
-			$this->generateWMCMetadataJSON($res,$n);
-			$this->wmcJSON->wmc->md->genTime = $usedTime;
-			$this->wmcJSON = $this->json->encode($this->wmcJSON);
-				$admin->putToStorage($filename, $this->wmcJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
-				/*if($wmcFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wmcFileHandle,$this->wmcJSON);
-					fclose($wmcFileHandle);
-				echo $this->wmcJSON;
-				} else {
-				$this->allJSON->wmc = $this->json->decode($this->wmcJSON);
-				//echo "test";
-		$e = new mb_notice("Time to generate WMC-Metadata: ".$usedTime2);
-		$e = new mb_notice("Wrote the MD_WMC-File");
-	private function generateDatasetMetadata($xmlDoc) {
-			//generate json
-			$this->generateDatasetMetadataJSON($res,$n);
-			$this->datasetJSON->dataset->md->genTime = $usedTime;
-			$this->datasetJSON = $this->json->encode($this->datasetJSON);
-				$admin->putToStorage($filename, $this->datasetJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
-				/*if($datasetFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($datasetFileHandle,$this->datasetJSON);
-					fclose($datasetFileHandle);
-				echo $this->datasetJSON;
-				} else {
-				$this->allJSON->dataset = $this->json->decode($this->datasetJSON);
-				//echo "test";
-		$e = new mb_notice("Time to generate Dataset-Metadata: ".$usedTime2);
-		$e = new mb_notice("Wrote the MD_Dataset-File");
-	private function replaceChars_all($text){
-		$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
-		$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
-		$replaced = str_replace($search, $repWith, $text);
-		return $replaced;
-	private function generateSearchSQL() {
-		//elements needed to exist in mb wfs,wms,wmc view or table:
-		//1. textfield - all texts - searchText
-		//2. responsible organisations - given id
-		//3. bbox - is not explicit given in the wfs metadata? Since WFS 1.1.0 a latlonbbox is present
-		//4. isoTopicCategory - is not been saved til now
-		//5. ...
-		//parse searchText into different array elements to allow an AND search
-		$searchStringArray = $this->generateSearchStringArray();
-		$v = array();
-		$t = array();
-		$sql = "SELECT * from ".$this->searchView." ";
-		$whereStr = "";
-		$whereCondArray = array();
-		$isTextSearch = "false";
-		$e = new mb_notice("Number of used searchstrings: ".count($searchStringArray));
-		//textsearch
-		if ($this->searchText != NULL && trim($this->searchText) != '*') {
-			for($i=0; $i < count($searchStringArray); $i++){
-				$isTextSearch = "true";
-				if($i>0) {
-					$whereStr .= " AND ";
-				$whereStr .= "searchtext LIKE $".($i+1);
-				//output for debugging
-				$e = new mb_notice("Part of string".$i.": ".$searchStringArray[$i]);
-				$e = new mb_notice("converted: ".$this->replaceChars_all($searchStringArray[$i]));
-				$va = "%".trim(strtoupper($this->replaceChars_all($searchStringArray[$i])))."%";
-				$e = new mb_notice($this->searchResources." Searchtext in SQL: ".$va);
-				array_push($v,$va);
-				array_push($t,"s");
-		// This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
-		//check for postgis version
-		//sql for get version string
-		//get version number
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc" or strtolower($this->searchResources) === "dataset" or strtolower($this->searchResources) === "wfs" ) & $this->searchBbox != NULL) {
-			//decide which type of search should be done
-			//check for postgis version cause postgis versions < 1.4 have problems when doing disjoint and inside
-			$sqlPostgisVersion = "SELECT postgis_version();";
-			$vPostgisVersion = array();
-			$tPostgisVersion = array();
-			$resPostgisVersion = db_prep_query($sqlPostgisVersion, $vPostgisVersion, $tPostgisVersion);
-			// get version string
-			while($row = db_fetch_array($resPostgisVersion)){
-				$postgisVersion = $row['postgis_version'];
-				$postgisVersionArray = explode(" ",$postgisVersion);
-				$postgisVersionSmall = explode(".",$postgisVersionArray[0]);
-				$postgisSubNumber = $postgisVersionSmall[1];
-				$e = new mb_notice("class_metadata.php: postgis sub number = ".$postgisSubNumber);
-			$e = new mb_notice("class_metadata.php: spatial operator: ".$this->searchTypeBbox);
-			if ((integer)$postgisSubNumber >= 3){
-				#$spatialFilter = "(the_geom ";
-				if ($this->searchTypeBbox == 'outside') {
-					$spatialFilter = ' disjoint(';
-				} elseif ($this->searchTypeBbox == 'inside') {
-					$spatialFilter = ' within(';
-				} else {
-					$spatialFilter = ' intersects(';
-				//define spatial filter
-				if(count(explode(',',$this->searchBbox)) == 4){   //if searchBbox has 4 entries
-					$spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
-					//definition of the spatial filter
-					$spatialFilter .= 'the_geom,GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
-					$spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
-					$spatialFilter .= $spatialFilterCoords[0];//minx
-					$spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
-					$spatialFilter .= $spatialFilterCoords[2];//maxx
-					$spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
-					$spatialFilter .= ")";
-					array_push($whereCondArray, $spatialFilter);
-			} else {
-				$spatialFilter = ' the_geom && ';
-					$spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
-					#$spatialFilter .= ",the_geom)";
-		//search filter for isopen - open data classification of the managed termsofuse
-		if ($this->restrictToOpenData) {
-			array_push($whereCondArray, '(isopen = 1)');
-		//search filter for md_topic_categories
-		if ($this->isoCategories != NULL) {
-			$isoArray = explode(',',$this->isoCategories);
-			$topicCond = "(";
-			for($i=0; $i < count($isoArray); $i++){
-				if ($i == 0) {
-					$topicCond .= "(md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-				} else {
-					$topicCond .= "AND (md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-			$topicCond .= ")";
-			array_push($whereCondArray, $topicCond);
-		//search filter for inspire_categories
-		if ($this->inspireThemes != NULL) {
-			$inspireArray = explode(',',$this->inspireThemes);
-			$inspireCond = "(";
-			for($i=0; $i < count($inspireArray); $i++){
-				if ($i == 0) {
-					$inspireCond .= "(md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
-				} else {
-					$inspireCond .= "AND (md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
-			$inspireCond .= ")";
-			array_push($whereCondArray, $inspireCond);
-		//search filter for custom_categories
-		if ($this->customCategories != NULL) {
-			$customArray = explode(',',$this->customCategories);
-			$customCond = "(";
-			for($i=0; $i < count($customArray); $i++){
-				if ($i == 0) {
-					$customCond .= "(md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
-				} else {
-					$customCond .= "AND (md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
-			$customCond .= ")";
-			array_push($whereCondArray, $customCond);
-		//date condition
-		//if begin and end are set
-		//echo "<br> regTimeBegin: ".$this-> regTimeBegin." regTimeEnd: ".$this-> regTimeEnd."<br>";
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) BETWEEN '".$this->regTimeBegin."' AND '".$this->regTimeEnd."')";
-			array_push($whereCondArray, $time);
-			//only begin is set
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd == NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) > '".$this->regTimeBegin."')";
-		if ($this->regTimeBegin == NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) < '".$this->regTimeEnd."')";
-		//filter for data actuality (only for datasets)
-		if (strtolower($this->searchResources) === "dataset") {
- 			if ($this->timeBegin != NULL && $this->timeEnd != NULL){
-				$time ="((to_timestamp('".$this->timeBegin."','YYYY-MM-DD'),to_timestamp('".$this->timeEnd."','YYYY-MM-DD')) OVERLAPS (timebegin,timeend))";
-			if ($this->timeBegin != NULL && $this->timeEnd == NULL){
-				$time ="(timeend >= '".$this->timeBegin."')";
-			if ($this->timeBegin == NULL && $this->timeEnd != NULL){
-				$time ="(timeend <= '".$this->timeEnd."')";
-		//department condition
-		//TODO: generate filter for new sql check if at least some department is requested
-		//generate array
-		//$this->registratingDepartments = explode(',',$this->registratingDepartments);
-		#if(count($this->registratingDepartments) > 0 & $this->registratingDepartments){
-		if($this->registratingDepartments != NULL){
-			$dep = " department IN (".$this->registratingDepartments.") ";
-			array_push($whereCondArray, $dep);
-		//resourceId conditions
-		if($this->resourceIds != NULL){
-			$resourceCondition = " ".$this->databaseIdColumnName." IN (".$this->resourceIds.") ";
-			array_push($whereCondArray, $resourceCondition);
-		// Creating the WHERE clause, based on a array
-		if(count($whereCondArray) > 0){
-			$txt_whereCond = "";
-			for ($index = 0; $index < sizeof($whereCondArray); $index++) {
-				$array_element = $whereCondArray[$index];
-				if($isTextSearch == "true") {
-					$txt_whereCond .= " AND ".$array_element;
-				} else {
-					if($index>0){
-					} else {
-						$txt_whereCond .= " ".$array_element;
-			$whereStr .= $txt_whereCond;
-		//Add WHERE condition to search
-		if ($whereStr !== '') {
-			$whereStr = "WHERE ".$whereStr;
-		$sql .= $whereStr;
-		//TODO ORDER BY in SQL - not necessary for counting things:
-		$sql .= $this->orderBy;
-		//Calculate Paging for OFFSET and LIMIT values:
-		$offset = ((integer)$this->maxResults) * ((integer)$this->searchPages -1);
-		$limit = (integer)$this->maxResults;
-		//defining range for paging
-		$sql .= " LIMIT ".$limit." OFFSET ".$offset."";
-		//Print out search SQL term
-		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata: ".$sql."");
-		//parameter: searchId -> can be used global, searchResources -> is only one type per instance!!-> global,which categories -> can be defined global! $whereStr
-		$n = $this->writeCategories($whereStr, $v, $t);
-		//write counts to filesystem to avoid to many database connections
-		//only write them, if searchId is given - problem: searches with same searchId's maybe get wrong information
-		return array($sql, $v, $t, $n);
-/** Function to write a json file which includes the categories of the search result for each searchResource - wms/wfs/wmc/georss, new: it should also count the keyword distribution of the searchResource ans save it as a special json file!
-	private function writeCategories($whereStr, $v, $t) {
-		//generate count sql
-		//generate count of all entries
-		$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." ";
-		if ($whereStr != '') {
-			$sqlN .= $whereStr;
-		//Get total number of results
-		$count = db_prep_query($sqlN, $v, $t);
-		$n = db_fetch_all($count);
-		#echo "<br>N: ".var_dump($n)."<br>";
-		$n = $n[0]['count'];
-		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata N: ".$sqlN." Number of found objects: ".$n);
-		if ($this->searchId != 'dummysearch') { //searchId is not the default id! - it has been explicitly defined
-			//check if cat file already exists:
-			//filename to search for:
-			$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_cat.json";
-			$keyFilename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_keywords.json";
-			//check filename exists in storage
-			if ($fileExists == false  or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
-				//open category file for results
-				$this->catJSON = new stdClass;
-				$this->catJSON->searchMD = (object) array(
-					'searchId' => $this->searchId,
-					'n' => $n
-				//new: also generate a json object for the keyword distribution
-				$this->keyJSON = new stdClass;
-				$this->keyJSON->tagCloud = (object) array(
-					'maxFontSize' => $this->maxFontSize,
-					'maxObjects' => $this->maxObjects,
-					'title' => $this->keywordTitle,
-					'tags' => array()
-				$this->inc = ($this->maxFontSize-$this->minFontSize)/$this->maxObjects;//maybe 10 or 5 or ...
-				//generate the list of category counts
-				$sqlCat = array();
-				//generate the sql for the keyword count
-				$sqlKeyword = "select keyword.keyword, COUNT(*) ";
-				$sqlKeyword .= "FROM (select ";
-				$sqlKeyword .= $this->databaseIdColumnName;
-				//$sqlKeyword .= " FROM ".$this->searchView." WHERE ".$whereStr.") as a";
-					$sqlKeyword .= " FROM ".$this->searchView." ".$whereStr.") as a";
-				} else {
-					$sqlKeyword .= " FROM ".$this->searchView.") as a";
-				$sqlKeyword .= " INNER JOIN ".$this->databaseTableName."_keyword ON (";
-				$sqlKeyword .= $this->databaseTableName."_keyword.fkey_".$this->databaseIdColumnName." = a.";
-				$sqlKeyword .= $this->databaseIdColumnName.") ";
-				$sqlKeyword .= "INNER JOIN keyword ON (keyword.keyword_id=".$this->databaseTableName."_keyword.fkey_keyword_id) WHERE (keyword.keyword NOTNULL AND keyword.keyword <> '') ";
-				$sqlKeyword .= "GROUP BY keyword.keyword  ORDER BY COUNT DESC LIMIT  ".$this->maxObjects;
-				//do sql select for keyword cloud
-				$resKeyword = db_prep_query($sqlKeyword, $v, $t);
-				$keywordCounts = db_fetch_all($resKeyword);
-				if (count($keywordCounts) > 0) {
-					$this->maxWeight = $keywordCounts[0]['count'];
-					for ($j = 0; $j < count($keywordCounts); $j++) {
-						if ($this->scale == 'linear'){
-							//order in a linear scale desc
-							$keywordCounts[$j]['count'] = $this->maxFontSize-($j*$this->inc);
-						} else {
-							//set weight prop to count
-							 $keywordCounts[$j]['count'] = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
-	/*if ($scale == 'linear'){
-		$tags[$i]['weight'] = $maxFontSize-($i*$inc);
-	} else {
-		$tags[$i]['weight'] = $tags[$i]['weight']*$maxFontSize/$maxWeight;
-					shuffle($keywordCounts);
-						$this->keyJSON->tagCloud->tags[$j]->title = $keywordCounts[$j]['keyword'];
-						$this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count'];
-						$paramValue = $this->getValueForParam('searchText', $this->searchURL);
-						//delete resources part from query and set some new one
-						$searchUrlKeywords = $this->delTotalFromQuery('searchResources',$this->searchURL);
-						//append the resource parameter:
-						$searchUrlKeywords .= '&searchResources='.$this->searchResources;
-						$e = new mb_notice("class_metadata_new: value ".$paramValue." for searchText param found");
-						$paramValue = urldecode($paramValue);
-						if ($paramValue == false || $paramValue == '*') {
-							$this->keyJSON->tagCloud->tags[$j]->url = $searchUrlKeywords."&searchText=".$keywordCounts[$j]['keyword'];
-						} else {
-							$this->keyJSON->tagCloud->tags[$j]->url = $this->addToQuery('searchText',$searchUrlKeywords,$keywordCounts[$j]['keyword'],$paramValue);
-				//encode json!
-				$this->keyJSON = $this->json->encode($this->keyJSON);
-				//write clouds to file
-				$admin->putToStorage($keyFilename, $this->keyJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
-				/*if($keyFileHandle = fopen($keyFilename, "w")){
-					fwrite($keyFileHandle,$this->keyJSON);
-					fclose($keyFileHandle);
-					$e = new mb_notice("class_metadata: new ".$this->searchResources."_keyword_file created!");
-				} else {
-					$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_keyword_file!");
-				if ($this->resultTarget == 'debug') {
-					echo "<br>DEBUG: show keywords: <br>".$this->keyJSON."<br><br>";
-/** "$resourceId." from ".$wms_view." where ".$whereClause.") as a";
-				$sqlKeyword .= "(select keyword, count(*) from keyword INNER JOIN  layer_keyword  ON (layer_keyword.fkey_keyword_id = keyword.keyword_id) GROUP BY keyword.keyword) ";
-				$sqlKeyword .= " GROUP BY keyword.keyword)) as a WHERE a.keyword <> '' GROUP BY a.keyword ORDER BY sum DESC LIMIT $1";
-				//check if categories are defined for the resource
-				if ($this->resourceClasses != NULL) {
-					$this->catJSON->searchMD->category = array();
-					for ($i = 0; $i < count($this->resourceClasses); $i++) {
-						//TODO: not to set the classification?
-						$this->catJSON->searchMD->category[$i]->title = $this->resourceClassifications[$i]['title'];
-						$sqlCat[$i] = "SELECT ".$this->resourceClassifications[$i]['tablename'];
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['tablename']."_id, ";
-						$sqlCat[$i] .= " ".$this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_";
-						$sqlCat[$i] .= $this->languageCode.", COUNT(*) FROM ".$this->searchView;
-						//first join for connection table
-						$sqlCat[$i] .= " INNER JOIN ".$this->resourceClassifications[$i]['relation_'.$this->searchResources];
-						$sqlCat[$i] .= " ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['relation_'.$this->searchResources].".fkey_";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['id_'.$this->searchResources]."=".$this->searchView;
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['id_'.$this->searchResources];
-						$sqlCat[$i] .= ") INNER JOIN ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']." ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id=";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id)";
-						//the following is needed to filter the custom cats for those which should not be seen in the classification
-						if ($this->resourceClassifications[$i]['title'] != $this->resourceClassifications[2]['title']){
-								$sqlCat[$i] .= " ".$whereStr." GROUP BY ";
-							} else {
-								$sqlCat[$i] .= " GROUP BY ";
-						} else {
-								$sqlCat[$i] .= " ".$whereStr.$this->whereStrCatExtension." GROUP BY ";
-							} else {
-								$sqlCat[$i] .= " WHERE ".$this->whereStrCatExtension." GROUP BY ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id,";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode." ORDER BY ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id";
-						$sqlCategory = $sqlCat[$i];
-						//call sql for count of category
-						$res = db_prep_query($sqlCategory, $v, $t);
-						$e = new mb_notice("class_metadata: countCatsql: ".$sqlCategory);
-						$categoryCounts = db_fetch_all($res);
-						//if none found: $categoryCounts=false
-						#echo "<br>count sub categories :".$categoryCounts."<br>";
-						if ($categoryCounts) {
-							//write results in json object
-							if (count($categoryCounts) > 0) {
-								#echo "<br>count main categories".count($categoryCounts)."<br>";
-								#echo "<br>vardump main categories".var_dump($categoryCounts)."<br>";
-								$this->catJSON->searchMD->category[$i]->subcat = array();
-								for ($j = 0; $j < count($categoryCounts); $j++) {
-									$this->catJSON->searchMD->category[$i]->subcat[$j]->id = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-									$this->catJSON->searchMD->category[$i]->subcat[$j]->title = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode];
-									$this->catJSON->searchMD->category[$i]->subcat[$j]->count = $categoryCounts[$j]['count'];
-									//delete requestParam for this category and for id - cause a new search is started from searchURL
-									$filteredSearchString = $this->delTotalFromQuery('searchId',$this->searchURL);
-									//uncomment the following line if a or category search is intended
-									//$filteredSearchString = $this->delTotalFromQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString);
-									//TODO: maybe adopt this to do a and search and not a or like it is done now
-									//check if category search was requested and rewrite the search url
-									//get the value of the param as string or false if not set!
-									$paramValue = $this->getValueForParam($this->resourceClassifications[$i]['requestName'], $filteredSearchString);
-									if ($paramValue == false) {
-										//add new category to search
-									//set filter for this categoryid
-									$filteredSearchString .= "&".$this->resourceClassifications[$i]['requestName']."=".$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-									} else {
-										//rewrite the searchUrl
-										$filteredSearchString = $this->addToQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString,$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"],$paramValue);
-									$this->catJSON->searchMD->category[$i]->subcat[$j]->filterLink = $filteredSearchString;
-						} else {
-							#$this->catJSON->searchMD->category[$i]->subcat = array();
-						$e = new mb_notice("class_metadata: countsql: ".$sqlCat[$i]);
-					//create a facet for publishing organizations
-					$i = 3;
-						case "de":
-							$this->catJSON->searchMD->category[$i]->title = "Organisationen";
-							break;
-						case "en":
-							$this->catJSON->searchMD->category[$i]->title = "Organizations";
-							break;
-						default:
-							break;
-					$sqlCat[$i] = "SELECT department AS id, COUNT(department) AS count, mb_group.mb_group_name AS title FROM ".$this->searchView." INNER JOIN mb_group ON department = mb_group.mb_group_id";
-					// GROUP BY department, mb_group.mb_group_name";
-					//$e = new mb_exception("test");
-							} else {
-						} else {
-							} else {
-					$sqlCat[$i] .= "department, mb_group.mb_group_name";
-					//TODO solve problem
-					$sqlCategory = str_replace("WHERE  AND", "WHERE", $sqlCategory);
-					//$e = new mb_exception("class_metadata: countOrgaSql: ".$sqlCategory);
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->id = $categoryCounts[$j]["id"];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->title = $categoryCounts[$j]["title"];
-									$filteredSearchString .= "&".$this->resourceClassifications[$i]['requestName']."=".$categoryCounts[$j]["id"];
-								} else {
-									$filteredSearchString = $this->addToQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString,$categoryCounts[$j]["id"],$paramValue);
-					} else {
-				$this->catJSON = $this->json->encode($this->catJSON);
-				//write categories files only when file is requested and the searchid was not used before!
-					//$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json";
-					$admin->putToStorage($filename, $this->catJSON, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
-					/*if($catFileHandle = fopen($filename, "w")){
-						fwrite($catFileHandle,$this->catJSON);
-						fclose($catFileHandle);
-						$e = new mb_notice("class_metadata: new ".$this->searchResources."_class_file created!");
-					} else {
-						$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_cat_file!");
-					echo "<br>DEBUG: show categories: <br>".$this->catJSON."<br><br>";
-			} else {
-				$e = new mb_notice("class_metadata: ".$this->searchResources."_class_file: ".$filename." already exists - no new one is generated!");
-		} else {
-				echo "<br>DEBUG: Standard ID dummysearch was invoked - classifications won't be counted!<br>";
-			$e = new mb_notice("class_metadata: standard dummysearch was invoked - classifications won't be counted!");
-		return $n;
-	private function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
-		//TODO: Set Email of owner into view for ressource - so it don't have to be searched?
-		$return_permission = "";
-		//get permission
-		$myWFSconfs = $admin->getWfsConfByPermission($this->userId);
-		$this->myWFSConfs = $myWFSconfs;
-		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
-			$array_element = $this->myWFSConfs[$index];
-		if (in_array($wfs_conf_id, $this->myWFSConfs)){
-			$return_permission = "true";
-		} else {
-			$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id "."and wfs.wfs_id=$1";
-			$v = array($wfs_id);
-			$t = array('i');
-			// get email
-			$mail = "";
-			while($row = db_fetch_array($res)){
-				$mail = $row['email'];
-				$return_permission = $mail;
-		return $return_permission;
-	private function getMapUrlfromWMSId($wmsId) {
-			$sql = "SELECT wms_getmap, wms_owsproxy FROM wms WHERE wms_id = $1";
-			$v = array($wmsId);
-			$t = array('i');
-				$getMap = $row['wms_getmap'];
-				$owsProxy = $row['wms_owsproxy'];
-			//hostname does not exist! - use hostname from parameter instead
-			if ($owsProxy != null && $owsProxy != '') {
-				//create dummy session - no one knows the user which requests this metadata!
-				$sessionId = "00000000000000000000000000000000";
-				$getMap = "http://".$this->hostName."/owsproxy/".$sessionId."/".$owsProxy."?";
-			return $getMap;
-	private function getInfofromLayerId($layerId) {
-			$sql = "SELECT layer_wms.*, layer_style.legendurl, layer_style.legendurlformat FROM (SELECT layer_id, f_get_download_options_for_layer(layer_id) as layer_metadata, layer_minscale, layer_maxscale, wms_getlegendurl, wms_owsproxy FROM layer INNER JOIN wms ON layer.fkey_wms_id = wms.wms_id WHERE layer.layer_id = $1) as layer_wms LEFT OUTER JOIN layer_style ON layer_style.fkey_layer_id = layer_wms.layer_id";
-			$v = array($layerId);
-			$t = array('i');
-				$getLegendUrl = $row['wms_getlegendurl'];
-				$legendUrl = $row['legendurl'];
-				$legendUrlFormat = $row['legendurlformat'];
-				$minScale = $row['layer_minscale'];
-				$maxScale = $row['layer_maxscale'];
-				$downloadOptions = $row['layer_metadata'];
-			if ($owsProxy != null && $owsProxy != '' && $getLegendUrl != '' && $getLegendUrl != null) {
-				$getLegendUrlNew = "http://".$this->hostName."/owsproxy/".$sessionId."/".$owsProxy."?";
-				//also let go legendurl thru owsproxy exchange first legendurl part with owsproxy part!
-				$legendUrl = str_replace($getLegendUrl,$getLegendUrlNew,$legendUrl);
-				$getLegendUrl = $getLegendUrlNew;
-			$returnArray['legendUrl'] = $legendUrl;
-			$returnArray['getLegendGraphicUrl'] = $getLegendUrl;
-			$returnArray['getLegendGraphicUrlFormat'] = $legendUrlFormat;
-			$returnArray['minScale'] = $minScale;
-			$returnArray['maxScale'] = $maxScale;
-			$returnArray['downloadOptions'] = $downloadOptions;
-			return $returnArray;
-	private function getInfofromFeaturetypeId($featuretypeId) {
-			$sql = "SELECT wfs_id, wfs_version, wfs_getcapabilities, wfs_describefeaturetype, featuretype_name, wfs_owsproxy FROM wfs_featuretype INNER JOIN wfs ON wfs_featuretype.fkey_wfs_id = wfs.wfs_id WHERE wfs_featuretype.featuretype_id = $1";
-			$v = array($featuretypeId);
-			$t = array('i');
-				$getCapabilitiesUrl = $row['wfs_getcapabilities'];
-				$describeFeaturetypeUrl = $row['wfs_describefeaturetype'];
-				$featuretypeName = $row['featuretype_name'];
-				$owsProxy = $row['wfs_owsproxy'];
-				$wfsVersion = $row['wfs_version'];
-				$wfsId = $row['wfs_id'];
-			//if proxy is activated change request urls
-				$getCapabilitiesUrl = "http://".$this->hostName."/registry/wfs/".$wfsId."?SERVICE=WFS&VERSION=".$wfsVersion."&REQUEST=GetCapabilities";
-				$describeFeaturetypeUrl = "http://".$this->hostName."/registry/wfs/".$wfsId."?SERVICE=WFS&VERSION=".$wfsVersion."&REQUEST=DescribeFeaturetype&typename=".$featuretypeName;
-			} else {
-				$getCapabilitiesUrl = $admin->checkURL($getCapabilitiesUrl)."SERVICE=WFS&VERSION=".$wfsVersion."&REQUEST=GetCapabilities";
-				$describeFeaturetypeUrl = $admin->checkURL($describeFeaturetypeUrl)."SERVICE=WFS&VERSION=".$wfsVersion."&REQUEST=DescribeFeaturetype&typename=".$featuretypeName;
-			$returnArray['getCapabilitiesUrl'] = $getCapabilitiesUrl;
-			$returnArray['describeFeaturetypeUrl'] = $describeFeaturetypeUrl;
-			$returnArray['featuretypeName'] = $featuretypeName;
-			$returnArray['owsProxy'] = $owsProxy;
-	private function getPermissionValueForLayer($layerId,$wmsId){
-		$return_permission="";
-		#$admin = new administration();
-		#$permission = $admin->getLayerPermission($wms_id, $layer_name, $this->userId);
-		#echo "<br>wms_id: ".$wms_id."<br>";
-		#echo "<br>layer_name: ".$layer_name."<br>";
-		#echo "<br>user_id: ".$this->userId."<br>";
-		#echo "<br>Permission: ".$permission."<br>";
-               # var_dump($this->accessableLayers);
-		if (in_array($layerId, $this->accessableLayers)){
-		} else {
-			$sql = "SELECT mb_user.mb_user_email as email FROM wms, mb_user WHERE wms.wms_owner=mb_user.mb_user_id";
-			$sql .= " AND wms.wms_id=$1";
-			$t = array('i');
-			// get email
-			$mail="";
-	private function generateSearchStringArray() {
-		//'wfs test array' -> ('wfs' 'test' 'array')
-		$asstr = array();
-		if ($this->searchText != "false"){
-			$asstr = explode(",",$this->searchText);
-			//delete left and right whitespaces
-			for ($i=0; $i<count($asstr);$i++) {
-				$asstr[$i]=ltrim($asstr[$i]);
-				$asstr[$i]=rtrim($asstr[$i]);
-		} else {
-			$asstr[0]='%';
-		//check for single wildcard search
-		$e = new mb_notice('class_metadata_new: searchText: '.$this->searchText);
-		if ((count($asstr) == 1) && (($asstr[0]=='*') || ($asstr[0]==='false'))) {
-			$asstr[0]='%';
-		$e = new mb_notice('class_metadata_new: asstr[0]: '.$asstr[0]);
-		return $asstr;
-	//out of php doc - test if it is faster than normal array_search
-	private function fast_in_array($elem, $array) {
-   		$top = sizeof($array) -1;
-   		$bot = 0;
-		while($top >= $bot) {
-			$p = floor(($top + $bot) / 2);
-			if ($array[$p] < $elem) $bot = $p + 1;
-			elseif ($array[$p] > $elem) $top = $p - 1;
-			else return TRUE;
-    	return FALSE;
-	* filtering an array
-	private function filter_by_value ($array, $index, $value){
-        	if(is_array($array) && count($array)>0) {
-            		foreach(array_keys($array) as $key){
-                		$temp[$key] = $array[$key][$index];
-                		if ($temp[$key] == $value){
-                    			$newarray[$key] = $array[$key];
-      	return $newarray;
-	//function to get the parent of the given layer by crawling the layertree upwards
-	private function getLayerParent ($layerArray, $index){
-		//only layers of one service should be in $layerArray
-		#$parentExists = false;
-		#var_dump($layerArray);
-		$layerIDKey = $layerArray['layer_id'][$index];
-		#echo ("layerIDKey= ".$layerIDKey."<br>");
-		$layerParentPos = $layerArray['layer_parent'][$index];//get first parent object position
-		#echo ("layerParentPos= ".$layerParentPos."<br>");
-		#echo("<br>number of sublayers ".count(flipDiagonally($layerArray))."<br>");
-		#echo("<br>size of layerArray['layer_pos']: ".count($layerArray['layer_pos'])."<br>");
-		#var_dump($layerArray['layer_pos']);
-		#echo "<br>flipped layerArray: <br> ";
-		#var_dump(flipDiagonally($layerArray));
-		#echo "<br>";
-		if ($layerParentPos == '') {
-			//root layer directly found
-			return $index;
-		//Initialize index of layer parent - first it references the layer itself
-		$layerParentIndex = $index;
-		//loop to search higher parent objects - maybe this can be faster if the loop is not used over all sublayer elements! Do a while loop instead!
-		$highestParentLayerNotFound = true;
-		while ($highestParentLayerNotFound) {
-			#echo("<br>i= ".$i."<br>");
-			#echo("<br>layerParentPosNew= ".$layerParentPos."<br>");
-			$layerParentIndexNew = array_search((string)$layerParentPos, $layerArray['layer_pos']);
-			#echo("<br>layerParentIndexNew= ".$layerParentIndexNew."<br>");
-			if ($layerParentIndexNew != false) {
-				//some parent has been found
-				$layerParentIndex = $layerParentIndexNew;
-				$layerParentPos = $layerArray['layer_parent'][$layerParentIndex];
-					$highestParentLayerNotFound = false;
-					return $layerParentIndex; //a real root layer was found!
-				#$layerParentIndex = array_search($layerParentPos, $layerArray['layer_pos']);
-			} else {
-				$highestParentLayerNotFound = false; //no higher layer could be found
-	//function to write the child elements to the resulting wms object -> object is given by reference
-	private function writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, &$servObject) {
-		#echo "test";
-		#echo "<br>subLayers:<br>";
-		#var_dump($subLayers);
-		#echo "<br>";
-		$childLayers = $this->filter_by_value($subLayers, 'layer_parent', $rootLayerPos); //the root layer position in the sublayer array was located before. In this step, all layers will be pulled out of sublayer, where root layer position is parent object
-		#echo "<br<childLayers:<br>";
-		#var_dump($childLayers);
-		#echo "<br>";
-		#echo "test";
-		#print_r($childLayers);
-		$countsublayer = 0;
-		//if child exists create a new layer array for these
-		if (count($childLayers) != 0) {
-			$servObject->layer = array();
-		foreach ($childLayers as $child){
-			#echo "<br>countsublayer: ".$countsublayer."<br>";
-			#echo "<br>Child id: ".$child['layer_id']."<br>";
-			#echo "<br>Child pos: ".$child['layer_pos']."<br>";
-			$servObject->layer[$countsublayer]->id = $child['layer_id'];
-			$servObject->layer[$countsublayer]->title = $child['layer_title'];
-			$servObject->layer[$countsublayer]->name = $child['layer_name'];
-			$servObject->layer[$countsublayer]->abstract = $child['layer_abstract'];
-			$servObject->layer[$countsublayer]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=layer&id=".$child['layer_id'];
-			$legendInfo = $this->getInfofromLayerId($servObject->layer[$countsublayer]->id);
-			$servObject->layer[$countsublayer]->getLegendGraphicUrl = $legendInfo['getLegendGraphicUrl'];
-			$servObject->layer[$countsublayer]->getLegendGraphicUrlFormat = $legendInfo['getLegendGraphicUrlFormat'];
-			$servObject->layer[$countsublayer]->legendUrl = $legendInfo['legendUrl'];
-			$servObject->layer[$countsublayer]->minScale = $legendInfo['minScale'];
-			$servObject->layer[$countsublayer]->maxScale = $legendInfo['maxScale'];
-			//$e = new mb_exception("class_metadata_new.php: legendInfo[downloadOptions]: ".$legendInfo['downloadOptions']);
-			//$e = new mb_exception("class_metadata_new.php: downloadOptions as string: ".json_encode($downloadOptions));
-			$servObject->layer[$countsublayer]->downloadOptions = $downloadOptions;
-			$servObject->layer[$countsublayer]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=layer&layout=tabs&id=".$child['layer_id'];
-			if ($child['layer_name'] == ''){
-				$servObject->layer[$countsublayer]->loadable = 0;
-			} else {
-				$servObject->layer[$countsublayer]->loadable = 1;
-			if ($child['md_inspire_cats'] == ''){
-				$servObject->layer[$countsublayer]->inspire = 0;
-			else {
-				$servObject->layer[$countsublayer]->inspire = 1;
-			if ($child['layer_queryable'] == 1){
-				$servObject->layer[$countsublayer]->queryable = 1;
-			else {
-				$servObject->layer[$countsublayer]->queryable = 0;
-			$servObject->layer[$countsublayer]->loadCount = $child['load_count'];
-			$servObject->layer[$countsublayer]->bbox = $child['bbox'];
-			$servObject->layer[$countsublayer]->permission = $this->getPermissionValueForLayer($child['layer_id'],$child['wms_id']); //TODO: make this much faster!!!! - is done by collecting all accessable resources once. Maybe this has to be adopted if the count of the resources become higher
-			//call this function itself - search sublayers in the layer object.
-			$layerIdArray = $this->writeWMSChilds($layerIdArray, $child['layer_pos'], $subLayers, $servObject->layer[$countsublayer]);//TODO create a timeout condition !
-			array_push($layerIdArray, $child['layer_id']); //child have been identified and recursively written
-			#var_dump($layerIdArray);#
-			#echo "<br>";
-			$countsublayer ++;
-		return $layerIdArray;
-	private function hasConstraints($type,$id) {
-		if ($type == "wms") {
-			$sql = "SELECT wms.accessconstraints, wms.fees, wms.wms_network_access , wms.wms_pricevolume, wms.wms_proxylog, termsofuse.name,";
-			$sql .= " termsofuse.termsofuse_id, termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from wms LEFT OUTER JOIN";
-			$sql .= "  wms_termsofuse ON  (wms.wms_id = wms_termsofuse.fkey_wms_id) LEFT OUTER JOIN termsofuse ON";
-			$sql .= " (wms_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where wms.wms_id = $1";
-		if ($type == "wfs") {
-			$sql = "SELECT accessconstraints, fees, wfs_network_access , termsofuse.name,";
-			$sql .= " termsofuse.termsofuse_id ,termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from wfs LEFT OUTER JOIN";
-			$sql .= "  wfs_termsofuse ON  (wfs.wfs_id = wfs_termsofuse.fkey_wfs_id) LEFT OUTER JOIN termsofuse ON";
-			$sql .= " (wfs_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where wfs.wfs_id = $1";
-		if ($type == "dataset") {
-			$sql = "SELECT constraints as accessconstraints, fees, termsofuse.name,";
-			$sql .= " termsofuse.termsofuse_id ,termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from mb_metadata LEFT OUTER JOIN";
-			$sql .= "  md_termsofuse ON  (mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id) LEFT OUTER JOIN termsofuse ON";
-			$sql .= " (md_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where mb_metadata.metadata_id = $1";
-		$v = array();
-		$t = array();
-		array_push($t, "i");
-		array_push($v, $id);
-		$res = db_prep_query($sql,$v,$t);
-		$row = db_fetch_array($res);
-		if ((isset($row[$type.'_proxylog']) & $row[$type.'_proxylog'] != 0) or strtoupper($row['accessconstraints']) != "NONE" or strtoupper($row['fees']) != "NONE" or isset($row['termsofuse_id']) ) {
-		//service has some constraints defined!
-		//give symbol and true
-		//termsofuse symbol or exclamation mark
-			if (isset($row['termsofuse_id']) & $row['symbollink'] != "") {
- 				$symbolLink = $row['symbollink'];
-			} else {
-				$symbolLink = "http://".$this->hostName."/portal/fileadmin/design/icn_warn.png";
-			$hasConstraints = true;
-			#$disclaimerLink = $_SERVER['HTTP_HOST']."/mapbender/php/mod_getServiceDisclaimer.php?type=".$type."&id=".$id;
-			#$symbolMouseOver = "Nutzungsbedingungen"; //TODO internationalize it
-		} else {
-		//give symbol and false
-		//green symbol
-			$symbolLink = "http://".$this->hostName."/portal/fileadmin/design/icn_ok.png";
-       			#$disclaimerLink = "";
-			$hasConstraints = false;
-			#$symbolMouseOver = "Frei zugänglich"; //TODO internationalize it
-		//generate json output:
-		#$json = new Mapbender_JSON;
-		#$returnJSON = new stdClass;
-		#$returnJSON->serviceConstraints = (object) array(
-				#'hasConstraints' => $hasConstraints,
-				#'disclaimerLink' => $disclaimerLink,
-				#'symbolLink' => $symbolLink,
-				#'symbolMouseOver' => $symbolMouseOver
-		#$returnJSON = $json->encode($returnJSON);
-		#echo $returnJSON;
-		return array($hasConstraints, $symbolLink);
-	//function to delete one of the comma separated values from a HTTP-GET request
-	private function delFromQuery($paramName,$queryString,$string,$queryArray,$queryList) {
-		//check if if count searchArray = 1
-		if (count($queryArray) == 1){
-			//remove request parameter from url by regexpr or replace
-			$str2search = $paramName."=".$queryList;
-			if ($paramName == "searchText") {
-				$str2exchange = "searchText=*&";
-			} else {
-				$str2exchange = "";
-			$queryStringNew = str_replace($str2search, $str2exchange, $queryString);
-			$queryStringNew = str_replace("&&", "&", $queryStringNew);
-		} else {
-		//there are more than one filter - reduce the filter
-			$objectList = "";
-			for($i=0; $i < count($queryArray); $i++){
-				if ($queryArray[$i] != $string){
-					$objectList .= $queryArray[$i].",";
-			//remove last comma
-			$objectList = rtrim($objectList, ",");
-			$str2exchange = $paramName."=".$objectList;
-	return $queryStringNew;
-	private function getValueForParam($paramName,$queryString) {
-		#another approach:
-		parse_str($queryString, $allQueries);
-		if (isset($allQueries[$paramName]) & $allQueries[$paramName] != '') {
-			return $allQueries[$paramName];
-		} else {
-			return false;
-#		old version
-/*		#TODO: check if last and first ampersand was set before
-		$queryString = "&".$queryString."&";
-		#$pattern = '/\b'.$paramName.'=([a-z0-9-]+)\&?/';
-		$pattern = '/\b&'.$paramName.'\=[^&]+&?/';
-		#$pattern = '/^&'.$paramName.'=[a-zA-ZöäüÖÄÜß,]*&$/';
-		$e = new mb_notice("class_metadata_new.php: look for pattern: ".$pattern."  in ".$queryString);
- 		if (!preg_match($pattern, $queryString, $matches)){
-			return false;
-		} else {
-			//some param found
-			//delete $paramName= and the last ampersand!
-			if (count($matches) == 1) {
-				$requestString = $matches[0];
-				$requestString = ltrim($requestString,"&".$paramName."=");
-				$requestString = rtrim($requestString,'&');
-				return $requestString;
-			} else {
-				$e = new mb_notice("class_metadata_new.php: There are parameter ambiguities!");
-				#echo "Parameter Ambiguities found!";
-				die();
-// function to add a new variable or complete parameter to a GET parameter query url
-	private function addToQuery($paramName,$queryString,$string,$queryList) {
-		//test if string was part of query before, if so, don't extent the query
-		//TODO: the strings come from json and so they are urlencoded! maybe we have to decode them to find the commata
-		$queryListComma = urldecode($queryList);
-		$queryListC = ",".$queryListComma.",";
-		$pattern = ','.$string.',';
- 		if (!preg_match($pattern, $queryListC)){
-			//append the new element
-			$queryListNew = $queryListC.$string;
-			//echo "query string new: ".$queryListNew."<br>";
-			//delete the commatas
-			$queryListNew = ltrim($queryListNew,',');
-			//generate the new query string
-			$queryStringNew = str_replace($paramName.'='.$queryList,$paramName.'='.$queryListNew,$queryString);
-			//dump old and new querystring for debugging
-			//$this->logit("class_metadata_new: queryString_old:".$queryString);
-			//$this->logit("class_metadata_new: queryString_new:".$queryStringNew);
-		} else {
-			//$this->logit("class_metadata_new: queryString unchanged:".$queryString);
-			//return the old one!
-			return $queryString;
-//for debugging purposes only
-	private function logit($text){
-	 	if($h = fopen("/tmp/class_metadata_new.log","a")){
-					$content = $text .chr(13).chr(10);
-					if(!fwrite($h,$content)){
-						#exit;
-					fclose($h);
-// function to delete one GET parameter totally from a query url
-	private function delTotalFromQuery($paramName,$queryString) {
-		$queryString = "&".$queryString;
-		//only delete totally if not searchText itself
-			} else {
-		#echo "<br>queryString: ".$queryString."<br>";
-		$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',$str2exchange,$queryString);
-		$queryStringNew = ltrim($queryStringNew,'&');
-		$queryStringNew = rtrim($queryStringNew,'&');
More information about the Mapbender_commits mailing list
