[Mapbender-commits] r9942 - in trunk/mapbender/resources/db: . pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Aug 9 08:25:29 PDT 2018
Author: armin11
Date: 2018-08-09 08:25:29 -0700 (Thu, 09 Aug 2018)
New Revision: 9942
Added:
trunk/mapbender/resources/db/gui_Owsproxy_csv.sql
Removed:
trunk/mapbender/resources/db/Search_extended_DE.sql
trunk/mapbender/resources/db/admin_wfs_metadata.sql
trunk/mapbender/resources/db/admin_wms_metadata.sql
trunk/mapbender/resources/db/extendedSearchGui.sql
trunk/mapbender/resources/db/geoportal_gui.sql
trunk/mapbender/resources/db/metadataGui.sql
trunk/mapbender/resources/db/metadataGuiWfs.sql
trunk/mapbender/resources/db/metadataGuiWmc.sql
trunk/mapbender/resources/db/new_role_concept.sql
trunk/mapbender/resources/db/gui_Administration_DE.sql
trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql
trunk/mapbender/resources/db/gui_admin_metadata.sql
trunk/mapbender/resources/db/gui_admin_ows_scheduler.sql
trunk/mapbender/resources/db/gui_admin_wfs_metadata.sql
trunk/mapbender/resources/db/gui_admin_wmc_metadata.sql
trunk/mapbender/resources/db/gui_admin_wms_metadata.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
new versions of admin interfaces
Deleted: trunk/mapbender/resources/db/Search_extended_DE.sql
--- trunk/mapbender/resources/db/Search_extended_DE.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/Search_extended_DE.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,329 +0,0 @@
--- SQL laden
--- WMS in Gui laden z. B. Germany
--- grau aus gui: ../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css
--- blau aus gui digi: ../extensions/jquery-ui-1.7.2.custom/css/ui-customized_4_digitize/jquery-ui-1.7.3.custom.css
--- buttons ersetzen img breite
--- mapframe1 breiter und etwas schmaler
--- double click zoom, mousewheel zoom
--- Probleme GeoRSS Newsfeeds lässt sich nicht wählen (disabled im Geoportal RLP)
--- bei Suche: Aufruf /portal/nc/servicebereich/erweiterte-suche.html
----- * hier muss das Suchskrip von Jens angesteuert werden
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Search_extended_DE',
-'Search_extended_DE','Erweiterte Suche',1);
-insert into gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('Search_extended_DE',1,'owner');
-INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES('Search_extended_DE',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapframe1',1,1,'Frame for a map','','div','','',10,180,276,182,20,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.widget.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomOut1',1,1,'zoomOut button','','img','../img/button_blue_red/zoomOut2_off.png','',300,200,28,28,20,'','','','mod_zoomOut1.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomIn1',1,1,'zoomIn button','','img','../img/button_blue_red/zoomIn2_off.png','',300,171,28,28,20,'','','','mod_zoomIn1.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','zoomFull',1,1,'zoom to full extent button','','img','../img/button_blue_red/zoomFull_off.png','',300,258,28,28,20,'','','img','mod_zoomFull.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','selArea1',1,1,'zoombox','','img','../img/button_blue_red/selArea_off.png','',300,229,28,28,20,'','','','mod_selArea.js','mod_box1.js','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','css_class_bg','body{ background-color: #ffffff; }','to define the color of the body','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','css_file_body','../css/mapbender.css','file/css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','favicon','../img/favicon.ico','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/ui-customized_4_digitize/jquery-ui-1.7.3.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','popupcss','../css/popup.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','tablesortercss','../css/tablesorter.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','body','use_load_message','false','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','pan1',1,1,'pan','','img','../img/button_blue_red/pan_off.png','',300,287,28,28,20,'','','','mod_pan.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_helpDialog',1,1,'Mapbender wrapper for helptexts in jq dialogs','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','mb_helpDialog.js','','jq_ui, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','forward',1,1,'History.forward()','','img','../img/button_blue_red/forward_off_disabled.png','',300,316,28,28,20,'','','','mod_forward.php','','mapframe1,overview0','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_metadata',1,1,'jQuery Metadata plugin - selects elements by tag names out of html?','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui',1,1,'jQuery UI core','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','jq_ui','css','../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','dependentDiv',2,0,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,NULL ,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','back',2,1,'History.back()','','img','../img/button_blue_red/back_off_disabled.png','',300,345,28,28,20,'','','','mod_back.php','','mapframe1,overview0','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','doubleclickZoom',2,1,'adds doubleclick zoom to map module (target).
-Deactivates the browser contextmenu!!!','Doubleclick zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_doubleclickZoom.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.position.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','loadData',2,0,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,NULL ,'visibility:visible','','iframe','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top
) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapcheck',2,1,'alert if a map-image fails to load','','div','','',0,0,NULL ,NULL,NULL ,'','','div','','mod_mapcheck.php','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_div_collection1',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','mapframe1, zoomIn1,zoomFull,zoomOut1,selArea1,pan1,forward,back,navFrame','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','navFrame',2,1,'navigation mapborder','','div','','',0,0,NULL ,NULL,20,'font-size:1px','','div','mod_navFrame.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','renderGML',2,0,'renders a gml contained in $_SESSION[''GML'']','','div','','',NULL ,NULL,NULL ,NULL,1,'','','div','../javascripts/mod_renderGML.php','mod_highlight.php','overview,mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','spatialBackground',2,0,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,160,704,200,1,'color: #008000;background-color:#e3e3e3;position:absolute','','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','spatialFilter',2,1,'Div which shows the spatial filter options for the metadata search','','div','','class=''spatialFilter''',NULL ,NULL,NULL ,NULL,20,'',' <fieldset>
- <img class="help-dialog" id="helpSpatialFilter" title="Help" help="{text:''Help SpatialFilter''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''checkbox'' name=''searchBbox'' id=''searchBbox''>
- <label id="labelSpatialFilter" name="labelSpatialFilter">Activate Spatial Filter</label>
- <legend id="labelSpatialFilterType" name="labelSpatialFilterType">how?</legend>
- <input type=''radio'' name=''searchTypeBbox'' value=''intersects'' id=''searchTypeBbox''>
- <label id="labelIntersects" name="labelIntersects" for="bbox">intersects</label>
- <input type=''radio'' name=''searchTypeBbox'' value=''outside'' id=''searchTypeBbox''>
- <label id="labelOutside" name="labelOutside">outside</label>
- <input type=''radio'' name=''searchTypeBbox'' value=''inside'' id=''searchTypeBbox''>
- <label id="labelInside" name="labelInside">fully inside</label>
- </p>
- </fieldset>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','wholeBackground',2,1,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,0,750,600,NULL ,'color: #008000;background-color:#ffffff;position:absolute','','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','provider',3,1,'Div which shows a list of providers for the metadata search','Anbieter','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
-<legend id="legendDepartment" name="legendDepartment">Provider</legend>
-<img class="help-dialog" id="helpProvider" title="Help" help="{text:''Help Provider''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''registratingDepartments'' id=''registratingDepartments'' multiple ></select>
- <br><a id="deleteSelection1" name="deleteSelection" href="#" c onclick=''removeListSelections("registratingDepartments");''>Drop current selection</a>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','button',3,1,'Div for the button to submit extended search module','','div','','class=''button''',500,25,60,40,20,'','<button id="search" name="search" type="button" value="Start Search" onclick="validate();">Start Search</button>
-','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','classifications',3,1,'Put category divs into one div collection','Themen','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
- <legend id="classificationsLegend" name="classificationsLegend">Classifications</legend>
- <div class="inspire">
- <fieldset>
- <legend id="legendInspireThemes" name="legendInspireThemes">Inspire Themes</legend>
- <img class="help-dialog" id="helpInspireThemes" title="Help" help="{text:''Help Inspire Categories''}" src="../img/questionmark.png" align="right"></img>
-<img id="imageInspireThemes" title="Inspire" src="../img/inspire_tr_36.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''inspireThemes'' id=''inspireThemes'' multiple ></select>
- <br><a id="deleteSelection2" name="deleteSelection" href="#" onclick=''removeListSelections("inspireThemes");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
- <div class="iso">
- <fieldset>
- <legend id="legendIsoCategories" name="legendIsoCategories">ISO19115 Themes</legend>
- <img class="help-dialog" id="helpIsoCategories" title="Help" help="{text:''Help ISO Categories''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''isoCategories'' id=''isoCategories'' width="200px" multiple></select>
- <br><a id="deleteSelection3" name="deleteSelection" href="#" onclick=''removeListSelections("isoCategories");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
- <div class="custom">
- <fieldset>
- <legend id="legendCustomCategories" name="legendCustomCategories">Other Themes</legend>
- <img class="help-dialog" id="helpCustomCategories" title="Help" help="{text:''Help Custom Categories''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''customCategories'' id=''customCategories'' multiple></select>
- <br><a id="deleteSelection4" name="deleteSelection" href="#" onclick=''removeListSelections("customCategories");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','form2',3,1,'Form for the extended mapbender metadata search - this form submits the values as hidden to the search script','','form','','method=''get'' name=''form2'' action=''/portal/nc/servicebereich/erweiterte-suche.html'' target=''_top''',0,250,NULL ,NULL,NULL ,'',' <input type="hidden" value='''' name=''searchText''>
- <input type="hidden" value='''' name=''registratingDepartments''>
- <input type="hidden" value='''' name=''isoCategories''>
- <input type="hidden" value='''' name=''inspireThemes''>
- <input type="hidden" value='''' name=''customCategories''>
- <input type="hidden" value='''' name=''regTimeBegin''>
- <input type="hidden" value='''' name=''regTimeEnd''>
- <input type="hidden" value='''' name=''timeBegin''>
- <input type="hidden" value='''' name=''timeEnd''>
- <input type="hidden" value='''' name=''searchBbox''>
- <input type="hidden" value='''' name=''searchTypeBbox''>
- <input type="hidden" value='''' name=''searchResources''>
- <input type="hidden" value='''' name=''orderBy''> ','form','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','actuality',3,1,'Div which shows the date field for temporal filters for metadata search','Wann?','div','','class=''actuality''',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
-<legend id="legendActuality" name="legendActuality">Actuality</legend>
- <fieldset>
- <legend id="legendDateOfPublication" name="legendDateOfPublication">Date of Publication</legend>
- <img class="help-dialog" id="helpDateOfPublication" title="Help" help="{text:''Help DateOfPublication''}" src="../img/questionmark.png" align="right"></img>
- <table>
- <p>
- <tr>
- <td><label id="labelDateOfPublicationStart" name="labelDateOfPublicationStart" for="regTimeBegin">Date from</label></td>
- <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeBegin'' id=''regTimeBegin'' > </td>
- </tr>
- <tr>
- <td><label id="labelDateOfPublicationEnd" name="labelDateOfPublicationEnd" for="regTimeEnd">Date to</label></td>
- <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeEnd'' id=''regTimeEnd'' > </td>
- </tr>
- </p>
- </table>
- </fieldset>
- <fieldset>
- <legend id="legendDateOfLastRevision" name="legendDateOfLastRevision">Data actuality</legend>
- <img class="help-dialog" id="helpDateOfLastRevision" title="Help" help="{text:''Help DateOfLastRevision''}" src="../img/questionmark.png" align="right"></img>
- <table>
- <p>
- <tr>
- <td><label id="labelDateOfLastRevisionStart" name="labelDateOfLastRevisionStart" for="timeBegin" >Date from</label></td>
- <td><input disabled="disabled" type=''text'' size=15 name=''timeBegin'' id=''timeBegin'' > </td>
- </tr>
- <tr>
- <td><label id="labelDateOfLastRevisionEnd" name="labelDateOfLastRevisionEnd" for="timeEnd">Date to</label></td>
-<td><input disabled="disabled" type=''text'' size=15 name=''timeEnd'' id=''timeEnd'' > </td>
- </tr>
- </p>
- </table>
- </fieldset>
-</fieldset>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','classSearchResources',3,1,'Div which shows the different bsearchable resources for metadata search','Was?','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset><legend id="legendSearchResources" name="legendSearchResources">Types of Resources</legend>
- <img class="help-dialog" id="helpSearchResources" title="Help" help="{text:''Help SearchResources''}" src="../img/questionmark.png" align="right"></img>
- <div id=''searchResources'' name=''searchResources''>
- <input name=''checkResourcesWms'' id=''checkResourcesWms'' type=''checkbox'' value=''wms''>
- <label id="labelCheckResourcesWms" name="labelCheckResourcesWms">Viewing Services</label>
- <input name=''checkResourcesWfs'' id=''checkResourcesWfs'' type=''checkbox'' value=''wfs''>
- <label id="labelCheckResourcesWfs" name="labelCheckResourcesWfs">Search/Download/Digitize Modules</label>
- <input name=''checkResourcesWmc'' id=''checkResourcesWmc'' type=''checkbox'' value=''wmc''>
- <label id="labelCheckResourcesWmc" name="labelCheckResourcesWmc">Map Collections</label>
- <input disabled="disabled" name=''checkResourcesGeorss'' id=''checkResourcesGeorss'' type=''checkbox'' value=''georss''>
- <label disabled="disabled" id="labelCheckResourcesGeorss" name="labelCheckResourcesGeorss">GeoRSS Feeds</label>
- </div>
-</fieldset>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','orderBy',3,1,'Div which shows orderby options for the metadata search','Order','div','','class=''orderBy''',0,80,480,NULL ,20,'','<fieldset>
-<legend id="legendOrderBy" name="legendOrderBy">Sort by:</legend>
- <img class="help-dialog" id="helpOrderBy" title="Help" help="{text:''Help OrderBy''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''radio'' name=''orderBy'' value=''rank'' id=''orderBy'' checked >
- <label id="labelOrderByRank" name="labelOrderByRank">relevance</label>
- <input type=''radio'' name=''orderBy'' value=''title'' id=''orderBy''>
- <label id="labelOrderByTitle" name="labelOrderByTitle">title</label>
- <input type=''radio'' name=''orderBy'' value=''id'' id=''orderBy''>
- <label id="labelOrderById" name="labelOrderById">identification</label>
- <input type=''radio'' name=''orderBy'' value=''date'' id=''orderBy''>
- <label id="labelOrderByDate" name="labelOrderByDate">date</label>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','searchField',3,1,'Div which shows the search field for the metadata search','','div','','class=''searchField''',0,0,480,NULL ,20,'',' <fieldset>
- <legend id="legendSearchTextTitle" name="legendSearchTextTitle">Searchterm(s):</legend>
- <img class="help-dialog" id="helpSearchText" title="Help" help="{text:''Help SearchText''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''text'' size=30 name=''searchText'' id=''searchText''>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_div_collection2',3,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','Wo?','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','spatialFilter,mb_div_collection1,spatialBackground','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','form1',3,1,'Form for the extended mapbender metadata search','','form','','method=''post'' name=''form1''',0,0,400,NULL ,NULL,'','','form','../plugins/mb_div_collection.js','../plugins/mb_extendedSearch.js','searchField,button,orderBy,mb_tabs_horizontal','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mb_tabs_horizontal',4,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,700,NULL ,NULL,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_div_collection2,actuality,classifications,provider,classSearchResources','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mb_tabs_horizontal','inputs','[
- "type": "id",
- "method": "select",
- "title": "Select a tab",
- "linkedTo": [
- "id": "mb_md_select",
- "event": "selected",
- "value": "mb_md_edit"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.droppable.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','mapframe1_mousewheelZoom',4,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_mousewheelZoom.js','../extensions/jquery.mousewheel.min.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Search_extended_DE','mapframe1_mousewheelZoom','factor','2','The factor by which the map is zoomed on each mousewheel unit','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Search_extended_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
--- Load WMS to application
---WMS demis world gui_wms
-INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,
-gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl)
-(SELECT
-'Search_extended_DE', fkey_wms_id, 0,
-gui_wms_mapformat,gui_wms_featureinfoformat,
-gui_wms_exceptionformat,gui_wms_epsg,1 as gui_wms_visible,gui_wms_opacity,gui_wms_sldurl
-FROM gui_wms WHERE fkey_gui_id = 'gui' AND fkey_wms_id = 250);
--- WMS demis world gui_layer
-INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,
-gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,
-gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype,gui_layer_title)
-(SELECT
-fkey_layer_id,gui_layer_wms_id ,gui_layer_status,gui_layer_selectable,
-gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype,gui_layer_title
- FROM gui_layer WHERE fkey_gui_id = 'gui' AND gui_layer_wms_id = 250);
---WMS germany gui_wms
-(SELECT
-'Search_extended_DE', fkey_wms_id, 1,
-FROM gui_wms WHERE fkey_gui_id = 'gui1' AND fkey_wms_id = 893);
--- WMS germany gui_layer
-(SELECT
- FROM gui_layer WHERE fkey_gui_id = 'gui1' AND gui_layer_wms_id = 893);
Deleted: trunk/mapbender/resources/db/admin_wfs_metadata.sql
--- trunk/mapbender/resources/db/admin_wfs_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/admin_wfs_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,316 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wfs_metadata','admin_wfs_metadata','Administration for WFS metadata',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
- font-family: Verdana;
- font-size: 96%;
-label {
- width: 250px;
- height: 40px;
- float: left;
-p {
- clear: both;
-input {
- font-weight: bold;
- vertical-align: top;
- width: 250px;
- height: 25px;
-.metadata_span {
- padding-right: 30px;
-.metadata_img {
- width: 25px;
- height: 25px;
-.metadata_selectbox {
- height: 130px;
- width: 250px;
-div#choose {
- float: left;
- width: 20%;
- height:100%;
-div#layer {
- margin-left: 20%;
- width: 80%;
-div#preview {
- width: 30%;
- padding-top: 5px;
- float: left;
-div#classification {
- margin-left: 50%;
- padding-top: 5px;
- width: 50%;
-div#save {
- margin-left: 45em;
-div#buttons {
- float: left;
-div#selectbox {
- margin-left: 312px;
- padding-top: 20px;
-}','to define the color of the body','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.ccss.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','center','mb_tabs_horizontal','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','south','mb_md_wfs_submit','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wfs_submit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_submit','inputs','[
- "method": "enable",
- "linkedTo": [
- "id": "mb_md_wfs_select",
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import_wfs.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddonWfs.js','','','jq_ui_dialog','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs','differentFromOriginalCss','.differentFromOriginal{
-background-color:#FFFACD;
-}','css for class differentFromOriginal','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs','inputs','[
- "method": "init",
- "title": "initialize",
- "linkedTo": [
- "id": "mb_md_edit",
- "event": "showOriginalMetadata",
- "attr": "data"
- "method": "initLayer",
- "linkedTo": [
- "id": "mb_md_layer",
- "event": "showOriginalLayerMetadata",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree',2,1,'Select a featuretype from a featuretype tree','Select a featuretype from a featuretype tree','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretypeTree.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree','inputs','[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_featuretype",
- "event": "initialized",
- "attr": "wfsId"
- "method": "serialize",
- "linkedTo": [
- "id": "mb_md_wfs_submit",
- "event": "submit",
- "attr": "callback"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_edit',2,1,'Edit WFS metadata','Edit WFS metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_wfs_edit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_edit','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wfsId"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "id": "mb_md_wfs_showOriginal",
- "event": "replaceMetadata",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_select',2,1,'Select a WFS','Select WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_wfs_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_wfs_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal','differentFromOriginalCss','.differentFromOriginal{
-}','','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal','inputs','[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_wfs_edit",
- "attr": "data"
- "linkedTo": [
- "event": "showOriginalFeaturetypeMetadata",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wfs_select,mb_md_wfs_edit,mb_md_featuretype','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_tabs_horizontal','inputs','[
- "type": "id",
- "linkedTo": [
- "value": "mb_md_wfs_edit"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype',3,1,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_featuretype','inputs','[
- "method": "init",
- "title": "initialize wfs data",
- "linkedTo": [
- "attr": "wfsId"
- "method": "fillForm",
- "title": "initialize featuretype data",
- "linkedTo": [
- "id": "mb_md_featuretype_tree",
- "attr": "featuretype"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "attr": "data"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
-insert into gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('admin_wfs_metadata',1,'owner');
Deleted: trunk/mapbender/resources/db/admin_wms_metadata.sql
--- trunk/mapbender/resources/db/admin_wms_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/admin_wms_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,392 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','Administration for WMS metadata',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_pane','center','mb_tabs_horizontal','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_pane','south','mb_md_submit','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_geodata_import',1,0,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_metadata_import.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
- font-size: 96%;
-label {
- width: 250px;
- height: 40px;
- float: left;
-p {
- clear: both;
-input {
- width: 250px;
- height: 25px;
-fieldset {
- margin-top: 10px;
-.metadata_span {
-.help-dialog {
- cursor: pointer;
-.metadata_img, .help-dialog, .original-metadata-wms {
- width: 25px;
- height: 25px;
- vertical-align: middle;
- height: 66px;
- width: 250px;
-.label_classification {
- width: 150px;
- height: 40px;
- float: left;
-div#choose {
- float: left;
- width: 35%;
- height:100%;
-position:relative;
-div#layer {
- margin-left: 35%;
- width: 65%;
-div#preview {
- padding: 5px 0px 0px 35%;
- width: 25%;
- float: left;
- margin-left: 60%;
- padding-top: 5px;
- width: 40%;
-div#buttons {
- float: left;
-div#selectbox {
- margin-left: 280px;
- padding-top: 60px;
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,0,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.testbaudson.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','slippy','0','1 = Activates an animated, pseudo slippy map','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input type=''checkbox'' id=''twitter_news''>Publish via Twitter<input type=''checkbox'' id=''rss_news''>Publish via RSS</input><input disabled="disabled" type=''button'' value=''Preview metadata''><input disabled="disabled" type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_submit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_submit','inputs','[
- "linkedTo": [
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddon.js','','','jq_ui_dialog','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon','differentFromOriginalCss','.differentFromOriginal{
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "data"
- "linkedTo": [
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','selArea1',2,1,'zoombox','Ausschnitt wählen','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomFull',2,1,'zoom to full extent button','gesamte Karte anzeigen','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomIn1',2,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_edit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_edit','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wmsId"
- "linkedTo": [
- "id": "mb_md_submit",
- "method": "fill",
- "linkedTo": [
- "id": "mb_md_showOriginal",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL,NULL ,NULL,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview_save','inputs','[
- "method":"setLayer",
- "title":"set the current Layer",
- "linkedTo": [
- "id":"mb_md_layer_tree",
- "event":"selected",
- "attr":"layer"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_tree','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wmsId"
- "linkedTo": [
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Projektion ändern','select','','',432,25,107,24,1,'','<option value="">undefined</option>
-<option value="EPSG:4326">EPSG:4326</option>
-<option value="EPSG:31466">EPSG:31466</option>
-<option value="EPSG:31467">EPSG:31467</option>
-<option value="EPSG:31468">EPSG:31468</option>
-<option value="EPSG:31469">EPSG:31469</option>','select','mod_changeEPSG.js','','overview','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showOriginal','differentFromOriginalCss','.differentFromOriginal{
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showOriginal','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "data"
- "linkedTo": [
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Ausschnitt verschieben','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL,NULL ,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','sandclock','mod_sandclock_image','../img/sandclock.gif','define a sandclock image ','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','scaleSelect',2,1,'Scale-Selectbox','Auswahl des Maßstabes','select','','',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <o
ption value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','../plugins/mb_selectScale.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_tabs_horizontal','inputs','[
- "type": "id",
- "linkedTo": [
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer','inputs','[
- "method": "init",
- "title": "initialize wms data",
- "linkedTo": [
- "attr": "wmsId"
- "title": "initialize layer data",
- "linkedTo": [
- "id": "mb_md_layer_tree",
- "attr": "layer"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "attr": "data"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',4,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wmsId"
- "method":"layer",
- "linkedTo": [
- "attr":"layer"
-]','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','map','mapframe1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarLower','[''changeEPSG'',''scaleSelect'']','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarUpper','[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_layer_preview_save'']','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
-insert into gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) values ('admin_wms_metadata',1,'owner');
Deleted: trunk/mapbender/resources/db/extendedSearchGui.sql
--- trunk/mapbender/resources/db/extendedSearchGui.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/extendedSearchGui.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,283 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('extended_search','extended_search','Extented metadata search form',1);
--- give root access to extended_search
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('extended_search', 1, 'owner');
-DELETE FROM gui_element WHERE fkey_gui_id = 'extended_search';
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mb_helpDialog',1,1,'Mapbender wrapper for helptexts in jq dialogs','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','mb_helpDialog.js','','jq_ui, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mapframe1',1,1,'Frame for a map','','div','','',10,218,280,154,20,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','css_class_bg','body{ background-color: #f3f3f3; }','to define the color of the body','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','css_file_body','../css/mapbender.css','file/css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','jq_ui_theme','../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','popupcss','../css/popup.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','tablesortercss','../css/tablesorter.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','body','use_load_message','false','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_metadata',1,1,'jQuery Metadata plugin - selects elements by tag names out of html?','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui',1,1,'jQuery UI core','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','jq_ui','css','../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','imprint',2,0,'Information about the owner of the gui','','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','dependentDiv',2,0,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,NULL ,'visibility:visible;position:absolute;font-size: 11px;font-family: \"Arial\", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) +
parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','copyright',2,1,'a Copyright in the map','','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','copyright','mod_copyright_text','©IMAGI-rlp','Copyright text displayed in mapframe1','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','loadData',2,0,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,NULL ,'visibility:visible','','iframe','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mapcheck',2,1,'alert if a map-image fails to load','','div','','',0,0,NULL ,NULL,NULL ,'','','div','','mod_mapcheck.php','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','zoomOut1',2,1,'zoomOut button','','img','../img/button_blink_red/zoomOut2_off.png','',305,233,24,24,20,'','','','mod_zoomOut1.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','back',2,1,'History.back()','','img','../img/button_blink_red/back_off_disabled.png','',305,358,24,24,20,'','','','mod_back.php','','mapframe1,overview0','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','forward',2,1,'History.forward()','','img','../img/button_blink_red/forward_off_disabled.png','',305,333,24,24,20,'','','','mod_forward.php','','mapframe1,overview0','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','navFrame',2,1,'navigation mapborder','','div','','',0,0,NULL ,NULL,20,'font-size:1px;','','div','mod_navFrame.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','pan1',2,1,'pan','','img','../img/button_blink_red/pan_off.png','',305,308,24,24,20,'','','','mod_pan.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','selArea1',2,1,'zoombox','','img','../img/button_blink_red/selArea_off.png','',305,258,24,24,20,'','','','mod_selArea.js','mod_box1.js','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','zoomFull',2,1,'zoom to full extent button','','img','../img/button_blink_red/zoomFull_off.png','',305,283,24,24,20,'','','img','mod_zoomFull.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','zoomIn1',2,1,'zoomIn button','','img','../img/button_blink_red/zoomIn2_off.png','',305,208,24,24,20,'','','','mod_zoomIn1.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','renderGML',2,0,'renders a gml contained in $_SESSION[''GML'']','','div','','',NULL ,NULL,NULL ,NULL,1,'','','div','../javascripts/mod_renderGML.php','mod_highlight.php','overview,mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','classSearchResources',3,1,'Div which shows the different bsearchable resources for metadata search','Resources','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset><legend id="legendSearchResources" name="legendSearchResources">Types of Resources</legend>
- <img class="help-dialog" id="helpSearchResources" title="Help" help="{text:''Help SearchResources''}" src="../img/questionmark.png" align="right"></img>
- <div id=''searchResources'' name=''searchResources''>
- <input name=''checkResourcesWms'' id=''checkResourcesWms'' type=''checkbox'' value=''wms''>
- <label id="labelCheckResourcesWms" name="labelCheckResourcesWms">Viewing Services</label>
- <input name=''checkResourcesWfs'' id=''checkResourcesWfs'' type=''checkbox'' value=''wfs''>
- <label id="labelCheckResourcesWfs" name="labelCheckResourcesWfs">Search/Download/Digitize Modules</label>
- <input name=''checkResourcesWmc'' id=''checkResourcesWmc'' type=''checkbox'' value=''wmc''>
- <label id="labelCheckResourcesWmc" name="labelCheckResourcesWmc">Map Collections</label>
- <input disabled="disabled" name=''checkResourcesGeorss'' id=''checkResourcesGeorss'' type=''checkbox'' value=''georss''>
- <label disabled="disabled" id="labelCheckResourcesGeorss" name="labelCheckResourcesGeorss">GeoRSS Feeds</label>
- </div>
-</fieldset>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','form2',3,1,'Form for the extended mapbender metadata search - this form submits the values as hidden to the search script','','form','','method=''get'' name=''form2'' action=''../php/mod_callMetadata.php'' target=''_top''',0,250,NULL ,NULL,NULL ,'',' <input type="hidden" value='''' name=''searchText''>
- <input type="hidden" value='''' name=''registratingDepartments''>
- <input type="hidden" value='''' name=''isoCategories''>
- <input type="hidden" value='''' name=''inspireThemes''>
- <input type="hidden" value='''' name=''customCategories''>
- <input type="hidden" value='''' name=''regTimeBegin''>
- <input type="hidden" value='''' name=''regTimeEnd''>
- <input type="hidden" value='''' name=''timeBegin''>
- <input type="hidden" value='''' name=''timeEnd''>
- <input type="hidden" value='''' name=''searchBbox''>
- <input type="hidden" value='''' name=''searchTypeBbox''>
- <input type="hidden" value='''' name=''searchResources''>
- <input type="hidden" value='''' name=''orderBy''> ','form','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,700,NULL ,NULL,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_div_collection2,actuality,classifications,provider,classSearchResources','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('extended_search','mb_tabs_horizontal','inputs','[
- "type": "id",
- "method": "select",
- "title": "Select a tab",
- "linkedTo": [
- "id": "mb_md_select",
- "event": "selected",
- "value": "mb_md_edit"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mb_div_collection1',3,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','mapframe1, zoomIn1,zoomFull,zoomOut1,selArea1,pan1,forward,back,navFrame','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','orderBy',3,1,'Div which shows orderby options for the metadata search','Order','div','','class=''orderBy''',0,80,480,NULL ,20,'','<fieldset>
-<legend id="legendOrderBy" name="legendOrderBy">Sort by:</legend>
- <img class="help-dialog" id="helpOrderBy" title="Help" help="{text:''Help OrderBy''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''radio'' name=''orderBy'' value=''rank'' id=''orderBy'' checked >
- <label id="labelOrderByRank" name="labelOrderByRank">relevance</label>
- <input type=''radio'' name=''orderBy'' value=''title'' id=''orderBy''>
- <label id="labelOrderByTitle" name="labelOrderByTitle">title</label>
- <input type=''radio'' name=''orderBy'' value=''id'' id=''orderBy''>
- <label id="labelOrderById" name="labelOrderById">identification</label>
- <input type=''radio'' name=''orderBy'' value=''date'' id=''orderBy''>
- <label id="labelOrderByDate" name="labelOrderByDate">date</label>
- </p>
- </fieldset>','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','searchField',3,1,'Div which shows the search field for the metadata search','','div','','class=''searchField''',0,0,480,NULL ,20,'',' <fieldset>
- <legend id="legendSearchTextTitle" name="legendSearchTextTitle">Searchterm(s):</legend>
- <img class="help-dialog" id="helpSearchText" title="Help" help="{text:''Help SearchText''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''text'' size=30 name=''searchText'' id=''searchText''>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','button',3,1,'Div for the button to submit extended search module','','div','','class=''button''',500,25,60,40,20,'','<button id="search" name="search" type="button" value="Start Search" onclick="validate();">Start Search</button>
-','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','actuality',3,1,'Div which shows the date field for temporal filters for metadata search','Wann?','div','','class=''actuality''',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
-<legend id="legendActuality" name="legendActuality">Actuality</legend>
- <fieldset>
- <legend id="legendDateOfPublication" name="legendDateOfPublication">Date of Publication</legend>
- <img class="help-dialog" id="helpDateOfPublication" title="Help" help="{text:''Help DateOfPublication''}" src="../img/questionmark.png" align="right"></img>
- <table>
- <p>
- <tr>
- <td><label id="labelDateOfPublicationStart" name="labelDateOfPublicationStart" for="regTimeBegin">Date from</label></td>
- <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeBegin'' id=''regTimeBegin'' > </td>
- </tr>
- <tr>
- <td><label id="labelDateOfPublicationEnd" name="labelDateOfPublicationEnd" for="regTimeEnd">Date to</label></td>
- <td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeEnd'' id=''regTimeEnd'' > </td>
- </tr>
- </p>
- </table>
- </fieldset>
- <fieldset>
- <legend id="legendDateOfLastRevision" name="legendDateOfLastRevision">Data actuality</legend>
- <img class="help-dialog" id="helpDateOfLastRevision" title="Help" help="{text:''Help DateOfLastRevision''}" src="../img/questionmark.png" align="right"></img>
- <table>
- <p>
- <tr>
- <td><label id="labelDateOfLastRevisionStart" name="labelDateOfLastRevisionStart" for="timeBegin" >Date from</label></td>
- <td><input disabled="disabled" type=''text'' size=15 name=''timeBegin'' id=''timeBegin'' > </td>
- </tr>
- <tr>
- <td><label id="labelDateOfLastRevisionEnd" name="labelDateOfLastRevisionEnd" for="timeEnd">Date to</label></td>
-<td><input disabled="disabled" type=''text'' size=15 name=''timeEnd'' id=''timeEnd'' > </td>
- </tr>
- </p>
- </table>
- </fieldset>
-</fieldset>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','classifications',3,1,'Put category divs into one div collection','Themen','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
- <legend id="classificationsLegend" name="classificationsLegend">Classifications</legend>
- <div class="inspire">
- <fieldset>
- <legend id="legendInspireThemes" name="legendInspireThemes">Inspire Themes</legend>
- <img class="help-dialog" id="helpInspireThemes" title="Help" help="{text:''Help Inspire Categories''}" src="../img/questionmark.png" align="right"></img>
-<img id="imageInspireThemes" title="Inspire" src="../img/inspire_tr_36.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''inspireThemes'' id=''inspireThemes'' multiple ></select>
- <br><a id="deleteSelection2" name="deleteSelection" href="#" onclick=''removeListSelections("inspireThemes");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
- <div class="iso">
- <fieldset>
- <legend id="legendIsoCategories" name="legendIsoCategories">ISO19115 Themes</legend>
- <img class="help-dialog" id="helpIsoCategories" title="Help" help="{text:''Help ISO Categories''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''isoCategories'' id=''isoCategories'' width="200px" multiple></select>
- <br><a id="deleteSelection3" name="deleteSelection" href="#" onclick=''removeListSelections("isoCategories");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
- <div class="custom">
- <fieldset>
- <legend id="legendCustomCategories" name="legendCustomCategories">Other Themes</legend>
- <img class="help-dialog" id="helpCustomCategories" title="Help" help="{text:''Help Custom Categories''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''customCategories'' id=''customCategories'' multiple></select>
- <br><a id="deleteSelection4" name="deleteSelection" href="#" onclick=''removeListSelections("customCategories");''>Drop current selection</a>
- </p>
- </fieldset>
- </div>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','provider',3,1,'Div which shows a list of providers for the metadata search','Anbieter','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
-<legend id="legendDepartment" name="legendDepartment">Provider</legend>
-<img class="help-dialog" id="helpProvider" title="Help" help="{text:''Help Provider''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <select class=''selectCat'' size=''5'' name=''registratingDepartments'' id=''registratingDepartments'' multiple ></select>
- <br><a id="deleteSelection1" name="deleteSelection" href="#" c onclick=''removeListSelections("registratingDepartments");''>Drop current selection</a>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','spatialFilter',3,1,'Div which shows the spatial filter options for the metadata search','','div','','class=''spatialFilter''',NULL ,NULL,NULL ,NULL,20,'',' <fieldset>
- <img class="help-dialog" id="helpSpatialFilter" title="Help" help="{text:''Help SpatialFilter''}" src="../img/questionmark.png" align="right"></img>
- <p>
- <input type=''checkbox'' name=''searchBbox'' id=''searchBbox''>
- <label id="labelSpatialFilter" name="labelSpatialFilter">Activate Spatial Filter</label>
- <legend id="labelSpatialFilterType" name="labelSpatialFilterType">how?</legend>
- <input type=''radio'' name=''searchTypeBbox'' value=''intersects'' id=''searchTypeBbox''>
- <label id="labelIntersects" name="labelIntersects" for="bbox">intersects</label>
- <input type=''radio'' name=''searchTypeBbox'' value=''outside'' id=''searchTypeBbox''>
- <label id="labelOutside" name="labelOutside">outside</label>
- <input type=''radio'' name=''searchTypeBbox'' value=''inside'' id=''searchTypeBbox''>
- <label id="labelInside" name="labelInside">fully inside</label>
- </p>
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','mb_div_collection2',3,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','Wo?','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','mb_div_collection1,spatialFilter','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','form1',3,1,'Form for the extended mapbender metadata search','','form','','method=''post'' name=''form1''',0,0,400,NULL ,NULL,'','','form','../plugins/mb_div_collection.js','../plugins/mb_extendedSearch.js','searchField,button,orderBy,mb_tabs_horizontal','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('extended_search','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.datepicker.min.js','','jq_ui','');
-insert into translations (locale,msgid,msgstr) values ('de','Where?','Wo?');
-insert into translations (locale,msgid,msgstr) values ('de','When?','Wann?');
-insert into translations (locale,msgid,msgstr) values ('de','Themes','Themen');
-insert into translations (locale,msgid,msgstr) values ('de','Provider','Anbieter');
-insert into translations (locale,msgid,msgstr) values ('de','What?','Was?');
-insert into translations (locale,msgid,msgstr) values ('en','Where?','Where?');
-insert into translations (locale,msgid,msgstr) values ('en','When?','When?');
-insert into translations (locale,msgid,msgstr) values ('en','Themes','Themes');
-insert into translations (locale,msgid,msgstr) values ('en','Provider','Provider');
-insert into translations (locale,msgid,msgstr) values ('en','What?','What?');
Deleted: trunk/mapbender/resources/db/geoportal_gui.sql
--- trunk/mapbender/resources/db/geoportal_gui.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/geoportal_gui.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,214 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Geoportal-RLP','Geoportal-RLP','GUI combining most of the Mapbender functionality',1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.widget.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.core.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','mapframe1',1,1,'Frame for a map','','div','','',215,15,480,360,3,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mapframe1','wfsConfIdString','94','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/wz_jsgraphics.js,geometry.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','css_file_wfstree','../css/wfsconftree.css','file/css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','css_class_bg','body{ background-color: #ffffff; }','to define the color of the body','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','css_file_body','../css/mapbender.css','file/css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','favicon','../img/favicon.ico','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','includeWhileLoading','../include/gui1_splash.php','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','jquery_datatables','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','popupcss','../css/popup.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','tablesortercss','../css/tablesorter.css','file css','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','use_load_message','true','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','print_css','../css/print_div.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','body','css_file_feedtree','../css/feedtree.css','file/css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','toolbar',1,0,'This toolbar appends all its target elements to its container','Toolbar','div','','class=''mb-toolbar'' style=''background:url(../img/Mapbender_logo_and_text_200x50.png) no-repeat 10px 10px''',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_toolbar.js','','measure_widget','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','toolbar','css','.mb-toolbar ul, .mb-toolbar li {
- display: inline;
-.mb-toolbar ul {
- float: right;
-.mb-toolbar li {
- margin:2px
-}','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','sessionWmc',1,1,'','Please confirm','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_sessionWmc.js','','','mapframe1','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','sessionWmc','displayTermsOfUse','1','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','dependentDiv',2,0,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,NULL ,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','jhfggfjfjhgfh','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','feeds',2,1,'','GeoRSS/KML','ul','','',1,1,1,1,NULL ,'','','ul','../plugins/feedTree.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','wfsConfTree',2,1,'','Such- und Downloadmodule','ul','','',10,400,1,1,NULL ,'','','ul','../plugins/wfsConfTree.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','wfsConfTree','wfs_spatial_request_conf_filename','wfs_default.conf','','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','legend',2,1,'legend','Legende','div','','',0,0,NULL ,NULL,600,'','','div','../javascripts/mod_legendDiv.php','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','checkbox_on_off','false','display or hide the checkbox to set the legend on/off','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','css_file_legend','../css/legend.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','legendlink','false','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','showgroupedlayertitle','true','show the title of the grouped layers in the legend','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','showlayertitle','true','show the layer title in the legend','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','showwmstitle','true','show the wms title in the legend','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','legend','stickylegend','false','parameter to decide wether the legend should stick on the mapframe1','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','scaleText',2,1,'Scale-description field','Maßstab per Texteingabe','form','','action="window.location.href" onsubmit="return mod_scaleText()" ',5,155,30,30,NULL ,'','<input type="text" style="width:100px;">','form','mod_scaleText.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Projektion ändern','select','','',5,185,196,26,1,'','<option value="">undefined</option>','select','mod_changeEPSG.php','','overview','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','changeEPSG','projections','EPSG:4326;Geographic Coordinates,EPSG:31466;Gauss-Krueger 2,EPSG:31467;Gauss-Krueger 3,EPSG:31468;Gauss-Krueger 4,EPSG:31469;Gauss-Krueger 5','','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','resultList',2,1,'','Result List','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_ResultList.js','../../lib/resultGeometryListController.js, ../../lib/resultGeometryListModel.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList','position','[600,50]','position of the result list dialog','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList','resultListHeight','400','height of the result list dialog','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList','resultListTitle','Search results','title of the result list dialog','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList','resultListWidth','600','width of the result list dialog','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','resultList_DetailPopup',2,1,'Detail Popup For resultList','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_resultList_DetailPopup.js','','resultList','','http://www.mapbender.org/resultList_DetailPopup');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_DetailPopup','detailPopupHeight','250','height of the result list detail popup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_DetailPopup','detailPopupTitle','Details','title of the result list detail popup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_DetailPopup','detailPopupWidth','350','width of the result list detail popup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_DetailPopup','openLinkFromSearch','0','open link directly if feature attr is defined as link','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_DetailPopup','position','[700,300]','position of the result list detail popup','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','resultList_Highlight',2,1,'highlighting functionality for resultList','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_resultList_Highlight.js','','resultList,mapframe1,overview','','http://www.mapbender.org/resultList_Highlight');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_Highlight','maxHighlightedPoints','500','max number of points to highlight','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_Highlight','resultHighlightColor','#ff0000','color of the highlighting','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_Highlight','resultHighlightLineWidth','2','width of the highlighting line','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resultList_Highlight','resultHighlightZIndex','100','zindex of the highlighting','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','resultList_Zoom',2,1,'zoom functionality for resultList','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_resultList_Zoom.js','','resultList,mapframe1','','http://www.mapbender.org/resultList_Zoom');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','dragMapSize',2,1,'drag & drop Mapsize','Karte vergrößern','div','','class="ui-state-default"',-59,1,15,15,2,'font-size:1px; cursor:move; width:10; height:10;','<span class="ui-icon ui-icon ui-icon-arrow-4"></span>','div','mod_dragMapSize.php','','mapframe1','','http://www.mapbender.org/index.php/DragMapSize');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
-for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Karten','div','','class="ui-widget"',12,144,152,300,2,'visibility:hidden;overflow:auto','','div','../html/mod_treefolderPlain.php','jsTree.js','mapframe1','mapframe1','http://www.mapbender.org/index.php/TreeGde');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','alerterror','true','alertbox for wms loading error','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','css','../css/treeGDE2.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','enlargetreewidth','300','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','ficheckbox','true','checkbox for featureInfo requests','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','handlesublayer','true','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','imagedir','../img/tree_new','image directory','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','menu','wms_up,wms_down,opacity_up,opacity_down,remove,layer_up,layer_down,metainfo,zoom,hide','context menu elements','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','metadatalink','true','link for layer-metadata','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','openfolder','false','initial open folder','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','showstatus','true','show status in folderimages','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','switchwms','true','enables/disables all layer of a wms','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','treeGDE','wmsbuttons','false','wms management buttons','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','addGeoRSS',2,0,'add a GeoRSS Feed to a running application','GeoRSS hinzufügen','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',115,65,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','addGeoRSS','loadGeorssFromSession','1','','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','featureInfo1',2,1,'FeatureInfoRequest','Datenabfrage','img','../img/button_blue_red/query_off.png','',175,95,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','featureInfo1','featureInfoLayerPopup','true','display featureInfo in dialog popup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','featureInfo1','featureInfoPopupHeight','200','height of the featureInfo dialog popup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','featureInfo1','featureInfoPopupPosition','[100,100]','position of the featureInfoPopup','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','featureInfo1','featureInfoPopupWidth','270','width of the featureInfo dialog popup','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','zoomIn1',2,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_blue_red/zoomIn2_off.png','',145,5,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_blue_red/zoomOut2_off.png','',175,5,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','back',2,1,'History.back()','Zurück','img','../img/button_blue_red/back_off_disabled.png','',145,125,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','pan1',2,1,'pan','Ausschnitt verschieben','img','../img/button_blue_red/pan_off.png','',175,35,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','selArea1',2,1,'zoombox','Ausschnitt wählen','img','../img/button_blue_red/selArea_off.png','',145,35,24,24,1,'','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','showCoords_div',2,1,'displays coordinates by onmouseover','Koordinaten anzeigen','img','../img/button_blue_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',175,65,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','zoomFull',2,1,'zoom to full extent button','gesamte Karte anzeigen','img','../img/button_blue_red/zoomFull_off.png','',145,65,24,24,2,'','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','loadwmc',2,1,'load workspace from WMC','laden eines Web Map Context Dokumentes','img','../img/button_blue_red/wmc_load_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',115,155,24,24,1,'','','','mod_loadwmc.php','popup.js','mapframe1','jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables','http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','loadwmc','deleteWmc','1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','loadwmc','loadFromSession','1','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','loadwmc','publishWmc','0','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','loadwmc','saveWmcTarget','savewmc','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','savewmc',2,1,'save workspace as WMC','Ansicht als Web Map Context Dokument speichern','img','../img/button_blue_red/wmc_save_off.png','',115,125,24,24,1,'','','','mod_savewmc.php','','mapframe1','jq_ui_dialog','http://www.mapbender.org/index.php/SaveWMC');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','savewmc','overwrite','1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','savewmc','saveInSession','1','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','addWMS',2,1,'add a WMS to the running application','WMS hinzufügen','img','../img/button_blue_red/add_off.png','',175,155,24,24,1,'','','','mod_addWMS.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS Einstellungen','img','../img/button_blue_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',145,155,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','addWMSfromfilteredList_ajax',2,0,'add a WMS to the running application from a filtered list','WMS von gefilteter Liste hinzufügen','img','../img/button_gray/add_filtered_list_off.png','',620,60,24,24,1,'','','','mod_addWmsFromFilteredList_button.php','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','addWMSfromfilteredList_ajax','capabilitiesInput','1','load wms by capabilities url','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','addWMSfromfilteredList_ajax','option_dball','1','1 enables option "load all configured wms from db"','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','addWMSfromfilteredList_ajax','option_dbgroup','0','1 enables option "load configured wms by group"','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','addWMSfromfilteredList_ajax','option_dbgui','0','1 enables option "load configured wms by gui"','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + pa
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','setBackground',2,0,'switch background-wms','Hintegrundkarte auswählen','form','','action="window.location.href"',15,190,0,0,1,'','<select style="font-family: Arial, sans-serif; font-size:12" title="Set background" name="mod_setBackground_list" onchange="mod_setBackground_change(this)"><option value="0"></option></select>','form','mod_setBackground.php','','mapframe1','','http://www.mapbender.org/index.php/SetBackground');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.position.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','deleteSessionWmc',2,1,'delete Session Wmc','Reset','img','../img/button_blue_red/repaint_off.png','onclick=''$("#sessionWmc").mapbender().deleteWmc();''
-onmouseover="this.src = this.src.replace(/_off/,''_over'');" onmouseout="this.src = this.src.replace(/_over/, ''_off'');"',115,35,24,24,NULL ,'','','','','','mapframe1','sessionWmc','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','resizeMapsize',2,1,'resize_mapsize','Fullscreen','img','../img/button_blue_red/resizemapsize_off.png','onmouseover="this.src = this.src.replace(/_off/,''_over'');" onmouseout="this.src = this.src.replace(/_over/, ''_off'');"',115,65,24,24,NULL ,'','','','mod_resize_mapsize.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resizeMapsize','adjust_height','-35','to adjust the height of the mapframe on the bottom of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resizeMapsize','adjust_width','-50','to adjust the width of the mapframe on the right side of the window','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','resizeMapsize','resize_option','button','auto (autoresize on load), button (resize by button)','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','center1',2,0,'Center button','Kartenmittelpunkt setzen','img','../img/button_blue_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','logout',2,0,'Logout','Abmelden','img','../img/button_blue_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',704,46,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','logout','logout_location','http://www.mapbender.org/','webside to show after logout','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','measure_widget',2,1,'Measure','Messen','img','../img/button_blue_red/measure_off.png','',145,95,24,24,1,'','','','../plugins/mb_measure_widget.php','../widgets/w_measure.js,../extensions/RaphaelJS/raphael-1.4.7.min.js','mapframe1','jq_ui_dialog,jq_ui_widget','http://www.mapbender.org/index.php/Measure');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','lineStrokeDefault','#C9F','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','lineStrokeSnapped','#F30','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','lineStrokeWidthDefault','3','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','lineStrokeWidthSnapped','5','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','measurePointDiameter','7','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','opacity','0.4','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','pointFillDefault','#CCF','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','pointFillSnapped','#F90','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','polygonFillDefault','#FFF','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','polygonFillSnapped','#FC3','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','polygonStrokeWidthDefault','1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','measure_widget','polygonStrokeWidthSnapped','5','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','measure',2,0,'Measure','Messen','img','../img/button_blue_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',145,95,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','printPDF',2,1,'pdf print','Druck','div','','',860,10,200,380,5,'','<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="subm
it" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>','div','../plugins/mb_print.php','../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js,../extensions/wz_jsgraphics.js','mapframe1','','http://www.mapbender.org/index.php/Print');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','printPDF','mbPrintConfig','{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','print1',2,0,'start print GUI','Druck','img','../img/button_blue_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','forward',2,0,'History.forward()','Nach vorne','img','../img/button_blue_red/forward_off_disabled.png','',175,125,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Karten','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','repaint',2,0,'refresh a mapobject','Neu laden oder Tastatur: Leertaste','img','../img/button_blink_red/repaint_off.png','',360,60,24,24,1,'','','','mod_repaint.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','setBackground_all',2,0,'switch all background-wms','Hintegrundkarte auswählen','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','wfs_gazetteer',2,0,'gazetteer using wfs','Suche','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','mousewheelZoom',2,1,'adds mousewheel zoom to map module (target)','Mousewheel zoom','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','mod_mousewheelZoom.js','../extensions/jquery.mousewheel.min.js','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mousewheelZoom','factor','3','The factor by which the map is zoomed on each mousewheel unit','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','setPOI2Scale','mod_setPOI2Scale_defScale','5000','default scale','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','changePassword_button',2,0,'button: change password of logged user','Passwort ändern','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','help',2,0,'button help','Hilfe','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','help1',2,0,'button help','Hilfe','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','addWMSfromList',2,0,'add a WMS to the running application from a list','WMS aus Liste hinzufügen','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','scaleSelect',2,1,'Scale-Selectbox','Auswahl des Maßstabes','select','','onchange=''mod_scaleSelect(this)''',5,125,105,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300
000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','navFrame',2,1,'navigation mapborder','Navigationsfenster','div','','',0,0,0,0,10,'font-size:1px;','','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','scalebar',2,1,'scalebar','Maßstabsleiste','div','','',0,0,0,0,0,'','','div','mod_scalebar.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','addCSW',2,0,'search via a CSW Client','Katalogsuche','img','../img/button_gray/csw_off.png','',288,25,24,24,1,'','','','mod_searchCSW_ajax_button.php','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddCSW');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','overview',2,1,'OverviewFrame','','div','','',5,5,110,115,2,'overflow:hidden;background-color:#ffffff','<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>','div','../plugins/mb_overview.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','mapframe1','mapframe1','http://www.mapbender.org/index.php/Overview');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','overview','overview_wms','1','wms that shows up as overview','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','overview','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','georss',2,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../../lib/mb.ui.displayFeatures.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL,NULL ,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','copyright','mod_copyright_text','mapbender.org','define a copyright text which should be displayed','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','sandclock','mod_sandclock_image','../img/sandclock.gif','define a sandclock image ','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','treeConfGDE',2,0,'configurable directory tree','Karten','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','tabs',2,1,'vertical tabs to handle iframes','','div','','',5,215,195,20,3,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_ids[1]','wfsConfTree','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_ids[2]','feeds','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','open_tab','0','define which tab should be opened when a gui is opened','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_frameHeight[0]','200','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_frameHeight[1]','260','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_frameHeight[2]','380','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_ids[0]','treeGDE','','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_prefix',' ','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','expandable','0','1 = expand the tabs to fit the document vertically, default is 0','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','tabs','tab_style','position:absolute;visibility:visible;cursor:pointer;','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','highlightPOI',2,0,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','highlightPOI','poi_height','25','height of the poi_image','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','highlightPOI','poi_image','../img/redball.gif','image to use to mark the poi(s)','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','highlightPOI','poi_style','background-color:white;font-weight: bold;color:blue;font-family:Arial;','style to display the poi text','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','highlightPOI','poi_width','25','width of the poi_image','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','metadata',2,0,'shows informations about the wms and the requests of the gui','Anzeige von WMS Informationen','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',703,18,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','layout_1',3,1,'layout, background for buttons','','div','','',383,93,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','mapframe1_zoomBar',4,0,'zoom bar - slider to handle navigation, define zoom level with an element var','Zoom to scale','div','','',30,100,NULL ,200,100,'','','div','../plugins/mb_zoomBar.js','','mapframe1','mapframe1, jq_ui_slider','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mapframe1_zoomBar','defaultLevel','1','define the default level for application start','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','mapframe1_zoomBar','level','[2500,5000,10000,50000,100000,500000,1000000,3000000,5000000,10000000]','define an array of levels for the slider (element_var has to be defined)','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.droppable.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','mapframe1_navigation',4,0,'Adds navigation arrows on top of the map','Navigation','div','','',20,30,NULL ,NULL,100,'','','div','../plugins/mb_navigation.js','','mapframe1','mapframe1','http://www.mapbender.org/Navigation');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','renderGML',4,1,'renders a gml contained in $_SESSION[''GML'']','','div','','',NULL ,NULL,NULL ,NULL,1,'','','','../javascripts/mod_renderGML.php','','overview,mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','overviewToggle',5,0,'','','div','','class="ui-widget-header ui-corner-all"',NULL ,NULL,NULL ,NULL,NULL ,'display:none;height:24px;width:35px;vertical-align: middle;text-align:right','<img style="position:absolute;top:0px;left:0px" src="../img/ovtoggle.png" /><span style="margin-left: auto; margin-right: 0;" class="ui-icon ui-icon-triangle-1-e"></span>','div','../javascripts/mod_overviewToggle.js','','legend','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,15,15,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','jq_ui_slider',5,1,'slider from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.slider.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','popup',6,1,'popup replacement','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','popup.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','printPdfButton',7,1,'popup','Print PDF','img','../img/button_blue_red/print_off.png','',115,95,24,24,NULL ,'','','','../plugins/mb_button.js','','printPDF','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','legendButton',7,1,'popup','Legende','img','../img/button_blue_red/select_choose_off.png','',175,125,24,24,NULL ,'','','','../plugins/mb_button.js','','legend','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','coordsLookUpButton',7,1,'popup','Koordinatensuche','img','../img/button_blue_red/user_off.png','',115,5,24,24,NULL ,'','','','../plugins/mb_button.js','','coordsLookup','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP','coordsLookup',10,1,'','Koordinatensuche','div','','',1000,0,NULL ,NULL,NULL ,'z-index:9999;','','div','mod_coordsLookup.php','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','coordsLookup','perimeters','[50,200,1000,10000]','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP','coordsLookup','projections','EPSG:4326;Geographic Coordinates,EPSG:31466;Gauss-Krueger 2,EPSG:31467;Gauss-Krueger 3,EPSG:31468;Gauss-Krueger 4,EPSG:31469;Gauss-Krueger 5','','php_var');
Modified: trunk/mapbender/resources/db/gui_Administration_DE.sql
--- trunk/mapbender/resources/db/gui_Administration_DE.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_Administration_DE.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -136,16 +136,15 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','adminGroupId','36','','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','authorizeRoleId','3','','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','allowPublishMetadata','file css','../css/allow_publishing_metadata.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs',2,1,'secure services','OWSProxy WFS','a','','href="../php/mod_owsproxy_wfs_conf.php?sessionID"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_metadata',2,1,'dataset metadata admin menu','Admin Metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata_collection,ckan_sync_collection','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','deleteWFS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','wms_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wms_metadata,wms_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata',2,1,'dataset metadata manager','Metadataeditor Dataset','a','','href = "../frames/index.php?guiID=admin_metadata"
-',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten - Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata,dataset_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','menu_metadata',2,1,'dataset metadata admin menu','Admin Metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','dataset_metadata_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_wfs',2,1,'secure services','OWSProxy WFS','a','','href="../php/mod_owsproxy_wfs_conf.php?sessionID"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync',2,1,'ckan sync module','Ckan Synchronisierung','a','','href = "../javascripts/mod_syncCkan_client.php?compareTimestamps=true"',80,10,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Ckan Synchronisierungsmodul','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','ckan_sync,ckan_sync_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','ckan_sync_icon',2,1,'icon','','img','../img/misc/ckan.png','',0,0,NULL ,NULL,2,'','','','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','updateWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWFS,updateWFS_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
@@ -162,6 +161,10 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','menu_wms','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc',2,1,'secure services','OWSProxy WMS Calculation','a','','href = "../frames/index.php?guiID=Owsproxy_csv"',80,10,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Sicherheits Proxy (Abrechnung)','a','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_calc,owsproxy_calc_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','owsproxy_calc_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','dataset_metadata',2,1,'dataset metadata manager','Metadataeditor Dataset','a','','href = "../frames/index.php?guiID=admin_metadata"
+',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Metadaten - Editor','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
@@ -169,3 +172,4 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_wms,menu_wfs,menu_metadata,menu_wmc,menu_user,menu_gui,menu_auth','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
Added: trunk/mapbender/resources/db/gui_Owsproxy_csv.sql
--- trunk/mapbender/resources/db/gui_Owsproxy_csv.sql (rev 0)
+++ trunk/mapbender/resources/db/gui_Owsproxy_csv.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -0,0 +1,41 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Owsproxy_csv','Owsproxy_csv','GUI combining most of the Mapbender functionality',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','i18n',1,0,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','jq_validate',1,0,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/js/jquery-ui-1.8.16.custom.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','jq_ui','css','../extensions/jquery-ui-1.8.16.custom/css/ui-lightness/jquery-ui-1.8.16.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,550,NULL ,'position:relative !important;overflow:visible;','','body','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','css_file_body','../css/mapbender.css','file/css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','css_file_feedtree','../css/feedtree.css','file/css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','css_file_wfstree','../css/wfsconftree.css','file/css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','css_owsproxy_log','../css/owsproxy_logs.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','favicon','../img/favicon.ico','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','includeWhileLoading','../include/gui1_splash.php','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','jquery_datatables','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','popupcss','../css/popup.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','print_css','../css/print_div.css','','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','tablesortercss','../css/tablesorter.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','body','use_load_message','true','','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','tabs',2,0,'vertical tabs to handle iframes','','div','','',5,295,195,20,3,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','expandable','0','1 = expand the tabs to fit the document vertically, default is 0','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','open_tab','0','define which tab should be opened when a gui is opened','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_frameHeight[0]','230','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_frameHeight[1]','230','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_frameHeight[2]','230','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_ids[0]','treeGDE','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_ids[1]','wfsConfTree','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_ids[2]','feeds','','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_prefix',' ','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','tabs','tab_style','position:absolute;visibility:visible;cursor:pointer;','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','logout',2,0,'Logout','Abmelden','img','../img/button_blue_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',704,126,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','logout','logout_location','http://www.mapbender.org/','webside to show after logout','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','owsproxy_log_csv',2,1,'Load owsproxy log data as csv','Load oxsproxy log csv','div','','',NULL ,NULL,NULL ,NULL,2,'overflow:auto;background-color: white;width:100%;height:100%;padding:20px;','','div','../plugins/mb_owsproxy_log_csv.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Owsproxy_csv','owsproxy_log_csv','owsproxy_log_css','#owsproxy-log-query{width:500px;}
+#owsproxy-log-query div.field label { width:150px;}','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Owsproxy_csv','ig_ui_timepicker',5,1,'Includes the jQuery plugin timepicker','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.timepicker.js','','','','');
Modified: trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql
--- trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_PortalAdmin_DE.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -11,8 +11,8 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexDATASET,reindexDATASET_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS',2,1,'Start Monitor for WMS','Start Monitor for WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=monitor"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Start Monitor for WMS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS',2,1,'Reindex search WFS','Reindex search WFS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wfs&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WFS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWFS','file css','../css/administration_alloc.css','file css','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','reindexWFS,reindexWFS_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWMS',2,1,'Reindex search WMS','Reindex search WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WMS','a','','','','','http://www.mapbender.org/');
@@ -48,8 +48,7 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','deleteCategory',2,1,'Anwendungskategorie löschen','Anwendungskategorie löschen','a','','href = "../php/mod_deleteCategory.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Anwendungskategorie löschen','a','','','','','http://www.mapbender.org/GUI_Category');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Group_User',2,1,'Gruppen Nutzer Zuordnung','Gruppen <-> Nutzer','a','','href = "../php/mod_group_user.php?sessionID"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Gruppen Nutzer Zuordnung','a','','','','','http://www.mapbender.org/GUI_Category');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Group_User','file css','../css/administration_alloc.css','file css','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexWFS',2,1,'Reindex search WFS','Reindex search WFS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wfs&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search WFS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','reindexWFS','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_maintenance',2,1,'GUI admin menu','Wartung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,Start_Monitor_for_WMS_collection','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','Start_Monitor_for_WMS,Start_Monitor_for_WMS_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS_icon',2,1,'icon','','img','../img/gnome/system-run.png','',0,0,NULL ,NULL,2,'','','','','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','reindexDATASET',2,1,'Reindex search DATASET','Reindex search DATASET','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=dataset&maintenanceFunction=reindex"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Reindex search DATASET','a','','','','','http://www.mapbender.org/');
@@ -57,10 +56,11 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser,editUser_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editUser',2,1,'Benutzer anlegen und editieren','Benutzer anlegen und editieren','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Benutzer anlegen und editieren','a','','','','','http://www.mapbender.org/index.php/user');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','editUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_maintenance',2,1,'GUI admin menu','Wartung','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,Start_Monitor_for_WMS_collection','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','editMaintenance_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','orphanWMS,orphanWMS_icon','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS',2,1,'display orphaned wms','','a','','href = "../php/mod_orphanWMS.php?sessionID" target="AdminFrame"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Verwaiste WMS löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','orphanWMS_icon',2,1,'icon','','img','../img/gnome/edit-clear.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS',2,1,'Start Monitor for WMS','Start Monitor for WMS','a','','href = "../php/mod_catalogueMaintenance.php?sessionID&resourceType=wms&maintenanceFunction=monitor"',80,15,210,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Start Monitor for WMS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','Start_Monitor_for_WMS','file css','../css/administration_alloc.css','file css','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','menu_user',2,1,'User admin menu','Admin Nutzer','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editUser_collection','','');
@@ -72,3 +72,4 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_iframepopup',7,1,'iframepopup','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_iframepopup.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('PortalAdmin_DE','mb_horizontal_accordion',10,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_maintenance,menu_group,menu_user,menu_role,menu_category','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('PortalAdmin_DE','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
Modified: trunk/mapbender/resources/db/gui_admin_metadata.sql
--- trunk/mapbender/resources/db/gui_admin_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_admin_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,32 +1,13 @@
INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_metadata','admin_metadata','Simple administration gui for dataset-metadata',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_geodata_import',1,0,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_metadata_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_metadata_gml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_gml_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
-* {font-family: Verdana;font-size: 96%;box-sizing: border-box;}
-#ui-datepicker-div {display: none;}
-div.ui-layout-content {padding:0px; !important}
-div.ui-tabs-panel{padding:0 !important;margin:0 !important;}
-label {width: 40%;float: left;}
-label>input {width:190px}
-p {clear: both;display: table;width: 100%;}
-input {font-weight: bold;vertical-align: top;width: 50%;}
-input[type=''checkbox''],input[type=''radio''],input[type=''button''],input[type=''submit''] {width:auto;height:auto;}
-input[type=''button''],input[type=''submit'']{margin:10px}
-input[disabled]{background-color:lightgrey;color:grey;cursor:no-drop;}
-input[readonly]{background-color:lightgrey;color:grey;cursor:no-drop;}
-fieldset {margin-top: 10px;}
-.dataTables_wrapper{min-height:unset;}
-.metadata_span {padding-right:0;vertical-align: top;}
-.help-dialog {cursor: pointer;}
-.metadata_img, .help-dialog, .original-metadata-wms {width: 25px;height: 25px;vertical-align: middle;}
-.metadata_selectbox {height:66px;width:250px;vertical-align:top;}
-.label_classification {width: 150px;height: 40px;float: left;}
-div#choose {float: left;width: 30%;height:100%;position:relative;overflow:hidden;}
-div#choose:hover{overflow:initial !important;background-color:white;display:inline-block;width:unset;}
-div#layer {margin-left: 31%;width: 69%;}
-div#preview {max-width:305px;float: left;}
-div#classification {float: left;max-width: 305px;}
-div#buttons {float: left;}
-div#selectbox {margin-left: 280px;padding-top: 60px;}','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','body','favicon','../img/favicon.png','favicon','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','body','includeWhileLoading','1','show splash screen while the application is loading','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
@@ -51,11 +32,42 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_md_showMetadataAddon',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddon.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','mb_md_showMetadataAddon','differentFromOriginalCss','.differentFromOriginal{
+background-color:#FFFACD;
+}','css for class differentFromOriginal','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_metadata','mb_md_showMetadataAddon','inputs','[
+ "method": "init",
+ "title": "initialize",
+ "linkedTo": [
+ "id": "mb_md_edit",
+ "event": "showOriginalMetadata",
+ "attr": "data"
+ "method": "initLayer",
+ "linkedTo": [
+ "id": "mb_md_layer",
+ "event": "showOriginalLayerMetadata",
+ "attr": "data"
+]','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','mb_metadata_manager_select',2,1,'Select a metadata resource','Select metadata resource','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_manager_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
Modified: trunk/mapbender/resources/db/gui_admin_ows_scheduler.sql
--- trunk/mapbender/resources/db/gui_admin_ows_scheduler.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_admin_ows_scheduler.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -13,33 +13,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','slide','0','1 = effect active','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','transfer','0','1 = effect active','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','favicon','../img/favicon.png','favicon','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','includeWhileLoading','1','show splash screen while the application is loading','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
@@ -59,3 +33,4 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
Modified: trunk/mapbender/resources/db/gui_admin_wfs_metadata.sql
--- trunk/mapbender/resources/db/gui_admin_wfs_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_admin_wfs_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,50 +1,30 @@
INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wfs_metadata','admin_wfs_metadata','Administration for WFS metadata',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','center','mb_tabs_horizontal','','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','south','mb_md_wfs_submit','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','favicon','../img/favicon.png','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css','../extensions/dataTables-1.7.5/media/css/demo_table_jui.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_metadata_gml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_gml_import.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import.js','','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.7.5/media/js/jquery.dataTables.min.js,../extensions/dataTables-1.7.5/extras/TableTools-2.0.0/media/js/TableTools.min.js','','','http://www.datatables.net/');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wfs_submit.js','','','','');
@@ -61,21 +41,15 @@
]','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css','../extensions/dataTables-1.7.5/media/css/demo_table_jui.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddon',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddon.js','','','jq_ui_dialog','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddon','differentFromOriginalCss','.differentFromOriginal{
@@ -104,6 +78,7 @@
]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_select',2,1,'Select a WFS','Select WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_wfs_select.js','','','jq_datatables','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree',2,1,'Select a featuretype from a featuretype tree','Select a featuretype from a featuretype tree','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretypeTree.js','','','','');
@@ -164,7 +139,6 @@
]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_select',2,1,'Select a WFS','Select WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_wfs_select.js','','','jq_datatables','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_wfs_showOriginal.js','','','jq_ui_dialog','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal','differentFromOriginalCss','.differentFromOriginal{
@@ -193,22 +167,6 @@
]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wfs_select,mb_md_wfs_edit,mb_md_featuretype','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_tabs_horizontal','inputs','[
- "type": "id",
- "method": "select",
- "title": "Select a tab",
- "linkedTo": [
- "id": "mb_md_wfs_select",
- "event": "selected",
- "value": "mb_md_wfs_edit"
-] ','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype',3,1,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_featuretype','inputs','[
@@ -254,6 +212,22 @@
] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wfs_select,mb_md_wfs_edit,mb_md_featuretype','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_tabs_horizontal','inputs','[
+ "type": "id",
+ "method": "select",
+ "title": "Select a tab",
+ "linkedTo": [
+ "id": "mb_md_wfs_select",
+ "event": "selected",
+ "value": "mb_md_wfs_edit"
+] ','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
@@ -263,3 +237,4 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
Modified: trunk/mapbender/resources/db/gui_admin_wmc_metadata.sql
--- trunk/mapbender/resources/db/gui_admin_wmc_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_admin_wmc_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -6,33 +6,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_datatables_css','../extensions/dataTables-1.7.5/media/css/demo_table_jui.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','center','mb_tabs_horizontal','','var');
@@ -249,3 +223,4 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
Modified: trunk/mapbender/resources/db/gui_admin_wms_metadata.sql
--- trunk/mapbender/resources/db/gui_admin_wms_metadata.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/gui_admin_wms_metadata.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,7 +1,7 @@
---test svn
INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','GUI with tab, search modules',1);
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','favicon','../img/favicon.png','favicon','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
@@ -9,40 +9,12 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_datatables_css','../extensions/dataTables-1.7.5/media/css/demo_table_jui.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','css_class_bg','../css/metadataeditor.css','to define the color of the body','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,0,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.testbaudson.js','','','http://www.jstree.com/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','slippy','0','1 = Activates an animated, pseudo slippy map','var');
@@ -85,11 +57,9 @@
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL,NULL ,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','sandclock','mod_sandclock_image','../img/sandclock.gif','define a sandclock image ','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','scaleSelect',2,1,'Scale-Selectbox','Auswahl des Maßstabes','select','','',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <o
ption value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','../plugins/mb_selectScale.js','','mapframe1','','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','selArea1',2,1,'zoombox','Ausschnitt wählen','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddon.js','','','jq_ui_dialog','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon','differentFromOriginalCss','.differentFromOriginal{
@@ -202,7 +172,6 @@
] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table style=''cursor:pointer'' class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showOriginal','differentFromOriginalCss','.differentFromOriginal{
@@ -233,8 +202,11 @@
]','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Ausschnitt verschieben','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL,NULL ,'','','div','mod_sandclock.js','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','sandclock','mod_sandclock_image','../img/sandclock.gif','define a sandclock image ','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomFull',2,1,'zoom to full extent button','gesamte Karte anzeigen','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomIn1',2,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer','inputs','[
@@ -295,8 +267,6 @@
] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',4,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','inputs','[
@@ -327,12 +297,15 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','map','mapframe1','','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarLower','[''changeEPSG'',''scaleSelect'']','','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarUpper','[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_layer_preview_save'']','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','coordsLookup',10,0,'','Koordinatensuche','div','','',1000,0,NULL ,NULL,NULL ,'z-index:9999;','','div','mod_coordsLookup.php','','mapframe1','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','coordsLookup','perimeters','[50,200,1000,10000]','','var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','coordsLookup','projections','EPSG:4326;Geographic Coordinates,EPSG:31466;Gauss-Krueger 2,EPSG:31467;Gauss-Krueger 3,EPSG:31468;Gauss-Krueger 4,EPSG:31469;Gauss-Krueger 5,EPSG:25832;UTM zone 32N','','php_var');
Deleted: trunk/mapbender/resources/db/metadataGui.sql
--- trunk/mapbender/resources/db/metadataGui.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/metadataGui.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,366 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','GUI with tab, search modules',1);
--- give root access to admin_wms_metadata
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wms_metadata', 1, 'owner');
-INSERT into gui_gui_category VALUES ('admin_wms_metadata', 1);
-DELETE FROM gui_element WHERE fkey_gui_id = 'admin_wms_metadata';
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','select','','',432,25,107,24,1,'','<option value="">undefined</option>
-<option value="EPSG:4326">EPSG:4326</option>
-<option value="EPSG:31466">EPSG:31466</option>
-<option value="EPSG:31467">EPSG:31467</option>
-<option value="EPSG:31468">EPSG:31468</option>
-<option value="EPSG:31469">EPSG:31469</option>','select','mod_changeEPSG.js','','overview','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,0,'jsTree','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.testbaudson.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_layout',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'overflow:auto','','div','../plugins/mb_metadata_edit.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',4,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL ,NULL ,NULL ,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input disabled="disabled" type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_submit.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL ,NULL ,'','','div','mod_sandclock.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option valu
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'css_class_bg', 'body{ background-color: #ffffff; margin: 5 5 5 5 }
- font-family: Verdana;
- font-size: 96%;
-label {
- width: 250px;
- height: 40px;
- float: left;
-p {
- clear: both;
-input {
- font-weight: bold;
- vertical-align: top;
- width: 250px;
- height: 25px;
-fieldset {
- margin-top: 10px;
-.metadata_span {
- padding-right: 30px;
-.help-dialog {
- cursor: pointer;
-.metadata_img, .help-dialog, .original-metadata-wms {
- width: 25px;
- height: 25px;
- vertical-align: middle;
-.metadata_selectbox {
- height: 66px;
- width: 250px;
-.label_classification {
- width: 150px;
- height: 40px;
- float: left;
-div#choose {
- float: left;
- width: 35%;
- height:100%;
-position:relative;
-div#layer {
- margin-left: 35%;
- width: 65%;
-div#preview {
- padding: 5px 0px 0px 35%;
- width: 25%;
- float: left;
-div#classification {
- margin-left: 60%;
- padding-top: 5px;
- width: 40%;
-div#buttons {
- float: left;
-div#selectbox {
- margin-left: 280px;
- padding-top: 60px;
-}', 'to define the color of the body', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'favicon', '../img/favicon.png', 'favicon', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'includeWhileLoading', '', 'show splash screen while the application is loading', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'jq_datatables_css', '../extensions/dataTables-1.5/media/css/site_jui.css', 'css-file for jQuery datatables', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'jq_datatables_css_ui', '../extensions/dataTables-1.5/media/css/demo_table_jui.min.css', 'css-file for jQuery datatables', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'jq_ui_theme', '../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'body', 'use_load_message', 'true', 'show splash screen while the application is loading', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'blind', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'bounce', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'clip', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'drop', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'explode', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'fold', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'highlight', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'pulsate', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_ui_effects', 'transfer', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'jq_validate', 'css', 'label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }', '', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mapframe1', 'slippy', '0', '1 = Activates an animated, pseudo slippy map', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_edit', 'inputs', '[
- "method": "init",
- "title": "initialize",
- "linkedTo": [
- "id": "mb_md_select",
- "event": "selected",
- "attr": "wmsId"
- "method": "serialize",
- "linkedTo": [
- "id": "mb_md_submit",
- "event": "submit",
- "attr": "callback"
- "method": "fill",
- "linkedTo": [
- "id": "mb_md_showOriginal",
- "event": "replaceMetadata",
- "attr": "data"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer', 'inputs', '[
- "method": "init",
- "title": "initialize wms data",
- "linkedTo": [
- "attr": "wmsId"
- "method": "fillForm",
- "title": "initialize layer data",
- "linkedTo": [
- "id": "mb_md_layer_tree",
- "attr": "layer"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "attr": "data"
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_layer",
- "event": "initialized",
- "attr": "wmsId"
- "method":"layer",
- "title":"set the current Layer",
- "linkedTo": [
- "id":"mb_md_layer_tree",
- "event":"selected",
- "attr":"layer"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'map', 'mapframe1', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'toolbarLower', '[''changeEPSG'',''scaleSelect'']', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview', 'toolbarUpper', '[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_layer_preview_save'']', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_preview_save', 'inputs', '[
- "method":"setLayer",
- "linkedTo": [
- "attr":"layer"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_layer_tree', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "attr": "wmsId"
- "linkedTo": [
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_showOriginal', 'differentFromOriginalCss', '.differentFromOriginal{
-background-color:#FFFACD;
-}', 'css for class differentFromOriginal', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_showOriginal', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_edit",
- "event": "showOriginalMetadata",
- "attr": "data"
- "method": "initLayer",
- "linkedTo": [
- "event": "showOriginalLayerMetadata",
- "attr": "data"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_md_submit', 'inputs', '[
- "method": "enable",
- "linkedTo": [
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_pane', 'south', 'mb_md_submit', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'mb_tabs_horizontal', 'inputs', '[
- "type": "id",
- "method": "select",
- "title": "Select a tab",
- "linkedTo": [
- "value": "mb_md_edit"
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,hu,it,fr,es,pt', '', 'var');
Deleted: trunk/mapbender/resources/db/metadataGuiWfs.sql
--- trunk/mapbender/resources/db/metadataGuiWfs.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/metadataGuiWfs.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,278 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wfs_metadata','admin_wfs_metadata','GUI with tab, search modules',1);
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wfs_metadata', 1, 'owner');
-INSERT into gui_gui_category VALUES ('admin_wfs_metadata', 1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_jstree',1,1,'jsTree','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_layout',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype',3,1,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree',2,1,'Select a featuretype from a featuretype tree','Select a featuretype from a featuretype tree','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_metadata_featuretypeTree.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_edit',2,1,'Edit WFS metadata','Edit WFS metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'overflow:auto','','div','../plugins/mb_metadata_wfs_edit.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_select',2,1,'Select a WFS','Select WFS','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_wfs_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'display:none;','','div','../plugins/mb_metadata_wfs_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_submit',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wfs_submit.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wfs_select,mb_md_wfs_edit,mb_md_featuretype','jq_ui_tabs','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'css_class_bg', 'body{ background-color: #ffffff; margin: 5 5 5 5 }
- font-size: 96%;
-label {
- width: 250px;
- height: 40px;
- float: left;
-p {
- clear: both;
-input {
- width: 250px;
- height: 25px;
-.metadata_span {
-.metadata_img {
- width: 25px;
- height: 25px;
- height: 130px;
- width: 250px;
-div#choose {
- float: left;
- width: 20%;
- height:100%;
-div#layer {
- margin-left: 20%;
- width: 80%;
-div#preview {
- width: 30%;
- padding-top: 5px;
- float: left;
- margin-left: 50%;
- padding-top: 5px;
- width: 50%;
-div#save {
- margin-left: 45em;
-div#buttons {
- float: left;
-div#selectbox {
- margin-left: 312px;
- padding-top: 20px;
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'favicon', '../img/favicon.png', 'favicon', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'includeWhileLoading', '', 'show splash screen while the application is loading', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'jq_datatables_css', '../extensions/dataTables-1.5/media/css/site_jui.ccss.css', 'css-file for jQuery datatables', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'jq_datatables_css_ui', '../extensions/dataTables-1.5/media/css/demo_table_jui.min.css', 'css-file for jQuery datatables', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'jq_ui_theme', '../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css', 'UI Theme from Themeroller', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'body', 'use_load_message', 'true', 'show splash screen while the application is loading', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_datatables', 'defaultCss', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui', 'css', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '', 'file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'blind', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'bounce', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'clip', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'drop', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'explode', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'fold', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'highlight', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'pulsate', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'scale', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_ui_effects', 'transfer', '0', '1 = effect active', 'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'jq_validate', 'css', 'label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }', '', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_featuretype', 'inputs', '[
- "method": "init",
- "title": "initialize wfs data",
- "linkedTo": [
- "id": "mb_md_wfs_select",
- "attr": "wfsId"
- "title": "initialize featuretype data",
- "linkedTo": [
- "id": "mb_md_featuretype_tree",
- "attr": "featuretype"
- "linkedTo": [
- "id": "mb_md_wfs_submit",
- "method": "fill",
- "linkedTo": [
- "id": "mb_md_wfs_showOriginal",
- "attr": "data"
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_featuretype_tree', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_featuretype",
- "attr": "wfsId"
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_wfs_edit', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "attr": "wfsId"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "attr": "data"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_wfs_showOriginal', 'differentFromOriginalCss', '.differentFromOriginal{
-}', '', 'text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_wfs_showOriginal', 'inputs', '[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_wfs_edit",
- "attr": "data"
- "linkedTo": [
- "event": "showOriginalFeaturetypeMetadata",
- "attr": "data"
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_md_wfs_submit', 'inputs', '[
- "linkedTo": [
-]', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_pane', 'center', 'mb_tabs_horizontal', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_pane', 'south', 'mb_md_wfs_submit', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'mb_tabs_horizontal', 'inputs', '[
- "type": "id",
- "linkedTo": [
- "value": "mb_md_wfs_edit"
-] ', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,hu,it,fr,es,pt', '', 'var');
Deleted: trunk/mapbender/resources/db/metadataGuiWmc.sql
--- trunk/mapbender/resources/db/metadataGuiWmc.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/metadataGuiWmc.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,306 +0,0 @@
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wmc_metadata','admin_wmc_metadata','GUI with tab, search modules',1);
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wmc_metadata', 1, 'owner');
-INSERT into gui_gui_category VALUES ('admin_wmc_metadata', 1);
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wmc_submit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_submit','inputs','[
- "linkedTo": [
- "id": "mb_md_wmc_select",
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_position',1,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_jstree',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.js','','','http://www.jstree.com/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
- font-size: 96%;
-label {
- width: 250px;
- height: 40px;
- float: left;
-p {
- clear: both;
-input {
- width: 250px;
- height: 25px;
-.metadata_span {
-.metadata_img {
- width: 25px;
- height: 25px;
- height: 130px;
- width: 250px;
-div#choose {
- float: left;
- width: 20%;
- height:100%;
-div#layer {
- margin-left: 20%;
- width: 80%;
-div#preview {
- width: 30%;
- padding-top: 5px;
- float: left;
- margin-left: 50%;
- padding-top: 5px;
- width: 50%;
-div#save {
-div#buttons {
- float: left;
-div#selectbox {
-}','to define the color of the body','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','favicon','../img/favicon.ico','favicon','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.ccss.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','center','mb_tabs_horizontal','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','css','../extensions/jquery.layout.all-1.2.0/jquery.layout.css','','file/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_pane','south','mb_md_wmc_submit','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mapframe1','slippy','0','1 = Activates an animated, pseudo slippy map','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','zoomFull',2,1,'zoom to full extent button','gesamte Karte anzeigen','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL,NULL ,NULL,NULL ,'display: none;','','','../plugins/mb_metadata_saveWmcPreview.js','','mapframe1','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_preview_save','inputs','[
- "method":"setWmc",
- "title":"set the current Wmc",
- "linkedTo": [
- "id":"mb_md_wmc_select",
- "attr":"wmcId"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_wmc_showOriginal.js','','','jq_ui_dialog','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal','differentFromOriginalCss','.differentFromOriginal{
-}','','text/css');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_showOriginal','inputs','[
- "method": "init",
- "linkedTo": [
- "id": "mb_md_wmc_edit",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_edit',2,1,'Edit WMC metadata','Edit WMC metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_wmc_edit.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_edit','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wmcId"
- "linkedTo": [
- "id": "mb_md_wmc_submit",
- "method": "fill",
- "linkedTo": [
- "id": "mb_md_wmc_showOriginal",
- "attr": "data"
-]','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','loadwmc',2,1,'load workspace from WMC','laden eines Web Map Context Dokumentes','img','../img/button_blink_red/wmc_load_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'display:none;','','','mod_loadwmc.php','popup.js','mapframe1','jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables','http://www.mapbender.org/index.php/LoadWMC');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','loadwmc','deleteWmc','0','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','loadwmc','inputs','[
- "method": "load",
- "linkedTo": [
- "attr": "wmcId"
-]','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','loadwmc','publishWmc','1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','loadwmc','saveWmcTarget','savewmc','target for savewmc ','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Projektion ändern','select','','',432,25,107,24,1,'','<option value="">undefined</option>
-<option value="EPSG:4326">EPSG:4326</option>
-<option value="EPSG:31466">EPSG:31466</option>
-<option value="EPSG:31467">EPSG:31467</option>
-<option value="EPSG:31468">EPSG:31468</option>
-<option value="EPSG:31469">EPSG:31469</option>','select','mod_changeEPSG.js','','overview','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','pan1',2,1,'pan','Ausschnitt verschieben','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','selArea1',2,1,'zoombox','Ausschnitt wählen','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_select',2,1,'Select a WMC','Select WMC','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_wmc_select.js','','','jq_datatables','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','zoomIn1',2,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','scaleSelect',2,1,'Scale-Selectbox','Auswahl des Maßstabes','select','','',555,25,100,24,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <o
ption value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','../plugins/mb_selectScale.js','','mapframe1','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_featuretype',3,0,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_featuretype','inputs','[
- "method": "init",
- "linkedTo": [
- "attr": "wmcId"
- "linkedTo": [
- "method": "fill",
- "linkedTo": [
- "attr": "data"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wmc_select,mb_md_wmc_edit','jq_ui_tabs','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_tabs_horizontal','inputs','[
- "type": "id",
- "linkedTo": [
- "value": "mb_md_wmc_edit"
-] ','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','mb_md_wmc_preview',4,1,'Allows selection of a preview image of a wmc','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_preview','inputs','[
- "method": "init",
- "linkedTo": [
-]','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_preview','map','mapframe1','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_preview','toolbarLower','[''changeEPSG'',''scaleSelect'']','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','mb_md_wmc_preview','toolbarUpper','[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_wmc_preview_save'']','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wmc_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wmc_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
Deleted: trunk/mapbender/resources/db/new_role_concept.sql
--- trunk/mapbender/resources/db/new_role_concept.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/new_role_concept.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1,70 +0,0 @@
---UPDATE mb_user_mb_group set mb_user_mb_group_type = 2 where mb_user_mb_group_type = 1 ;
-UPDATE mb_user_mb_group set mb_user_mb_group_type = 1 where mb_user_mb_group_type IS NULL;
---***** new role system - should not influence the normal behaviour
--- Table: mb_role
--- DROP TABLE mb_role;
-CREATE TABLE mb_role
- role_id serial NOT NULL,
- role_name character varying(50),
- role_description character varying(255),
- role_exclude_auth integer NOT NULL DEFAULT 0,
- CONSTRAINT role_id PRIMARY KEY (role_id)
-WITH (
- OIDS=FALSE
-ALTER TABLE mb_role OWNER TO postgres;
---things to be done for mb_user_mb_group table:
---drop old constraint
---Allow to be member in a group with different roles
-ALTER TABLE mb_user_mb_group DROP CONSTRAINT pk_fkey_mb_user_mb_group_id;
-UPDATE mb_user_mb_group SET mb_user_mb_group_type = 1 WHERE mb_user_mb_group_type IS NULL OR mb_user_mb_group_type = 0;
---default to standard role
-ALTER TABLE mb_user_mb_group ALTER COLUMN mb_user_mb_group_type SET DEFAULT 1;
--- Constraint: pk_fkey_mb_user_mb_group_id
--- ALTER TABLE mb_user_mb_group DROP CONSTRAINT pk_fkey_mb_user_mb_group_id;
---create new constraint
- ADD CONSTRAINT pk_fkey_mb_user_mb_group_id PRIMARY KEY(fkey_mb_user_id, fkey_mb_group_id, mb_user_mb_group_type);
---things for the role table
---standard roles:
-INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('standard role','No special role - old behaviour.',0);
-INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('primary','Primary group for a mapbender user.',0);
-INSERT INTO mb_role (role_name,role_description,role_exclude_auth) VALUES ('metadata editor','Group for which the user can edit and publish metadata.',1);
---constraint for new role system
--- ALTER TABLE mb_user_mb_group DROP CONSTRAINT fkey_mb_user_mb_group_role_id;
- ADD CONSTRAINT fkey_mb_user_mb_group_role_id FOREIGN KEY (mb_user_mb_group_type)
- REFERENCES mb_role (role_id) MATCH SIMPLE
- ON UPDATE CASCADE ON DELETE CASCADE;
---link for admin1
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Group_User_Role',2,1,'allocate groups to user and roles','','a','','href = "../php/mod_group_user_role.php?sessionID&e_id_css=Group_User_Role" target = "AdminFrame" ',10,1234,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER -> ROLE','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'Group_User_Role', 'file css', '../css/administration_alloc.css', 'file css' ,'file/css');
---update the group for the decentral registrating institutions
--- View: registrating_groups
-CREATE OR REPLACE VIEW registrating_groups AS
- SELECT f.fkey_mb_group_id, f.fkey_mb_user_id
- FROM mb_user_mb_group f, mb_user_mb_group s
- WHERE f.mb_user_mb_group_type = 2 AND s.fkey_mb_group_id = 36 AND f.fkey_mb_user_id = s.fkey_mb_user_id
- ORDER BY f.fkey_mb_group_id, f.fkey_mb_user_id;
---*****end of role concept****
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2018-08-09 13:13:14 UTC (rev 9941)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2018-08-09 15:25:29 UTC (rev 9942)
@@ -1 +1,101 @@
UPDATE gui_element SET e_content='<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="opacity" name="opacity" value=""/> <input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><input type="hidden" name="map_svg_kml" /><input type="hidden" name="svg_extent" /><input type="hidden" name="map_svg_measures" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></f
orm><div id="printPDF_result"></div></div>' WHERE e_id='printPDF';
+--create new database content
+--geoportal specific extensions
+ALTER TABLE mb_user ADD COLUMN mb_user_glossar character varying(5);
+--ALTER TABLE mb_user ADD COLUMN mb_user_glossar character varying(14);
+--ALTER TABLE mb_user ADD COLUMN mb_user_textsize character varying(14);
+ALTER TABLE mb_user ADD COLUMN mb_user_textsize character varying(14);
+ALTER TABLE mb_user ADD COLUMN mb_user_last_login_date date;
+ALTER TABLE mb_user ADD COLUMN mb_user_spatial_suggest character varying(5);
+UPDATE gui_category SET category_name='Anwendung' WHERE category_id=2;
+UPDATE gui_category SET category_description='Anwendungen (Applications)' WHERE category_id=2;
+--add anonymous user
+INSERT INTO mb_user (mb_user_id, mb_user_name, mb_user_password, mb_user_owner, mb_user_description, mb_user_login_count, mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_organisation_name, mb_user_position_name, mb_user_phone1, mb_user_facsimile, mb_user_delivery_point, mb_user_city, mb_user_postal_code, mb_user_country, mb_user_online_resource, mb_user_textsize, mb_user_glossar, mb_user_last_login_date, mb_user_digest, mb_user_realname, mb_user_street, mb_user_housenumber, mb_user_reference, mb_user_for_attention_of, mb_user_valid_from, mb_user_valid_to, mb_user_password_ticket, mb_user_firstname, mb_user_lastname, mb_user_academictitle, timestamp_create, timestamp, mb_user_spatial_suggest, mb_user_newsletter, mb_user_allow_survey, mb_user_aldigest) VALUES (2, 'guest', '084e0343a0486ff05530df6c705c8bb4', 1, 'test', 0, 'kontakt at geoportal.rlp.de', NULL, '', 72, '', '', NULL, NULL, NULL, '', NULL, NULL, NULL, 'textsize3', 'ja', '2012-01-26', '', NULL, NUL
L, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, '2013-07-05 08:09:25.560359', '2015-08-20 10:04:04.952796', 'nein', true, true, NULL);
+INSERT INTO mb_user (mb_user_id, mb_user_name, mb_user_password, mb_user_owner, mb_user_description, mb_user_login_count, mb_user_email, mb_user_phone, mb_user_department, mb_user_resolution, mb_user_organisation_name, mb_user_position_name, mb_user_phone1, mb_user_facsimile, mb_user_delivery_point, mb_user_city, mb_user_postal_code, mb_user_country, mb_user_online_resource, mb_user_textsize, mb_user_glossar, mb_user_last_login_date, mb_user_digest, mb_user_realname, mb_user_street, mb_user_housenumber, mb_user_reference, mb_user_for_attention_of, mb_user_valid_from, mb_user_valid_to, mb_user_password_ticket, mb_user_firstname, mb_user_lastname, mb_user_academictitle, timestamp_create, timestamp, mb_user_spatial_suggest, mb_user_newsletter, mb_user_allow_survey, mb_user_aldigest) VALUES (3, 'bereichsadmin1', '3ad58afdc417b975256af7a6d3eda7a5', 1, '', 0, 'kontakt at geoportal.rlp.de', NULL, NULL, 72, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, 'nein', '2017-07-28', '3c34
5c2af80400e1e4c94ed0a967e713', NULL, NULL, NULL, NULL, NULL, NULL, NULL, '', 'bereichsadmin1', 'bereichsadmin1', '', '2013-07-05 08:09:25.560359', '2017-07-28 10:12:13.926954', 'nein', false, false, '2a32c845b23d82bea4653810f146397b');
+INSERT INTO mb_group VALUES (21, 'Bereichsadmin', 1, 'Diensteadministratoren der Behörden', '', NULL, '', '', '', '', '', '', '', '', '', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+INSERT INTO mb_group VALUES (22, 'guest', 1, 'Gastgruppe', '', NULL, '', '', '', '', '', '', '', '', '', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+INSERT INTO mb_group VALUES (23, 'testgruppe1', 1, 'testgruppe1', 'testgruppe1', NULL, 'Musterstraße 11', '11111 Musterstadt', 'Musterstadt', 'DE-RP', 'DE', '1111', '1111', 'mustermail at musterdomain.com', 'http://www.geoportal.rlp.de/metadata/GDI-RP_mit_Markenschutz_RGB_70.png', NULL, NULL, '2013-07-05 08:09:25.732456', '2018-05-25 08:57:07.988259', NULL, NULL, NULL, NULL, NULL, NULL, true);
+--guest user into guest group
+INSERT INTO mb_user_mb_group VALUES (2, 22, 1);
+--bereichsadmin1 into guest group
+INSERT INTO mb_user_mb_group VALUES (3, 22, 1);
+--bereichsadmin1 into Bereichsadmin group
+INSERT INTO mb_user_mb_group VALUES (3, 21, 1);
+--bereichsadmin1 into testgruppe1 group - role primary
+INSERT INTO mb_user_mb_group VALUES (3, 23, 2);
+--bereichsadmin1 into testgruppe1 group - role standard
+INSERT INTO mb_user_mb_group VALUES (3, 23, 1);
+--root into guest group
+INSERT INTO mb_user_mb_group VALUES (1, 22, 1);
+--guis: Geoportal-RLP, Geoportal-RLP_erwSuche2, Administration_DE, Portal_Admin, Owsproxy_csv - admin_metadata fehlt noch!!!!
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('service_container1', 'service_container1', 'service_container1', 1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('service_container1_free', 'service_container1_free', 'service_container1_free', 1);
+--guis: Geoportal-RLP, Administration_DE, Owsproxy_csv, admin_metadata, .....
+DELETE FROM gui WHERE gui_id IN ('Geoportal-RLP', 'Owsproxy_csv', 'admin_wms_metadata', 'admin_wfs_metadata', 'admin_wmc_metadata', 'admin_metadata', 'admin_ows_scheduler', 'PortalAdmin_DE', 'Administration_DE');
+--recreate them via psql
+--psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_Geoportal-RLP.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_Owsproxy_csv.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_admin_wms_metadata.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_admin_wfs_metadata.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_admin_wmc_metadata.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_admin_metadata.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_admin_ows_scheduler.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_PortalAdmin_DE.sql
+psql -d mapbender -f /home/armin/GDI-RP/devel/Geoportal/mapbender_trunk/resources/db/gui_Administration_DE.sql
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('Geoportal-RLP', 2);
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('Administration_DE', 2);
+INSERT INTO gui_gui_category (fkey_gui_id, fkey_gui_category_id) VALUES ('PortalAdmin_DE', 2);
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('PortalAdmin_DE', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Geoportal-RLP', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Administration_DE', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Owsproxy_csv', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wms_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wfs_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_wmc_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_metadata', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('admin_ows_scheduler', 1, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('service_container1', 3, 'owner');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('service_container1_free', 3, 'owner');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Administration_DE', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Owsproxy_csv', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wmc_metadata', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wms_metadata', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_wfs_metadata', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_ows_scheduler', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('admin_metadata', 21);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('Geoportal-RLP', 22);
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id) VALUES ('service_container1_free', 22);
More information about the Mapbender_commits
