[Mapbender-commits] r10004 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Fri Dec 7 06:01:10 PST 2018
Author: armin11
Date: 2018-12-07 06:01:10 -0800 (Fri, 07 Dec 2018)
New Revision: 10004
trunk/mapbender/resources/db/install_geoportal_mb28.sh
Fix for sequences and new configuration options - thanx to frank jaeger
Modified: trunk/mapbender/resources/db/install_geoportal_mb28.sh
--- trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-12-06 10:27:57 UTC (rev 10003)
+++ trunk/mapbender/resources/db/install_geoportal_mb28.sh 2018-12-07 14:01:10 UTC (rev 10004)
@@ -51,6 +51,27 @@
bbox_wgs84_space="6.05 48.9 8.6 50.96"
+# other values for configuration files - mobile viewer & atomFeedClient
+# atomFeedClient.conf / config.js - mm2_config.js
+center_x_i="385000"
+center_y_i="5543000"
+# config.js - mm2_config.js
+initial_scale_i="1500000"
+map_extent_csv=$bbox_wgs84
+if [ $use_ssl = 'true' ]; then
+ server_url="https://"$domain_name
+else
+if [ $use_ssl = 'false' ]; then
+ server_url="http://"$domain_name
+fi
+background_hybrid_tms_url="http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/topplusbkg@UTM32"
+background_aerial_wms_url="http://geo4.service24.rlp.de/wms/dop_basis.fcgi"
+# mobilemap.conf
+dhm_wms_url="http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/dhm_query/dhm.map&"
+catalogue_interface=$server_url"/mapbender/php/mod_callMetadata.php?"
+background_wms_csv="1819,1382,1635"
# default services
#wms_1_url="'http://geo4.service24.rlp.de/wms/dop_basis.fcgi?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS'"
@@ -343,6 +364,8 @@
su - postgres -c "dropdb -p $mapbender_database_port $mapbender_database_name"
su - postgres -c "createdb -p $mapbender_database_port -E UTF8 $mapbender_database_name -T template0"
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -c "DROP USER $mapbender_database_user"
sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -c "CREATE USER $mapbender_database_user WITH ENCRYPTED PASSWORD '$mapbender_database_password'"
# su -c - postgres "createlang plpgsql -d $mapbender_database_name" - not needed for debian 8+
@@ -634,6 +657,9 @@
UPDATE spatial_ref_sys SET proj4text='+proj=tmerc +lat_0=0 +lon_0=15 +k=1 +x_0=5500000 +y_0=0 +datum=potsdam +ellps=bessel +nadgrids=@BETA2007.gsb,null +units=m +no_defs' WHERE srid = 31469;
EOF
sudo -u postgres psql -q -d mapbender -f ${installation_folder}geoportal_database_proj_adaption.sql
+sudo -u postgres psql -q -p $mapbender_database_port -d $mapbender_database_name -f ${installation_folder}mapbender/resources/db/pgsql/pgsql_serial_set_sequences_2.7.sql
fi # end of installation of the mapbender database
@@ -780,7 +806,25 @@
sed -i "s#%%INSTALLATIONFOLDER%%#${installation_folder}#g" ${installation_folder}conf/extent_service_geoportal_rlp.conf
sed -i "s/%%BBOXWGS84%%/$bbox_wgs84/g" ${installation_folder}conf/extent_service_geoportal_rlp.conf
cp ${installation_folder}conf/extent_service_geoportal_rlp.conf ${installation_folder}mapbender/tools/wms_extent/extent_service.conf
-fi
+ # conf file for atomFeedClient
+ sed -i "s#%%center_x_i%%#${center_x_i}#g" ${installation_folder}conf/atomFeedClient.conf
+ sed -i "s#%%center_y_i%%#${center_y_i}#g" ${installation_folder}conf/atomFeedClient.conf
+ cp ${installation_folder}conf/atomFeedClient.conf ${installation_folder}mapbender/conf/atomFeedClient.conf
+ # conf file for mobilemap client
+ sed -i "s#%%center_x_i%%#${center_x_i}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%center_y_i%%#${center_y_i}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%initial_scale_i%%#${initial_scale_i}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%map_extent_csv%%#${map_extent_csv}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%server_url%%#${server_url}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%background_hybrid_tms_url%%#${background_hybrid_tms_url}#g" ${installation_folder}conf/config.js
+ sed -i "s#%%background_aerial_wms_url%%#${background_aerial_wms_url}#g" ${installation_folder}conf/config.js
+ cp ${installation_folder}conf/config.js ${installation_folder}mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
+ # conf file for mobilemap.conf
+ sed -i "s#%%dhm_wms_url%%#${dhm_wms_url}#g" ${installation_folder}conf/mobilemap.conf
+ sed -i "s#%%catalogue_interface%%#${catalogue_interface}#g" ${installation_folder}conf/mobilemap.conf
+ sed -i "s#%%background_wms_csv%%#${background_wms_csv}#g" ${installation_folder}conf/mobilemap.conf
+ cp ${installation_folder}conf/mobilemap.conf ${installation_folder}mapbender/conf/mobilemap.conf
if [ $checkout_custom_svn = 'true' ]; then
# override information in custom conf files
# mapbender.conf
More information about the Mapbender_commits
