[Mapbender-commits] r10014 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 14 03:01:34 PST 2018
Author: armin11
Date: 2018-12-14 03:01:33 -0800 (Fri, 14 Dec 2018)
New Revision: 10014
   trunk/mapbender/http/php/mod_mobileClientQr.php
allow invocation from other path
Modified: trunk/mapbender/http/php/mod_mobileClientQr.php
--- trunk/mapbender/http/php/mod_mobileClientQr.php	2018-12-14 08:19:16 UTC (rev 10013)
+++ trunk/mapbender/http/php/mod_mobileClientQr.php	2018-12-14 11:01:33 UTC (rev 10014)
@@ -17,6 +17,18 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once dirname(__FILE__) . "/../../core/globalSettings.php";
 require_once dirname(__FILE__) . "/../extensions/phpqrcode/phpqrcode.php";
+$pathExtension = "";
+if (isset($_REQUEST["pathExtension"]) & $_REQUEST["pathExtension"] != "") {
+	//validate to de, en, fr
+	$testMatch = $_REQUEST["pathExtension"];
+ 	if (!($testMatch == '../../mapbender/tmp/' or $testMatch == '../mapbender/tmp/')){
+		//echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>pathExtension</b> is not valid ("../../mapbender/tmp/","../mapbender/tmp/").<br/>';
+		die();
+	$pathExtension = $testMatch;
+	$testMatch = NULL;
 $filename = "qr_mobileclient.png";
 //generate qr on the fly in tmp folder
 //link to invoke wmc per get api if wrapper path isset
@@ -23,7 +35,7 @@
 if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != "") {
     $invokeLink = MAPBENDER_PATH."/extensions/mobilemap2/index.html";
     QRcode::png($invokeLink,TMPDIR."/".$filename);
-    $htmlElement = "<a href = '".$invokeLink."'><img src='".TMPDIR."/".$filename."'></a>";
+    $htmlElement = "<a href = '".$invokeLink."'><img src='$pathExtension".TMPDIR."/".$filename."'></a>";
 } else {
     echo "MAPBENDER_PATH not defined in mapbender.conf - please define it to activate linkage and qr code!";
     die();
More information about the Mapbender_commits mailing list
