[Mapbender-commits] r10015 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Fri Dec 14 03:52:12 PST 2018
Author: armin11
Date: 2018-12-14 03:52:12 -0800 (Fri, 14 Dec 2018)
New Revision: 10015
   trunk/mapbender/http/php/mod_mobileClientQr.php
some more functions
Modified: trunk/mapbender/http/php/mod_mobileClientQr.php
--- trunk/mapbender/http/php/mod_mobileClientQr.php	2018-12-14 11:01:33 UTC (rev 10014)
+++ trunk/mapbender/http/php/mod_mobileClientQr.php	2018-12-14 11:52:12 UTC (rev 10015)
@@ -18,6 +18,7 @@
 require_once dirname(__FILE__) . "/../../core/globalSettings.php";
 require_once dirname(__FILE__) . "/../extensions/phpqrcode/phpqrcode.php";
 $pathExtension = "";
+$return = "default";
 if (isset($_REQUEST["pathExtension"]) & $_REQUEST["pathExtension"] != "") {
 	//validate to de, en, fr
 	$testMatch = $_REQUEST["pathExtension"];
@@ -29,6 +30,18 @@
 	$pathExtension = $testMatch;
 	$testMatch = NULL;
+if (isset($_REQUEST["return"]) & $_REQUEST["return"] != "") {
+	//validate to de, en, fr
+	$testMatch = $_REQUEST["return"];
+ 	if (!($testMatch == 'applicationlink' or $testMatch == 'imagelink')){
+		//echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>return</b> is not valid ("applicationlink","imagelink").<br/>';
+		die();
+	$return = $testMatch;
+	$testMatch = NULL;
 $filename = "qr_mobileclient.png";
 //generate qr on the fly in tmp folder
 //link to invoke wmc per get api if wrapper path isset
@@ -35,11 +48,24 @@
 if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != "") {
     $invokeLink = MAPBENDER_PATH."/extensions/mobilemap2/index.html";
     QRcode::png($invokeLink,TMPDIR."/".$filename);
-    $htmlElement = "<a href = '".$invokeLink."'><img src='$pathExtension".TMPDIR."/".$filename."'></a>";
+    $htmlElement = "<a href='".$invokeLink."' target='_blank'><img src='$pathExtension".TMPDIR."/".$filename."'></a>";
 } else {
     echo "MAPBENDER_PATH not defined in mapbender.conf - please define it to activate linkage and qr code!";
     die();
+switch ($return) {
+    case "imagelink":
+        echo $pathExtension.TMPDIR."/".$filename;
+        break;
+    case "applicationlink":
+        echo $invokeLink;
+        break;
+    case "default":
+        echo $htmlElement;
+        break;
 //echo html image tag with link to mobile client
-echo $htmlElement;
+//echo $htmlElement;
More information about the Mapbender_commits
