[Mapbender-commits] r10232 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Fri Aug 30 04:02:38 PDT 2019
Author: armin11
Date: 2019-08-30 04:02:38 -0700 (Fri, 30 Aug 2019)
New Revision: 10232
   trunk/mapbender/http/classes/class_syncCkan.php
Rewind new resource view
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php	2019-08-30 10:56:56 UTC (rev 10231)
+++ trunk/mapbender/http/classes/class_syncCkan.php	2019-08-30 11:02:38 UTC (rev 10232)
@@ -1547,7 +1547,7 @@
 		    // add new linked open data proxy uri if wfs is classified open data!
-		    $sql = "SELECT * FROM (SELECT wfs_id, wfs_version FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id AND wfs_id = $1) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
+		    /*$sql = "SELECT * FROM (SELECT wfs_id, wfs_version FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id AND wfs_id = $1) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
     		    $v = array($option->serviceId);
     		    $t = array($i);
     		    $res = db_prep_query($sql, $v, $t);
@@ -1584,6 +1584,7 @@
 		            $viewArray[$indexViewArray]['json'] = json_encode($viewJson);
 		            $indexViewArray++;
                     break;
                 case "downloadlink":
More information about the Mapbender_commits
