[Mapbender-commits] r10233 - in trunk/mapbender/http: classes php plugins
svn_mapbender at osgeo.org
Fri Aug 30 05:33:32 PDT 2019
Author: armin11
Date: 2019-08-30 05:33:32 -0700 (Fri, 30 Aug 2019)
New Revision: 10233
trunk/mapbender/http/classes/class_syncCkan.php
trunk/mapbender/http/php/mod_linkedDataProxy.php
trunk/mapbender/http/plugins/mb_button.js
Fix export of linkedopendata client to ckan and mapviewer position on item page
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php 2019-08-30 11:02:38 UTC (rev 10232)
+++ trunk/mapbender/http/classes/class_syncCkan.php 2019-08-30 12:33:32 UTC (rev 10233)
@@ -1482,7 +1482,7 @@
//for INSPIRE ATOM Feed implementations
- //$e = new mb_exception("Download options for: ".$metadataUuid);
+ //$e = new mb_exception("Download options for: ".$metadataUuid);
$downloadOptionsMetadataArray = array();
$downloadOptionsMetadataArray[0] = $metadataUuid;
$downloadOptionsJson = getDownloadOptions($downloadOptionsMetadataArray);
@@ -1547,7 +1547,7 @@
// add new linked open data proxy uri if wfs is classified open data!
- /*$sql = "SELECT * FROM (SELECT wfs_id, wfs_version FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id AND wfs_id = $1) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
+ $sql = "SELECT * FROM (SELECT wfs_id, wfs_version, fkey_termsofuse_id FROM wfs INNER JOIN wfs_termsofuse ON wfs_id = fkey_wfs_id AND wfs_id = $1) AS wfs_tou INNER JOIN termsofuse ON fkey_termsofuse_id = termsofuse_id WHERE isopen = 1";
$v = array($option->serviceId);
$t = array($i);
$res = db_prep_query($sql, $v, $t);
@@ -1584,7 +1584,7 @@
$viewArray[$indexViewArray]['json'] = json_encode($viewJson);
$indexViewArray++;
break;
case "downloadlink":
Modified: trunk/mapbender/http/php/mod_linkedDataProxy.php
--- trunk/mapbender/http/php/mod_linkedDataProxy.php 2019-08-30 11:02:38 UTC (rev 10232)
+++ trunk/mapbender/http/php/mod_linkedDataProxy.php 2019-08-30 12:33:32 UTC (rev 10233)
@@ -296,6 +296,7 @@
if ($i == 0) {
$returnObject->success = false;
$returnObject->message = "No services found in registry";
+ //$e = new mb_exception("no wfs found");
} else {
$returnObject->success = true;
$returnObject->message = "Services found in registry!";
@@ -1438,7 +1439,7 @@
$html .= '</div>'.$newline;
if ($map_position == "below_filter") {
- $html .= '<div id= "map"></div>'.$newline;
+ $html .= '<div id="map"></div>'.$newline;
//Navigation elements
@@ -1508,6 +1509,9 @@
$html .= $nav;
} else {
//only one feature is found!
+ if ($map_position == "below_filter") {
$feature = $returnObject;
$html .= ' <div itemscope itemtype="http://schema.org/Place">'.$newline;
$html .= ' <h1 itemprop="name">'.$feature->id.'</h1>'.$newline;
Modified: trunk/mapbender/http/plugins/mb_button.js
--- trunk/mapbender/http/plugins/mb_button.js 2019-08-30 11:02:38 UTC (rev 10232)
+++ trunk/mapbender/http/plugins/mb_button.js 2019-08-30 12:33:32 UTC (rev 10233)
@@ -69,6 +69,7 @@
var openDialog = function () {
+alert("try to open dialog: o.target: "+JSON.stringify(o));
dialog.dialog("open");
dialog.dialog({ height: options.dialogHeight });
dialog.dialog({ width: options.dialogWidth });
More information about the Mapbender_commits
