[Mapbender-commits] r10061 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Fri Feb 22 00:43:22 PST 2019
Author: armin11
Date: 2019-02-22 00:43:22 -0800 (Fri, 22 Feb 2019)
New Revision: 10061
Added:
trunk/mapbender/resources/db/materialize_wmc_view.sql
New sql to make search for wmc faster ;-)
Added: trunk/mapbender/resources/db/materialize_wmc_view.sql
--- trunk/mapbender/resources/db/materialize_wmc_view.sql (rev 0)
+++ trunk/mapbender/resources/db/materialize_wmc_view.sql 2019-02-22 08:43:22 UTC (rev 10061)
@@ -0,0 +1,79 @@
+DROP TABLE IF EXISTS wmc_search_table_tmp;
+select * into wmc_search_table_tmp from search_wmc_view;
+DROP TABLE IF EXISTS wmc_search_table;
+ALTER TABLE wmc_search_table_tmp RENAME TO wmc_search_table;
+UPDATE wmc_search_table SET load_count=0 WHERE load_count is NULL;
+-- Index: gist_wst_wmc_the_geom
+-- DROP INDEX gist_wst_wmc_the_geom;
+CREATE INDEX gist_wst_wmc_the_geom
+ ON wmc_search_table
+ USING gist
+ (the_geom);
+-- Index: idx_wst_wmc_searchtext
+-- DROP INDEX idx_wst_wmc_searchtext;
+CREATE INDEX idx_wst_wmc_searchtext
+ USING btree
+ (searchtext);
+-- Index: idx_wst_wmc_department
+-- DROP INDEX idx_wst_wmc_department;
+CREATE INDEX idx_wst_wmc_department
+ USING btree
+ (department);
+-- Index: idx_wst_wmc_md_topic_cats
+-- DROP INDEX idx_wst_wmc_md_topic_cats;
+CREATE INDEX idx_wst_wmc_md_topic_cats
+ USING btree
+ (md_topic_cats);
+-- DROP INDEX idx_wst_wmc_wmc_id;
+CREATE INDEX idx_wst_wmc_wmc_id
+ USING btree
+ (wmc_id);
+-- Index: idx_wst_wmc_md_inspire_cats
+-- DROP INDEX idx_wst_wmc_md_inspire_cats;
+CREATE INDEX idx_wst_wmc_md_inspire_cats
+ USING btree
+ (md_inspire_cats);
+-- Index: idx_wst_wmc_md_custom_cats
+-- DROP INDEX idx_wst_wmc_md_custom_cats;
+CREATE INDEX idx_wst_wmc_md_custom_cats
+ USING btree
+ (md_custom_cats);
+CREATE INDEX idx_wst_wmc_timestamp
+ USING btree
+ (wmc_timestamp);
More information about the Mapbender_commits
