[Mapbender-commits] r10062 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri Feb 22 00:43:42 PST 2019
Author: armin11
Date: 2019-02-22 00:43:42 -0800 (Fri, 22 Feb 2019)
New Revision: 10062
trunk/mapbender/http/php/mod_catalogueMaintenance.php
trunk/mapbender/http/php/mod_catalogueMaintenance_server.php
New options to make search for wmc faster ;-)
Modified: trunk/mapbender/http/php/mod_catalogueMaintenance.php
--- trunk/mapbender/http/php/mod_catalogueMaintenance.php 2019-02-22 08:43:22 UTC (rev 10061)
+++ trunk/mapbender/http/php/mod_catalogueMaintenance.php 2019-02-22 08:43:42 UTC (rev 10062)
@@ -23,8 +23,8 @@
//validate parameter values
if (isset($_REQUEST["resourceType"]) & $_REQUEST["resourceType"] != "") {
$testMatch = $_REQUEST["resourceType"];
- if (!($testMatch == 'wms' or $testMatch == 'wfs' or $testMatch == 'dataset')){
- echo 'Parameter <b>resourceType</b> is not valid (wms, wfs, dataset).<br/>';
+ if (!($testMatch == 'wms' or $testMatch == 'wfs' or $testMatch == 'dataset' or $testMatch == 'wmc')){
+ echo 'Parameter <b>resourceType</b> is not valid (wms, wfs, dataset, wmc).<br/>';
die();
$resourceType = $testMatch;
@@ -57,7 +57,8 @@
$allowedFunctions = array(
'wms' => array('reindex','monitor'),
'wfs' => array('reindex'),
- 'dataset' => array('reindex')
+ 'dataset' => array('reindex'),
+ 'wmc' => array('reindex')
$functionThatNeedIdList = array('monitor');
@@ -101,6 +102,9 @@
case "dataset":
$title .= _mb('Dataset(s)');
break;
+ case "wmc":
+ $title .= _mb('WebMapContext Document(s)');
+ break;
echo $title;
@@ -116,8 +120,11 @@
$sqlCount = "SELECT count(featuretype_id) from wfs_featuretype WHERE featuretype_searchable = 1;";
break;
case "dataset":
- $sqlCount = "SELECT count(metadata_id) from mb_metadata;";
+ $sqlCount = "SELECT count(metadata_id) from mb_metadata WHERE searchable;";
break;
+ case "wmc":
+ $sqlCount = "SELECT count(wmc_serial_id) from mb_user_wmc WHERE wmc_public = 1;";
+ break;
$resCount = db_query($sqlCount);
if (!$resCount) {
Modified: trunk/mapbender/http/php/mod_catalogueMaintenance_server.php
--- trunk/mapbender/http/php/mod_catalogueMaintenance_server.php 2019-02-22 08:43:22 UTC (rev 10061)
+++ trunk/mapbender/http/php/mod_catalogueMaintenance_server.php 2019-02-22 08:43:42 UTC (rev 10062)
@@ -34,9 +34,9 @@
$resultObj['success'] = false;
- $resultObj['message'] = "Parameter <b>resourceType</b> is not valid (wms, wfs, dataset).<br/>";
+ $resultObj['message'] = "Parameter <b>resourceType</b> is not valid (wms, wfs, dataset, wmc).<br/>";
echo json_encode($resultObj);
die();
@@ -80,7 +80,8 @@
More information about the Mapbender_commits
