[Mapbender-commits] r10146 - trunk/mapbender/http_auth/http
svn_mapbender at osgeo.org
Wed Jun 12 06:39:52 PDT 2019
Author: armin11
Date: 2019-06-12 06:39:52 -0700 (Wed, 12 Jun 2019)
New Revision: 10146
trunk/mapbender/http_auth/http/index.php
further fix from simon.seyock - thanx
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php 2019-06-07 13:52:24 UTC (rev 10145)
+++ trunk/mapbender/http_auth/http/index.php 2019-06-12 13:39:52 UTC (rev 10146)
@@ -707,7 +707,7 @@
* @param string the original url of the image to send
-function getImage($log_id, $or)
+function getImage($log_id, $or, $auth = false)
global $reqParams;
global $imageformats;
@@ -716,8 +716,7 @@
} else {
$header = "Content-Type: ".$reqParams['format'];
- if (func_num_args() == 3) { //new for HTTP Authentication
- $auth = func_get_arg(2);
+ if ($auth) { //new for HTTP Authentication
//$e = new mb_exception("try to get: ". $or);
getDocumentContent($log_id, $or, $header, $auth);
} else {
@@ -732,13 +731,12 @@
* @param string the url of the FeatureInfoRequest
* @return string the content of the FeatureInfo document
-function getFeatureInfo($log_id, $url)
+function getFeatureInfo($log_id, $url, $auth = false)
global $reqParams;
//$e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: " . $url);
//header("Content-Type: " . $reqParams['info_format']);
getDocumentContent($log_id, $url, false, $auth);
} else {
getDocumentContent($log_id, $url);
@@ -1008,13 +1006,12 @@
return $id;
-function getCapabilities($request, $requestFull, $extraParameter)
+function getCapabilities($request, $requestFull, $extraParameter, $auth = false)
global $arrayOnlineresources;
global $layerId;
header("Content-Type: application/xml");
- if (func_num_args() == 4) { //new for HTTP Authentication
- $auth = func_get_arg(3);
$d = new connector($requestFull, $auth);
} else {
$d = new connector($requestFull);
@@ -1162,18 +1159,17 @@
$new = $owsproxyUrl['scheme'] . "://" .$owsproxyUrl['host']. $port . "/registry/wfs/" . $wfsId;# ."?";
if ($extraParameter !== false) {
- $new .= '?'.$extraParameter;
- //force https if authType is basic!
- $new = str_replace("http://", "https://", $new);
- if ($postData == false) {
- $d = new connector($request, $auth);
- } else {
- $d = new connector($request);
- $wfsCaps = $d->file;
+ $new .= '?'.$extraParameter;
+ //force https if authType is basic!
+ $new = str_replace("http://", "https://", $new);
+ if ($postData == false) {
+ $d = new connector($request, true);
+ } else {
+ $d = new connector($request);
+ $wfsCaps = $d->file;
} else {
//$e = new mb_exception("owsproxy/index.php: postData will be send: ".$postData);
$postInterfaceObject = new connector();
@@ -1181,8 +1177,7 @@
$postInterfaceObject->set('curlSendCustomHeaders',true);
$postInterfaceObject->set('httpPostData', $postData);
$postInterfaceObject->set('httpContentType','text/xml');
$postInterfaceObject->load($request, $auth);
} else {
$postInterfaceObject->load($request);
@@ -1510,14 +1505,13 @@
return $ret;
-function getDocumentContent($log_id, $url, $header = false)
+function getDocumentContent($log_id, $url, $header = false, $auth = false)
global $reqParams, $n, $postData;
//debug
$startTime = microtime();
$d = new connector($url, $auth);
} else {
$d = new connector($url);
@@ -1530,8 +1524,7 @@
$postInterfaceObject->load($url, $auth);
} else {
$postInterfaceObject->load($url);
More information about the Mapbender_commits
