[Mapbender-commits] r10119 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri May 10 04:08:21 PDT 2019
Author: armin11
Date: 2019-05-10 04:08:21 -0700 (Fri, 10 May 2019)
New Revision: 10119
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
New fields for more secure password hashing !
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2019-05-10 11:05:44 UTC (rev 10118)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2019-05-10 11:08:21 UTC (rev 10119)
@@ -2603,4 +2603,16 @@
ALTER FUNCTION f_get_layer_featuretype_coupling(INT[], boolean)
OWNER TO postgres;
+--add new fields for better password hashing
+ALTER TABLE mb_user ADD COLUMN salt character varying(100);
+ALTER TABLE mb_user ADD COLUMN password character varying(255);
+ALTER TABLE mb_user ADD COLUMN is_active boolean;
+ALTER TABLE mb_user ADD COLUMN activation_key character varying(255);
+ALTER TABLE mb_user ADD COLUMN timestamp_delete bigint;
+ALTER TABLE mb_user ADD COLUMN timestamp_dsgvo_accepted bigint;
More information about the Mapbender_commits
