[Mapbender-commits] r10120 - trunk/mapbender/tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 10 05:52:33 PDT 2019
Author: armin11
Date: 2019-05-10 05:52:32 -0700 (Fri, 10 May 2019)
New Revision: 10120
   trunk/mapbender/tools/mod_runScheduler.php
Fix for wms update scheduler with authenticated wms
Modified: trunk/mapbender/tools/mod_runScheduler.php
--- trunk/mapbender/tools/mod_runScheduler.php	2019-05-10 11:08:21 UTC (rev 10119)
+++ trunk/mapbender/tools/mod_runScheduler.php	2019-05-10 12:52:32 UTC (rev 10120)
@@ -3,9 +3,9 @@
 require_once(dirname(__FILE__)."/../http/classes/class_wms.php");
 $sql = <<<SQL
-SELECT scheduler_id, wms_id, wms_title, to_timestamp(wms_timestamp)::date AS last_change, last_status, fkey_upload_id, wms_upload_url,
+SELECT scheduler_id, wms_id, wms_title, wms_auth_type, wms_username, wms_password, to_timestamp(wms_timestamp)::date AS last_change, last_status, fkey_upload_id, wms_upload_url,
 scheduler_interval,scheduler_mail,wms_owner,scheduler_publish,scheduler_searchable,scheduler_overwrite, scheduler_overwrite_categories,
-scheduler_status FROM (SELECT scheduler_id, wms_id, fkey_wms_id, wms_title, wms_timestamp, wms_owner,
+scheduler_status FROM (SELECT scheduler_id, wms_id, fkey_wms_id, wms_title, wms_timestamp, wms_owner, wms_auth_type, wms_username, wms_password,
 scheduler_interval,scheduler_mail,scheduler_publish,scheduler_searchable,scheduler_overwrite,scheduler_overwrite_categories,
 scheduler_status,wms_upload_url FROM scheduler
 INNER JOIN wms ON scheduler.fkey_wms_id=wms.wms_id ) AS test
@@ -32,9 +32,14 @@
 	   	"scheduler_searchable"  =>  $row['scheduler_searchable'],
 		"scheduler_overwrite"  =>  $row['scheduler_overwrite'],
 		"scheduler_overwrite_categories"  =>  $row['scheduler_overwrite_categories'],
-	   	"scheduler_status"  =>  $row['scheduler_status']
+	   	"scheduler_status"  =>  $row['scheduler_status'],
+	   	"wms_auth_type"  =>  $row['wms_auth_type'],
+	   	"wms_username"  =>  $row['wms_username'],
+	   	"wms_password"  =>  $row['wms_password']
+	//echo json_encode($resultObj)."\n";
 	if($row['scheduler_interval'] == '1 mon') {
 	    $row['scheduler_interval'] = "1 month";
@@ -46,9 +51,10 @@
     	$schedulerDateMonitoring = date("Y-m-d",strtotime(date("Y-m-d", $row['fkey_upload_id']) . $row['scheduler_interval']));
     	//if calculated $schedulerDateTimestamp is in the past
-    	//or last_status value of monitoring does not have the value 1 which means wms has been updated by monitoring
+    	//or last_status value of monitoring does not have the value 1 which means wms has changed!
     	if($currentDate >= $schedulerDateTimestamp) {
         	if ($row['last_status'] == 1) {
+			//nothing to change!!!!
             		if($currentDate >= $schedulerDateMonitoring) {
                 		array_push($wmsToUpdate, $resultObj);
@@ -56,8 +62,9 @@
     	} else {
-        	if ($row['last_status'] == 0) {
-            	array_push($wmsToUpdate, $resultObj);
+		//if service is not up to date
+        	if ($row['last_status'] == 0 || $row['last_status'] == -1 || $row['last_status'] == -2) {
+            		array_push($wmsToUpdate, $resultObj);
@@ -69,10 +76,25 @@
 die();*/
 for ($i=0; $i<count($wmsToUpdate); $i++) {
     	//create new wms object
+	echo "\nTry to call wms ".$wmsToUpdate[$i]['wms_id']."\n";
+	//echo "auth_type:  ".$wmsToUpdate[$i]['wms_auth_type']."\n";
+	//echo "auth_username:  ".$wmsToUpdate[$i]['wms_username']."\n";
+	//echo "auth_password:  ".$wmsToUpdate[$i]['wms_password']."\n";
     	$updateWms = new wms();
         $updateWms->harvestCoupledDatasetMetadata = true;
+	//check for authentication!
+	$auth = null;
 	try {
-    		$createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
+		if ($wmsToUpdate[$i]['wms_auth_type'] == "basic" || $wmsToUpdate[$i]['wms_auth_type'] == "digest"){
+			//echo "call with auth array!"."\n";
+			$auth = array();
+			$auth['auth_type'] = $wmsToUpdate[$i]['wms_auth_type'];
+			$auth['username'] = $wmsToUpdate[$i]['wms_username'];
+			$auth['password'] = $wmsToUpdate[$i]['wms_password'];
+			$createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url'], $auth);
+		} else {
+    			$createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
 	catch(Exception $e) {
   		throw $e;
More information about the Mapbender_commits mailing list
