[Mapbender-commits] r10353 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 22 04:36:31 PST 2019
Author: armin11
Date: 2019-11-22 04:36:30 -0800 (Fri, 22 Nov 2019)
New Revision: 10353
   trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
Fix for loading wmc from metadataCarouselTinySlider - also loads the wfs_conf elements
Modified: trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
--- trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php	2019-11-22 10:19:26 UTC (rev 10352)
+++ trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php	2019-11-22 12:36:30 UTC (rev 10353)
@@ -201,6 +201,7 @@
     this.fillInitialMetadata = function() {
         //initialize slider from first request to search interface
         var initialResult = $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&maxResults="+maxResults+that.resourceFilterString, async: false, success: function(result){
+	//var initialResult = $.ajax({url: searchUrl+"searchText=*&searchResources=wmc&maxResults="+maxResults+that.resourceFilterString, async: true, success: function(result){
             if (result.valid)
                 return true;
             else
@@ -258,7 +259,10 @@
     this.removeEvent = function(){
         that.mainSlider.events.off('indexChanged', that.customizedFunction);
+    //wait some time?
+    //setTimeout(that.fillInitialMetadata(), 3000);
+        //workaround
+	var kml = $('#mapframe1').data('kml');
     that.fillInitialMetadata();
     that.addEvent();
@@ -314,10 +318,27 @@
                                                             // just ignore the exception for now
-							that.events.loaded.trigger({
-								extensionData: restoredWmcExtensionData
+						    //following will not work, because event is not defined here
+						    //that.events.loaded.trigger({
+						    //		extensionData: restoredWmcExtensionData
+                                                //following copied from wfsConTree.js - because there it is only called via loadwmc module, which is not available in new GUI types (>2019 fullcreen with new layout. wfsConfTree.js / wfsConfTree_single.js triggers the loadwmc module!)
+						/*load wfs confs via ajax*/
+                                                if (restoredWmcExtensionData && restoredWmcExtensionData.WFSCONFIDSTRING) {
+							var req = Mapbender.Ajax.Request({
+								url: 	"../php/mod_wfs_conf_server.php",
+								method:	"getWfsConfsFromId",
+								parameters: {
+									wfsConfIdString: restoredWmcExtensionData.WFSCONFIDSTRING
+								callback: function(result,success,message){
+									//reset(result);
+							req.send();
+                                                /*end load wfs confs via ajax*/
 					that.hide();
 					new Mapbender.Notice(args.message);
@@ -331,6 +352,8 @@
 //register object in mapbender!
 Mapbender.events.init.register(function() {
     Mapbender.modules[options.id] = $.extend(new metadataCarouselTinySlider(),Mapbender.modules[options.id]);
More information about the Mapbender_commits mailing list
