[Mapbender-commits] r10354 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Nov 22 05:37:01 PST 2019
Author: armin11
Date: 2019-11-22 05:37:00 -0800 (Fri, 22 Nov 2019)
New Revision: 10354
trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
trunk/mapbender/http/plugins/wfsConfTree.js
trunk/mapbender/http/plugins/wfsConfTree_single.js
Fix for loading wfs_conf dynamically, if wmc is loaded from new module metadataCarouselTinySlider.
Modified: trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php
--- trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php 2019-11-22 12:36:30 UTC (rev 10353)
+++ trunk/mapbender/http/plugins/mod_metadataCarouselTinySlider.php 2019-11-22 13:37:00 UTC (rev 10354)
@@ -140,6 +140,12 @@
//hide during initialization
//$('#' + options.id).hide();
+ //add event for loaded wmc like done in javascripts/mod_loadwmc.js
+ /*this.events = {
+ loaded: new Mapbender.Event()
//add 3 dummy slides to container identified by class dummy
this.sliderContainer.append('<div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 1</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div><div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 2</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div><div class="slider-item dummy"><div class="card"><img src="https://www.geoportal.rlp.de/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=2506" alt=""><h2>Titel 3</h2><p class="card_description">Loresm ipsum dolor sit amet consectetur adipisicing elit. Dignissimos, voluptas!</p></div></div>');
@@ -321,7 +327,7 @@
//following will not work, because event is not defined here
//that.events.loaded.trigger({
// extensionData: restoredWmcExtensionData
//following copied from wfsConTree.js - because there it is only called via loadwmc module, which is not available in new GUI types (>2019 fullcreen with new layout. wfsConfTree.js / wfsConfTree_single.js triggers the loadwmc module!)
/*load wfs confs via ajax*/
if (restoredWmcExtensionData && restoredWmcExtensionData.WFSCONFIDSTRING) {
@@ -332,7 +338,11 @@
wfsConfIdString: restoredWmcExtensionData.WFSCONFIDSTRING
callback: function(result,success,message){
- //reset(result);
+ //alert("try to reset wfsConfTree");
+ //alert(JSON.stringify(Mapbender.modules.wfsConfTree));
+ if (Mapbender.modules.wfsConfTree) {
+ Mapbender.modules.wfsConfTree.reset(result);
req.send();
Modified: trunk/mapbender/http/plugins/wfsConfTree.js
--- trunk/mapbender/http/plugins/wfsConfTree.js 2019-11-22 12:36:30 UTC (rev 10353)
+++ trunk/mapbender/http/plugins/wfsConfTree.js 2019-11-22 13:37:00 UTC (rev 10354)
@@ -42,7 +42,7 @@
wfsConfIdString: obj.extensionData.WFSCONFIDSTRING
- reset(result);
+ that.reset(result);
req.send();
@@ -69,7 +69,7 @@
- var reset = function(aWFSConf){
+ this.reset = function(aWFSConf){
wfsconfs = [];
$confTree.children().remove();
$confTree.append("<li class='emptymessage'>"+translatedI18nObject.labelNoWfsConfAvailable+"</li>");
@@ -162,7 +162,7 @@
newWFSConf.push(currentWFSConf[i]);
- reset(newWFSConf);
+ that.reset(newWFSConf);
@@ -184,7 +184,7 @@
wfsConfIdString: wfsConfIdString
- reset(result);
req.send();
@@ -201,7 +201,7 @@
wfsConfIdString: obj.wfsConfIdString
- reset(result);
req.send();
Modified: trunk/mapbender/http/plugins/wfsConfTree_single.js
--- trunk/mapbender/http/plugins/wfsConfTree_single.js 2019-11-22 12:36:30 UTC (rev 10353)
+++ trunk/mapbender/http/plugins/wfsConfTree_single.js 2019-11-22 13:37:00 UTC (rev 10354)
@@ -42,7 +42,7 @@
- reset(result);
req.send();
@@ -66,7 +66,7 @@
wfsconfs = [];
@@ -161,7 +161,7 @@
@@ -183,7 +183,7 @@
- reset(result);
req.send();
@@ -200,7 +200,7 @@
- reset(result);
req.send();
More information about the Mapbender_commits
