[Mapbender-commits] r10311 - trunk/mapbender/tools
    svn_mapbender at osgeo.org
    Wed Oct 30 06:32:24 PDT 2019
Author: armin11
Date: 2019-10-30 06:32:22 -0700 (Wed, 30 Oct 2019)
New Revision: 10311
Added:
   trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php
Script to add uuids to exported metadata xml documents and add some special keyword for inspire spatial scope:
https://webgate.ec.europa.eu/fpfis/wikis/display/InspireMIG/Spatial+scope+code+list
Added: trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php
--- trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php	                        (rev 0)
+++ trunk/mapbender/tools/mod_qualifyPersistedMetadataXml.php	2019-10-30 13:32:22 UTC (rev 10311)
@@ -0,0 +1,219 @@
+<?php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../http/classes/class_iso19139.php");
+require_once(dirname(__FILE__) . "/../http/classes/class_Uuid.php");
+$startTimeForAll = microtime(true);
+$metadataClass = new Iso19139();
+$injectRegistryUuid = false;
+$metadataDir = str_replace("../../", "../", METADATA_DIR);
+if (defined("MAPBENDER_REGISTRY_UUID") && MAPBENDER_REGISTRY_UUID != "") {
+    $uuid = new Uuid(MAPBENDER_REGISTRY_UUID);
+    $injectRegistryUuid = $uuid->isValid();
+$numberOfFile = 0;
+if ($handle = opendir($metadataDir)) {
+    //echo "Read files from temporary metadata folder:<br>";
+    /* This is the correct way to loop over the directory. */
+    while (false !== ($file = readdir($handle))) {
+        $startTime = microtime(true);
+        //check if file name begin with "mapbender";
+        $pos = strpos($file, "mapbender");
+        if ($pos !== false) {
+            //delete file with unlink
+            //unlink($metadataDir."/".$file);
+            //echo filesize($metadataDir."/".$file)."<br>";
+            //read with class Iso19139()
+            $h = fopen($metadataDir."/".$file, "r");
+            $newKeywordsIndex = 0;
+            logMessages($metadataDir."/".$file);
+            if (filesize($metadataDir."/".$file) != 0) {
+                $metadataXml = fread($h, filesize($metadataDir."/".$file));
+		$metadataObject = $metadataClass->createMapbenderMetadataFromXML($metadataXml);
+		logMessages("fileIdentifier: ".$metadataObject->fileIdentifier);
+		logMessages("type: ".$metadataObject->hierarchyLevel);
+		if (in_array('inspireidentifiziert', $metadataObject->keywords) && !in_array('Regional', $metadataObject->keywords) && $metadataObject->hierarchyLevel == 'dataset') {
+		    //echo $metadataObject->title."<br>";
+                    //echo $metadataDir."/".$file." has keyword inspireidentifiziert!<br>";
+		    $keywordsArray[$newKeywordsIndex]->keyword = "Regional";
+		    $keywordsArray[$newKeywordsIndex]->thesaurusTitle = "Spatial scope";
+		    $keywordsArray[$newKeywordsIndex]->thesaurusPubDate = "2019-05-22";
+		    /*$newKeywordsIndex++;
+		    $keywordsArray[$newKeywordsIndex]->keyword = "Regional1";
+		    $keywordsArray[$newKeywordsIndex]->thesaurusTitle = "Spatial scope1";
+                    $e = new mb_exception("test3");*/
+logMessages("Actual keywords: ".json_encode($metadataObject->keywords));
+                if ($injectRegistryUuid && !in_array($uuid, $metadataObject->keywords)) {  //add mapbender registry keyword
+		    $newKeywordsIndex++;
+		    $keywordsArray[$newKeywordsIndex]->keyword = $uuid;
+		    $keywordsArray[$newKeywordsIndex]->thesaurusTitle = "mapbender.2.registryId";
+		    $keywordsArray[$newKeywordsIndex]->thesaurusPubDate = "2019-10-30";
+		if (count($keywordsArray) > 0 && count($metadataObject->keywords) > 0) {
+		    $metadataXml = addKeywords($metadataXml, $keywordsArray);
+		} else {
+		    //TODO inject keyword after some other element!
+		unset($keywordsArray);
+		//debug
+		//header("Content-type: text/xml");
+		//echo $metadataXml;
+		//die();
+		//save xml to file
+	    fclose($h); //close file for read
+	    //open same file for write and insert xml into the file!
+            $writeHandle = fopen($metadataDir."/".$file, "w+");
+	    fwrite($writeHandle, $metadataXml);
+	    fclose($writeHandle);
+	    logMessages("number of altered file: ".$numberOfFile);
+	    $numberOfFile++;
+	    $timeToBuild = microtime(true) - $startTime;
+            logMessages("time to alter xml: ".$timeToBuild);
+	    //echo $metadataDir."/".$file." will be altered!<br>";
+	} else {
+        	//echo "$file will not be altered!<br>";
+    closedir($handle);
+    $timeToBuildAll = microtime(true) - $startTimeForAll;
+    logMessages("time to alter all xml: ".$timeToBuildAll);
+//function to inject keywords into metadata xml
+//keywords to add -
+//keywordsArray[0]->keyword = "test";
+//keywordsArray[0]->thesaurusTitle = "testThesaurus";
+//keywordsArray[0]->thesaurusPubDate = "2019-05-22";
+function addKeywords($metadataXml, $keywordsArray) {
+	//parse XML part
+	//die();
+	//do parsing with dom, cause we want to alter the xml which have been parsed afterwards
+	$metadataDomObject = new DOMDocument();
+	libxml_use_internal_errors(true);
+	try {
+		$metadataDomObject->loadXML($metadataXml);
+		if ($metadataDomObject === false) {
+			foreach(libxml_get_errors() as $error) {
+        			logMessages("php/mod_qualifyPersistedMetadataXml.php:".$error->message);
+			throw new Exception("php/mod_qualifyPersistedMetadataXml.php:".'Cannot parse metadata with dom!');
+	catch (Exception $e) {
+    		logMessages("php/mod_qualifyPersistedMetadataXml.php:".$e->getMessage());
+	if ($metadataDomObject !== false) {
+		//importing namespaces
+		$xpath = new DOMXPath($metadataDomObject);
+		$rootNamespace = $metadataDomObject->lookupNamespaceUri($metadataDomObject->namespaceURI);
+		$xpath->registerNamespace('defaultns', $rootNamespace);
+		//$xpath->registerNamespace('georss','http://www.georss.org/georss');
+		$xpath->registerNamespace("csw", "http://www.opengis.net/cat/csw/2.0.2");
+		$xpath->registerNamespace("gml", "http://www.opengis.net/gml");
+		$xpath->registerNamespace("gco", "http://www.isotc211.org/2005/gco");
+		$xpath->registerNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+		$xpath->registerNamespace("gts", "http://www.isotc211.org/2005/gts");
+		//$xpath->registerNamespace("srv", "http://www.isotc211.org/2005/srv");
+		$xpath->registerNamespace("xlink", "http://www.w3.org/1999/xlink");
+		//inspire specific keywords
+		//https://webgate.ec.europa.eu/fpfis/wikis/display/InspireMIG/Spatial+scope+code+list
+		//problem: gmx namespace does not exists !!!!! - have to be declared before!!!!!!
+		/*$keywordXMLSnippet = '<?xml version="1.0" encoding="UTF-8"?><gmd:descriptiveKeywords xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink"><gmd:MD_Keywords><gmd:keyword><gmx:Anchor xlink:href="http://inspire.ec.europa.eu/metadata-codelist/SpatialScope/national">Regional</gmx:Anchor></gmd:keyword><gmd:thesaurusName><gmd:CI_Citation><gmd:title><gmx:Anchor xlink:href="http://inspire.ec.europa.eu/metadata-codelist/SpatialScope">Spatial scope</gmx:Anchor></gmd:title><gmd:date><gmd:CI_Date><gmd:date><gco:Date>2019-05-22</gco:Date></gmd:date><gmd:dateType><gmd:CI_DateTypeCode codeList="http://standards.iso.org/iso/19139/resources/gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode></gmd:dateType></gmd:CI_Date></gmd:date></gmd:CI_Citation></gmd:thesaurusName></gmd:MD_Keywords
 ></gmd:descriptiveKeywords>';*/
+		$descriptiveKeywordsNodeList = $xpath->query('/gmd:MD_Metadata/gmd:identificationInfo//gmd:descriptiveKeywords');
+		//data and service identification!
+		$arrayDescriptiveKeywordsNodeList = (array)$descriptiveKeywordsNodeList;
+		foreach ($keywordsArray as $keyword) {
+			$keywordXMLSnippet ='<?xml version="1.0" encoding="UTF-8"?><gmd:descriptiveKeywords xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink">
+    <gmd:MD_Keywords>
+        <gmd:keyword>
+            <gco:CharacterString>'.$keyword->keyword.'</gco:CharacterString>
+        </gmd:keyword>
+	<gmd:thesaurusName>
+	    <gmd:CI_Citation>
+		<gmd:title>
+		    <gco:CharacterString>'.$keyword->thesaurusTitle.'</gco:CharacterString>
+		</gmd:title>
+		<gmd:date>
+		    <gmd:CI_Date>
+			<gmd:date>
+			    <gco:Date>'.$keyword->thesaurusPupDate.'</gco:Date>
+			</gmd:date>
+			<gmd:dateType>
+			    <gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode>
+			</gmd:dateType>
+		    </gmd:CI_Date>
+		</gmd:date>
+	    </gmd:CI_Citation>
+	</gmd:thesaurusName>
+    </gmd:MD_Keywords>
+</gmd:descriptiveKeywords>';
+			//count old resourceConstraints elements
+			//TODO - if this is empty - create a new entry
+			//if (!empty($arrayResourceConstraintsNodeList)) {
+logMessages("Count of existing descriptiveKeywordsNodeList: ".count($descriptiveKeywordsNodeList));
+//$e = new mb_exception("count array descriptiveKeywordsNodeList: ".count($arrayDescriptiveKeywordsNodeList));
+			if (count($descriptiveKeywordsNodeList) > 0) {
+				//$e = new mb_exception("list is not empty!");
+				//load xml from constraint generator
+				$keywordDomObject = new DOMDocument();
+				$keywordDomObject->loadXML($keywordXMLSnippet);
+				$xpathKeyword = new DOMXpath($keywordDomObject);
+				$keywordNodeList = $xpathKeyword->query('/gmd:descriptiveKeywords');
+//$e = new mb_exception("new keyword length: ".$keywordNodeList->length);
+//$e = new mb_exception("old keyword length: ".$descriptiveKeywordsNodeList->length);
+				//insert new keyword before first old constraints node
+				//for ($i = ($keywordNodeList->length)-1; $i >= 0; $i--) {
+					$descriptiveKeywordsNodeList->item(0)->parentNode->insertBefore($metadataDomObject->importNode($keywordNodeList->item(0), true), $descriptiveKeywordsNodeList->item(0));
+				//delete all resourceConstraints from original xml document
+				/*for ($i = 0; $i <  $resourceConstraintsNodeList->length; $i++) {
+    						$temp = $resourceConstraintsNodeList->item($i); //avoid calling a function twice
+    						$temp->parentNode->removeChild($temp);
+		} //end - foreach keyword in array
+		//test http://localhost/mb_trunk/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=0da11651-aa61-d75a-446c-ea4ea073bc48
+	return $metadataDomObject->saveXML();
+function logMessages($message) {
+    if (php_sapi_name() === 'cli' OR defined('STDIN')) {
+        echo __FILE__.$message."\n";
+    } else {
+        $e = new mb_exception(__FILE__.$message);
More information about the Mapbender_commits
