[Mapbender-commits] r10312 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Oct 30 06:33:14 PDT 2019
Author: armin11
Date: 2019-10-30 06:33:02 -0700 (Wed, 30 Oct 2019)
New Revision: 10312
   trunk/mapbender/conf/mapbender.conf-dist
Script to add uuids to exported metadata xml documents and add some special keyword for inspire spatial scope:
https://webgate.ec.europa.eu/fpfis/wikis/display/InspireMIG/Spatial+scope+code+list
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2019-10-30 13:32:22 UTC (rev 10311)
+++ trunk/mapbender/conf/mapbender.conf-dist	2019-10-30 13:33:02 UTC (rev 10312)
@@ -436,6 +436,13 @@
 #define('SYNC_CATALOGUE_ID',5);
 #define('SYNC_CHANGES_TO_CSW', true);
+# Configuration for adding further keyword into exported xml based metadata records - this will help to identify them in portals
+# which harvest metadata from the mapbender registry.
+#define('MAPBENDER_REGISTRY_UUID','2f23ed6e-0196-4c2b-8380-768389036509');
 ###HACK for GLOBALS
 $DBSERVER=DBSERVER;
   $DB=DB;
More information about the Mapbender_commits mailing list
