[Mapbender-commits] r10245 - in trunk/mapbender: http/css http/geoportal http/javascripts http/plugins lib resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Sep 13 03:26:42 PDT 2019
Author: armin11
Date: 2019-09-13 03:26:42 -0700 (Fri, 13 Sep 2019)
New Revision: 10245
trunk/mapbender/http/css/reset.css
trunk/mapbender/http/geoportal/print_div.css
trunk/mapbender/http/javascripts/mod_addWMS.php
trunk/mapbender/http/javascripts/mod_coords_div.php
trunk/mapbender/http/javascripts/mod_featureInfo.php
trunk/mapbender/http/javascripts/mod_pan.js
trunk/mapbender/http/javascripts/mod_savewmc.js
trunk/mapbender/http/javascripts/mod_selArea.js
trunk/mapbender/http/plugins/mb_button.js
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/http/plugins/mb_measure_widget.php
trunk/mapbender/lib/button.js
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
New options to build nicer guis ;-) - thanx to karl owesny
Modified: trunk/mapbender/http/css/reset.css
--- trunk/mapbender/http/css/reset.css 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/css/reset.css 2019-09-13 10:26:42 UTC (rev 10245)
@@ -3,8 +3,9 @@
height: 100%;
padding: 0;
margin: 0;
+ overflow: hidden;
.hide-during-splash {
- display: none;
\ No newline at end of file
+ display: none !important;
Modified: trunk/mapbender/http/geoportal/print_div.css
--- trunk/mapbender/http/geoportal/print_div.css 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/geoportal/print_div.css 2019-09-13 10:26:42 UTC (rev 10245)
@@ -1,25 +1,28 @@
@CHARSET "ISO-8859-1";
-#printPDF label, #printPDF input, #printPDF select, #printPDF textarea {
+#printPDF input, #printPDF select, #printPDF textarea {
display: block;
- width: 150px;
+ width: 154px;
float: left;
margin-bottom: 2px;
margin-top: 2px;
+#printPDF label {
+ display: block;
+ width: 100px;
+ float: left;
+ margin-bottom: 2px;
+ margin-top: 2px;
#printPDF input#submit {
display: block;
- width: 80px;
+ width: 100px;
float: left;
margin-bottom: 2px;
margin-top: 2px;
- margin-left: 50px;
+ margin-left: 0px;
-#printPDF select {
- width: 160px;
#printPDF label {
text-align: left;
@@ -49,4 +52,4 @@
opacity: 0.75;
width:100%;
height:100%;
Modified: trunk/mapbender/http/javascripts/mod_addWMS.php
--- trunk/mapbender/http/javascripts/mod_addWMS.php 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_addWMS.php 2019-09-13 10:26:42 UTC (rev 10245)
@@ -24,14 +24,18 @@
$(this).click(function () {
mod_addWMS();
+ $(this).addClass('myOnClass');
+ $('#toolsContainer').hide() && $('a.toggleToolsContainer').removeClass('activeToggle');
}).mouseover(function () {
if (options.src) {
this.src = options.src.replace(/_off/, "_over");
+ $(this).addClass('myOverClass');
}).mouseout(function () {
if (options.src) {
this.src = options.src;
+ $(this).removeClass('myOverClass');
//var mod = new function(){
// var title = "URL:";
@@ -94,8 +98,10 @@
title: "WebMapService hinzufügen",
close: function () {
opened = false;
+ $("#addWMS").removeClass("myOnClass");
Modified: trunk/mapbender/http/javascripts/mod_coords_div.php
--- trunk/mapbender/http/javascripts/mod_coords_div.php 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_coords_div.php 2019-09-13 10:26:42 UTC (rev 10245)
@@ -57,12 +57,15 @@
function mod_showCoords_div_run(){
var $map = $(mod_showCoords_div_mapObj.getDomElement());
$map.bind("mousemove", mod_showCoords_div_display);
+ $map.css("cursor", "crosshair");
$map.bind("click", mod_showCoords_div_click);
function mod_showCoords_div_disable(){
$map.unbind("mousemove", mod_showCoords_div_display);
+ $map.css("cursor", "default");
$map.unbind("click", mod_showCoords_div_click);
if(document.getElementById(displayTarget)){
writeTag("",displayTarget,"");
@@ -165,5 +168,14 @@
str += "</div>";
writeTag("",displayTarget, str);
+//erweiterung close-button
+ $(document.createElement('span')).attr({'id':'closeDivButton'}).appendTo(".actualcoords");
+ $("#closeDivButton").attr({'style':'position:absolute;top:1px;right:1px;border:1px solid transparent;cursor:pointer;'});
+ $("#closeDivButton").attr({'class':'ui-icon ui-icon-closethick'});
+ $("#closeDivButton").bind("click", mod_showCoords_div_disable) && $("#showCoords_div").removeClass('myOnClass');
+// $("#closeDivButton").onclick = function(){
+ // writeTag("",displayTarget, "")};
Modified: trunk/mapbender/http/javascripts/mod_featureInfo.php
--- trunk/mapbender/http/javascripts/mod_featureInfo.php 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_featureInfo.php 2019-09-13 10:26:42 UTC (rev 10245)
@@ -21,6 +21,8 @@
include '../include/dyn_js.php';
//defaults for element vars
+// <script>
var ignoreWms = typeof ignoreWms === "undefined" ? [] : ignoreWms;
if(typeof(featureInfoLayerPopup)==='undefined')
@@ -31,15 +33,18 @@
var featureInfoPopupWidth = '270';
if(typeof(featureInfoPopupPosition)==='undefined')
var featureInfoPopupPosition = 'center';
-var reverseInfo = typeof reverseInfo === "undefined" ? "false" : reverseInfo;
-if(typeof(featureInfoLayerPreselect)==='undefined' || featureInfoLayerPreselect == 'false')
+if(typeof(reverseInfo)==='undefined' || reverseInfo === 'false')
+ var reverseInfo = false;
+if(typeof(featureInfoLayerPreselect)==='undefined' || featureInfoLayerPreselect === 'false')
var featureInfoLayerPreselect = false;
if(typeof(featureInfoDrawClick)==='undefined')
var featureInfoDrawClick = false;
if(typeof(featureInfoCircleColor)==='undefined')
var featureInfoCircleColor = '#ff0000';
-if(typeof(featureInfoCollectLayers)==='undefined' || featureInfoCollectLayers == 'false')
+if(typeof(featureInfoCollectLayers)==='undefined' || featureInfoCollectLayers === 'false')
var featureInfoCollectLayers = false;
+if (typeof(featureInfoShowKmlTreeInfo) === 'undefined' || featureInfoShowKmlTreeInfo === 'false')
+ var featureInfoShowKmlTreeInfo = false;
var mod_featureInfo_elName = "<?php echo $e_id;?>";
var mod_featureInfo_frameName = "";
@@ -124,10 +129,161 @@
if (el) {
$(el).unbind("click", mod_featureInfo_event)
+ $("#featureInfo1").removeClass("myOnClass");
+function makeDialog($content, title, dialogPosition, offset) {
+ dialogPosition = dialogPosition || featureInfoPopupPosition;
+ if(featureInfoPopupPosition.length === 2 && !isNaN(featureInfoPopupPosition[0]) && !isNaN(featureInfoPopupPosition[1])) {
+ offset = offset || 0;
+ var dialogPosition = [];
+ dialogPosition[0] = featureInfoPopupPosition[0] + offset;
+ dialogPosition[1] = featureInfoPopupPosition[1] + offset;
+ return $content.dialog({
+ bgiframe: true,
+ autoOpen: true,
+ modal: false,
+ title: title,
+ width: parseInt(featureInfoPopupWidth, 10),
+ height: parseInt(featureInfoPopupHeight, 10),
+ position: dialogPosition,
+ buttons: {
+ "Ok": function() {
+ if (standingHighlightFeatureInfo !== null) {
+ standingHighlightFeatureInfo.clean();
+ $(this).dialog('close').remove();
+ }).parent().css({ position:"fixed" });
+function featureInfoDialog(request, dialogPosition, offset) {
+ var title = "<?php echo _mb("Information");?>";
+ var $iframe = $("<iframe>")
+ .attr("frameborder", 0)
+ .attr("height", "100%")
+ .attr("width", "100%")
+ .attr("id", "featureInfo")
+ .attr("title", title)
+ .attr("src", request)
+ return makeDialog($("<div>").append($iframe), title, dialogPosition, offset);
+function ownDataDialog(ownData, dialogPosition, offset) {
+ var $box = $('<div>').html(ownData.content);
+ return makeDialog($box,
+ "<?php echo _mb("Information");?>", dialogPosition, offset);
+function featureInfoWindow(request) {
+ return window.open(request, "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+function ownDataWindow(ownData) {
+ var w = featureInfoWindow("");
+ var $body = $(w.document.body);
+ $body.html(ownData.content);
+function makeListLine(url, title, legendurls, onclick) {
+ var $row = $("<tr>");
+ var $title = $("<td>")
+ .attr("valign", "top")
+ .appendTo($row);
+ var $link = $("<a>")
+ .css("text-decoration", "underline")
+ .attr("href", url)
+ .attr("target", "_blank")
+ .html(title)
+ .appendTo($title);
+ if (onclick) {
+ $link.bind('click', onclick);
+ var $legend = $("<td>")
+ .appendTo($row);
+ if (legendurls.length === 0) {
+ legendurls = [""];
+ legendurls.forEach(function (legendurl) {
+ $("<img>")
+ .attr("src", legendurl)
+ .attr("alt", "<?php echo _mb("No legend available");?>")
+ .appendTo($legend);
+ $("<br/>")
+ return $row;
+function makeFeatureInfoListLine(url, title, legendurls) {
+ return makeListLine(url, title, legendurls)
+function makeOwnDataListLine(ownData) {
+ return makeListLine("#", ownData.title, [], function (e) {
+ ownDataWindow(ownData)
+ e.preventDefault();
+function featureInfoListDialog(urls, ownDataInfos) {
+ var $featureInfoList = $("<table>")
+ .attr("border", 1);
+ if (reverseInfo) {
+ urls.reverse();
+ ownDataInfos.reverse();
+ ownDataInfos.forEach(function (ownDataInfo) {
+ $featureInfoList.append(makeOwnDataListLine(ownDataInfo));
+ for(var i=0; i < urls.length; i++){
+ var $line;
+ if (featureInfoCollectLayers) {
+ $line = makeFeatureInfoListLine(urls[i].request, urls[i].title, urls[i].legendurl.split(","));
+ } else {
+ if (urls[i].inBbox) {
+ if (urls[i].legendurl !== "empty" ) {
+ $line = makeFeatureInfoListLine(urls[i].request, urls[i].title, [urls[i].legendurl]);
+ } else {
+ $line = makeFeatureInfoListLine(urls[i].request, urls[i].title, [""]);
+ if ($line) {
+ $featureInfoList.append($line);
+ if (!reverseInfo) {
+ makeDialog($("<div id='featureInfo_preselect'></div>").append($featureInfoList),
+ "<?php echo _mb("Please choose a requestable Layer");?>");
function mod_featureInfo_event(e){
+ var urls;
var point = mod_featureInfo_mapObj.getMousePosition(e);
+ //calculate realworld position
+ var realWorldPoint = Mapbender.modules[options.target].convertPixelToReal(point);
+ var ownDataInfos = [];
+ if (featureInfoShowKmlTreeInfo) {
+ if (Mapbender.modules.kmlTree === undefined) {
+ console.error('kmltree module is needed if element_var \'featureInfoShowKmlTreeInfo\' is set to true')
+ var kmlTree = Mapbender.modules.kmlTree;
+ ownDataInfos = kmlTree.getFeatureInfos(e);
if (featureInfoDrawClick) {
var map = Mapbender.modules[options.target];
if(standingHighlightFeatureInfo !== null){
@@ -139,24 +295,24 @@
{"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
2);
- //calculate realworld position
- realWorldPoint = Mapbender.modules[options.target].convertPixelToReal(point);
//get coordinates from point
var ga = new GeometryArray();
//TODO set current epsg!
ga.importPoint({
coordinates:[realWorldPoint.x,realWorldPoint.y,null]
- },Mapbender.modules[options.target].getSRS())
+ }, Mapbender.modules[options.target].getSRS())
var m = ga.get(-1,-1);
standingHighlightFeatureInfo.add(m, featureInfoCircleColor);
standingHighlightFeatureInfo.paint();
map.setMapRequest();
- eventBeforeFeatureInfo.trigger({"fName":mod_featureInfo_target});
- //TODO that code should go to featureInfo Redirect module
+ eventBeforeFeatureInfo.trigger({ "fName": mod_featureInfo_target });
if(document.getElementById("FeatureInfoRedirect")){
+ //TODO this code should go to featureInfo Redirect module
+ //FIXME this does not work for multiple urls
+ //FIXME this does not work for kmlTree
//fill the frames
- for(var i=0; i<mod_featureInfo_mapObj.wms.length; i++){
+ for(var i=0; i < mod_featureInfo_mapObj.wms.length; i++){
var req = mod_featureInfo_mapObj.wms[i].getFeatureInfoRequest(mod_featureInfo_mapObj, point);
if(req)
window.frames.FeatureInfoRedirect.document.getElementById(mod_featureInfo_mapObj.wms[i].wms_id).src = req;
@@ -167,139 +323,64 @@
if (featureInfoLayerPreselect) {
$("#featureInfo_preselect").remove();
//build list of possible featureInfo requests
- urls = mod_featureInfo_mapObj.getFeatureInfoRequestsForLayers(point, ignoreWms, Mapbender.modules[options.target].getSRS(), realWorldPoint, featureInfoCollectLayers);
- if (urls.length == 0 || typeof urls.length =='undefined') {
+ urls = mod_featureInfo_mapObj.getFeatureInfoRequestsForLayers(point, ignoreWms, Mapbender.modules[options.target].getSRS(), realWorldPoint, featureInfoCollectLayers) || [];
+ var length = urls.length + ownDataInfos.length;
+ if (length === 0) {
alert("<?php echo _mb("Please enable some layer to be requestable");?>!");
return false;
- if (urls.length == 1) {
+ if (length === 1) {
//don't show interims window!
//open featureInfo directly
- if(featureInfoLayerPopup == 'true'){
- $("<div><iframe frameborder='0' height='100%' width='100%' id='featureInfo' title='<?php echo _mb("Information");?>' src='" + urls[0].request + "'></iframe></div>").dialog({
- bgiframe: true,
- autoOpen: true,
- modal: false,
- title: '<?php echo _mb("Information");?>',
- width:parseInt(featureInfoPopupWidth, 10),
- height:parseInt(featureInfoPopupHeight, 10),
- position:dialogPosition,
- buttons: {
- "Ok": function(){
- $(this).dialog('close').remove();
- }).parent().css({position:"fixed"});
+ if (featureInfoLayerPopup){
+ if (urls.length === 1) {
+ featureInfoDialog(urls[0].request);
+ } else {
+ ownDataDialog(ownDataInfos[0]);
return false;
} else {
- window.open(urls[0].request, "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+ featureInfoWindow(urls[0].request);
+ } else {
+ ownDataWindow(ownDataInfos[0]);
return false;
- featureInfoList = "<table border='1'>";
- if (reverseInfo == "true") {
- for(var i=0;i<urls.length;i++){
- if (featureInfoCollectLayers) {
- featureInfoList += "<tr><td valign='top'><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td>";
- //get legend urls if available
- var legend = urls[i].legendurl.split(",");
- for(var k=0;k<legend.length;k++){
- featureInfoList +="<img src='"+legend[k]+"' alt='<?php echo _mb("No legend available");?>!'/><br>";
- featureInfoList += "</td></tr>";
- } else {
- if (urls[i].inBbox) {
- if (urls[i].legendurl !== "empty" ) {
- featureInfoList += "<tr><td valign='top'><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='"+urls[i].legendurl+"' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
- } else {
- featureInfoList += "<tr><td valign='top'><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
- } else {
- for(var i=urls.length-1; i>=0; i--){
- } else {
- } else {
- featureInfoList += "</table>";
- $("<div id='featureInfo_preselect'></div>").dialog({
- bgiframe: true,
- autoOpen: true,
- modal: false,
- title: '<?php echo _mb("Please choose a requestable Layer");?>',
- buttons: {
- "Close": function(){
- if(standingHighlightFeatureInfo !== null){
- standingHighlightFeatureInfo.clean();
- $("#featureInfo_preselect").append(featureInfoList);
+ featureInfoListDialog(urls, ownDataInfos);
} else {
- urls = mod_featureInfo_mapObj.getFeatureInfoRequests(point, ignoreWms);
- if(urls){
- for(var i=0;i<urls.length;i++){ //To change order : var i=urls.length-1; i>=0; i--
+ urls = mod_featureInfo_mapObj.getFeatureInfoRequests(point, ignoreWms) || [];
+ if (length > 0){
+ for (var i=0; i < urls.length; i++){
//TODO: also rewind the LAYERS parameter for a single WMS FeatureInfo REQUEST if needed?
- var cnt = i;
- if (reverseInfo == 'true') {
if (typeof(urls[i]) !== "undefined") {
urls[i] = changeURLValueOrder(urls[i], 'LAYERS');
- if(featureInfoPopupPosition.length == 2 && !isNaN(featureInfoPopupPosition[0]) && !isNaN(featureInfoPopupPosition[1])) {
- var dialogPosition = [];
- dialogPosition[0] = featureInfoPopupPosition[0]+cnt*25;
- dialogPosition[1] = featureInfoPopupPosition[1]+cnt*25;
+ if(featureInfoLayerPopup){
+ featureInfoDialog(urls[i], dialogPosition, i * 25);
else {
- var dialogPosition = featureInfoPopupPosition;
+ featureInfoWindow(urls[i]);
+ for(var i=0; i < ownDataInfos.length; i++){
+ if(featureInfoLayerPopup === 'true'){
+ ownDataDialog(ownDataInfos[i], dialogPosition, (urls.length + i) * 25);
- $("<div><iframe frameborder='0' height='100%' width='100%' id='featureInfo_"+ i + "' title='<?php echo _mb("Information");?>' src='" + urls[i] + "'></iframe></div>").dialog({
- bgiframe: true,
- autoOpen: true,
- modal: false,
- buttons: {
- "Ok": function(){
- else
- window.open(urls[i], "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
- } //end for
- } //end if urls
- else
+ else {
+ ownDataWindow(ownDataInfos[i]);
+ else {
alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
- setFeatureInfoRequest(mod_featureInfo_target,point.x,point.y);
+ setFeatureInfoRequest(mod_featureInfo_target, point.x, point.y);
Modified: trunk/mapbender/http/javascripts/mod_pan.js
--- trunk/mapbender/http/javascripts/mod_pan.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_pan.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -94,6 +94,7 @@
.mouseleave(moveend);
stop: function () {
+ $("#pan1").removeClass("myOnClass");
if (!map) {
return false;
@@ -108,7 +109,7 @@
// deactivate if ui-dialog opens
- $(document).bind('dialogopen', function () {
- button.stop();
+ // $(document).bind('dialogopen', function () {
+ // button.stop()
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -361,11 +361,31 @@
attributes.keywords = $("#" + options.id + "_wmckeywords").val();
attributes.isoTopicCat = isoTopicCat;
- if(!attributes.title.match(/^[a-zA-Z0-9]+$/) || !attributes.abstract.match(/^[a-zA-Z0-9]+$/) || !attributes.keywords.match(/^[a-zA-Z0-9]+$/)){
- alert("Allowed characters are: A-Z, a-z, 0-9, -, _");
- return;
+ if(attributes.title != ""){
+ if(!attributes.title.match(/^[a-zA-Z0-9]+$/)){
+ alert("Allowed characters for title are: A-Z, a-z, 0-9, -, _");
+ return;
+ }else{
+ alert("Please fill out title!");
+ return;
+ if(attributes.abstract != ""){
+ if(!attributes.abstract.match(/^[a-zA-Z0-9]+$/)){
+ alert("Allowed characters for abstract are: A-Z, a-z, 0-9, -, _");
+ return;
+ if(attributes.keywords != ""){
+ if(!attributes.keywords.match(/^[a-zA-Z0-9]+$/)){
+ alert("Allowed characters for keywords are: A-Z, a-z, 0-9, -, _");
+ return;
if (!!attributes.title) {
sendMapDataToServer(attributes, 0, (function(result, status, message) {
alert(message);
@@ -396,15 +416,20 @@
$this.click(function () {
+ $('#savewmc').toggleClass('myOnClass');
+ $('#tree2Container').hide('fast') && $('a.toggleLayerTree').removeClass('activeToggle');
mod_savewmc();
if (options.src) {
+ $('#savewmc').addClass('myOverClass');
if (options.src) {
+ $('#savewmc').removeClass('myOverClass');
Mapbender.events.afterInit.register(function(){
//check if wmc should be saved into session
@@ -486,7 +511,7 @@
bgiframe: true,
autoOpen: false,
height: 400,
- width: 500,
+ width: 400,
modal: false,
beforeclose: function (event, ui) {
try {
@@ -498,6 +523,7 @@
new Mb_warning("jq_ui_effect is missing.");
+ close: function() {$('#savewmc').toggleClass('myOnClass')},
buttons: getButtons()
// set uuid
Modified: trunk/mapbender/http/javascripts/mod_selArea.js
--- trunk/mapbender/http/javascripts/mod_selArea.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/javascripts/mod_selArea.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -76,7 +76,8 @@
.mouseup(mouseup);
stop: function () {
- if (!map) {
+ $("#selArea1").removeClass("myOnClass");
+ if (!map) {
return;
$(map.getDomElement())
@@ -86,4 +87,4 @@
box = null;
Modified: trunk/mapbender/http/plugins/mb_button.js
--- trunk/mapbender/http/plugins/mb_button.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/plugins/mb_button.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -54,7 +54,7 @@
var $button = $(this);
var ButtonApi = function (o) {
- o.position = o.position || 'center';
+ o.position = o.position || 'center';
var that = this;
var target = (o.$target && o.$target.jquery && o.$target.size() === 1) ?
o.$target : $([]);
@@ -64,16 +64,18 @@
left: "auto"
}).hide().dialog({
autoOpen: false,
- position: o.position,
- dialogClass: o.target + "-dialog"
+ position: [o.$target.offset().left+20, o.$target.offset().top+80],
+ dialogClass: o.target + "-dialog",
+ close: function() {$button.removeClass("myOnClass");button.stop();}
var openDialog = function () {
-//alert("try to open dialog: o.target: "+JSON.stringify(o));
dialog.dialog("open");
dialog.dialog({ height: options.dialogHeight });
dialog.dialog({ width: options.dialogWidth });
- button.stop();
+ $('#toolsContainer').hide('fast') && $('a.toggleToolsContainer').removeClass('activeToggle');
+ $('.ui-dialog').css('top', '80px');$('.ui-dialog').css('left', '20px');;
var button = new Mapbender.Button({
@@ -83,6 +85,7 @@
off: o.src,
go: openDialog
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2019-09-13 10:26:42 UTC (rev 10245)
@@ -267,7 +267,7 @@
digitizeDialog = $(digitizeHtml);
digitizeDialog.dialog({
autoOpen: false,
- position: [o.$target.offset().left, o.$target.offset().top]
}).bind("dialogclose", function () {
button.stop();
$(this).find('.digitize-image').unbind('click');
@@ -276,7 +276,7 @@
editDialog = $(editHtml);
editDialog.dialog({
autoOpen: false,
button.stop();
@@ -288,7 +288,7 @@
copyDialog = $(copyHtml);
copyDialog.dialog({
autoOpen: false,
button.stop();
that.destroy();
@@ -297,7 +297,7 @@
labelDialog = $(labelHtml);
labelDialog.dialog({
autoOpen: false,
button.stop();
that.destroy();
@@ -307,7 +307,7 @@
attributesDialog = $(editAttributesHtml);
attributesDialog.dialog({
autoOpen: false,
- position: [o.$target.offset().left, o.$target.offset().top],
width: 400
button.stop();
@@ -326,7 +326,7 @@
editStyleDialog = $(editStyleHtml);
editStyleDialog.dialog({
autoOpen: false,
width: 400,
height: 260
}).bind('dialogclose', function() {
Modified: trunk/mapbender/http/plugins/mb_measure_widget.php
--- trunk/mapbender/http/plugins/mb_measure_widget.php 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/http/plugins/mb_measure_widget.php 2019-09-13 10:26:42 UTC (rev 10245)
@@ -122,8 +122,10 @@
measureDialog = $(defaultHtml);
measureDialog.dialog({
+ width: 350,
autoOpen: false,
+ close: function (){$('#measure_widget').removeClass('myOnClass')}
button.stop();
that.destroy();
@@ -297,6 +299,7 @@
measureDialog.dialog("open");
this.destroy = function () {
Modified: trunk/mapbender/lib/button.js
--- trunk/mapbender/lib/button.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/lib/button.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -120,11 +120,13 @@
if(mb_button[ind].status === 0){
mb_button[ind].prev = mb_button[ind].src;
mb_button[ind].src = mb_button[ind].img_over;
+ $(mb_button[ind]).addClass('myOverClass');
function mb_button_out(ind){
mb_button[ind].src = mb_button[ind].img_off;
+ $(mb_button[ind]).removeClass('myOverClass');
function mb_button_click(ind){
@@ -134,6 +136,8 @@
mb_button[ind].prev = mb_button[ind].img_on;
mb_button[ind].src = mb_button[ind].img_on;
mb_button[ind].status = 1;
+ $(mb_button[ind]).addClass('myOnClass');
if (mb_button[ind].frameName !== "") {
window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
@@ -144,8 +148,10 @@
else{
mb_button[ind].prev = mb_button[ind].img_off;
- mb_button[ind].status = 0;
+ mb_button[ind].status = 0;
+ $(mb_button[ind]).removeClass('myOnClass');
window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
else {
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2019-09-13 10:26:42 UTC (rev 10245)
@@ -57,54 +57,39 @@
self.render();
- this.element.bind('click', function(e) {
- if (self.lastWasBox) {
- self.lastWasBox = false;
- return;
- var map = self.element.mapbender();
- var pos = map.getMousePosition(e);
- var clickPoint = map.convertPixelToReal(new Point(pos.x, pos.y));
- var wgspt = Proj4js.transform(self.targetProj, self.wgs84, {
- x: clickPoint.x,
- y: clickPoint.y
- var res = map.getScale() / mb_resolution / 100;
+ var delta = 2;
+ var lastX, lastY;
+ var box;
+ this.element.bind('mousedown', function(e) {
if (!self.queriedLayer) return;
- var matchedIds = self.findFeatures(pos);
- self.updateSelectedFeatures(matchedIds, e.ctrlKey);
- var boxfun;
- this.element.bind('mousedown', boxfun = function(e) {
- if (!self.queriedLayer) return;
- var box = new Mapbender.Box({
+ lastX = e.clientX;
+ lastY = e.clientY;
+ box = new Mapbender.Box({
target: 'mapframe1'
box.start(e);
$('#mapframe1').css("cursor", "crosshair")
- .mouseup(function(e) {
- box.stop(e, function(extent) {
- if (typeof extent === "undefined") {
- return;
+ $('#mapframe1').mouseup(function(e) {
+ if (!self.queriedLayer) return;
+ var matchedIds;
+ var extent = box.stop(e);
+ $('#mapframe1').css("cursor", "default");
+ if (Math.abs(lastX - e.clientX) <= delta && Math.abs(lastY - e.clientY) <= delta) {
+ // click
+ matchedIds = self.findFeaturesAtClick(e);
+ } else {
+ // drag
+ if (typeof extent === "undefined") {
+ return;
- var matchedIds = self.findFeatures(extent);
- self.lastWasBox = true;
- $('#mapframe1')
- .css("cursor", "default")
- .unbind("mousedown")
- .unbind("mouseup")
- .unbind("mousemove")
- .bind('mousedown', boxfun);
- return false;
+ matchedIds = self.findFeaturesInExtent(extent);
+ self.updateSelectedFeatures(matchedIds, e.ctrlKey);
+ return false;
self.element.bind('kml:loaded', function(event, obj) {
@@ -149,95 +134,90 @@
self._load(o.url);
- findFeatures: function(posOrBox) {
- var matchedIds = [];
- var self = this;
- var ispoint;
- var clickPoint, wgspt, clickBox, min, max;
- if (posOrBox.x) {
- clickPoint = map.convertPixelToReal(new Point(posOrBox.x, posOrBox.y));
- wgspt = Proj4js.transform(self.targetProj, self.wgs84, {
- x: clickPoint.x,
- y: clickPoint.y
- ispoint = true;
+ * Check if the point lies inside the box.
+ * @param {type} point
+ * @param {type} box
+ * @returns {Boolean}
+ pointInBox: function (point, box) {
+ if (point.x >= box.minx && point.x <= box.maxx
+ && point.y >= box.miny && point.y <= box.maxy) {
+ return true;
} else {
- clickBox = posOrBox;
- min = Proj4js.transform(self.targetProj, self.wgs84, {
- x: clickBox.minx,
- y: clickBox.miny
- max = Proj4js.transform(self.targetProj, self.wgs84, {
- x: clickBox.maxx,
- y: clickBox.maxy
- ispoint = false;
+ return false;
- $.each(self._kmls, function(_, itm) {
- $.each(itm.data.features, function(k, v) {
- if (ispoint) {
- //console.log( "isPoint" );
- self.matchFeatureToPoint(v, clickPoint, matchedIds, res, itm, wgspt, k);
- } else {
- self.matchFeatureToBox(v, {
- min: min,
- max: max
- }, matchedIds, itm, k);
- return matchedIds;
+ * Checks if value x is between y1 and y2. It works also if y2 < y1.
+ * @param {type} x
+ * @param {type} y1
+ * @param {type} y2
+ * @returns {Number}
+ valueIsBetween: function (x, y1, y2) {
+ return (y1 - x) * (y2 - x) <= 0;
+ * calculates the Y value of line for a given X.
+ * @param {type} line
+ * @param {type} y
+ lineYAtX: function (line, x) {
+ return line.y2 + (x - line.x2) * (line.y1 - line.y2) / (line.x1 - line.x2)
- inBox: function(minx, miny, maxx, maxy, selectBoxMinx, selectBoxMaxx, selectBoxMiny, selectBoxMaxy) {
+ * calculates the X value of line for a given Y.
+ * @param {type} y
+ lineXAtY: function (line, y) {
+ return line.x2 + (y - line.y2) * (line.x1 - line.x2) / (line.y1 - line.y2)
- // ############## proof the min-point ##################
- // proof hit on the x-axis
- if ( ( minx >= selectBoxMinx && minx <= selectBoxMaxx ) ) {
- // if x hit, proof y
- if ( ( miny >= selectBoxMiny && miny <= selectBoxMaxy ) ) {
- return true;
+ * First checks if line is completely contained inside of the box. If not it checks
+ * if one of the sides of the box intersects with the line.
+ lineIntersectsBox: function (line, box) {
+ if (this.pointInBox({ x: line.x1, y: line.y1 }, box)
+ || this.pointInBox({ x: line.x1, y: line.y1 }, box)) {
+ return true;
- // proof hit on the y-axis
- // if y hit, proof x
+ if (this.valueIsBetween(box.minx, line.x1, line.x2)) {
+ var y = this.lineYAtX(line, box.minx);
+ if (y >= box.miny && y <= box.maxy) {
return true;
- // ############## proof the max-point ##################
- if ( ( maxx >= selectBoxMinx && maxx <= selectBoxMaxx ) ) {
- if ( ( maxy >= selectBoxMiny && maxy <= selectBoxMaxy ) ) {
- return true;
+ if (this.valueIsBetween(box.maxx, line.x1, line.x2)) {
+ var y = this.lineYAtX(line, box.maxx);
return true;
- // ############## proof if selectbox contains the feature geometry ##################
- // proof on x-axis
- if ( minx >= selectBoxMinx && minx <= selectBoxMaxx && maxx >= selectBoxMinx && maxx <= selectBoxMaxx ) {
- if ( miny <= selectBoxMiny && maxy >= selectBoxMaxy ) {
+ if (this.valueIsBetween(box.miny, line.y1, line.y2)) {
+ var x = this.lineXAtY(line, box.miny);
+ if (x >= box.minx && x <= box.maxx) {
return true;
- // proof on y-axis
- if ( miny >= selectBoxMiny && miny <= selectBoxMaxy && maxy >= selectBoxMiny && maxx <= selectBoxMaxy ) {
- if ( minx <= selectBoxMinx && maxx >= selectBoxMaxx ) {
+ if (this.valueIsBetween(box.maxy, line.y1, line.y2)) {
+ var x = this.lineXAtY(line, box.maxy);
return true;
@@ -244,92 +224,209 @@
return false;
+ getLines: function (points, connect) {
+ lines = [];
+ for (var i = 0; i < points.length - 1; i ++) {
+ lines.push({
+ x1: points[i][0],
+ y1: points[i][1],
+ x2: points[i + 1][0],
+ y2: points[i + 1][1]
+ if (connect) {
+ lines.push({
+ x1: points[points.length - 1][0],
+ y1: points[points.length - 1][1],
+ x2: points[0][0],
+ y2: points[0][1]
+ return lines;
+ lineStringIntersectsBox: function (lineStringPoints, box) {
+ var self = this;
+ return this.getLines(lineStringPoints).some(function (line) {
+ return self.lineIntersectsBox(line, box);
- pointInBox: function(pointX, pointY, selectBoxMinx, selectBoxMaxx, selectBoxMiny, selectBoxMaxy) {
+ * Checks whether a polygon intersects a box.
+ * On the one hand it checks if any of the lines on the polygon ring intersect
+ * with the box and on the other hand it checks how many times a ray cast outwards
+ * from the middle of the box intersects with one of the lines. If it intersects
+ * an odd number of times it lays inside the polygon.
+ * @param {type} polygon
+ polygonIntersectsBox: function (polygonRings, box) {
+ var rayPoint = {
+ x: box.minx + (box.maxx - box.minx) / 2,
+ y: box.miny + (box.maxy - box.miny) / 2
+ var rayIntersections = 0;
- if ( ( pointX >= selectBoxMinx && pointX <= selectBoxMaxx ) && ( pointY >= selectBoxMiny && pointY <= selectBoxMaxy )) {
+ var self = this;
+ var lines = polygonRings.reduce(function (lines, ring) {
+ Array.prototype.push.apply(lines, self.getLines(ring, true));
+ return lines;
+ for (var i = 0; i < lines.length; i++) {
+ if (this.lineIntersectsBox(lines[i], box)) {
+ return true;
+ if (this.valueIsBetween(rayPoint.y, lines[i].y1, lines[i].y2)) {
+ var x = this.lineXAtY(lines[i], rayPoint.y);
+ if (x >= rayPoint.x) {
+ rayIntersections++;
+ if (rayIntersections % 2 === 1) {
return true;
+ } else {
+ return false;
- matchFeatureToPoint: function(feat, clickPoint, matchedIds, res, itm, wgspt, idx) {
- //console.log( "point" );
- if (feat.geometry.type.match(/point/i)) {
- var pt = Proj4js.transform(this.wgs84, this.targetProj, {
- x: feat.geometry.coordinates[0],
- y: feat.geometry.coordinates[1]
- var minx = pt.x - 20 * res;
- var miny = pt.y - 20 * res;
- var maxx = minx + 40 * res;
- var maxy = miny + 40 * res;
- if (minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
- matchedIds.push({
- url: itm.url,
- id: idx
+ boxInBox: function (boxA, boxB) {
+ return this.pointInBox({ x: boxA.minx, y: boxA.miny }, boxB) &&
+ this.pointInBox({ x: boxA.maxx, y: boxA.maxy }, boxB);
+ * Checks whether the geometry of the feature intersects with the box
+ * @param {type} feature
+ featureIntersectsBox: function (feature, box) {
+ var geometryType = feature.geometry.type.toLowerCase();
+ switch (geometryType) {
+ case 'point':
+ x: feature.geometry.coordinates[0],
+ y: feature.geometry.coordinates[1]
+ }, box);
+ case 'linestring':
+ return this.lineStringIntersectsBox(feature.geometry.coordinates, box);
+ case 'polygon':
+ return this.polygonIntersectsBox(feature.geometry.coordinates, box);
+ default:
+ throw new Error('feature geometry type not supported');
+ featureInBox: function (feature, box) {
+ if (feature.geometry.type.toLowerCase() === 'point') {
+ }, box);
} else {
- var box = this.getBbox(feat);
- if (this.inBox(box[0], box[1], box[2], box[3], wgspt.x, wgspt.y)) {
- matchedIds.push({
- url: itm.url,
- id: idx
+ var arrayBox = this.getBbox(feature);
+ return this.boxInBox({
+ minx: arrayBox[0],
+ miny: arrayBox[1],
+ maxx: arrayBox[2],
+ maxy: arrayBox[3]
+ }, box);
+ * Finds all features that intersect with a buffer around a point or a given box.
+ * @param {type} posOrBox
+ * @returns {Array|displayFeatures.findIntersectingFeatures.ids}
+ findFeaturesAtClick: function (e) {
+ var map = this.element.mapbender();
+ var pos = map.getMousePosition(e);
+ var min = {
+ x: pos.x - 20,
+ y: pos.y + 20 // screen y is in opposite direction of map y
+ var max = {
+ x: pos.x + 20,
+ y: pos.y - 20
+ min = map.convertPixelToReal(min);
+ max = map.convertPixelToReal(max);
+ min = Proj4js.transform(this.targetProj, this.wgs84, min);
+ max = Proj4js.transform(this.targetProj, this.wgs84, max);
+ var box = {
+ minx: min.x,
+ miny: min.y,
+ maxx: max.x,
+ maxy: max.y
+ var self = this;
+ var matches = [];
+ for (var kmlId in this._kmls) {
+ if (this._kmls.hasOwnProperty(kmlId)) {
+ var kml = this._kmls[kmlId];
+ matches = kml.data.features.reduce(function (matches, feature, index) {
+ if (self.featureIntersectsBox(feature, box)) {
+ matches.push({
+ url: kml.url,
+ id: index
+ return matches;
+ }, matches);
+ return matches;
- matchFeatureToBox: function(feat, wgsbox, matchedIds, itm, idx) {
- //console.log( feat.geometry );
- if (this.pointInBox(feat.geometry.coordinates[0], feat.geometry.coordinates[1], wgsbox.min.x, wgsbox.max.x, wgsbox.min.y, wgsbox.max.y)) {
- matchedIds.push({
- url: itm.url,
- id: idx
+ findFeaturesInExtent: function(extent) {
+ var min = Proj4js.transform(this.targetProj, this.wgs84, {
+ x: extent.minx,
+ y: extent.miny
+ var max = Proj4js.transform(this.targetProj, this.wgs84, {
+ x: extent.maxx,
+ y: extent.maxy
+ var box = {
+ minx: min.x,
+ miny: min.y,
+ maxx: max.x,
+ maxy: max.y
+ var matches = [];
+ var self = this;
+ if (self.featureInBox(feature, box)) {
+ matches.push({
+ url: kml.url,
+ id: index
+ return matches;
+ }, matches);
- } else {
- if (this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.x, wgsbox.min.y, wgsbox.max.y) ) {
- matchedIds.push({
- url: itm.url,
- id: idx
- return;
- if ( this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.x, wgsbox.min.x, wgsbox.max.x) ) {
- matchedIds.push({
- url: itm.url,
- id: idx
- // if (wgsbox.min.x < box[0] && wgsbox.max.x > box[2]) {
- // if (wgsbox.min.y > box[1] && wgsbox.min.y < box[3] || wgsbox.max.y > box[1] && wgsbox.max.y < box[3]) {
- // matchedIds.push({
- // url: itm.url,
- // id: idx
- // return;
- // if (wgsbox.min.y < box[1] && wgsbox.max.y > box[3]) {
- // if (wgsbox.min.x > box[0] && wgsbox.min.x < box[2] || wgsbox.max.x > box[0] && wgsbox.max.x < box[2]) {
- // url: itm.url,
- // id: idx
- // return;
- // if (wgsbox.min.x < box[0] && wgsbox.max.x > box[2] && wgsbox.min.y > box[1] && wgsbox.max.y < box[3]) {
- // url: itm.url,
- // id: idx
- // return;
+ return matches;
updateSelectedFeatures: function(ids, append) {
@@ -735,8 +832,6 @@
error: function(XMLHttpRequest, textStatus, errorThrown) {
self.element.trigger('kml:error', "Problem talking to server: " + errorThrown);
@@ -841,7 +936,6 @@
getBbox: function(feature) {
switch (feature.geometry.type.toLowerCase()) {
case 'point':
- var map = $(this.element).mapbender();
var minx = feature.geometry.coordinates[0] - 0.001;
var miny = feature.geometry.coordinates[1] - 0.001;
return [minx, miny, minx + 0.002, miny + 0.002];
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2019-09-12 15:43:37 UTC (rev 10244)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.8_pgsql_UTF-8.sql 2019-09-13 10:26:42 UTC (rev 10245)
@@ -132,4 +132,6 @@
ALTER FUNCTION f_simple_alter_service_operation_url(character varying, character varying, character varying)
OWNER TO postgres;
+-- 2019-09-13 - update css to have a nicer default gui!
+update gui_element set e_width=null, e_height=null where e_id = 'body' AND fkey_gui_id IN ( 'Administration_DE', 'PortalAdmin_DE', 'admin1');
More information about the Mapbender_commits
