[Mapbender-commits] r10246 - in trunk/mapbender/http/img: . geoportal2019
svn_mapbender at osgeo.org
Fri Sep 13 03:34:47 PDT 2019
Author: armin11
Date: 2019-09-13 03:34:47 -0700 (Fri, 13 Sep 2019)
New Revision: 10246
Added:
trunk/mapbender/http/img/geoportal2019/
trunk/mapbender/http/img/geoportal2019/branch_empty.png
trunk/mapbender/http/img/geoportal2019/clear.svg
trunk/mapbender/http/img/geoportal2019/clear_white.svg
trunk/mapbender/http/img/geoportal2019/clock.svg
trunk/mapbender/http/img/geoportal2019/down.svg
trunk/mapbender/http/img/geoportal2019/download.svg
trunk/mapbender/http/img/geoportal2019/empty2.svg
trunk/mapbender/http/img/geoportal2019/eye_off.svg
trunk/mapbender/http/img/geoportal2019/gear.svg
trunk/mapbender/http/img/geoportal2019/gear_sm.svg
trunk/mapbender/http/img/geoportal2019/globe_off.svg
trunk/mapbender/http/img/geoportal2019/globe_over.svg
trunk/mapbender/http/img/geoportal2019/horizontaldots.svg
trunk/mapbender/http/img/geoportal2019/info.svg
trunk/mapbender/http/img/geoportal2019/infoabfrage_off.svg
trunk/mapbender/http/img/geoportal2019/infoabfrage_on.svg
trunk/mapbender/http/img/geoportal2019/infoabfrage_over.svg
trunk/mapbender/http/img/geoportal2019/minus_off.svg
trunk/mapbender/http/img/geoportal2019/minus_over.svg
trunk/mapbender/http/img/geoportal2019/move_off.svg
trunk/mapbender/http/img/geoportal2019/move_on.svg
trunk/mapbender/http/img/geoportal2019/move_over.svg
trunk/mapbender/http/img/geoportal2019/plus_off.svg
trunk/mapbender/http/img/geoportal2019/plus_over.svg
trunk/mapbender/http/img/geoportal2019/roundminus.svg
trunk/mapbender/http/img/geoportal2019/roundplus.svg
trunk/mapbender/http/img/geoportal2019/search.svg
trunk/mapbender/http/img/geoportal2019/search_over.svg
trunk/mapbender/http/img/geoportal2019/search_white.svg
trunk/mapbender/http/img/geoportal2019/styling.svg
trunk/mapbender/http/img/geoportal2019/trash.svg
trunk/mapbender/http/img/geoportal2019/up.svg
trunk/mapbender/http/img/geoportal2019/verticaldots.svg
trunk/mapbender/http/img/geoportal2019/zoom.png
New options to build nicer guis ;-) - thanx to karl owesny
Added: trunk/mapbender/http/img/geoportal2019/branch_empty.png
(Binary files differ)
Index: trunk/mapbender/http/img/geoportal2019/branch_empty.png
--- trunk/mapbender/http/img/geoportal2019/branch_empty.png 2019-09-13 10:26:42 UTC (rev 10245)
+++ trunk/mapbender/http/img/geoportal2019/branch_empty.png 2019-09-13 10:34:47 UTC (rev 10246)
Property changes on: trunk/mapbender/http/img/geoportal2019/branch_empty.png
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Added: trunk/mapbender/http/img/geoportal2019/clear.svg
--- trunk/mapbender/http/img/geoportal2019/clear.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/clear.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<svg width="18" height="18" viewBox="0 0 18 18" fill="none" xmlns="http://www.w3.org/2000/svg">
+<path d="M15 4.41L13.59 3L9 7.59L4.41 3L3 4.41L7.59 9L3 13.59L4.41 15L9 10.41L13.59 15L15 13.59L10.41 9L15 4.41Z" fill="#333"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/clear_white.svg
--- trunk/mapbender/http/img/geoportal2019/clear_white.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/clear_white.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M15 4.41L13.59 3L9 7.59L4.41 3L3 4.41L7.59 9L3 13.59L4.41 15L9 10.41L13.59 15L15 13.59L10.41 9L15 4.41Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/clock.svg
--- trunk/mapbender/http/img/geoportal2019/clock.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/clock.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M9 17C6.87827 17 4.84344 16.1571 3.34315 14.6569C1.84285 13.1566 1 11.1217 1 9C1 6.87827 1.84285 4.84344 3.34315 3.34315C4.84344 1.84285 6.87827 1 9 1C11.1217 1 13.1566 1.84285 14.6569 3.34315C16.1571 4.84344 17 6.87827 17 9C17 11.1217 16.1571 13.1566 14.6569 14.6569C13.1566 16.1571 11.1217 17 9 17ZM9 15C10.5913 15 12.1174 14.3679 13.2426 13.2426C14.3679 12.1174 15 10.5913 15 9C15 7.4087 14.3679 5.88258 13.2426 4.75736C12.1174 3.63214 10.5913 3 9 3C7.4087 3 5.88258 3.63214 4.75736 4.75736C3.63214 5.88258 3 7.4087 3 9C3 10.5913 3.63214 12.1174 4.75736 13.2426C5.88258 14.3679 7.4087 15 9 15ZM8 5H9.01L9 9.36L12.22 11.46L11.62 12.39L8 10V5Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/down.svg
--- trunk/mapbender/http/img/geoportal2019/down.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/down.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M16.0142 6.42843L14.6042 5.01843L9.01416 10.6084L3.42416 5.01843L2.01416 6.42843L9.01416 13.4284L16.0142 6.42843Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/download.svg
--- trunk/mapbender/http/img/geoportal2019/download.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/download.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,13 @@
+<svg version="1.0" xmlns="http://www.w3.org/2000/svg"
+ width="10.000000pt" height="10.000000pt" viewBox="0 0 1280.000000 1280.000000"
+ preserveAspectRatio="xMidYMid meet">
+<g transform="translate(0.000000,1280.000000) scale(0.100000,-0.100000)"
+fill="#fff" stroke="none">
+<path d="M4560 9980 l0 -2240 -1050 -2 -1050 -3 1969 -2427 c1083 -1335 1972
+-2433 1975 -2440 4 -9 8 -10 12 -1 3 6 892 1104 1975 2440 l1970 2428 -1048 5
+-1048 5 -3 2238 -2 2237 -1850 0 -1850 0 0 -2240z"/>
+<path d="M310 2885 l0 -2305 6090 0 6090 0 -2 2293 -3 2292 -727 3 -728 2 0
+-1566 0 -1567 -1392 7 c-766 3 -2340 11 -3498 16 -1158 5 -2615 13 -3237 16
+l-1133 6 0 1554 0 1554 -730 0 -730 0 0 -2305z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/empty2.svg
--- trunk/mapbender/http/img/geoportal2019/empty2.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/empty2.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,11 @@
+<svg width="22" height="15" viewBox="0 0 18 14" xmlns="http://www.w3.org/2000/svg">
+ <g>
+ <title>background</title>
+ <rect fill="none" id="canvas_background" height="22" width="22" y="-1" x="-1"/>
+ </g>
+ <g>
+ <title>Layer 1</title>
+ <path id="svg_1" fill="#555" d="m5.6875,1.125l-5,5l5,5l13,0c1.105,0 2,-0.895 2,-2l0,-6c0,-1.105 -0.895,-2 -2,-2l-13,0zm8.995,6.566l-1.414,1.413999l-1.573,-1.566l-1.592,1.566l-1.414001,-1.413999l1.592,-1.566l-1.592,-1.578l1.414001,-1.414l1.592,1.578l1.573,-1.578l1.414,1.414l-1.573,1.578l1.573,1.566z"/>
+ </g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/eye_off.svg
--- trunk/mapbender/http/img/geoportal2019/eye_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/eye_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M5.0242 9.44334L2.80465 11.6312C1.63183 10.2637 1 9 1 9C1 9 4 3 9.06 3C9.81294 3 10.5208 3.13939 11.1799 3.37567L9.50063 5.03091C9.33672 5.01051 9.16964 5 9 5C6.8 5 5 6.8 5 9C5 9.14992 5.00821 9.29784 5.0242 9.44334ZM7.04777 12.4921C7.62606 12.8158 8.29234 13 9 13C11.22 13 13 11.22 13 9C13 8.27183 12.805 7.58748 12.4636 6.99771L10.9467 8.53657C10.9816 8.68516 11 8.8403 11 9C11 10.11 10.11 11 9 11C8.85036 11 8.70472 10.9838 8.56472 10.9531L7.04777 12.4921ZM14.1644 5.27226C15.9853 6.97056 17 9 17 9C17 9 14 15 9.06 15C7.74976 15 6.57765 14.5977 5.55998 14.0014L3.59 16L2 14.41L14.59 2L16 3.41L14.1644 5.27226Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/gear.svg
--- trunk/mapbender/http/img/geoportal2019/gear.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/gear.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M14.5344 6.3088L14.8064 6.968C17 7.7664 17 7.8592 17 8.1232V9.8C17 10.0624 17 10.1536 14.816 11.024L14.5456 11.6816C15.5264 13.792 15.4624 13.8576 15.2784 14.0464L13.9856 15.3376H13.8256C13.632 15.3376 12.9168 15.0656 11.6928 14.5376L11.0256 14.8128C10.224 17 10.1328 17 9.8752 17H8.2C7.9392 17 7.8512 17 6.9888 14.8224L6.3232 14.5456C4.5088 15.3856 4.2944 15.3856 4.2224 15.3856H4.0832L3.9648 15.2816L2.7728 14.0912C2.592 13.9072 2.5296 13.8432 3.4624 11.6912L3.1904 11.0352C1 10.2336 1 10.1408 1 9.8768V8.2C1 7.9296 1 7.8464 3.1824 6.9856L3.4544 6.328C2.46856 4.21253 2.53581 4.14419 2.73199 3.94483L2.7328 3.944L4.0128 2.664H4.1728C4.3664 2.664 5.0848 2.936 6.3088 3.464L6.9728 3.1888C7.7712 1 7.8688 1 8.1216 1H9.8C10.056 1 10.144 1 11.0064 3.1808L11.6736 3.456C13.4864 2.6176 13.7024 2.6176 13.776 2.6176H13.9136L14.032 2.72L15.224 3.9088C15.4064 4.0928 15.4672 4.1568 14.5344 6.3088ZM6.13793 10.1908C6.61987 11.3492 7.75251 12.1029 9.00713 12
.1C10.7149 12.0941 12.0971 10.7096 12.1 9.00181C12.1007 7.74719 11.3451 6.61584 10.1859 6.13589C9.02674 5.65594 7.69255 5.92202 6.80616 6.80993C5.91978 7.69784 5.65598 9.03249 6.13793 10.1908Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/gear_sm.svg
--- trunk/mapbender/http/img/geoportal2019/gear_sm.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/gear_sm.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<svg width="14" height="14" viewBox="0 0 18 18" fill="none" xmlns="http://www.w3.org/2000/svg">
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/globe_off.svg
--- trunk/mapbender/http/img/geoportal2019/globe_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/globe_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<svg width="20" height="20" viewBox="0 0 18 18" fill="none" xmlns="http://www.w3.org/2000/svg">
+<path d="M9 1C6.87827 1 4.84344 1.84285 3.34315 3.34315C1.84285 4.84344 1 6.87827 1 9C1 11.1217 1.84285 13.1566 3.34315 14.6569C4.84344 16.1571 6.87827 17 9 17C11.1217 17 13.1566 16.1571 14.6569 14.6569C16.1571 13.1566 17 11.1217 17 9C17 6.87827 16.1571 4.84344 14.6569 3.34315C13.1566 1.84285 11.1217 1 9 1ZM8 15.32C7.13432 15.1819 6.30624 14.8674 5.56711 14.3961C4.82798 13.9248 4.19356 13.3066 3.70319 12.58C3.21282 11.8533 2.87696 11.0337 2.71643 10.1719C2.55591 9.31006 2.57414 8.42447 2.77 7.57L7 11.68V12.48C7 13.36 7.12 13.8 8 13.8V15.32ZM13.72 13.32C13.52 12.66 12.72 12 12 12H11V10C11 9.56 10.44 9 10 9H6V7H7C7.44 7 8 6.44 8 6V5H10C10.88 5 11.4 4.28 11.4 3.4V3.07C12.3551 3.45825 13.2023 4.0715 13.8694 4.85755C14.5365 5.6436 15.0039 6.57919 15.2317 7.5847C15.4595 8.5902 15.441 9.63586 15.1778 10.6327C14.9146 11.6295 14.4145 12.548 13.72 13.31V13.32Z" fill="#777"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/globe_over.svg
--- trunk/mapbender/http/img/geoportal2019/globe_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/globe_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M9 1C6.87827 1 4.84344 1.84285 3.34315 3.34315C1.84285 4.84344 1 6.87827 1 9C1 11.1217 1.84285 13.1566 3.34315 14.6569C4.84344 16.1571 6.87827 17 9 17C11.1217 17 13.1566 16.1571 14.6569 14.6569C16.1571 13.1566 17 11.1217 17 9C17 6.87827 16.1571 4.84344 14.6569 3.34315C13.1566 1.84285 11.1217 1 9 1ZM8 15.32C7.13432 15.1819 6.30624 14.8674 5.56711 14.3961C4.82798 13.9248 4.19356 13.3066 3.70319 12.58C3.21282 11.8533 2.87696 11.0337 2.71643 10.1719C2.55591 9.31006 2.57414 8.42447 2.77 7.57L7 11.68V12.48C7 13.36 7.12 13.8 8 13.8V15.32ZM13.72 13.32C13.52 12.66 12.72 12 12 12H11V10C11 9.56 10.44 9 10 9H6V7H7C7.44 7 8 6.44 8 6V5H10C10.88 5 11.4 4.28 11.4 3.4V3.07C12.3551 3.45825 13.2023 4.0715 13.8694 4.85755C14.5365 5.6436 15.0039 6.57919 15.2317 7.5847C15.4595 8.5902 15.441 9.63586 15.1778 10.6327C14.9146 11.6295 14.4145 12.548 13.72 13.31V13.32Z" fill="#333"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/horizontaldots.svg
--- trunk/mapbender/http/img/geoportal2019/horizontaldots.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/horizontaldots.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M4.5 10C3.67157 10 3 9.32843 3 8.5C3 7.67157 3.67157 7 4.5 7C5.32843 7 6 7.67157 6 8.5C6 9.32843 5.32843 10 4.5 10ZM9.5 10C8.67157 10 8 9.32843 8 8.5C8 7.67157 8.67157 7 9.5 7C10.3284 7 11 7.67157 11 8.5C11 9.32843 10.3284 10 9.5 10ZM13 8.5C13 9.32843 13.6716 10 14.5 10C15.3284 10 16 9.32843 16 8.5C16 7.67157 15.3284 7 14.5 7C13.6716 7 13 7.67157 13 8.5Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/info.svg
--- trunk/mapbender/http/img/geoportal2019/info.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/info.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M9 1C13.4183 1 17 4.58172 17 9C17 13.4183 13.4183 17 9 17C4.58172 17 1 13.4183 1 9C1 4.58172 4.58172 1 9 1ZM10 14V8H8V14H10ZM10 6V4H8V6H10Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/infoabfrage_off.svg
--- trunk/mapbender/http/img/geoportal2019/infoabfrage_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/infoabfrage_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,41 @@
+<?xml version="1.0" standalone="no"?>
+<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 20010904//EN"
+ "http://www.w3.org/TR/2001/REC-SVG-20010904/DTD/svg10.dtd">
+ width="22.500000pt" height="22.500000pt" viewBox="0 0 1280.000000 1280.000000"
+<metadata>
+Created by potrace 1.15, written by Peter Selinger 2001-2017
+</metadata>
+fill="#777" stroke="none">
+<path d="M4516 10676 c-47 -18 -94 -60 -112 -103 -18 -41 -21 -854 -3 -900 34
+-90 153 -137 246 -98 50 21 72 42 94 90 17 37 19 74 19 453 0 444 -1 455 -53
+510 -47 51 -127 71 -191 48z"/>
+<path d="M2992 10029 c-85 -43 -124 -147 -87 -237 19 -44 545 -578 614 -623
+107 -69 246 -10 280 119 24 90 20 96 -307 426 -194 195 -311 305 -337 317 -53
+25 -110 24 -163 -2z"/>
+<path d="M5990 10030 c-47 -25 -706 -688 -719 -723 -29 -76 1 -166 70 -217 51
+-37 99 -46 152 -30 35 10 96 66 385 353 189 188 349 353 357 367 36 69 26 146
+-28 207 -56 64 -146 82 -217 43z"/>
+<path d="M4197 8956 c-70 -19 -125 -63 -161 -126 -26 -47 -31 -65 -31 -125 0
+-61 11 -102 82 -315 45 -135 177 -535 293 -890 116 -355 260 -793 320 -975 60
+-181 203 -619 319 -972 116 -354 305 -930 420 -1280 115 -351 222 -676 237
+-722 22 -70 35 -92 78 -137 52 -53 120 -84 186 -84 51 0 131 31 170 66 27 24
+156 229 406 642 202 334 379 624 392 646 l24 39 566 -566 c395 -394 580 -572
+611 -587 53 -26 145 -31 206 -11 58 19 1046 1002 1081 1076 31 64 32 151 3
+215 -15 34 -153 179 -587 612 -360 360 -563 571 -557 577 6 5 294 181 640 390
+662 401 698 426 723 508 36 119 -6 245 -102 307 -22 14 -121 53 -220 85 -975
+320 -1458 478 -1711 561 -165 54 -453 149 -640 210 -646 212 -950 312 -1035
+340 -97 32 -1084 356 -1385 454 -228 74 -261 81 -328 62z"/>
+<path d="M2362 8549 c-121 -60 -125 -259 -7 -326 l40 -23 542 0 c360 0 551 4
+570 11 90 34 137 153 98 246 -21 50 -42 72 -90 94 -37 17 -77 19 -575 19 -525
+0 -536 0 -578 -21z"/>
+<path d="M3695 7695 c-5 -2 -23 -6 -40 -10 -22 -5 -121 -97 -368 -343 -186
+-185 -348 -352 -359 -370 -29 -47 -28 -128 2 -176 47 -77 129 -114 209 -94 42
+10 76 41 388 351 195 194 350 356 359 376 38 79 9 188 -64 235 -34 22 -104 40
+-127 31z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/infoabfrage_on.svg
--- trunk/mapbender/http/img/geoportal2019/infoabfrage_on.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/infoabfrage_on.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,41 @@
+<metadata>
+</metadata>
+fill="#333" stroke="none">
+-127 31z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/infoabfrage_over.svg
--- trunk/mapbender/http/img/geoportal2019/infoabfrage_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/infoabfrage_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,41 @@
+<metadata>
+</metadata>
+-127 31z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/minus_off.svg
--- trunk/mapbender/http/img/geoportal2019/minus_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/minus_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<svg width="20" height="20" viewBox="0 0 14 14" fill="none" xmlns="http://www.w3.org/2000/svg">
+<path fill-rule="evenodd" clip-rule="evenodd" d="M3 6V8H11V6H3Z" fill="#777"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/minus_over.svg
--- trunk/mapbender/http/img/geoportal2019/minus_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/minus_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M3 6V8H11V6H3Z" fill="#333"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/move_off.svg
--- trunk/mapbender/http/img/geoportal2019/move_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/move_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,28 @@
+ width="18.000000pt" height="18.000000pt" viewBox="0 0 1280.000000 1238.000000"
+<g transform="translate(0.000000,1238.000000) scale(0.100000,-0.100000)"
+<path d="M6418 12369 c-10 -5 -100 -107 -201 -227 -861 -1021 -1751 -2077
+-1790 -2125 -26 -32 -47 -65 -47 -73 0 -8 11 -26 25 -39 l24 -25 451 0 450 0
+0 -753 c0 -718 1 -755 18 -770 17 -16 109 -17 1115 -17 l1096 0 15 22 c14 20
+16 110 16 770 l0 748 458 0 c432 0 460 1 475 18 24 27 21 56 -10 94 -16 18
+-239 280 -498 583 -258 302 -694 813 -969 1135 -274 322 -517 604 -539 628
+-42 43 -59 49 -89 31z"/>
+<path d="M1395 7299 c-643 -556 -1185 -1024 -1202 -1042 -18 -17 -33 -40 -33
+-52 0 -11 19 -39 43 -61 50 -49 2308 -1970 2353 -2003 29 -21 34 -22 60 -9
+l29 13 3 493 2 492 749 0 c722 0 750 1 772 19 l24 19 0 1036 c0 1023 0 1035
+-20 1050 -17 13 -117 15 -772 16 l-753 0 0 504 c0 552 2 536 -58 536 -21 0
+-277 -216 -1197 -1011z"/>
+<path d="M10155 8244 c-19 -14 -20 -28 -23 -499 l-3 -485 -744 0 c-733 0 -745
+0 -765 -20 -20 -20 -20 -29 -18 -1055 3 -1021 3 -1034 23 -1049 17 -13 117
+-15 773 -16 l752 0 0 -494 c0 -541 -2 -521 59 -514 23 2 283 217 1153 953
+1348 1141 1278 1080 1278 1108 0 14 -17 39 -42 63 -41 39 -2300 1954 -2362
+2002 -33 26 -53 27 -81 6z"/>
+<path d="M5351 4503 l-21 -18 -3 -755 -2 -755 -454 -3 c-498 -2 -491 -2 -491
+-61 0 -20 241 -306 1026 -1221 564 -657 1034 -1199 1044 -1204 38 -18 66 4
+185 146 66 79 519 616 1007 1194 487 578 889 1061 893 1073 4 14 1 31 -9 46
+l-16 25 -460 0 -460 0 -2 761 c-3 740 -4 761 -22 775 -17 12 -184 14 -1107 14
+-1020 0 -1088 -1 -1108 -17z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/move_on.svg
--- trunk/mapbender/http/img/geoportal2019/move_on.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/move_on.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,28 @@
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/move_over.svg
--- trunk/mapbender/http/img/geoportal2019/move_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/move_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,28 @@
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/plus_off.svg
--- trunk/mapbender/http/img/geoportal2019/plus_off.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/plus_off.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M8 2H6V6H2V8H6V12H8V8H12V6H8V2Z" fill="#777"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/plus_over.svg
--- trunk/mapbender/http/img/geoportal2019/plus_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/plus_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M8 2H6V6H2V8H6V12H8V8H12V6H8V2Z" fill="#333"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/roundminus.svg
--- trunk/mapbender/http/img/geoportal2019/roundminus.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/roundminus.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,5 @@
+<svg id="Ebene_1" data-name="Ebene 1" xmlns="http://www.w3.org/2000/svg" width="14" height="14" viewBox="0 0 20 20">
+ <title>SymbolMinus20b</title>
+ <circle cx="10" cy="10" r="10" style="fill: #fff"/>
+ <line x1="3" y1="10" x2="17" y2="10" style="fill: none;stroke: #555;stroke-miterlimit: 10;stroke-width: 3px"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/roundplus.svg
--- trunk/mapbender/http/img/geoportal2019/roundplus.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/roundplus.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,8 @@
+ <title>SymbolPlus20b</title>
+ <g>
+ <line x1="10" y1="3" x2="10" y2="17" style="fill: none;stroke: #555;stroke-miterlimit: 10;stroke-width: 3px"/>
+ </g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/search.svg
--- trunk/mapbender/http/img/geoportal2019/search.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/search.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<svg width="15" height="15" viewBox="0 0 18 18" fill="none" xmlns="http://www.w3.org/2000/svg">
+<path fill-rule="evenodd" clip-rule="evenodd" d="M18 16.5L12.864 11.321L12.5079 11.3206C13.4426 10.1307 14 8.63044 14 7C14 3.13401 10.866 0 7 0C3.13401 0 0 3.13401 0 7C0 10.866 3.13401 14 7 14C8.6311 14 10.1319 13.4421 11.322 12.5068V12.864L16.5 18L18 16.5ZM12 7C12 9.76142 9.76142 12 7 12C4.23858 12 2 9.76142 2 7C2 4.23858 4.23858 2 7 2C9.76142 2 12 4.23858 12 7Z" fill="#777"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/search_over.svg
--- trunk/mapbender/http/img/geoportal2019/search_over.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/search_over.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M18 16.5L12.864 11.321L12.5079 11.3206C13.4426 10.1307 14 8.63044 14 7C14 3.13401 10.866 0 7 0C3.13401 0 0 3.13401 0 7C0 10.866 3.13401 14 7 14C8.6311 14 10.1319 13.4421 11.322 12.5068V12.864L16.5 18L18 16.5ZM12 7C12 9.76142 9.76142 12 7 12C4.23858 12 2 9.76142 2 7C2 4.23858 4.23858 2 7 2C9.76142 2 12 4.23858 12 7Z" fill="#333"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/search_white.svg
--- trunk/mapbender/http/img/geoportal2019/search_white.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/search_white.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M18 16.5L12.864 11.321L12.5079 11.3206C13.4426 10.1307 14 8.63044 14 7C14 3.13401 10.866 0 7 0C3.13401 0 0 3.13401 0 7C0 10.866 3.13401 14 7 14C8.6311 14 10.1319 13.4421 11.322 12.5068V12.864L16.5 18L18 16.5ZM12 7C12 9.76142 9.76142 12 7 12C4.23858 12 2 9.76142 2 7C2 4.23858 4.23858 2 7 2C9.76142 2 12 4.23858 12 7Z" fill="#fff"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/styling.svg
--- trunk/mapbender/http/img/geoportal2019/styling.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/styling.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,33 @@
+ width="13.500000pt" height="13.500000pt" viewBox="0 0 1280.000000 1280.000000"
+<metadata>
+</metadata>
+<path d="M6135 11194 c-1192 -76 -2249 -543 -3088 -1364 -762 -745 -1247
+-1695 -1396 -2737 -38 -261 -46 -384 -45 -698 0 -443 38 -760 139 -1165 89
+-351 181 -602 350 -945 185 -376 364 -652 636 -980 118 -143 461 -481 616
+-608 711 -581 1539 -940 2440 -1057 312 -41 690 -50 798 -20 182 51 328 143
+434 275 130 161 191 350 177 555 -12 197 -68 325 -219 505 -67 80 -137 216
+-163 320 -25 96 -25 285 0 380 63 243 225 437 449 540 149 68 141 67 887 75
+371 4 686 10 700 13 14 4 70 13 125 22 536 84 1050 351 1447 752 324 327 539
+688 672 1133 108 360 133 810 70 1265 -186 1335 -1066 2512 -2379 3180 -582
+296 -1185 471 -1865 540 -147 15 -654 27 -785 19z m-840 -1094 c272 -86 474
+-296 547 -568 28 -109 28 -287 -1 -397 -74 -281 -295 -502 -576 -576 -114 -30
+-280 -30 -394 0 -277 73 -484 271 -571 546 -28 90 -38 267 -20 368 54 313 301
+570 614 642 94 22 312 14 401 -15z m2603 15 c315 -66 567 -325 622 -642 18
+-101 8 -278 -20 -368 -87 -275 -294 -473 -571 -546 -114 -30 -280 -30 -394 0
+-281 74 -502 295 -576 576 -30 112 -30 289 0 399 79 297 323 527 622 585 71
+14 242 12 317 -4z m-4308 -2126 c177 -28 313 -100 445 -233 133 -134 200 -272
+225 -464 32 -245 -61 -496 -247 -673 -98 -94 -201 -151 -340 -191 -102 -29
+-304 -31 -403 -4 -362 99 -600 408 -600 775 0 165 42 311 127 439 175 263 486
+401 793 351z m5958 -19 c348 -98 582 -408 582 -770 0 -165 -39 -297 -126 -433
+-250 -387 -770 -483 -1146 -210 -122 88 -238 250 -286 399 -88 271 -20 577
+175 785 123 130 271 213 438 245 96 19 269 11 363 -16z"/>
+</g>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/trash.svg
--- trunk/mapbender/http/img/geoportal2019/trash.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/trash.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,4 @@
+<path d="M15 2C15.5523 2 16 2.44772 16 3V4H2V3C2 2.44772 2.44772 2 3 2H5C5 1.44772 5.44772 1 6 1H12C12.5523 1 13 1.44772 13 2H15Z" fill="white"/>
+<path d="M15 5H3V15C3 16.1046 3.89543 17 5 17H13C14.1046 17 15 16.1046 15 15V5Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/up.svg
--- trunk/mapbender/http/img/geoportal2019/up.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/up.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path d="M16.0142 11.6191L14.6042 13.0291L9.01416 7.43914L3.42416 13.0291L2.01416 11.6191L9.01416 4.61914L16.0142 11.6191Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/verticaldots.svg
--- trunk/mapbender/http/img/geoportal2019/verticaldots.svg (rev 0)
+++ trunk/mapbender/http/img/geoportal2019/verticaldots.svg 2019-09-13 10:34:47 UTC (rev 10246)
@@ -0,0 +1,3 @@
+<path fill-rule="evenodd" clip-rule="evenodd" d="M7 4.5C7 3.67157 7.67157 3 8.5 3C9.32843 3 10 3.67157 10 4.5C10 5.32843 9.32843 6 8.5 6C7.67157 6 7 5.32843 7 4.5ZM7 9.5C7 8.67157 7.67157 8 8.5 8C9.32843 8 10 8.67157 10 9.5C10 10.3284 9.32843 11 8.5 11C7.67157 11 7 10.3284 7 9.5ZM8.5 13C7.67157 13 7 13.6716 7 14.5C7 15.3284 7.67157 16 8.5 16C9.32843 16 10 15.3284 10 14.5C10 13.6716 9.32843 13 8.5 13Z" fill="white"/>
+</svg>
Added: trunk/mapbender/http/img/geoportal2019/zoom.png
Index: trunk/mapbender/http/img/geoportal2019/zoom.png
--- trunk/mapbender/http/img/geoportal2019/zoom.png 2019-09-13 10:26:42 UTC (rev 10245)
+++ trunk/mapbender/http/img/geoportal2019/zoom.png 2019-09-13 10:34:47 UTC (rev 10246)
Property changes on: trunk/mapbender/http/img/geoportal2019/zoom.png
## -0,0 +1 ##
More information about the Mapbender_commits
