[Mapbender-dev] mapbender 2.2.3 on mapbender_dev
Arnulf Christl arnulf.christl at ccgis.de
Wed Apr 5 13:41:43 EDT 2006
Michael Schulz wrote:
> Hi,
> think i found the "problem":
thanx for the quick solution, you code faster than i can read! :-) I
added the bug to the Wiki, if this fix solves the problem, so much the
better. We'll update asap.
Arnulf.
> - in class_wms.php - updateObjInDb - around line 1008:
> if($gui_layer_maxscale[$lastLayer_index]<=$this->objLayer[$i]->layer_maxscale)
>  $sql .= $gui_layer_maxscale[$lastLayer_index] . ", ";
> } else { $sql .= $this->objLayer[$i]->layer_maxscale . ", ";}
> When the updated wms has no ScaleHint defined, then layer_maxscale is
> set to 0, thus any gui_layer settings (which are, when set, usually > 0)
> will be overwritten.
> Maybe we should check two things:
> 1) when no ScaleHint is defined (layer_maxscale==0)
>  or
> 2) when the gui_layer_maxscale is smaller than the Scalehint value
> then use the values from the gui_layer, otherwise use the ScaleHint values:
> if($this->objLayer[$i]->layer_maxscale == 0 ||
> What do you think?
> Michael
> Michael Schulz schrieb:
>> Hi,
>> not sure, maybe this behaviour is already known:
>> After updating a wms, the gui_layers max_scale settings are always set
>> to 0, instead of taking an already existing value. min_scale settings
>> are preserved.
>> Greetings from the South (of Germany), Michael
More information about the Mapbender_dev mailing list
