[Mapbender-dev] primary key for mb_user_name?
Astrid Emde astrid.emde at ccgis.de
Fri Aug 4 05:57:24 EDT 2006
Christoph Baudson schrieb:
> Hello,
> when I start Mapbender like this
> login.php?name=<aUserName>&password=<thisUsersPassword>&mb_user_myGui=<aGuiId>
> I have to specify a user *name*, but not a user *ID*. But the column
> "mb_user_name" has no primary key. Isn't this a problem? Maybe adding a
> primary key to "mb_user_name" would not be a bad idea.
Hi Christoph,
I think we don't have a problem with mb_user_name not having a primary key.
If you have a look at the database-structure in the mapbender-wiki
http://www.mapbender.org/index.php/Database-structure you can see that
the connection between the mb_user-table and the other tables is
realised by the primary key mb_user_id.
Only for the login, we ask for the mb_user_name. After we checked the
authentication we go on with the mb_user_id.
Or did I forget something?
Greetings astrid
More information about the Mapbender_dev mailing list
