[Mapbender-dev] primary key for mb_user_name?
Astrid Emde astrid.emde at ccgis.de
Fri Aug 4 06:41:12 EDT 2006
Christoph Baudson schrieb:
> Astrid,
>> Only for the login, we ask for the mb_user_name. After we checked the
>> authentication we go on with the mb_user_id.
> Although the registration procedure checks, if this username is taken,
> it might occur that a database entry comes from another source but the
> registration form on the web, f.e. a command line entry or a different
> module (someone adds his own registration module for instance).
> Because the user name needs to be unique, it should be reflected in the
> database too, so adding a UNIQUE constraint should suffice.
Hi christoph,
now I unterstand your point and agree to the primary key on the column
mb_user_name.
Astrid
More information about the Mapbender_dev mailing list
