[Mapbender-dev] module for VSP's
Stefan P.
ptfeti at gmx.de
Fri Dec 15 14:49:05 EST 2006
is the module commited yet? I would appreciate to have a look at it.
regards
Stefan
Michael Schulz wrote:
> Hi Uli,
> thanks for the information. No hurry. Can you give a short overview
> how it works?
> I tried creating a module that adds vsp to the appropriate
> wms-services layer only. Therefore i changed the include script for
> php variables to also create php-arrays. Then you can add, via gui
> element vars of that module, the layername where the vsp should be
> added, the url-vsp-key and the vsp-value. The key is also checked
> against $SESSION, so one could add the parameter and value to the
> mapbender call, and the module would take this value and turn it in an
> vsp (e.g. if you want to link other applications with mapbender).
> Cheers, Michael
> On 11/2/06, Ulrich Rothstein <uli.rothstein at ccgis.de> wrote:
>> Hi Michael,
>> that module exists but is not commited yet.
>> I'm back in the office at wednesday. If you need it earlier please
>> contact
>> Astrid.
>> regards
>> Uli
>> On Tue, October 31, 2006 4:01 pm, Michael Schulz wrote:
>> > Hi,
>> > i wanted to check whether there is an existing module to configure
>> > vendor specific parameters (vsp) for wms services through a mapbender
>> > admin-GUI?
>> > The background is, that when configuring access to wms services (for
>> > at the moment mostly umn mapserver wms) there is very often the need
>> > to have variable vsp, e.g. to transmit user information, that is used
>> > in the umn-mapfile for variable substitution.
>> > Anybody feeling a similar need?
>> > Cheers, Michael
>> > Michael Schulz
>> > mschulz at webgis.de
>> > in medias res
>> > Gesellschaft für Informationstechnologie mbH
>> > In den Weihermatten 66
>> > 79108 Freiburg
>> > Tel +49 (0)761 556959-5
>> > Fax +49 (0)761 556959-6
>> > http://www.webgis.de / http://www.zopecms.de
>> > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
>> > For additional commands, e-mail: dev-help at mapbender.osgeo.org
>> Ulrich Rothstein
>> CCGIS GbR
>> Siemensstraße 8
>> 53121 Bonn
>> GERMANY
>> www.ccgis.de
>> www.mapbender.org
>> Zentrale: ++49 (0) 228 90826 0
>> Durchwahl: ++49 (0) 228 90826 17
>> Fax: ++49 (0) 228 90826 11
> Michael Schulz
> in medias res
> 79108 Freiburg
View this message in context: http://www.nabble.com/module-for-VSP%27s-tf2546305.html#a7898056
Sent from the mapbender-dev mailing list archive at Nabble.com.
More information about the Mapbender_dev
