[Mapbender-dev] module for VSP's
Astrid Emde
astrid.emde at ccgis.de
Wed Dec 20 04:19:07 EST 2006
Stefan P. schrieb:
> Hi,
> is the module commited yet? I would appreciate to have a look at it.
> regards
> Stefan
> Michael Schulz wrote:
>> Hi Uli,
>> thanks for the information. No hurry. Can you give a short overview
>> how it works?
>> I tried creating a module that adds vsp to the appropriate
>> wms-services layer only. Therefore i changed the include script for
>> php variables to also create php-arrays. Then you can add, via gui
>> element vars of that module, the layername where the vsp should be
>> added, the url-vsp-key and the vsp-value. The key is also checked
>> against $SESSION, so one could add the parameter and value to the
>> mapbender call, and the module would take this value and turn it in an
>> vsp (e.g. if you want to link other applications with mapbender).
>> Cheers, Michael
>> On 11/2/06, Ulrich Rothstein <uli.rothstein at ccgis.de> wrote:
>>> Hi Michael,
>>> that module exists but is not commited yet.
>>> I'm back in the office at wednesday. If you need it earlier please
>>> contact
>>> Astrid.
>>> regards
>>> Uli
>>> On Tue, October 31, 2006 4:01 pm, Michael Schulz wrote:
>>>> Hi,
>>>> i wanted to check whether there is an existing module to configure
>>>> vendor specific parameters (vsp) for wms services through a mapbender
>>>> admin-GUI?
>>>> The background is, that when configuring access to wms services (for
>>>> at the moment mostly umn mapserver wms) there is very often the need
>>>> to have variable vsp, e.g. to transmit user information, that is used
>>>> in the umn-mapfile for variable substitution.
>>>> Anybody feeling a similar need?
>>>> Cheers, Michael
Hi devs, hi Stefan, hi Michael,
I checked in the modul mod_add_vendorspecific.php to add vendor
specific parameters to the MapRequest.
https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/mod_add_vendorspecific.php?view=auto&rev=983
Greetings
Astrid Emde
Astrid Emde
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 19
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
More information about the Mapbender_dev
