gml:featureMember with more than one geometry
Christoph Ratke
ratke at geoinformationsdienst.de
Tue Mar 7 04:19:45 EST 2006
Hi list,
when I made a Gazetteer request on geometries with "islands" (that is a
gml:featureMember element with ) I did not get the whole geometry but
only the last one. I am requesting a UMN Mapserver WFS (but I once
encountered the same with a Geoserver WFS). Finally I moved a counter in
another if condidtion in the parsegml function in classes/class_gml2.php.
I am not sure if this is a general problem or only a specific solution.
Could you please check it out once you got time (and maybe appropriate
geometries)? See the code snippet below:
// classes/class_gml2.php - parsegml($req):
changed
-- snip ---
else if(strtoupper($element[tag]) == strtoupper("gml:coordinates") &&
$geom == true){
$this->geometry[$this->member][$cnt_geom] =
str_replace(",,","",str_replace(" ",",",trim($element[value])));
else
if(in_array($this->sepNameSpace($element[tag]),$this->geometries) &&
$element[type] == "close"){
$cnt_geom++;
$geom = false;
--- snap ---
to
--- snip ---
$geom == true){
$cnt_geom++;
else
//$cnt_geom++;
$geom = false;
--- snap ---
regards
Christoph
Christoph Ratke
GeoInformationsDienst GmbH
Götzenbreite 10
37124 Rosdorf
Fon: ++49-(0)551-7890-25
eMail: ratke at geoinformationsdienst.de
Web: www.geoinformationsdienst.de
More information about the Mapbender_dev
