[Mapbender-dev] gml:featureMember with more than one geometry
Arnulf Christl (CCGIS)
arnulf.christl at ccgis.de
Tue Mar 7 04:25:02 EST 2006
> Hi list,
> when I made a Gazetteer request on geometries with "islands" (that is a
> gml:featureMember element with ) I did not get the whole geometry but
> only the last one. I am requesting a UMN Mapserver WFS (but I once
> encountered the same with a Geoserver WFS). Finally I moved a counter in
> another if condidtion in the parsegml function in classes/class_gml2.php.
> I am not sure if this is a general problem or only a specific solution.
> Could you please check it out once you got time (and maybe appropriate
> geometries)? See the code snippet below:
thanx for the info. The dev group is somewhat decimated due to illness and
holidays, so we will act upon this with a few days relay.
Best,
> // classes/class_gml2.php - parsegml($req):
> changed
> -- snip ---
> else if(strtoupper($element[tag]) == strtoupper("gml:coordinates") &&
> $geom == true){
> $this->geometry[$this->member][$cnt_geom] =
> str_replace(",,","",str_replace(" ",",",trim($element[value])));
> else
> if(in_array($this->sepNameSpace($element[tag]),$this->geometries) &&
> $element[type] == "close"){
> $cnt_geom++;
> $geom = false;
> --- snap ---
> to
> --- snip ---
> $geom == true){
> $cnt_geom++;
> else
> //$cnt_geom++;
> $geom = false;
> --- snap ---
> regards
> Christoph
> Christoph Ratke
> GeoInformationsDienst GmbH
> Götzenbreite 10
> 37124 Rosdorf
> Fon: ++49-(0)551-7890-25
> eMail: ratke at geoinformationsdienst.de
> Web: www.geoinformationsdienst.de
> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: dev-help at mapbender.osgeo.org
Arnulf Christl
http://www.ccgis.de
More information about the Mapbender_dev
