loadwmc needs addWMS!?
Michael Schulz
mschulz at webgis.de
Mon May 15 11:55:40 EDT 2006
in the module mb_listWMCs.php the action for load,merge,append uses the
module addWMS to load the required targets, etc.. Is this intended?
Because this adds a dependency to the loadwmc module that is not
necessary, is it?
At first glimpse, changing the e_id in the relevant SELECT-Statement to
loadwmc and adding the needed gui_element attribute values (treeGDE,
mapframe1 for target and loadData for requires) seems to work.
It might be useful to be able to load saved wmcs, but not to be able to
add arbitrary wms to a gui.
Cheers, Michael
Michael Schulz mschulz at webgis.de
in medias res Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66 Tel +49 (0)761 556959-5
79108 Freiburg Fax +49 (0)761 556959-6
www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
More information about the Mapbender_dev
