[Mapbender-dev] loadwmc needs addWMS!?
Michael Schulz
mschulz at webgis.de
Tue May 23 04:25:18 EDT 2006
Hi Christoph,
thanks, that looks good. To update accordingly, i would have to use this
module in the requires gui element field, e.g. of the loadwmc module?
Michael
Christoph Baudson schrieb:
> Hi Michael,
> There is a new module addWMSgeneralfunctions.js that contains the basic
> functions necessary to add a wms. Only this module is needed for WMCs,
> so adding arbitrary WMS to a gui is not possible.
> If you have any thoughts concerning this topic, please share them.
> Cheers,
> Christoph
> Arnulf Christl schrieb:
>> Michael,
>> Christoph has worked over the AddWMS Wiki section because of some other
>> problem. Please check whether this touches your last question and if not
>> suggest how to go on.
>> Arnulf.
>>>> On Mon, May 15, 2006 17:55, Michael Schulz wrote:
>>>>> Hi,
>>>>> in the module mb_listWMCs.php the action for load,merge,append uses
>>>>> the
>>>>> module addWMS to load the required targets, etc.. Is this intended?
>>>>> Because this adds a dependency to the loadwmc module that is not
>>>>> necessary, is it?
>>>>> At first glimpse, changing the e_id in the relevant
>>>>> SELECT-Statement to
>>>>> loadwmc and adding the needed gui_element attribute values (treeGDE,
>>>>> mapframe1 for target and loadData for requires) seems to work.
>>>>> It might be useful to be able to load saved wmcs, but not to be
>>>>> able to
>>>>> add arbitrary wms to a gui.
>>>>> Cheers, Michael
>>>> Hi,
>>>> the problem will grow a little more complex once we add Context
>>>> Documents
>>>> to the OWS security proxy module as we ill have to rewrite the
>>>> Capabilities and getMap requests withdynamic urls that have been masked
>>>> with an md5 hash generated from the sessions-id. So development is
>>>> still
>>>> open.
>>> Hi,
>>> sure, the new developments have priority, no question.
>>>> I do not quite understand your problem with adding arbitrary maps
>>>> because
>>>> add wms is included in the GUI. Does it mean you want to reestrict the
>>>> user to be able to only load services that are included in the context
>>>> doc?
>>> More or less, since he can only save wmc from his current set of wms.
>>> It's just that the functionality of adding any wms(-url) to the gui
>>> might not be in the user's
>>> security context (so module addWMS is not in the gui), whereas
>>> loading and
>>> saving wmc with the wms-services that lie inside his security context is
>>> very
>>> valuable (modules load/savewmc are present in the gui). At the moment
>>> this is not
>>> possible because there is a dependancy of loadwmc with addWMS.
>>> Greetings, Michael
>>> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
>>> For additional commands, e-mail: dev-help at mapbender.osgeo.org
Michael Schulz mschulz at webgis.de
in medias res Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66 Tel +49 (0)761 556959-5
79108 Freiburg Fax +49 (0)761 556959-6
www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
More information about the Mapbender_dev
