[Mapbender-dev] GUI Digitizing tests
Christoph Baudson christoph.baudson at ccgis.de
Fri Nov 10 04:23:34 EST 2006
Hello folks,
thanks for your help, Arnulf. I'm currently working on re-designing the
underlying architecture of the digitizing/WFS-components, that's why
some things might not have worked. I apologize, I should have been more
careful. I have updated the wiki page at
http://www.mapbender.org/index.php/Talk:Digitizing.
Previously, all modules were dependent on each other, so there was no
chance to have e.g. WFS-requests without digitizing. The new design (try
GUI gui_digitize_modular on http://wms1.ccgis.de/mapbender_dev/)
introduces a modular approach. Now, each module that intends working
with the results of a WFS request, registers at the WFS-request module
and is being handed the results whenever they occur.
Some insights I gained:
First of all, there is a need for a geometry library. I started out with
extending the geometry data types for digitizing only, but then realized
I can use them everywhere in Mapbender. So there will be a new module
geometry.js, which will contain all necessary data types and methods.
I'm still working on this module; in the end, all GUIs working with
digitizing and WFS stuff need to add this module via the administration.
Furthermore, I just wondered editing the digitzing talk wiki page, if
this kind of information would not better be stored in the bug tracker
at
http://sourceforge.net/tracker/?atid=587112&group_id=88554&func=browse
Please enlighten me, I might be wrong.
I will need some more time working on the new
digitizing/WFS-environment, so the documentation will have to wait a
little longer, as I am not yet sure about which way it is exactly going to.
I will specify my approach in a follow-up post.
Cheers, Christoph
BTW, is there a need for translation, or is this list in english only?
Arnulf Christl schrieb:
> Hi Christoph,
> there are some inconsistencies in the digitizing gui, I have added them
> to the discussion page. http://www.mapbender.org/index.php/Talk:Digitizing
> Seems like no one else had any issues with it, we have it out there now
> for several months and some seem to be using it productively already.
> So we should consider move this feature to stable. To do this we need
> work over the documentation which is a little spread out between more
> technical issues and a user doc. We need both but esp. the user doc
> version needs an update badly...
> Best regards, Arnulf.
> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: dev-help at mapbender.osgeo.org
More information about the Mapbender_dev mailing list
