geometry library
Christoph Baudson christoph.baudson at ccgis.de
Fri Nov 10 05:09:56 EST 2006
Hi again,
the new geometry library will probably contain all the stuff now
seperately located in
point.js
mod_geometryArray.js
mod_highlight.php
These classes are all dependent on each other; so I would rather build a
big module. Having to load many different modules in the administration
will make the application more difficult to use.
A problem with just including these files in php is, that modules may be
in different frames and you would have to make distinctions like
"parent.", "window.opener" or "window.frames[]" when two modules shared
the library (I believe loading a module twice in different frames is out
of the question).
The point class might be interesting to use generally in map.php, as it
would be useful in many cases, for example in map/real coordinate
conversion or bounding box representation. As it is not big, it might
not affect the performance of map.php. Should it be included in the
index.php generally?
If anyone is interested in these topics, I would be glad about some input.
Cheers, Christoph
More information about the Mapbender_dev mailing list
