[Mapbender-dev] geometry library
Christoph Baudson
christoph.baudson at ccgis.de
Tue Nov 14 09:15:32 EST 2006
Hi there,
Today I have committed the first draft of the geometry class. The
purpose is to have a single module that contains all geometric data
types and methods required for digitizing and handling geometries from
wfs requests.
https://mapbender.osgeo.org/source/browse/mapbender/trunk/mapbender/http/javascripts/geometry.js?view=auto&rev=818
It contains mainly everything from
mod_geometryArray.js
mod_highlight.php
plus two additional functions.
I have not included point.js, because I think it might be a good idea to
include it in index.php rightaway.
Pros:
+ simplifies information exchange between classes and functions (it's
more convenient handing over a point than an array of x-y-values)
+ saves code in the long run (no more arrays)
+ Possible enhancements: for example adding a boolean representing
whether the point is a real coordinate or a screen position.
+ when two modules using point.js are in seperate frames, the class
would have to be loaded twice otherwise.
Cons:
- Memory size of a point. The point object includes functions and data.
Imagine a geometry with thousands of points.
- despite its small size there is more overhead meaning more traffic
(we're talking about 2 KB here).
(*Please add your pros/cons!*)
It would be a good idea to vote which new code is allowed in
map.php/index.php. All members of the Mapbender PSC are eligible to
vote. But maybe we discuss the topic first, and have a vote next week.
BTW, modularisation already paid off for me:
* the class Highlight is now being used both for highlighting *and* snapping
* Snapping itself is being used in digitizing *and* closing a search
polygon.
* The function that returns only the part of a line that's visible in
the mapframe is being used both for digitized *and* highlighted geometries.
It saves a lot of code and is so much easier to maintain.
Cheers, Christoph
More information about the Mapbender_dev
