[Mapbender-dev] what about the new version Mapbender 2.4.1
Melchior Moos
melchior.moos at ccgis.de
Fri Nov 24 06:06:21 EST 2006
Hi all,
I've created a patch for mod_dragMapSize.php which enables dragging over
other iframes and cancels resizing when the new size would be negative.
I think this is also something that could be integrated in the new version.
Another patch I created enables approximated measuring for epsg 4326
with mod_measure.php. I don't know if this is interesting because there
is an other module which does it.
What about integrating the mod_mapcheck module from geoportal? It shows
an alert if there occures an error while loading a wms image file.
regards,
Melchior
Astrid Emde schrieb:
> Hi dev,
> the new version is planned for the middle of november. That's now.
> Mapbender has some nice features and nothing can stop us to bring out
> the new release. But as it seems we will have a little delay.
> Some work has to be done.
> * all new moduls have to be documented in the wiki
> http://www.mapbender.org/index.php/Version_History
> * the sqls for the database changes have to be prepared (I [Astrid]
> will do this)
> * if you notice any bugs tell it soon
> * and please check the code from the svn a try it out
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20061124/8361552a/dragMapSize.bin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20061124/8361552a/mod_measure.bin
More information about the Mapbender_dev
