[Mapbender-dev] svn not working?
Auke Jilderda
auke at collab.net
Thu Oct 12 13:56:36 EDT 2006
Just checking, it works flawlessly for me. Can you ping the site? Can you ping other sites?
Auke
> -----Original Message-----
> From: mandschulz at googlemail.com
> [mailto:mandschulz at googlemail.com] On Behalf Of Michael Schulz
> Sent: 12 October 2006 19:09
> To: dev at mapbender.osgeo.org
> Subject: [Mapbender-dev] svn not working?
> Hi,
> i get the following error trying to checkout mapbender:
> wms1:/tmp # svn checkout
> https://mapbender.osgeo.org/svn/mapbender/trunk mapbender --username
> guest
> svn: PROPFIND request failed on '/svn/mapbender/trunk'
> svn: PROPFIND of '/svn/mapbender/trunk': could not connect to server
> (https://mapbender.osgeo.org)
> I tested it on two servers, same error. The same checkout worked
> several weeks ago without problems.
> Cheers, Michael
> Michael Schulz
> mschulz at webgis.de
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
> To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: dev-help at mapbender.osgeo.org
More information about the Mapbender_dev
