[Mapbender-dev] svn not working?
Michael Schulz
mandschulz at googlemail.com
Thu Oct 12 15:32:06 EDT 2006
I'll try it tomorrow morning from this server again.
Sounds like my network has problems, when it works for you.
I'll check that again.
thx, Michael
On 10/12/06, Auke Jilderda <auke at collab.net> wrote:
> Just checking, it works flawlessly for me. Can you ping the site? Can you ping other sites?
> Auke
> > -----Original Message-----
> > From: mandschulz at googlemail.com
> > [mailto:mandschulz at googlemail.com] On Behalf Of Michael Schulz
> > Sent: 12 October 2006 19:09
> > To: dev at mapbender.osgeo.org
> > Subject: [Mapbender-dev] svn not working?
> > Hi,
> > i get the following error trying to checkout mapbender:
> > wms1:/tmp # svn checkout
> > https://mapbender.osgeo.org/svn/mapbender/trunk mapbender --username
> > guest
> > svn: PROPFIND request failed on '/svn/mapbender/trunk'
> > svn: PROPFIND of '/svn/mapbender/trunk': could not connect to server
> > (https://mapbender.osgeo.org)
> > I tested it on two servers, same error. The same checkout worked
> > several weeks ago without problems.
> > Cheers, Michael
> > Michael Schulz
> > mschulz at webgis.de
> > in medias res
> > Gesellschaft für Informationstechnologie mbH
> > In den Weihermatten 66
> > 79108 Freiburg
> > Tel +49 (0)761 556959-5
> > Fax +49 (0)761 556959-6
> > http://www.webgis.de / http://www.zopecms.de
> > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> > For additional commands, e-mail: dev-help at mapbender.osgeo.org
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev
