[Mapbender-dev] svn not working?
Auke Jilderda auke at collab.net
Fri Oct 13 09:56:01 EDT 2006
Michael,
any news on this?
Auke
> -----Original Message-----
> From: Michael Schulz [mailto:mandschulz at googlemail.com]
> Sent: 12 October 2006 21:32
> To: Auke Jilderda
> Cc: Frank Warmerdam; dev at mapbender.osgeo.org
> Subject: Re: [Mapbender-dev] svn not working?
> I'll try it tomorrow morning from this server again.
> Sounds like my network has problems, when it works for you.
> I'll check that again.
> thx, Michael
> On 10/12/06, Auke Jilderda <auke at collab.net> wrote:
> > Just checking, it works flawlessly for me.  Can you ping
> the site?  Can you ping other sites?
> > Auke
> > > From: mandschulz at googlemail.com
> > > [mailto:mandschulz at googlemail.com] On Behalf Of Michael Schulz
> > > Sent: 12 October 2006 19:09
> > > To: dev at mapbender.osgeo.org
> > > Subject: [Mapbender-dev] svn not working?
> > > Hi,
> > > i get the following error trying to checkout mapbender:
> > > wms1:/tmp # svn checkout
> > > https://mapbender.osgeo.org/svn/mapbender/trunk mapbender
> --username
> > > guest
> > > svn: PROPFIND request failed on '/svn/mapbender/trunk'
> > > svn: PROPFIND of '/svn/mapbender/trunk': could not
> connect to server
> > > (https://mapbender.osgeo.org)
> > > I tested it on two servers, same error. The same checkout worked
> > > several weeks ago without problems.
> > > Cheers, Michael
> > > Michael Schulz
> > > mschulz at webgis.de
> > > in medias res
> > > Gesellschaft für Informationstechnologie mbH
> > > In den Weihermatten 66
> > > 79108 Freiburg
> > > Tel  +49 (0)761 556959-5
> > > Fax +49 (0)761 556959-6
> > > http://www.webgis.de / http://www.zopecms.de
> > > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> > > For additional commands, e-mail: dev-help at mapbender.osgeo.org
> Michael Schulz
> in medias res
> 79108 Freiburg
More information about the Mapbender_dev mailing list
