[Mapbender-dev] svn not working?
Michael Schulz
mandschulz at googlemail.com
Fri Oct 13 11:01:10 EDT 2006
Hi Auke,
i tried succesfully to ping mapbender.osgeo.org, but svn checkout via
command line still not working. I assume a networking problem on my
side. I tried svn access via tortoise from another machine, and
successfully checked mapbender out. Sorry for the bother.
THX, Michael
On 10/13/06, Auke Jilderda <auke at collab.net> wrote:
> Michael,
> any news on this?
> Auke
> > -----Original Message-----
> > From: Michael Schulz [mailto:mandschulz at googlemail.com]
> > Sent: 12 October 2006 21:32
> > To: Auke Jilderda
> > Cc: Frank Warmerdam; dev at mapbender.osgeo.org
> > Subject: Re: [Mapbender-dev] svn not working?
> > I'll try it tomorrow morning from this server again.
> > Sounds like my network has problems, when it works for you.
> > I'll check that again.
> > thx, Michael
> > On 10/12/06, Auke Jilderda <auke at collab.net> wrote:
> > > Just checking, it works flawlessly for me. Can you ping
> > the site? Can you ping other sites?
> > > Auke
> > > > From: mandschulz at googlemail.com
> > > > [mailto:mandschulz at googlemail.com] On Behalf Of Michael Schulz
> > > > Sent: 12 October 2006 19:09
> > > > To: dev at mapbender.osgeo.org
> > > > Subject: [Mapbender-dev] svn not working?
> > > > Hi,
> > > > i get the following error trying to checkout mapbender:
> > > > wms1:/tmp # svn checkout
> > > > https://mapbender.osgeo.org/svn/mapbender/trunk mapbender
> > --username
> > > > guest
> > > > svn: PROPFIND request failed on '/svn/mapbender/trunk'
> > > > svn: PROPFIND of '/svn/mapbender/trunk': could not
> > connect to server
> > > > (https://mapbender.osgeo.org)
> > > > I tested it on two servers, same error. The same checkout worked
> > > > several weeks ago without problems.
> > > > Cheers, Michael
> > > > Michael Schulz
> > > > mschulz at webgis.de
> > > > in medias res
> > > > Gesellschaft für Informationstechnologie mbH
> > > > In den Weihermatten 66
> > > > 79108 Freiburg
> > > > Tel +49 (0)761 556959-5
> > > > Fax +49 (0)761 556959-6
> > > > http://www.webgis.de / http://www.zopecms.de
> > > > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> > > > For additional commands, e-mail: dev-help at mapbender.osgeo.org
> > Michael Schulz
> > in medias res
> > 79108 Freiburg
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev
