[Mapbender-dev] svn not working?
Auke Jilderda auke at collab.net
Fri Oct 13 11:08:07 EDT 2006
No problem.  Such propfind errors generally indicate network connectivity errors indeed but it's hard to tell what the issue is from here ;-)
Good luck,
Auke
> -----Original Message-----
> From: Michael Schulz [mailto:mandschulz at googlemail.com]
> Sent: 13 October 2006 17:01
> To: Auke Jilderda
> Cc: Frank Warmerdam; dev at mapbender.osgeo.org
> Subject: Re: [Mapbender-dev] svn not working?
> Hi Auke,
> i tried succesfully to ping mapbender.osgeo.org, but svn checkout via
> command line still not working. I assume a networking problem on my
> side. I tried svn access via tortoise from another machine, and
> successfully checked mapbender out. Sorry for the bother.
> THX, Michael
> On 10/13/06, Auke Jilderda <auke at collab.net> wrote:
> > Michael,
> > any news on this?
> > Auke
> > > Sent: 12 October 2006 21:32
> > > To: Auke Jilderda
> > > I'll try it tomorrow morning from this server again.
> > > Sounds like my network has problems, when it works for you.
> > > I'll check that again.
> > > thx, Michael
> > > On 10/12/06, Auke Jilderda <auke at collab.net> wrote:
> > > > Just checking, it works flawlessly for me.  Can you ping
> > > the site?  Can you ping other sites?
> > > > Auke
> > > > > From: mandschulz at googlemail.com
> > > > > [mailto:mandschulz at googlemail.com] On Behalf Of Michael Schulz
> > > > > Sent: 12 October 2006 19:09
> > > > > To: dev at mapbender.osgeo.org
> > > > > Subject: [Mapbender-dev] svn not working?
> > > > > Hi,
> > > > > i get the following error trying to checkout mapbender:
> > > > > wms1:/tmp # svn checkout
> > > > > https://mapbender.osgeo.org/svn/mapbender/trunk mapbender
> > > --username
> > > > > guest
> > > > > svn: PROPFIND request failed on '/svn/mapbender/trunk'
> > > > > svn: PROPFIND of '/svn/mapbender/trunk': could not
> > > connect to server
> > > > > (https://mapbender.osgeo.org)
> > > > > I tested it on two servers, same error. The same
> checkout worked
> > > > > several weeks ago without problems.
> > > > > Cheers, Michael
> > > > > Michael Schulz
> > > > > mschulz at webgis.de
> > > > > in medias res
> > > > > Gesellschaft für Informationstechnologie mbH
> > > > > In den Weihermatten 66
> > > > > 79108 Freiburg
> > > > > Tel  +49 (0)761 556959-5
> > > > > Fax +49 (0)761 556959-6
> > > > > http://www.webgis.de / http://www.zopecms.de
> > > > > To unsubscribe, e-mail: dev-unsubscribe at mapbender.osgeo.org
> > > > > For additional commands, e-mail: dev-help at mapbender.osgeo.org
> > > Michael Schulz
> > > in medias res
> > > 79108 Freiburg
> Michael Schulz
> in medias res
> 79108 Freiburg
More information about the Mapbender_dev mailing list
