[Mapbender-dev] noscript tag
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon Apr 2 09:59:16 EDT 2007
I think this is a very sensible addition. Thanks very much for your
contribution and I guess we will add this to the next Mapbender version.
Cheers
Christoph
Marc Jansen schrieb:
> Hi list,
> some smaller improvements:
> * give measurement-units within the CSS part: e.g. top:300px;
> * do not use the <font>-tag, as this is deprecated
> * use HTML-entities for German Umlauts (e.g. ü instead of ü)
> * embed a link with the current location so the user can refresh the
> page easily after enabling JavaScript
> all the best
> -- Marc
> Hr. Johannes Loose schrieb:
>> Hello List,
>> Mapbender uses a lot of Javascript, what has the effect that the GUI
>> will not load properly if JavaScript is disabled. In this case, the
>> user can expect at least a small 'Javascript is off...' notice. I have
>> not found such a function in the mapbender sources, so I used the
>> <noscript> tag to display such a notice. This solution works fine in
>> IE and firefox (recent version), to make IE work I had to put the
>> style attributes in an additional <div> .
>> Maybe there are better ways to solve that problem, if someone knows a
>> better solution, please let me know. Unfortunately it is not possible
>> to go over an 'introducing page' because the users will call our
>> mapbender installation from very diffenent locations with optional
>> parameters (user, pw, gui, meeting point).
>> INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
>> e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
>> e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
>> e_target, e_requires, e_url) VALUES('myGUI','JSCheck',2,1,'Gibt einen
>> Hinweis aus falls JavaScript deaktiviert ist','noscript','','',NULL
>> ,,NULL ,,NULL ,'','<div style =
>> ''position:absolute;left:250;top:300;width:500;height:400;z-index:1;''><font
>> size="+1" color="red">Für diesen Service ist die Aktivierung von
>> JavaScript erforderlich. Wie Sie in Ihrem Web-Browser JavaScript
>> aktivieren können, erfahren Sie in der Anleitung zu Ihrem
>> Web-Browser.</font></div>','noscript','','','','','');
>> Greetings
>> Johannes
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - **
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_dev
