[Mapbender-dev] noscript tag
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Apr 24 03:42:10 EDT 2007
On the other hand, would it suffice to add a noscript tag to index.php
manually? The more modules we produce, the slower Mapbender gets.
It would be less configurable, but maybe there is no need to do that.
What do you think?
Christoph Baudson (WhereGroup) schrieb:
> I think this is a very sensible addition. Thanks very much for your
> contribution and I guess we will add this to the next Mapbender version.
> Cheers
> Christoph
> Marc Jansen schrieb:
>> Hi list,
>> some smaller improvements:
>>    * give measurement-units within the CSS part: e.g. top:300px;
>>    * do not use the <font>-tag, as this is deprecated
>>    * use HTML-entities for German Umlauts (e.g. &uuml; instead of ü)
>>    * embed a link with the current location so the user can refresh the
>>      page easily after enabling JavaScript
>> all the best
>> -- Marc
>> Hr. Johannes Loose schrieb:
>>> Hello List,
>>> Mapbender uses a lot of Javascript, what has the effect that the GUI
>>> will not load properly if JavaScript is disabled. In this case, the
>>> user can expect at least a small 'Javascript is off...' notice. I
>>> have not found such a function in the mapbender sources, so I used
>>> the <noscript> tag to display such a notice. This solution works fine
>>> in IE and firefox (recent version), to make IE work I had to put the
>>> style attributes in an additional <div> .
>>> Maybe there are better ways to solve that problem, if someone knows a
>>> better solution, please let me know. Unfortunately it is not possible
>>> to go over an 'introducing page' because the users will call our
>>> mapbender installation from very diffenent locations with optional
>>> parameters (user, pw, gui, meeting point).
>>> INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
>>> e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
>>> e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
>>> e_mb_mod, e_target, e_requires, e_url)
>>> VALUES('myGUI','JSCheck',2,1,'Gibt einen Hinweis aus falls JavaScript
>>> deaktiviert ist','noscript','','',NULL ,,NULL ,,NULL ,'','<div style
>>> ''position:absolute;left:250;top:300;width:500;height:400;z-index:1;''><font
>>> size="+1" color="red">Für diesen Service ist die Aktivierung von
>>> JavaScript erforderlich. Wie Sie in Ihrem Web-Browser JavaScript
>>> aktivieren können, erfahren Sie in der Anleitung zu Ihrem
>>> Web-Browser.</font></div>','noscript','','','','','');
>>> Greetings
>>> Johannes
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
