[Mapbender-dev] motion: establish jQuery as default Javascript
library
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Tue Apr 3 03:23:56 EDT 2007
Hi all,
I think we need jQuery to implement features with more look & feel and if it's
not possible to use a wrapper (as we use it for Ajax), we should use jQuery as a
default library in mapbender.
So I second the motion.
best regards
Uli
Christoph Baudson (WhereGroup) schrieb:
> In yesterday's IRC meeting
> (http://logs.qgis.org/mapbender/%23mapbender.2007-04-02.log) we
> discussed the usage of jQuery as a default JavaScript library.
> At the moment we're trying to solve an interface problem with a
> drag-and-drop approach. With jQuery it took merely 15 lines to
> implement. In the future we are planning to enhance the usability with
> features like this, so that Mapbender has more of an application feel
> (and not a website feel)...is that what you meant by clickeridoo, seven?
> :-) jQuery might be very helpful.
> The most important question are: Do we need a wrapper? Is it possible to
> implement a wrapper? I propose we can't and don't need to.
> Pro's of jQuery are
> - high level of abstraction; implementation of complex things is easy
> - jQuery seems to be stable; it seems to be widely used
> - we already use it for AJAX and are therefore used to it
> Con's are
> - depending on a single library might not be a good idea if you don't
> use a wrapper
> Someone has to second this motion, then the voting process begins. All
> developers (everyone) are allowed to vote.
> Christoph
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
