[Mapbender-dev] proposal: new column in db
Sebastian Schmitz sebastian.schmitz at wheregroup.com
Wed Aug 8 03:32:12 EDT 2007
+1
Sebastian
Samson, Marko schrieb:
> +1 to the new column
> @testbaudson have a nice vacation
> Marko
>> -----Original Message-----
>> From: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
>> Uli Rothstein (WhereGroup)
>> Sent: Wednesday, August 08, 2007 8:41 AM
>> To: Mapbender Developer List
>> Subject: Re: [Mapbender-dev] proposal: new column in db
>> Hi,
>> +1 for the new column e_title.
>> best regards
>> Uli
>> Christoph Baudson (WhereGroup) schrieb:
>>> When experimenting with internationalization I realized
>> that there is
>>> a general need to separate content from structure in Mapbender.
>>> An example is the tooltip for each module, which originates from a
>>> database entry "e_attributes" in table "gui_element". A
>> typical entry
>>> would look like this:
>>> onclick='mod_addWMS()'  onmouseover='this.src =
>>> this.src.replace(/_off/,"_over");'  onmouseout='this.src =
>>> this.src.replace(/_over/, "_off");' title="Adding WMS"
>>> It's not easy extracting the translation of the title from
>> this field.
>>> So I propose to add a new column "e_title" to gui_element,
>> where the
>>> tooltip may come from. By this way, it will be easy to
>> translate the
>>> title as it is isolated.
>>> The title may also be used for the headers in the module "mod_tab".
>>> Please vote on my proposal ASAP, so I can check in the
>> relevant code
>>> before my vacation starting Saturday.
>>> Thanks
>>> Baudson Christoph
>>> http://www.wheregroup.com
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Ulrich Rothstein
>> WhereGroup GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 17
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:uli.rothstein at wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
WhereGroup
GmbH & Co. KG
Siemensstr. 8
D-53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 24
mailto:sebastian.schmitz at wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev mailing list
