[Mapbender-dev] proposal: new column in db
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Wed Aug 8 02:46:57 EDT 2007
+1 to the new column
@testbaudson have a nice vacation
Marko
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Uli Rothstein (WhereGroup)
> Sent: Wednesday, August 08, 2007 8:41 AM
> To: Mapbender Developer List
> Subject: Re: [Mapbender-dev] proposal: new column in db
> Hi,
> +1 for the new column e_title.
> best regards
> Uli
> Christoph Baudson (WhereGroup) schrieb:
> > When experimenting with internationalization I realized
> that there is
> > a general need to separate content from structure in Mapbender.
> > An example is the tooltip for each module, which originates from a
> > database entry "e_attributes" in table "gui_element". A
> typical entry
> > would look like this:
> > onclick='mod_addWMS()' onmouseover='this.src =
> > this.src.replace(/_off/,"_over");' onmouseout='this.src =
> > this.src.replace(/_over/, "_off");' title="Adding WMS"
> > It's not easy extracting the translation of the title from
> this field.
> > So I propose to add a new column "e_title" to gui_element,
> where the
> > tooltip may come from. By this way, it will be easy to
> translate the
> > title as it is isolated.
> > The title may also be used for the headers in the module "mod_tab".
> > Please vote on my proposal ASAP, so I can check in the
> relevant code
> > before my vacation starting Saturday.
> > Thanks
> > Baudson Christoph
> > http://www.wheregroup.com
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Ulrich Rothstein
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:uli.rothstein at wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
