[Mapbender-dev] proposal: new column in db
Uli Rothstein (WhereGroup) uli.rothstein at wheregroup.com
Wed Aug 8 02:41:07 EDT 2007
+1 for the new column e_title.
best regards
Uli
Christoph Baudson (WhereGroup) schrieb:
> When experimenting with internationalization I realized that there is a
> general need to separate content from structure in Mapbender.
> An example is the tooltip for each module, which originates from a
> database entry "e_attributes" in table "gui_element". A typical entry
> would look like this:
> onclick='mod_addWMS()'  onmouseover='this.src =
> this.src.replace(/_off/,"_over");'  onmouseout='this.src =
> this.src.replace(/_over/, "_off");' title="Adding WMS"
> It's not easy extracting the translation of the title from this field.
> So I propose to add a new column "e_title" to gui_element, where the
> tooltip may come from. By this way, it will be easy to translate the
> title as it is isolated.
> The title may also be used for the headers in the module "mod_tab".
> Please vote on my proposal ASAP, so I can check in the relevant code
> before my vacation starting Saturday.
> Thanks
> Baudson Christoph
> http://www.wheregroup.com
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
