AW: [Mapbender-dev] proposal: new column in db
Heuser, Bjoern
Bjoern.Heuser at sag.de
Wed Aug 8 03:30:30 EDT 2007
+1 from me
Björn
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Thomas Baschetti
Gesendet: Mittwoch, 8. August 2007 09:22
An: Mapbender Developer List
Betreff: Re: [Mapbender-dev] proposal: new column in db
+1 from me,
bye
Thomas
> Christoph Baudson (WhereGroup) schrieb:
> > When experimenting with internationalization I realized that there is
> > a general need to separate content from structure in Mapbender.
> > An example is the tooltip for each module, which originates from a
> > database entry "e_attributes" in table "gui_element". A typical entry
> > would look like this:
> > onclick='mod_addWMS()' onmouseover='this.src =
> > this.src.replace(/_off/,"_over");' onmouseout='this.src =
> > this.src.replace(/_over/, "_off");' title="Adding WMS"
> > It's not easy extracting the translation of the title from this field.
> > So I propose to add a new column "e_title" to gui_element, where the
> > tooltip may come from. By this way, it will be easy to translate the
> > title as it is isolated.
> > The title may also be used for the headers in the module "mod_tab".
> > Please vote on my proposal ASAP, so I can check in the relevant code
> > before my vacation starting Saturday.
> +1 from me
> greetings astrid
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the Mapbender_dev
