[Mapbender-dev] SLD branch error msg
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Dec 18 07:29:09 EST 2007
Hi Joscha,
did you install the mb_string library in PHP?
Cheers
Christoph
Joscha Laubach schrieb:
> Hi dev list,
> yesterday I installed Mapbender from the SLD branch for testing
> reasons. After logging in and choosing one of the GUIs I always get
> the error message
> Fatal error: Call to undefined function mb_internal_encoding() in
> L:\Program Files\mapbender_sld\http\frames\index.php on line 22
> The mentioned line
> mb_internal_encoding("UTF-8");
> doesn't exist in my current Mapbender 2.4.3 installation.
> Does this work at your installations? Or is it a known error? There
> was some merging done in this branch lately.
> Regards, Joscha
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
