AW: [Mapbender-dev] oracle database support
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Tue Jan 9 03:24:43 EST 2007
Hi Devs,
The idea of including or supporting some more dbs is quiet a good idea. And Oracle is still one of the VI(P)DB.
I also thought about implementing Oracle cause we use it as main db for most of our software, but discarded it because of absence of time and priority.
But I still have included a search function (stone me to death cause of not using the WFS gazetteer for this;-) ) on our data, which uses the oci_functions and the oracle db.
I will provide support, as much as I can, too.
But if it will be integrated into the core of mb, there should be enough backup to hold the "database-oracle.php" and the addicted stuff up to date.
Which were the time-killing probs, while you implemented for example postgres?@Arnulf
btw.: Which tool do you use to form the db-structure? Is it en eclipse-plugin? (think the wiki-db-structure is not up to date in reference to the svn db update scripts)
@Arnulf: Is there a new idea for all the poor firewalled and port-blocked people, to use the IRC or something like this?
Gruß,
Marko
Marko Samson
Landesbetrieb Wald und Holz
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Achtung, neue Telefonnummer!
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
> -----Ursprüngliche Nachricht-----
> Von: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
> Arnulf Christl
> Gesendet: Montag, 8. Januar 2007 21:17
> An: Discussion of Mapbender Development
> Betreff: Re: [Mapbender-dev] oracle database support
> Hi Lars,
> thats good news! There have been several requests but none
> was really leading anywhere.
> We have made some decisions a while ago to not use a generic
> wrapper but implement the SQLs directly - mostly for
> performance issues and to minimize overall application
> dependencies. The database design also requires to use a
> table type that supports referential integrity. This means
> MySQL InnoDB which does not support spatial functionality.
> Therefore we try to avoid using spatial SQL in the database
> altogether but resort to GEOS. Sometimes we don't.
> History:
> We started off ~5 years ago with MS Access, then
> re-engineered 3 years ago and moved to MySQL. 2005 saw the
> support of PostgreSQL which took us 6 times the time we
> thought! So bear in mind that this might be quite a task.
> You will get all the support that we can provide!
> Uli: is this still up to date?
> http://www.mapbender.org/index.php/Database-structure
> Best regards, Arnulf.
> lars lingner wrote:
> > Hallo Liste,
> > ich werde mich ab 15.01. (spätestens aber Ende Januar)
> daran arbeiten
> > den Mapbender auch mit einer Oracle-DB betreiben zu können.
> Ich habe
> > mein Anliegen schon auf der mapbender-user-list kund getan
> und möchte
> > es auf Anregung auch noch an dieser Stelle tun.
> > Kurz etwas zu meiner Person: Ich bin Informatiker (FH) und
> angestellt
> > in einem mittelständigen Unternehmen. Meine Interessen
> gehen eindeutig
> > in Richtung Geoinformatik/GIS und dabei besonders webbasiertes GIS.
> > Sprich WMS/WFS, UMN Mapserver, Mapbender, Geoserver sind keine
> > Unbekannten für mich. Darüber kenne ich mich in Netzwerken (Aufbau,
> > Konfiguration,
> > Administration) aus, so das ich auch in der Lage bin eine
> > Arbeitsumgebung für kartenbasierte Webanwendungen aufzusetzen.
> > Ich hänge an das Ende dieser Email einfach mal meine
> Anfrage an. Mich
> > würde es interessieren ob evtl. schon jemand anderes an
> dieser Aufgabe
> > arbeitet, was man beachten sollte, was man nicht tun sollte etc.
> > Wer also Tipps und Vorschläge hat möchte sich doch bitte
> hier oder bei
> > mir melden.
> > Die Antwort von Uli Rothstein auf der user-list ist schon mal ein
> > guter Anfang. Ich werde mich daran halten und bei Bedarf
> einfach hier
> > nochmal vorsprechen ;)
> > Hier nun meine "Ur-Anfrage":
> > Hallo Liste,
> > wie sieht die aktuelle Entwicklung bezüglich der
> Oracle-Unterstützung
> > für Mapbender aus?
> > Ich kann mich an die Anfänge einer Disskusion hier auf der Liste
> > erinnern, aber die ist dann wohl nicht zu Ende geführt worden.
> > Für ein Projekt muss ich eine Oracle-DB benutzen und möchte
> auch gerne
> > den Mapbender in dieser Umgebung haben. Ich habe im Moment
> noch keine
> > Vorstellung vom Umfang dieser Anpassung und auch evtl.
> Stolpersteine
> > sind mir noch nicht bekannt.
> > Fakt ist, ich werde im Januar mit der Portierung anfangen.
> > Wenn es hier in der Liste weitere Interessierte gibt, würde
> ich mich
> > über eine Rückmeldung freuen. Vielleicht findet sich ja der
> eine oder
> > andere und es findet eine gemeinsame Entwicklung statt.
> Über ein wenig
> > Starthilfe würde ich mich riesig freuen.
> > Das durch diese Aktion zusammengetragene Wissen (und Code) wird
> > natürlich an das MB-Projekt weitergegeben.
> > Bis dahin wünsche ich Euch angenehme Weihnachtsfeiertage!
> > Hello List,
> > how far is the current development according to the
> Oracle-Support in
> > Mapbender?
> > I remember the beginning of an discussion on this list, but
> it never
> > finished.
> > For a project I have to use an Oracle-DB and I would like to use
> > Mapbender too. I don't know how much work it would be an
> what kind of
> > problems will appear. The only think I know is that I will start to
> > work on this in January.
> > I would appreciate any feedback on this subject and maybe a
> small team
> > gets founded to start an "corporate development".
> > Of course, every working line of code will be submitted to
> the MB-Project.
> > Thanks for now and enjoy the holidays!
> > lars
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
