[Mapbender-dev] JS exceptions
Marc Jansen
jansen.marc at gmx.de
Thu Jan 11 07:27:21 EST 2007
Hey Chrisptoph,
you've got me stuck to this now!
Christoph Baudson schrieb:
> Hi Marc,
> thanks for your fast reply.
>> try this (untested as usual):
>> function Mb_exception(message) {
>> return mb_ajax_post('../php/mb_js_exception.php', {text:message},
>> function(text, status){
>> return (text == "true") ? true : false;
The cleanest approach would be to extend Mb_exception with an additional
and optional parameter: the callback function!
function Mb_exception(message, callbackfunction) {
// make callback optional without raising an error
if (typeof callbackfunction != 'function') {
callbackfunction = function() {};
// always pass in callback function
callbackfunction );
(The wrapping stuff should than be updated as well, not sure about this,
but you'll get the idea)
one could the call it this way:
var myCallbackAfterSuccessfullLogging = function (text, status) {
if (text == 'false') {
alert('something has gone terribly wrong, and we could not even log
it!');
} else if (text == 'true') {
alert('something has gone terribly wrong, but the error at least
could be logged');
// put the critical functions within this block, and you're done.
Mb_exception('This is the error message',
myCallbackAfterSuccessfullLogging);
More information about the Mapbender_dev
