[Mapbender-dev] JS exceptions
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Jan 11 08:04:19 EST 2007
Hi Marc,
> With jquery you have the option of setting global ajax-parameters:
> $.ajaxSetup( {setting:'value', foo:'bar', ...} );
> if you pass in an object like the following, the JS will be halted while
> the post request remains unanswered:
> var myAJAX_settings = {type:'POST', async:true};
this is valuable information. I always wondered how to set these parameters.
Thanks for your input Marc, I'll add the functions we discussed and then
add it to the SVN.
Christoph
More information about the Mapbender_dev
